Désolé, bugg au démarrage...
<o:smarttagtype namespaceuri="urn:schemas-microsoft-com:office:smarttags" name="metricconverter"></o:smarttagtype><!--[if gte mso 9]> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:HyphenationZone>21</w:HyphenationZone> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument><![endif]--><!--[if gte mso 9]> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles><![endif]--><!--[if !mso]><style>st1\:*{behavior:url(#ieooui) }</style><![endif]--><style><!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";}@page Section1 {size:595.3pt 841.9pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;}div.Section1 {page:Section1;}--></style><!--[if gte mso 10]><style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}</style><![endif]-->
[FONT=Arial]Rebonjour,
<!--[if gte mso 9]> <u1:WordDocument> <u1:View>Normal</u1:View> <u1:Zoom>0</u1:Zoom> <u1:HyphenationZone>21</u1:HyphenationZone> <u1:PunctuationKerning/> <u1:ValidateAgainstSchemas/> <u1:SaveIfXMLInvalid>false</u1:SaveIfXMLInvalid> <u1:IgnoreMixedContent>false</u1:IgnoreMixedContent> <u1:AlwaysShowPlaceholderText>false</u1:AlwaysShowPlaceholderText> <u1:Compatibility> <u1:BreakWrappedTables/> <u1:SnapToGridInCell/> <u1:WrapTextWithPunct/> <u1:UseAsianBreakRules/> <u1
ontGrowAutofit/> </u1:Compatibility> <u1:BrowserLevel>MicrosoftInternetExplorer4</u1:BrowserLevel> </u1:WordDocument><![endif]--><!--[if gte mso 9]> <u2:LatentStyles DefLockedState="false" LatentStyleCount="156"> </u2:LatentStyles><![endif]-->Petit nouveau, bien content d'avoir pu lire de nombreux postsrépondant à mes questions.
Pour être bref, j'ai ma maison en cours de construction en voie delabellisation BBC (actuellement charpente posée et toiture zinc la semaineprochaine).
Je vous donne quelques renseignements avant ma question:
<u3:smarttagtype namespaceuri="urn:schemas-microsoft-com:office:smarttags" name="metricconverter"></u3:smarttagtype><!--[if gte mso 9]> <u4:WordDocument> <u4:View>Normal</u4:View> <u4:Zoom>0</u4:Zoom> <u4:HyphenationZone>21</u4:HyphenationZone> <u4:PunctuationKerning/> <u4:ValidateAgainstSchemas/> <u4:SaveIfXMLInvalid>false</u4:SaveIfXMLInvalid> <u4:IgnoreMixedContent>false</u4:IgnoreMixedContent> <u4:AlwaysShowPlaceholderText>false</u4:AlwaysShowPlaceholderText> <u4:Compatibility> <u4:BreakWrappedTables/> <u4:SnapToGridInCell/> <u4:WrapTextWithPunct/> <u4:UseAsianBreakRules/> <u4
ontGrowAutofit/> </u4:Compatibility> <u4:BrowserLevel>MicrosoftInternetExplorer4</u4:BrowserLevel> </u4:WordDocument><![endif]--><!--[if gte mso 9]> <u5:LatentStyles DefLockedState="false" LatentStyleCount="156"> </u5:LatentStyles><![endif]-->Voici la composition du mur de l'extérieur versl'intérieur:
- Optibric PV3+ de chez Imérys (R=1) avec enduit extérieur
- Isolant GR32 de <st1:metricconverter productid="100 mm" u6:st="on"><st1:metricconverter productid="100 mm" w:st="on">100 mm</st1:metricconverter></st1:metricconverter>(R=3,15)
- Brique platrière de <st1:metricconverter productid="5 cm" w:st="on">5 cm</st1:metricconverter>(R environ 0,45) puis enduit plâtre
- Fenêtre de tapée 160
J'ai pris le parti de poser moi même l'isolation, mais reste encore indécis surle type de GR 32 et du rôle soit du pare vapeur, soit du freine vapeur.
N'ayant pas trouver de sujet s'y rapportant ou y répondant, j'encombre le forumavec qq questions:
1- Faut-il prendre le GR32 avec papier kraft par vapeur?
2- GR 32 avec l'alu?
3- ou alors GR32 nu avec un freine vapeur mis séparément ?
Ou alors, sans changer la composition du mur, avez d'autres solutions aussiisolantes à épaisseur égale?[/FONT]
Merci d'avance...
[FONT=Arial]<o:p></o:p>[/FONT]
