Dimensions charpente pour appenti 1 pente
Ce sujet comporte 22 messages et a été affiché 1.741 fois
Env. 20 message Oise
Je souhaiterai construire un appenti à une pente adossé sur ma maison mai je n'ai aucune notion sur les dimensions de la charpente (solives, pannes etc....)
Les dimensions seraient longueur 4m x largeur 4m x passage avant 2m avec une toiture en tuiles plates (27x17).
Pourriez-vous m'indiquer quelques conseils sur les sections des différents bois à utiliser et le plan de la charpente.
Merci par avance
Ludovinci
Dept : Oise
Env. 7000 message 06 (6)
Il faudrait que vous fassiez un petit dessin, avec des cotes et dimensions, montrant comment vous voudriez que ce soit.
De : 06 (6)
Bonjour, voici le dessin de l'appenti.merci
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEBLAEsAAD/4RDqRXhpZgAATU0AKgAAAAgABgALAAIAAAAmAAAIYgESAAMAAAABAAEAAAExAAIAAAAmAAAIiAEyAAIAAAAUAAAIrodpAAQAAAABAAAIwuocAAcAAAgMAAAAVgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFdpbmRvd3MgUGhvdG8gRWRpdG9yIDEwLjAuMTAwMTEuMTYzODQAV2luZG93cyBQaG90byBFZGl0b3IgMTAuMC4xMDAxMS4xNjM4NAAyMDE2OjA1OjA2IDExOjE3OjUzAAAB6hwABwAACAwAAAjUAAAAABzqAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/4TGwaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wLwA8P3hwYWNrZXQgYmVnaW49J++7vycgaWQ9J1c1TTBNcENlaGlIenJlU3pOVGN6a2M5ZCc/Pg0KPHg6eG1wbWV0YSB4bWxuczp4PSJhZG9iZTpuczptZXRhLyI+PHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj48cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0idXVpZDpmYWY1YmRkNS1iYTNkLTExZGEtYWQzMS1kMzNkNzUxODJmMWIiIHhtbG5zOnhtcD0iaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wLyI+PHhtcDpDcmVhdG9yVG9vbD5XaW5kb3dzIFBob3RvIEVkaXRvciAxMC4wLjEwMDExLjE2Mzg0PC94bXA6Q3JlYXRvclRvb2w+PC9yZGY6RGVzY3JpcHRpb24+PC9yZGY6UkRGPjwveDp4bXBtZXRhPg0KICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgPD94cGFja2V0IGVuZD0ndyc/Pv/bAEMAAgEBAgEBAgICAgICAgIDBQMDAwMDBgQEAwUHBgcHBwYHBwgJCwkICAoIBwcKDQoKCwwMDAwHCQ4PDQwOCwwMDP/bAEMBAgICAwMDBgMDBgwIBwgMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDP/AABEIAm4CsAMBIgACEQEDEQH/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/xAAfAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/AP3gKY7fNghhn/P+fzoKs0mdueuB/n/OO1OQAzfj0/lQG43Dncc+5zz/AJ/+vXVczBurE8LjcPp/n8sU0HzAW+7z/wB9c8U4BnHl7sMxILY7HPamnaIlxj5jyAeh5H9KQAVwi/xc84PU4NDHyyB/EM0Owb5Tjpg+3+fSiQFWG7cx3cei/wCf60wAJllXb97GMt1/P/PFNX94/wAv8XGff/PPr0p0x8xmGcrxk4/z7/p9aReAOST+fv8A5/woAjYKisG+7g456/5/p3pCNwXj2P4dsf55qQA+Tu3bQo52nn/P+fXLDIQyjPXLcDrzx+WP6UAKMBsdFXHXvzmgL/pP5447f5/l60udo292BIHqfypjLkbQNy49OM4H8+KYDo1Bb5j8uM5/U/Q8UIWIbdwW7Y+ufzpXOZGbj5TgY579f8+opQNy7cHnAz/P+tACAMoUd+mR8wBHX+dOByV6dcnnj/P+fqkhOcN36+4/KlA2yY74x/u0gBcHouN3zA565NOI24xgsDwP8f0pnRf7xHI9/X8+PyoI2pk9hjr3HWgA3fIwGC2Mkfy/OnH5NrZX5sjr19DQ+1dvr09M0uzDdcr9P8/59aAEzsdflXcvQ47mmltrt/s9s/5/yacrMPm25IwQewpowA3PPU+9AB/rD6kn16cZ/nQxzGP4ehznr37fT8M0ONq+uc546c/40YycdARjPp0pgMY/px6f55OPwFK68L93OcgjtQvyp8w+6M47Af5zxQoZJDj8sdT/APr/AK0ARt0+7u6enFLEu7hsbj94k9+P68fhSvFklvu8cAetKynYvbjBHrTAVF4Ht0BoPMi7vTigj7v/ADz6n6f5/nShwrbduGYbjz9BSAQkGXop65J9f8iiTgk/d45yOvv+o/I03OyVVIBDd+5x/n9fycp387W2kY47j8vpTAcXVlx93sOf8+h//WaFADKvyj2PPHH8gf0pit8hZurH07nj/GlA5Y43dsevT8uf5delSA5hsfdjacY6df8AHvSPtDeu0Z4Pr/8Aq/z0p6MQvXr2x19umexFRyvtHBJ4yWAz7k/570ARseFHGVxg/wCev9c0xhuVsdj19P6VIF+Xd93nr/d+lKi4I/h6duuaoCLy1Yddu3jJ7cc/0p7x4KhR1HHHQf5A/I/Snj7+MHrzjjtn+dOQsuGbpjIP6E/59/rSAfEFjJY/xDJ7559fb/PSpIlBjH1J60yPJeNV55A6dOKcn3fvEHGM/l0/z+uakBHAYsuMZ5Pv1/z/APqpucbQ3y7cnnpj/P8AWpGB2Db8q4A6dPSmvtc4/n0xx+H/AOvFICPOZPmGSo5y3JI//V+tDKpclTg9B/n9PxpRulQgfNjIAx16EfnSIfMiByx4wBj/ADmqAVRg/MB1/Tj/AD+VKykIOpZQc89Mf5/z0pxO7ls7jnjr6n/JoZi6N3z0Gevt/SjUBsqKzMAvbPXoT/kUFfmz325PPv8ApRt2oF5DEY+vT/P86cRh9mPwGByfwoAaNuR/I/WhQMKT9c+maB8ygdCx546en+f50u1nG7DYz+JoAQA52/x45x+HP86WM/vOT2IHoKUBsDb1bnHqfajy8Fic56A4xj/Of5+9AAoBl+b06dz/AJyKRJM/7wGc9j0/x/WnlSWIzkNgHjpnP/1v89GvJtBbd90dTxge/wCX6UgDaob5h15PPTn+XIpq5cr/AAnjOR09/f1pQCzr9DjH6dv8+9IG3Fm+VmBz6ZPGKYD07ADocnn2x/iaepz838JyPX/Pf/PNM+bGeW25HI9M05WyDjpnB9fr/n1qQEcbFOfQkke3WopclVLbfmJB9OMHp0//AFflLJ8iKvK/x+uBnnn/AD/OmFWWVM5XOOnuaAIp3AVeuVIA5yRnj+tOiKgfNt9+2P8A9VOdA6tn5f4c44Bx3/EA02JmMbEZz1/zx7VQDo8qp3cbiPw/zz/ninbdgYD7x5+p7/n/AJ9KSQ+UC38DHZgDp2H+fQ0qEY3e2489PbP9aQBIoCK36E8NxSHlsZ2qvJ7+5/z7e+Q91/eYZfmYAYHTFG1hj2HOeNo7df8A61IBudrDdkZwfYfh+H6n1NJHFx03dMc/l/n/APVSghz0wpw2QOvbgf560it+63c+n6dvpz/+qmAuP3bBfz9P88U4hWjwPXpnODxQeu7+J8AZ600tgc5yfc9en19qACXgMv8Ae4PPT/PP5dqTyxEG/wCmYyoH4Z/lSj5lVd2ecgjt1B/p+tOaNmCdcLnPtwMCkA0D+HH4569cf1/OnKq7RwOWAOBxnOP/AK1KpZV+X72cDPuTxTDjPA+XoDjnjH/1vyoAEXzGAA29Mdx/n/CnIOg3fN3x37fT/wDV+NATy93X5Tx6jnk/l+ooxu3KqruHbHA9v5f/AFuaABvmP3fTPP8An/IprL5g/wBnPf3pzfKD/Fk5z/KkEeNuB8vGCT34/wA/nQAmG2huhznOe1CjySdx27eRjt6/0qT7x7rnAz+VJ8wGB67sY6c/5/SgBAVjOPlAxxj29vypQmT0+o+tKpKfKMrtxt745OaapYx9we4x3/woARRlAN2d3Qnt74/A+3WjdsbdtwGGeT2/z/nrTslZPr09j3pCpJ9VbB6/rQAu7Mi/Xn0/z/8AqpGHluuF4YMePwpyDMh3FSNo4AprthlbcG2nJI7k4HSgBGjwOM+ufrgfpiiUsFH+18p/Tv8AiaQnYg3fMyr09fanOvAB+8ePTp/h/nvQBD8zru+ZG7qRyP8AP+c0uDv/AIenQHGRjj+v4Up/1m07dy8cfz/SlTjLK3y9s9uf/wBX+eKq4DGHHy+nBP8AX8aGII+794DntjA/z+XvRIMv/s7SF559D/nuB+TslY+PvN146UAN2nG3GcHGAf5H/PWmyryd3tjJ7Zx/n6VIVWMKONq98/56+v8AkIf3T/NjgAEdM/T9aAE25/7559+4pR80rZ6Mefyyf5/rTMlQMEbcDgdTUjDI/hHIDZ54549/SgBoQ729WBJHT/PFOWPZu54yAOOv+cUjBlGfvHrz+H+FHl7F5H3Ox9R/k/hQArLtGW56cHHX/I/lSYbI+97ZA4GRn/PrThwHz+PH3gfak27UycbuMDv/AJ/+tQAZ+Xn0yR6/5x+vpQwLZ+8rd+c4/wA/5NNX/Vtnqrckc8j+v/1qdllVSNvBH4e38/yoAMFnXbleMnn3/wA/nQ3DDn5W9u/T/P0oCBtvquMD8PX/AD+lDDZJgevX9f60ANAEiryec9O3P/6z+HenI2c+559qaEVlbd/Fx9e9OJxD12seVx/P8qACRflP8X9MdM0rJ+8yfl28cf575NIw+X5vp9COv8qcRu3ceoI9OaAGFdrcDcevTI6f1pSuWYZ5/n9P89qcVBO35QD0/wA/570bs8KV3N36jFAEUgO3P3efTkn/ADmk++f9nHPSpD8ykLx6DP3e1NLgycZ/2f6f59zTAR9wYlevOaafmP8Augjn1yMfy/8A191cbW+9yuF49OD/AI/nTifmbH3lJwMdP84/z1pAQ/wsPur2+n+f1p4AXt9fTp1/z6fXLCoA3Agr1/Ad6Rvlb1bcPbn/ACB+nTswFJ27v4mXBPv+H+elSIdqbf4l4Hpwf5dOPxFRj5n5984P+f8AOfwRvlU7iAM+354/D+VMCWTdsDK23jpnp6f0/Gjyvkb5dv4enf8Al0pqjjI4PfHYjHr171IBuIHG4DJKnH+eaQAsO1em7aRwR3/yP5elHl/Mp7jA/wA/nTtu7np2PPp/+qhWxJt6HuP8/h1pAMDFsO3rx7D/AD/P2p2CifKDj+Rwf8O1MU79vA+XsOMEZ/zz/OnRuB93p0H+eo/z0oAmWMKR3XkdMZp4XK9/ugdOvH/66ijAi+9x6H/P+etS7WV4w2d3cfrUsBMDGfvc59fpj61GUYt24AB9D/n+tTYBK4PfPFRzISjbvlbqR6f5x+OaAIVKkNjqwGM/p/k+tKAMHGSG69OhJ/x/WmKwYmQcbOMH3/yT+dOxlCSvy/X/AD/j/SgHZ+7/AI9Kk2CTgfLzkHHSmpyduPuj8f8APOacF2O3Axkfh6/1/P8AGkAkfydto9P8/X9KGQKvP3n7H26f5/8A1U7kL/D6kn1/+vmkL/Kc/dHGD1P4UgIwu4An056dR/k0rKT/ADIHb0/pTlVS+5uvODjvz/8AqpHXYzEfeHCjPb/J/wA4qgHZXIZl7t1oG7dt/ixnkYGe/P8AnrTXiJBwx+o+lBXcP7oUcYHb/P8AkZpAO+bllGTjcATgZ4z/ACpGTKcDOB97/P1FLIVcj6UB1ifn+Lnk/n+v6/WkBGAQm3kLngf5+tOjjAfcPr079MfzpfI2Bh8o46E/qf8APanfdcA/e6r/AJ9v89TTAThhkYPGPr/nH605t3y7fm+YcHv2/wAP84oGf9nPPTt/n/D2w0xh06qd/B/ln/P/AOpALIN6cDcCuPrzTGb5mUDg9CR0P+Tinu/fvnOT796VQMqC23pjFADGX5u21c/h/nkUiReUv+zjH5U4HzMcck549+/+fSlUZUdflGM+3+RQA3y/3bBs/Nw2RzjPOfw/n60ihgxXtkd8f559KkUAR9eOQAPr/wDXpGXY+cY7ZoAaBsPcjrwOxp0q5KnrtIHA/CkxsfjG3sBSsnzD06Z9aYDAD5f3vu5wevP+fWnoMs3GBxx60mG+np7ev+P9KAOPc56jGff/AD70gDYGUfw7emKGHHH8Pb+lCx4k7dAB/LP+fT2pyfL6fgO3+c8UAI3zBiOpGf8A6/8AP9PxQDYxAB2tkZ/X+dEb4iPqD2P+fenEf5/P+dADfLztz26cfj/n6U5R8y9sAHOOlBUYX7uDxj170SHd09Dk0ACD1yu7IGOtIo+RSo5HQ8cn/OKUnDHuFPI9aRuv95jk/wCf/r0ANV8S7D94/d98DA/mafGP4eAMYHf6VFNGzEFWw24H1wO/+f8A9dPGAOR05xjp/nigBRwvO7gbgMdf8+1L8se7kDrzjtj/ADx/9agDjBI/ug0gG8nIHzc4/L/GgBQmEOPpjFNDZYbht64Xj5gDwfywae67oh833eTxSOMN8vRT19vf/P4UABU7h83+8QOM/wCT+vtQh+bPbqMc55H9KAAX7/iPTGaNn3gcdM+/tQAE7lXbu5J4H8VAwye2f5UY+Xpw3A75H+cf/WoT5lHv/n/P0oAaw3P/ALQHHqOvvTmCsc/e7j8M/wD1/wD9VKyg49PX0PH+f85oKMDwuGGMA+3NADGjy+7PPqeMD/61ARUk+U+314/zxUioFICjHXIxz1/yKaV8zqW6nv16f/W/KgBjjYODtXjn06c/zpAqsgzu3egHTvTwuFK/wn+tJ5WHX5efX+X1/wDr0ANY7l+Xk5znuM0mFdufutn2z3/z9Kfs3v0zz0J/z7UBdz/QYJx1/wAgimA0KGLc8AkYA6+o/pTfKDZ3YyenvUgXef4t3HTsf85/Klxvf7u7HT/a65/nQBEuCi5/3cDvx/8Ar6f4U8KpI46j+WP8Kds4+bJ29W/vf/qpxQ7hx82e46mlcCIruf5tpz1B/TmhTjnP4/dxz1/X+VP8nBPHXAx6/wCf8aRkzJuG7J4xT0AiQqD6DPTFDALF833ue3p/n/PWlZeGH049KbMxQcLy2CP68/rVAKjYk+gIPv3/AMKcMxv/ABZyBn1Hb/8AXQfkjI284GB26j/9X+FLGMYySq8EHGPx/n+XakA0dG/2uR/n8Kd8uCueV6HHf/P9acgwMY+buOOf85pVi+6F+o5B/wA//rpXAaNucjhWOSMdf8mg9FyN2Tg08LkY6nOB25/zn9aCpJ+90x26d6QDeDtHVj/n8OT/AJ4qMnzB7fTn/IqQR8fKCpbjHqP8/wAvwokiJyMkhRx9etADAFc/oAc/j/n6Uinc/wA248cDA6/15p6qXjzhvm6j/P5fl9KCrHdx8vv24pgMZQpUBuB1IHPr/n8aaECruBXcDjO3p2H8qm8va2Rn6f0/U/nTVjJOefqBRcCFk+Xk/Ljk/wCfamN/rTuXqf8AP+f071ZkiUqOMjgAe/XH8qhnjOBkFueOeo/yP89mmBHGVZAVbtjp0wPenMQFGedpwF/Ed/0/H8aaBvT26fTjj9al8nHXd1BGMfh+oNUAioFG35s9+OuP/wBX4U535wp6Y/D0/wA+1Oe33YHPynntn0/r+ZpQmRwvy9z6jp+H/wBepuAxei46EjHqT/8Arpy/Mf73AJ9vpUix7tvy/e4Hb2/z+NEceQWG7J6DHT+n/wCui4ETJtX5W3ck/T/OafGgRg3rnn/P+f1qRoNn+6en0+n+elDJuCt+vf2/z6UgD5SM5IPRTj0/p7U5dxuPRu31+n+f604pl8/Nt7/0qOYiH5m4Lfdx6kY/kcfiKQA1wm47fmPX8agI85COnVuBjBPP+PX3NKo8pT2wTx3PSpgpbry3X39aegEaRRoD6dPwpzR5AVuw6jt06U4LuCnHuMgYx1/pTim8/k2P1/OkA1eSG9AM+3pRnZ7dwMU8Rhnbjaeckjt1pUHybtu3PT2P/wCv+VADVC78EY5P+f8APpTeAM9sdMfpUiN/F90Dng9PSmyLwysG69emOR/h+nvQA0qHGD17HH4f4UHG7ueMEn+X8qc0efl2+wx24/8Ar/ypwXcehGQeMd8+v4/57gEYAHbrwaaFVXH8PBFSIhb1+XA47+n+elA5gH05JPT/AD/hQAm3Py/d9/Tp/n8KYAq7cDhie/oP61IEz2Xd0Pt3Hv8A59aUoW27d3qM98dKAIggB9WXOT69v6/rTpJNo+b5c9yOv4f5xmnJHubKjIx9fpSOc9sY9DjJ4/z+NACLhoepOccY4binRdV2888cdO36/wCfSgwsh/Edhx/k0OcHj7o565/z+lADSnTk5x/n/P0pxYBmx0zyOn+e1CAhsY6D8vaiIBI933tpH+f5UAJnj6ck/p/j+NIij09j3/z/APWpzLg7Wy3I9s47/wAqXDfMv4H5ev8AnH9KAGqvrnDdf9nP+cUp+bcud3Yj68j/AD2p3lfNtw3f8+lNHQN8wGc+uf8AOKAE2rnPcdz3/wA/56UihQMdehHv65qXZ5fyqO/pgDp0piJiL5h94c0ANxlE6evXr707pJ02/wAWMfl/SlEeT/eIJz3z/n/63WgnBLH5vcY/z/kUAMkVQu75sYxnPv8A5/KkIAyq4XqKeBuZuPm6E/SmqcKfpweOaAAOrg9P971/z/WlkVdv97rnnp/+v+nvSEZ29ev1x1/z+FPU7Jf7204/z+n50AJwz+pI5IHX0/wo6DOO/Y09I9yN/tfQcUqtu+goAhCARqB07UAZX9eew/z/ADqR4st+J6+nv/jTHwF+YfKuTjrwMf5/CgBAFyvO1e3U+9AIHfP1NCqWO306njPSmzzLaxSSMG+QFiQCxHBJwAMk9eAKAHlVHOfm78df84pSML06/N60J8wOfvZ9c4pX4T5gfm5JPb1/z6UAMKAKM87TgA9SR/8AX704KoO5hnacZ96ds/2crn1/z/kUbcnp16f5/wA96AGoNrfyP8qaiqsZx0weAOgP+R+VSLHu7dRge2P8ihRtjbjOBken5UARiQGMt0UjGePX/wCv+PFDLkn6dfy4oKbg3uOMdqGG4D65479f8/55ABm/yT/n/PtTnwCwYAhc9fT/ACKRT838JC9fY9P8/SiPjJ+Ze57YPp/n9aAEggjtbdYVUKkY2KM8KOmP6fn1p529Mt6f5/WkLjP8s9qduGPXd+n+elADX5U9GB5+n+c0HAH97sPc9RTgdkg7888f596afcfXuP8AOaAEZQfu/NjoT29KR1Ux7sjH3h6Dvn+tOxgH+JV6/rz+P6Yo+78pbPrx0NAEbRL1Cru5P+fSnMdo+vXPFSBtoXdgcc1EPujv04/z/n86AFkUFcFevbP+fypVIJ+bpnnvx/Okmkwm5VY7RwgPJPGBz/jTbN5J4f3i+W7EkJuDFR7kcZ6E4yASQCQMkAkT5jlvm7nn8f8AAf55aFHG4fQH+dOL5zzxjj2/z6UiDC9flVsdP8/5z70AI6fK2fm46H8/8KjkXll2/MORz36/TtmpSd65Xlm4z/n/AOvSfebdnvn6f54oAhLbTx8u7gD1NBby0Y5xt9Ovf/P41M8JUKCw6+nao3Xaqlfu8dT93r/nincA/wCWe3Od2QOMnI/wpxbYC3RiORnvUaECVQ2R/CePx/Men1p4k3p97oMkjoR7UgJSQz5I4XP8WT/nNEa4Xbxj1z0pA/G5do59OmO1KxwpILDbyccfT/P/AOugBrKpOe3QYPGKGXnkbgf84pyjaM8fLkgY96A+Pu5Pvj8c/wCf/rUABTAPOe/B/wA/1oK/OfQ8qPehG3KAR5fJ/LP6dP19eKGwqjdwPr09v8/TmgBoGPb/AD/+v8qaQAF527R0qQj5cdOv4f5zUU/VV9Tg5/H/AD+P5ACMMSfL93nr2AH+f88Ux1/d/wC0vPPbn/8AXT43A3dWCjIJ6Nye1LEMHI65+8RjH1pgMCkqflxjnGeR7e/rShdsTbV+YdBnvToEwn3T/e69D/8AWqUxjHbco5yfYH+lK4DWGD0Xd6Dt/nH8qcVy4xnkY+n+c0Hgrn5drcZ75/8A1H/JxQqbSvt8vP8AEf8AP86AEEeRxhRjGSenXv8A5607AU7gqqoPbsCcmk83ad34HJ/z/k0Kv3vl+8eo7Y4/pQA7Cx7flPYc9D9PzqMcYJwRnIHr1H+f606eTIZfXoBxxTG4b8PzGf0oAtGMhGX1AwarXbB93y/dOMg+nr+v51IlxlAvzZ4U+3b86a+12O3jjoD14qUgK5k3MTx8p6+h9f8APXFSxRmM/wC1/PFOSNYmVchhx/n+tO3A/wCzxg/h/wDr/wA9KoBTFz0yp9vy/Whmx6bu5B6+nb/PvRG2CozwCefTOcf/AK//AK9RmbAGPTAHYHGen+cYoAcVAj4XC9MZ7Uu7vjv379eaZHJgZ/p9fz/z+Ch9qDcN3f6f5/z3oAVF3ovygd8Z/wA+3+TTmUHaSNvXP0/z/OmhsMGGDnpz15H/ANenK67gxPXqCP8APrQADLce1AGN3y8+h/QU5unDcEc+3Xn+dN6xt3Xrz/n2/CkAgThfQcf0P9aeeVbj5sc/59/60H5MK3PTnp9fyoKYTaPfB25oAYy4De/P0xnH8qcr85I9x/8AWpAFRiTx7/59sUgX5WGe+Rx0oAXO4sSB8o55+tAQqF+Vt3/6qMgf7Xfj+I+lEh+X19f6UwEADPjpuH5DFK2euOgyMcf560Ejfy3X2pZMKf8AZOMgD6YoAjK7V564yOenXn/PrS9Iunrn9aD05yf1oBHljHO3HX1/zigBxGW/2SMD8c//AFv89HMchuV7EZ/OmL8srMwGOw75pQ3y8fxUAG3YqrjgD16D/P8AOkK7f9np1/z7/wCew+PM+7wvByP5j/P8qA204J65P5/5xQApHmAbe4wMc/5/z+AQo2nqx6fhQFDKvrz+P40obBK46Z569aAET5mz/kn/AD/ShvmTj73+cU5m3MTjuf8AP9f84pB9zbkqRxjP5f5FIBkqghWVtqrnI7fnSH5ZdpH3QM57YpwZSvJPzHP4f5/n7U3O1uDz9Mf57flTAAnzqT+R7nrT415O3twf0/z+NJtXH17emO3+fantuEmSx2t7feP+SKAG89+NwyeenX9adIcsMrtxkjPfp/8AWo569e+aavLAcjjJxSAc3yrjH3egz9P/AK35VHI3lqpbu20e/PTFOJyigcN2x2/zxTdvmkHuo4GOn096YDV6MfTPqff/AApxVSBu2jOD9e39KbGd47qpG4E9D/nj/wCvTgvdmxnB5HQcfl1zmgBVXYijHvyc4/zmnr9/39M9Rk1Hy0bKd2eR9P8AP9cU6R9y89MAevoaQDlHzH+9jGfrRn59wX5V5FJk78/UY9PT/P8AOlCLt64XpnHb3/z3oAaiBV5Hzc8E9DQAHH+PfmkV/MRl5Xgc9utOLg9Oxxj0pgMIyTxuz0z+P+cUMqnK9mXJyaCwwAdrbW7fT/62Kcf9bv8Al+U5/IUAJ8zvz/ESTz1pA2RxuOQAf8/rQwVywH3lORnuMf5/OgbZNp49QffOP6/5FAAq5T17n09f5/zoY7mzglcgA+gzj+eKYXzHz0Iyv+fb+tP2+WVHtx7en9OnrQBIoVDxkKo6e3Wo0+bdn6YHX+nr7U4MNo27eTnPp/n/ABpqBlUjgZznv+Xrxj9aAAjzOe3OCKCPOC5/i9D+f6/0qQybmJG3C8nnkU1I1wBwFXj8v8j/APVQA07UJPPynpnpQy/L6c4PP+f8inEjG7HocZ+lRI0j3W1o1WFfuv5nzOe/y44HvmgCQn7uV6duwpifKmMfMQSD6D1/WnN+8VvlB46A8DH+TQ22RexU5zz1/wA80AA4b5fTI569c0Km7d/u9/TrzTRwv+frxT85YMerfpQAjYY7tvuoPXt/n1pY+G7stI0WB93aVB5z2H+R+lC8sSOFxgnPY/5/I0AOxjav0AApzIB2zxyB9f8AH+ZoRPmH90EY9vp+NOJ9fx+tSBWubfEPuvzcd8U2Jcpgrt28gA9KlkPzuWOM8njjH+SP/rVGw2t/DyM89v8AINUAL1zg/M2MHnp/n6/WpN3GG+7kE/Tn/wDXUajKYb5VycYB45/z1pxOGHyjCnOPSgBxJUK3G5iM+3+eR+P4UMmxdvccfSmgZxlQc+/+evtTgAw9s4+g/wA4/wA9QBzDa/8AtFuR+v6UigMv3eowf8/iR/nhCd3zY4OD160sbZOfTnA75oAVU+8OucZB6jn/AOt/WqsmWnPGQT1z0/zxx3q4GDlgPp/Wo5IhMOPlYk9/r/n8KEBFEF3Z7ryPrzn/AD/jUqxiNdv8CgAkn6f59qaI9rbdvc80qORxjLY7Hp9Pz/zmgB6JtTaRhlBGc+3+fzpflZFOPlxuAx/npzQy5Yr/AJFI3UHPfJ5/AUgAje+NvPIPfHXjp9f88U1lX09CvNHVd3sAAPSmtzFt6cZ+lMBW45+6c9uM9jmhvmP3fmYcH6f5FJuDbuFz057f5/z3pOvPpwDn8P6n86AFlbDejHBx6Y/zn8Kbu3yKqqcIOOf0pdm5z9eR/Kmo2SCf4u/6f5+p68UAKf3bcL97PQU4PlMd+MAd/wDP9KYpyN3r1yvfp/nHekRVMbcEE989D/n0/CgCXKk47FsZH+fw/CmFvmDfe3YBH6Y/z6d6JGx/vKKV+DkY2jqSfSgB4Yufvfd/DPp+f+faJFJ+badynA54/wA8Cn8nHzd+T+WKaqhYuNqqePagABPlswX7pBwR605VEW3bg8kden+f89qSVtqN6N0BH3uhoOCCP73Unt/n/OOtACq3yquM7c/xd6cWG/5R/wDX/wA81HG/mSd255wOuOuPyxRu2yfKByfXqfT/AD60ASI3nbQBzg5x7/5/z2mXsV71HCwWNj+JPWns3b6A8+v+RUgJtwo44HAGenajH97p6Y60O+w/w99xHr2/r/kUyRhu3Hp2yfamA/cC3cNk9PajG1i23+Ln3oP7wsAO+CPeo1IdWXoeO/rg0AOKZ49euf8AP+eaV8A+3I/z/KheEfuucj8P/r0h+Ve20D8B6f4UwFThOnfnBz/np/nNIBuP3efX+9TmYLIM7c46/wA6HXYdre3BPv2pAN2/LnvnvQg6FV+6ePb/APUP5UA4O7aPXn/HFDAYZcZ2nH0//X/WmAFdx+72yOaMZkz/AA4z6jP+efyoUgtn056ev+f85oUKu0YUDoPYdf8AP+RQA7bgL8u7saaqjbhl+51546f5NNJ2ODxgDsec/WiJsP8Aw4X2AA/z/nrQAoYEZxyoHOfbNKx2vt56fl/nFRxuGDDGOcDPf/J/l06VMDz0x/Fj06igBCAu5tqjOcj+8RQefbPOT0Pr/jSkk+25c5/+v9cf56GFbgAZz0pAIcpIeD+XfkU0JjcPQ/l7/wCfenkbSx2jHof4v85/nSEfMG+8Gzn1P+f89aAEyE4xjufzzn+dOIG3cwzwR/n/AD3pqpld2AO4BI470J93p8o9+v8AnimAMwU9TwOo605zhhx90n6Y/wA/zpj/ALxfmU89yf8APak3Zz7EN07/AOQaAFKKn1+7nHbkf4mkPDDhvcDtzz/X8qMYUj5fl4NBbbn/AGv1oAFTMe3+EevbrinbcIB3X09j/n86bH36dT37cf5/Gnhv3jL/AAgY/lQAnC7cjJbB+pFOTI4P8OevXikBxJ688e3+ef8AJ5XO/oeRjp26f/XFIBv3W7Krc+vApwOwgY9ycdB/WkQ7n7fUUqjaOPvfT/D86AGtgrlunXGc05hypX6fXFBAI2j6j29/0ojUl+AMcbf8/wCeKAI3UK2Md8E+n+fSkbht34jjv/nNI4yflzxyO/T+v+fahU3c9OcfQUwHoPLT5jhsZyP8/wCf0pszZgH+zwR/d7f0pSGdl78naDxz/kf55qORjt45PQD9KAHO/mRhcjqc/n/+r/69Ijb/AKdP8/lTNvmr2Zv59B/nvx2pxIUncCvOOvPGCfp1H50ASb1ycj5TyaGbaM/d56D8/wDChOCeCowAe3+f8+tIeD+WAD/n1zQArJtBB6qcg+2f8acvTr82Rn6U1mIHyjOcEf5/z/ijfIPl/l0oAUPnnn5egA/z3o2hFb/a449P/wBVBYHHGMdgf8/5NNJ2Ocheh49qAJFXKNz1A2/5/Oo0G89vmwOO/wDnOPxpQVT6Y5/nSbcArt/h/L/Jx9Me1ADg5Vvl+bHP+f0oVtse3qdvXGcfWk++M55bp/n86QHen3e2Sc9c+p/r9KAJN3l4H939P8/zoJwu3nr09PxppGF9e2fbinBtsp/vZ6j/ADjnpQAqtuOR2/LtSbvMXn8qBu2njsOvemudzYxkdcHj8qADbuOc8/X9ajEgP+6owOP6U5jgbfT07/T60pJUbuvr7/5xQAwndJtOcdOO3H/1xQG2jI54yMfnTSuwHoo4AP5UobzF3bfTqOf8/wD1qAHMFckf3T19OCKR9oXdjqe/bt/hQp3Nj+H69qNwcZ7k9PTr/wDX/wA9QBxfA3Huc5xRJIGUe555Iyev9Kb95tuM7eRTmPPTjrkn6frmgBVk3qp3fLk59geKQNlfvbQQOR9aaGLFvmzzkZ7/AORQw+6f7o6Hr2x/kfkaAHBuRt/h/lRGvlHsu4Hp9TzRnMvQKVHGPxpvmccD8zyvFAD1k2EDnvxnr0/z/k0wtsYj2wMd+P8AP5U1nym78AT0I69Pwp2z94v5ZJx360ACS/Lu7juf8/5/A0ZxGreg6/j/AFz3p0a7Rnhdx/L/APV0/wA8tIyq9l5A4/z6fpQA3OVUYw38sc0K+WC575A67ff/AD/jT/lx8y9CP5f5+vNRgsyfd27QDnPt/n86YCh1BGPzwf8APTFJFtUfiOAOP8//AF6JCud3Ge60n3/mK7S2ST157/lin0AcnKdT9evQZoBKKr/eZjzjv+X9KGOf73zAY5ojbJ284AOB6dKkBzt8y7vmOeQKbkpJtHYYOOnfP4U1f9aFxna2e3Tt7f8A6q85+PP7U3hb9m77BJ4m/taH+1Fk+xG3smljnmR4kW2EnCLNIZQUVmAIRzkYAZ6WA9HL8Nxwpzk/5/GnnjIIHP3ff/I615/F+0Ro+vz/AGXwpbal42uMsvm6LD5mnxsMg776QrbDkYKrIzjP3DUyWfjrxcsf2y+0jwhayAlotNT+0r0emLiZFhQ4JyBA+DjDEHJQHZ6zq9n4c0iS+1C7tdPsbYb5ru6mWGKFR3Z2IA57kio9I1uy8RaZb32n3Nve2N5GJIbiCUSRyoejKwyCPcGua0T4LaBpt5b3V5b3XiDUoHMyX2t3L6hcQu23LR+YSkPA+7CqKMnAGTnrzuDhtx45bd1OR/n+VAD1OOe1IEJZudu04GB1z1J/Pp70qjaGbA3dsetSKpz8q/dOQc0AERCxN26Hbjp7f59aQHCtt/i5z+IpUcbefT5e+Cf1/wD10qDhdvGP8igBJGwf0xjrQV5PoVwKAA0nC/TnrSqMFuc9M4zQA0rgsvC5zj696R33KvOM4/Dv/SpIuCOPmIxx7cCmmH5cfd52/pj8qADep9umB7f5zQXydx59/wDPtUZDRnb/ABD0/KkHJb8+nWgCR2O7tnr69D3pyEH5e3T+fNRbsk/3c8fyzSsePx5z0x/n+VAEjvnJ7e/TFMDKR9Rz70q8r7sQeD/n0H50wsAn8Xy4yT2HP+FADi2SP9k8Z/ioR9mOO2QSMY7Ub8SZx9RmkZt3/wCr9P60ABCiFgOq8r+Oe351Ek5O3+9n0qRlbHPQ9v1pi5Zt23kDoOgP+T+n5ACl03emeRx/n/JqRG+b5j97n36f5FNXg+nt3H+fSkY7Arc7RjJI7f1/+tQBL91MfLu+lC8bW9jxmmnAXnsccnng/wBad/rH5O084z3oARxtYnPv9PX/AD/9al2LkqMnI9en501jxk8bcE+2T/n/ADmnE4yBn/ZHp60AC8pjHDc59PT3oVlkix27D/D9fypGyo68gDp39KRm+f8AIfrigAd8KMn5h/nP+f6UfeJ/P86aH+b8jijd8vzfw9cdRnH+NADmwSOfl5zj/P8A+ukU8bTx8xI56f5H+etIFwF2rjIzwaApEfA+6f8AP86AF3fKWHvkD/PX/Gl6L+eOajXBVVb5t2f88fzp+diMwPfn60AOb5gNuOOnH+enenFsn6g5HrTYztPI+ZeBz9aQHGP4eOv9aAHAhifTPHPX1oZsY3Dd7n/P+cUOuDtxgfqP84/WiQ7V2/dI756Y6f5/+vQABcH5sce2MH/69O3fvNox9M9T1prHacldpxzn17f4Zp2/DfN0b147f/qpAQsNrehxk4/GiIl3b+HGMY+lSD525GVIxzTCuSxzjucd/wDIx27DrTARducfw4x07Y/w/wA9aaVP3e+COnU5/wA/lTjy+fXoP8/l/nNMaEPOhDN8q4AB+9yP19/8aAECbvlPIbvnkZH+GKcEMYGFzjgADp/k/wCeaGT96DuPX5T6e/65zQGDfd+91x6/5FADnBZgeOeP8/jQDx93bz+dNxk/MOMY/wA/ypepb/aAxjuf/wBeKAH+Z+ZPX0ppXLZ+7xjB+tNU/L971J/x/XpTsiR/7o549f8AGgBwVjx74/z+lCfKu78P949qHyx+np/n8abuVt23PzcY9OOv+f60ACrg44+YHnt/n/PakypPT73I9V9f6ClHzH2yOTzx/n+v1pCVGePYgcD3/l/nnAApGMNx0x16+lOI2lh2x342+9Rq6srf3gMNyVP+ef6Uv8/f6cfyoAfj5sn64P6f5/8A1UBwSv8ACPypHGH3bu2Sfp/kUbcIfXHY+v8An9aAFHyqVx9RSEkr7AZBFIG4Yd/b/PtTmIwcntgHr/nNACPz83r/ACx/n9aVl3KPwB59cf4/5NNJ578+g5PU4/z70uMn5fvex6fT+dACMNx6c9Oecn1P+e/0ppjww/LHp3/rUjbRuA+Xr04A4oHLbcdP0oAjjURL+p9zTcFB36EjjvTlOVGBluuCeuSaaBgkrnn5s4xkdR+X+NAA64IXH3e/59P5U4sQ3A+Y8Yzx/n/PvTSCjKMDbk/1x/n/APVQBuRtvzcE5HYd/wDP/wBcUAO2/M319fX/APWaI0KJ0+6cg59fw+lG0RbueO3+fxoQsxHB5+XoQKABujMo+bAB6fh/n1ph5TB5x17cU4ttUN0Of8Mc/rSEYC9iQcf5/wA9KYBnLtj0+Y59/wDGgL8/HU8cfl/9b8R+LSQ4bnp0z9KkVD8v8OAMe2R1pgOzsXA+92Hp/np7UKOVC8nr9e/9R/nFNQ4QY6Y4A7e355pu7e33fmOM44z2P4dOtSBIp/u9jnj16/5+lN2fPwvoM56H/JP5U0DbJ/eP3up5/wAj+feg5LcAsW7qPegAL4k4+6vzev0+vb8qjGQdvb3PXFcJq37SvhKDVptL0u+m8Wa1bLul07w9A2pTRcgfvGj/AHUPXP72ROPWqEuofE7x2UFvp3h/4e2MknzS6lKda1SRPl6QwslvC/3hlppgOCVOStUB6UzbYWbOFjG4sf4Rg8nsB9ffrXDSftHeHb2eS38OtfeNr2GRo2g8Ow/b0ikUKWR7nK20bDcMiSZCM1jav+z54V1BY5PH2pal46k3KRB4iuRJYu4+6U06NUtDgnI/cs+dvJIFd1ZXkzW0dvpulNb2sICx/aF+yQqvcLGF8wd/lZEGeh5zQBzc0XxE8aKoR9D8C2bEA4X+2dRZfbOy3hboOlwOe1cj8XPgD4J1nQ2tvF0moeLrzUZra1mOtXbahMizSrCXgtMGCEnzMEwwJuBIzzXomsXtvp975Gsa5M9wxVlsrBHhkYE4DCOItcN7kNtOPu+nM/EvWX0TwTHNBpNr4c0ePV9NnuL7UGWBYSNQgbzGhTquRljK8RALHk8EA5/RvFfin9nS3htPEUd/4i+H1sNqeIJ5Xl1PRos/L9qi+d5rddwHnFjKirul3gs6ew6Nrtj4j06O60+6s7+3lVZUltp0mjkDqHUhlJBBVgwI4KsCODXjn7T+gS+ItK0Hwvf6te3EfifVIZdQfzFs7LT7C2eOW4k+TBwW8qMea74M2QQQCNVPDd18J9Qnvvh3pd1qmh3Unn33huJVtrTcQu6fTpJNqRyEDJgUmCUjIMLs8jgHrpdvM9d3I+v+f88cyBcP8yjjqB/L6dK534efEPSfih4e/tLRbnz4VkEFzC6mK4spwqs0E8TYeGZQwLRuAw3DjDAnoEYZHU+nv+FSA5FMi/dPTJ46GnKdsTfL93jGetNCbeGB44wfw/8A10u75lx1OCT+n+frQA8cIx/ED09qG5dQB3596YckcewJ+o/wpFP7z+JR+RHT/P40APkOD83+Hp/iKXcN3pycfT/OKIsoBxjaf8/1psZyvJ+XjjOP8/8A16AHLlY8beo6Hr9D/ntTvw+UEfhTQ2FOeRnp6Uf6x9p5OeD/AD/z6UAOZM7iflPTPp/j1qE53/d9AT6f54/SpTwvfcuR9f8A9dM6/wDAccdyOf8AP40ANBLnd2BOcHj2/n+tOcZTC/dIx8v401gE+XgYBPPA/wA/5706RW3NkHcB78n/AD/OgBANh3YGRj6Hp/n8qT+Bt33eAOPpRncrbeA3Tnp6UN8x6Hr3OOP/AK3FABwy/dGG7E9PY/y/GmhsuF9Rj1oHt8pA4569v8/hRJ8sbHq3sP1oAJOU6fj/AJ+tNY4f+8Wz36dM/wD6/pTgGwR8yrxjnkcetNPyL7emfxoAE5T028jn8j+FSIMBRx6HPfPFMxs3NnnPDEcY/wA/zpQDuz1578e9ADx8xx7+nA/Cn7d/I9eT/n2qM4X8jnJp2drYb0Bwf88dqAANkE9u/PT/AD/npRnYOx/Dgf5zQDgE+nf370jKAN2c7T39OT0oAUjC7dvBGAD345pH4duc46nGKTuG6+/XNAXYwXkenPPH/wCqgBfvPnbk80iptUfdw3TnOaB7gfMen1H+fyoUcjvtxnjtx/SgAU8jPB4xn/P6U1RgMvtgZ7+v+fencZ9Mfp/nP86QMSu7kZHHtxQA4sHbbtOGGRnj/PUf5zSIMN83XI564+n1oYfOW75xj6Hj8qQpkn34NACrnyxkbcjkHtjFB4H/AAIc9P8APajbtB/2sZyPr/P+tOKZAz/Fk+/b/wCuaAFRTsH8OeB7j6Ug+bGMdc//AFqCu5AAdvY47f8A1+PpRy65x06Dn/P50AIMFmzjA5yP4qceSBjluVGOtIq/d/2jk498f405P73dl6e/P/16AEVuM5P4jH+e9I8gbapbg5Of6/h/n1pN252yT0z9e4pUfav+197HYf55oAHGCWUEbeBn/Pt/nsx8s3Tbk5wfy/yKe3yEYXnn8aQrt+YH1GfSgBjH/eII446YoG3zOGwQxH1/z1pwbD+p9fT/AD6Ux2AGe/GMnr/+qgAjbzQuf4OeRx0H+fxp+dpHzfXP+f8AOaijcIfTnOPwPT+X50/gHGee3oCcZ/PpQAqAg53N1wPxHXHb1pN/zN6E7uvb0/z/ACoUqT75JPqR1oU7Ttz079M9f8+nNACjkZ+96E/5/wA/gRSq2e30Pr1GaGkIDc9Djn1/+t/nFG75/lb0zz9cZ/z6+2AAJwTjoT359aRhledvUdecD/8AWKVJFY/LnryP8/0oXa+3cd2RjPrx/X+lADY8Bdv3twG737D/AD/+ugqePm3dV+tAIUBst/j3OB3PtR5gkVecbeuD0/8A18/55oAcXGGY9QO/BoL7TnuhBOB6f/Wo2/KO56HHX/P/ANam7g5Xjvk/4foP1/AAcx2huflU8MBx/nihH+bOPu9veoyyyKFX0yuKeCp5B3L1BP8An60AKF8wL/FxjkfT/OKPMyFYntz7/wCetLvznnnAJHqf8/y70rYK4bHGRz37/wCfagBpHIK/LnB6dOh/z9aaSsZ/2egHYY/yP/r07cpLD7xzjjtn/P8AKmq4kXdy3OP8/XigAPz/AC7scjtyOKU8svZv6UifKqlfmbt7nj0/p60L6DlgOo7en070AO4f3wM9Px/TP+c03e2w/NjpyacpVjxy2B+H+elN4ZOu7jIIHagA3qOdzDGOcZ6ew9v8igoWmXn2IPQcjv8A56n60CRRJ16dVB54/wA9fag4QY25zwcdc/5/z6gC7t5zz6Zxx9abHJuJbpt5I/z9KA+wsq9P885/z0pQ4yu35izcAd6YDGbYn93+nTp+P8qUMpUEfxc5H+fY1w/jX9obwj4B1ubR7rWFvvEEcXmjQtIt5NT1bHP/AC626vKF6YZlVQOS2M4ybnx58SvGkrLoPhPSfCNmpKjUPFV2Lq6ICEh0sbNyCN20YkuomwGO3gbjcD1AJkBVySMnAX9K4HxR+054N8P63caPb6nJ4i8QW+fM0jQLZ9Wv4iM8SRwBvJ54zMUXjqOtY+tfs/2OvWEtx8QvFOveKLNY/wDSbe4vf7K0VVyM7rW3MaOntcPLxwScmum8L6hpfhvRrfS/CegqumW4xBFYWsen6dEOilWYIrLxjMKyY6Y9UBiW/iv4keO1R9P8PaT4FsWdcz+IJ/7R1AxbhnFpauIo5CMgF7ltpI3IeVNS9/Z/0WYSXnjzxRr/AI0SbMZi1q/W10kglDtFlbiG2fGwYMqSPjI3fM2es1zUbjTY45db1yz0e3lfbDDaAebI3PyCSQEybuMCONW46+lbTblvtbTaL4cnMuNp1HV5XtWkXuMyCS6OP7roi/7VOwF7R7qPSNNj0/QdF+z2duAsKeSNPs4sY4VNu8dOCkRX364qa/q8Wn3NrDrfiJLCW6z5Wn2OIprv1CjDXEhGODDsPt2Fh/C99qEDPrGuztGAd8GnIdPgxyfmcM0/AzyJVU91puiTaToKzJoOmm6eYfv5bOABZz03PO5CSn1+dm68GmBFpzXFvI39ieHRalmKyXuoOIGmxwGwN87kY6SCPtz6XE8PXc6GTWdZluEQZZbRDp9quDns7S4IwCGlZT6dqtpa6peyOJri109Og8lftEpzzks4Cr9Njexqaz8M2cMvmSLJeTLhvMun85hjnjdwuCeiADP6AGdo13pWmWrRaFpyzW87b3NhCkUDk9XMhKq/qSrM2c8Gsz4iWurah4bt1kntrFF1HTpDHbL58ilb+3bIkkULgYzjyj0zk9+2Zd6lju3Y9eQf8/pWX4ttmu9BdVzvWaGTluFWOVHJ6jjCn9aAOdtvh1D4L1SLUNLs/t62sflJaSspktVIGfsrOQseQOYuEOBtMYyr9bYarb6zaia1k8yPcVJKlWRh1RlIDKw7qwBB6gGpcKELLyvLLyPmB5/lis/WfDLT3zX1jN9j1LGxmKlorlR0SZM/MB2YYdeisFLKy03A5b4k/B6fVdc/4SXwrqSeG/GUSIhu2iMtnq0S9La+hBHnR8kI4IliJyjAFkeX4a/GaPxbrNx4f1rT5fDPjDT4RPcaPPMJfOh3MouLaYALcQEofnUBk4EiRsQD1OleIl1C5ktpo2tdQjBaSB23Bk/vo2AHjOfvDpnDBW+UZXxM+Fuk/Fzw8LHVluYprWX7RZ31nO1tfabMPuzW8yfNG4OOR8rYwysrFSgOkWQn/wDVyp/z/OiQ459sdPxrzPSPiVq3w116z8P+PGtnhv5vJ0rxPBF5NlqLcLHBdL922u3LHAH7mUg7CjEQj0rdtfH3mXIPt/n09aYEjy7WU9xyQDz1/wD1f/rpWXqCTtYfNx7DP8qj3hTjrzu/D+nHf/8AVSh8vj5sgEfWkA8Nk9M7iTkD2/8ArUoH7sduevrTEbAzub5STnI/z/8AWpSyl+O/XB+v/wBegBwmzzjqOn94U5m+Xp2zj+VNLq3/AALOfegyZ+ZueccfT/P5UAO3DcuOueppvmbg3+zzigSbl4/iP19KHKoeM+p49TQA0ncv8ROcZH1Hb9KcwwW56dD9aEO1G/yTSblxj+7jjHQ//XoAN2Fz83zfKBj0/wDr5/z1Rjj3IIzj9KHlVUYj2Ye3J/w9KdJtCA7vqTzt5/x/nQBG7bmGOSSeo7H/AD+tCMv8I+Zu35f4UucKMZG4dR65BpFkH3f19O39P5UARhi0XU/KeT2JP+f19qkY4ZeOuTj6/wCf/r0KNm4bh2/CiUjb/u8g+3+R/WgBAQijHzbm/Ppj9P8APWlZRlvmxu/M/wCf85pryhlJGM8Dp0H+RS+btTsrdDz9B+f9KAHeYCeOOeQO3+ev060ikM+PTnv/AJ70L8rqB6bc++R/h+lIjMy5A/3T0A/zigBysCAqn/EUofdtBYs306GgfP7DjHH+fpSR442+3PXIoAchyB0zkj+X+fypFZfLPzc/1/zxRv3vjPp/h/n0pSd0ny9emP1/n/P6ZAFLbn4/IduhpC3DH7ozzSEqrcFmVeTgdf8APH5d6C/7j5uNuBjPTnNAAMFMdiMH25xRJIo/3V6n+vv396B84wuSe9Kx3jrnp3/pQAhKv1bnrj16fyxTgQcZ+UL8x9qbHLt55bsD+X/1qcjbATz17H0oAaR/wHd+Hbp+ppynpkbQMke+TQFGFz1xx+dBYKccEt6n2oAM7lz/ABN39/5dM0I+5hn154/z70OA3T3A57/5z+lOJ+YMO3X/AD9f89aAGB8DnqwwMDp/k0u7LemDn/H+lMZwkqgN93qf73+T/wDqpYm3jc23OfzoAdHj+8STjGRTcbQuercD5fu/5/z2oVWICjrjg9Pr/n0pFVo12s27knJGOCTj8hx+A75oAXKvLtz82D2z/n8f6077wH8J6k47c0IfmZ/l+XHPr+Pb8ajLeWiuwbucdSp9KAB228e/PH8/yqPaZBk/w5wMdP8API/+v1abr97tYSIwJwpA9PUZH9eDUv8Ay2Ydf/1UwE+4g59SeMAjn+dOiRivoc//AKv1/wA96jblm+XJzk/n/wDr/KnbdsTbvpyRyT/jx/k0gFBULj14OO+OP/r0uWDFe3Y47/8A16RlwpHXHU9M5pFbnPzeucnjpQA5Ccbj6HPH5U4ltgY+m3/P5fjTEKouG6Hktj/Pv/8AXpzNw3Y9evXPr/n9KAFbcfzJ/wDr/qaSQA7f4lGO3Xr/AJ/x7qF3D+7uPANCOQqtt/P/AD9KAADfx/Cevt/n+lNjXbn0xgcdMf5/T8ac3PBwOMn8f8g0LwWGMbRzg/p/OgBCu4Zzy3Of8/54psbLu+Xp1xj/AD/nFORdo2jbwSvByP8AP1pC+OM7cYP4f5H+eaAHOSsuMndnj3odmdl+b5ecHH3f/r/5+oUKkjIwpHOOg/z/AJ70MrY+VtrEYz1xx+v+NACgfN8v4fT+nGKRjtXYefTj/PXI/KlbcT6cdB6f5/z1prNtPI7ngnpz1oAY2WZfmb5TyQOvOefb1/pUgCqu0/dzkcden4f5NRycNz944289O39aAMKQDjIwaAHLweeTkZIz/n/PvQfunb129cdOf8/99Uxs8gDcfqP8/wCfejILtuO319j/AJxQBIoyu3rz6f59cUm/cN+5snn7vXv+dct8QvjL4X+E0VuviLXtP0ma/IWztZZN11et/dhgXMsp68IrGsO4+K/i3xfax/8ACJ+A7qFZDgXniu7/ALGhA6ZWBEmumYZJ2vFCDx8wzkAHosifMq8/n39K5D4h/Hnwh8MNSj0/Wtds7fVpgHg0qEPdapcr0Bis4VeeQH/YjIrEb4OeIfG7y/8ACX+ONYurS4Kk6X4cU6HaIoVwymaNmvGDblJPnoPkHygFgbngnS/A/wAJLibS/Cmi6TYXkz4urfQ9PVpSx+YG4eMfKTuzumYZyOcmgCnH8TfGfjiRV8O+CZtFs5BzqXiub7JlduQ0dlEXnbnAImNuQCTzjBjT4Eal4suI7jxt448Qa9HHuLabpmdD0cDkHdFC5nlUc5We4kQ8/LXRaprmqQ2Ul1eTaT4X09Vwbm9uElmHfkZWGM8Zz5ko4PFY8UGm69JHJBpuueMHxvS71JhHYIf4XVJdkXpiSCBzz3FFgLHgNfCvw78PDS/BOh2a2e/JtvD1lHFalwPmJl+SEtxzufecZwTmtDVdS1SC0a41XVNJ8MWPK7o28+YnqMSyqI1bg/L5T84IJ72G0vXtYEbX2qQaamObfTYvMcY7GeYHK9fuxRtjHI709H07w/ol+s+n2ranqQHlm6QtfXYB6hriQsVHB4Z1Ax2wBVAU9Le3vb2O70vQdQ1q6iyY9S1ffbrE3qjzqZVVsnmCIoc8Zzxsf8I/q2szZ1DWGtYcZa20qPylIOch533SH/ejMRx2q/nUru4JVbSzhbgs5M8rD+7tAVV7HO5+/HGabH4WtZXzdmbUGZs4unMkf/foYjBHqFB/WgDO0FND8PSTS6Hp4vLy44mns4/PluW7+bcucMwzk+ZJng9+K0Hj1TU4mHm2umxnAGxftE3r1YBFPPTa4+taipst89NoKgAcEDpgelIT8qfeGTv+gz1NAGfb+GbQTLJMst9IvIkuiZSPoD8idP4VH41oKpQKWZssM5PPX/P609IeFzu+b1HQijpKu0cqM/ln/P8AnJAGg4U/N9PQdv8A9dTFcNnJJII+uen58U3GSy8n14+pp2zcOfugYwB261IAdpyd2VyMHHpnj/PtWb4yvZtL8JaldWzeXcQ2zyRkqGG5VyOCDkcAfjWpuCxs3tn/AD+VVNfsTqWjXlp/FdQSRenJQgZ9KAMxPD0ngydP7HjjOlRZVtKVVRYh2a3JwEI6eWSIznI2HJbZs7qO+t1ljZvLPqpUgg4OQRkEEEcjI5FPZtwIXtxkj15/z9DSAZHy9W5yB/n6fQCgCrrWi2+twLHcBvMhfzIZIztltnAxvRhyGxn6gkHKkg53/CRS+GJIrbWJAY5pBDb6gibYpnONqyjpFIT8o/gdtoUqzrGNpJGJfO7A4Az93rUNxDHeWrxzRxzRzJ5ciuAVZTwQQeMEcHtjPUdQCLXtEs/FGi3mmalZWt/p99E1vc2tzEssM6MMFHRgQynoQfT3rzKS01z9mwNJbnWfFnw/UD/RUV7zV/DQ3DJjJzJd2aq2fL+a4iCYTzlISPs/sV/4LmLWyXGpaQvC2u7zLqwHAPlE8yx99jEyKAQhcbIh0Ol6nDrFnFdWc0c9vMNySI2VYZI6+oIII6gg55zQxlPw/wCJNO8W6BZ6xpGoWmqaZqEXn2t7ZzLNBcxnoyOpKsPcHGau7j+p6DGf89a8+1v4Uah4G8TXHiHwG1taSahMJdX0Cdtmn6weS00Zx/ot4ck+aoKS4CyqTtkj3vhz8TdP+J2lSSWsd1Y6hYuLfUtKvlWK+0mYjiKaMEgEjlXVmSRSHRnQhjQjpGbzpCBuG/GRjqf85/zxT2J29Pm69OuP8j8PSoy2+Re4I5OP8+lKgZixX+LqR0PAqQJiBt3Z+XrnH+ff/JpI/mbb6H09MimI4L/7XHHTI/z/ACp27n+I7sf/AK/0PH+NADkPy4/AZ/XtTZPnUHdzk8Y6f55oBz0PQZzuHHHH0pAevHbjJ9T/AJ/OgB6knjOPTj/P6+9JwPl5b6fwnPNIoy+7Jbdzx6f5/maC4x7YB+n+f6UAHWPbu9un+fT9KGVnixuHynPTp/nmjPy/Mfm9+vY/5/yabkzfMejZHr1/+tQAp3MpJGMnbgjJFBzgj+Fjxx2oY5GTnrycc9c/jSxrtBz82D+XuPbr+v1oAbswP4jjJx69c/zpDnK5bnHpwP8AOcf404k7McjdkYJx6/8A16bzEO59OfrQAjjI4PG/gen+eaRroRHeVlKk7dqRsxPfoAT+Xp9ae3PJ/h6c98fzqOQ7QMDgUwHxONzH7wYZ5HTIH9KVFJHoV6/0poODtY+n5n/IpyHK/MD8vT1pAOByvU8/jn/PNDDL+pz7800NsI3buCO3QU0N5iru98/X/DigCQZ6s/Pc460FMq3twR6en5/590UsqfP977pOcD0/U8+2aXb97IPTH5df59KAHA7ZP4cYOSe3f/GmsTsbrn6c03cGfd75bjqadgom1QenY5/zn+tABINozz37c9etO27j68AZx1poGV9NoJx6f5/z3oBCN225wvP0/wDrfl+FADiM9SDxzx+o/KggZ2nsOT6D/OKaE8zj+HpnPf8Aw6ev+Lg/y+5/z/n6UAB6ncW/Adfp70Y2rzgewHAofcP+BjjjOR/k/wCe4Tjrzz64I/zxQA5WXavOPTvg/wCf5U9B8v8AF+IxUcfyt3z2xT4iYgHx6Dr7dvzpAU2bdMwX064xjk8Y9v696lQhk9uwx/n3NLNASWI6/wAPPT/PT8qarCM/N6dx1+v6fTNMBwbduPt8v+f8aOQPX+L8Pb/OaFHQtj2/z70E8/e9x7D/AD/nvQA0sT93kKO2O3/6j/nNIJMhuOn3uM/578fn60hYkk8Er6Hj0/z9Ka4/eFuOCCPbH+f50ABGQrZPmKQQT0PAH6/nTo0b5uOw4PJ78Z7/AOetNA+T5m+Xk9ev+ev+eJBF87Z7nHv3pgAXyz933LevpzQwLONuA2NvA65oyRjJUfNyPftTSdwX+6TnP49v89qQDlbax429vX/PWnEqO/PQg9uuP8n+lNAygBxwO/1/pTS3ckcZHPvx/WjcBY5P5/8A6/50o+b5vfPr+dNHyj5mztJIUew/z+dOZtnTrk4x2z0/z0p6ALnA2rxtOMnt/j/n6UobZz054+v+f600bgB0zknilJ8wDGMdPUYpAIHwGG3HHX07n/P/AOqlUZ5bvgbc9P8APJ/KkMfzHawG7B68Z+tAfADZ9ep9TQAuc46bexpZG4P3vl564ycf5/yc00N8q8DptORyf88/lTkOVX5vz/z/AJ/WgAU+WO3cemARRG/qu7nGe/P/AOqkByFLFcbuR6cj+lQ7+ey4IJOfw/w/L6UASD5gv8SZxnB/zzTWf9zjjJz3xgdcf59azPF/jbSPh9pa32uaxpei2f3RPfXUdtExxnAZyAT14B7dK4t/jpqHiyML4N8G69ryyAmPUdTVtC0wZ6Ze4Q3Lqf70NtKvvyMmgHojlSoHqemfw/rmsnxp4/0P4beH5NU8RaxpPh/S0IH2vUruO0gJPRd8hAyegHU9q4a68G/FDxe6/wBpeNvDvhm0k4ltvDuiNNdL838N5dyspOMgN9lAJOSpHFT2fw+8B/CDxLDqU8K3XiuSHYl9fvLq2vXCDr5ZbzLgjnOyIBRn7ozVAEfx7vvGsLL4H8H654iXcvlanqIOh6U4JxvEs6efKuCSGgt5UbHDHIy63+HfjTxoobxZ4wOmw+YrDTPCMLWMYXdkRyXkhe5k7ZaL7NkY+XBIO+fEeva3M/8AZ+i/YI1JButYnEeQP40hiLuwOOkrQNg1hpd2+tSSCbWta8YSSDcbbSE+z6amVwV8yMqnOeUuLiQ9PaheYFnwr4d8D/A7U57XQdJs7PWLxV+2LYWj3mq3eOj3Mqh53z8o8ydiOB82MZ1tQ8Qa1JZzXRttO8NWNuC0l1q8yzPEo7tHFII1B/vGfjuvpX0nQdWGkx2djHpHhPTFb5Lewt1nmA46ZVYYye42Sf7xzUd1onhrT9aRr5W1zWbeQSx/ai+pXUDAcNHFhhAfeNUHfiiwGa82l+Jo9y2+v+PFYMr7di6W4YH5QHaG0mTquR5rdiTjNbeg6RrMVvFawppPhnSbdSsFjpsCzSQr2+cgQp15RYnUEnDnrVtNW1jWCGsrGKxjZgTcak5347kQocn/AIE6EZ6Y5p0fhVrv5tRvrjUd3PlY+z2w5zwinLduJGf24oAzYrHw3ouvtNt/tbWrfIMxL6he2/TIB+YwA5HyjYvOcCtaWfWNTb93b2ulxkhnN03nyjjpsjYIv18w/TvWnbWMVhaLBDGkUCcJEiBI0HbAHHf2p4i+VV6bhnpQBmDw5HKq/bJ7nUuOftDAR9c5MShY+3UqT79TWjbhYY1ijRY41XACD5UAPYen6Y/AVIQpG4/dGSTnrzSDh1HG49ef89z/AJzQAqAKzM2MDt3+n9Pw/AO+83Tc3HH/ANemhSp3bu3p056f5/WlTM5PpjHHrznH+e9IBy4VRt+6xGB+n9OgFCScbiuDkfj7mjzPLkXaq8nnn2/yKav7w7gwZWI5J9f8RQA/dsKrjgAcntinKpz83y+/qTimqx7Y3bhuGeMHH9KN/wBMg9vy/TFIB2/zT/vDjjr607OD0+6c8Hp3/wA/5FNRfKT5SNy/oP8AP+etJjc2FYcDHHf8fyoAcvyyblAXB44656fyx+PeqWs6lFo2j3l7NuaG1heeRVA3bUUs2M4HQHqRz3FWt2fmPVuR7j/9VZfj2JpvA+uKv3msLhRtOGz5TDr7ZoW4Gpv3p9T+H/6zzxTt5O0df/1Y/wA/5zX0+Rri0g/vMitzx1APTPFTcMMdl4+v+etAMhu7Nb+IoJpomB3B4pNrKR09mHqGBU9weRUcd39mnWOYBZJGxGeiyH+6OeG6nBP0zzVpV6euc9M88/5+tNeITRMGCsrcbW7jrz9PWgB6qoH94Yx9RWRqXhuaz1KbUtIkjt9QuFDTRSEi1vyBgGQDJV8LtEqgsBjcHCha1o4iqsu5iD0J6/5+tODblVgyssgBGDxz0x9c0AZ+jeJIdcaWHy5rW7tSDcWk4Cy2+c4JxkMhIOHUlTg4JIYDm/il8HrXx7cW+sWN3JoPi/SYyuna1bpukjUkEwzpkC4tmIIeFzgg5UxuFkXpPEHhi310wSMZLe8s9wtruIhZrXPB2k5BU4GUYFGwNynAqjY+J7iz1CHT9ZWG3vJ2KW1xGNttfnGfkySUkwCfKcknDbGkCsQAc/4S+LdwvitfDHizT4/DviaZj9iKzGSw15QhYvZysAS4AYvA4EqBScOgEp7hnxGxX3IGev8An/H8cfxz4C0f4l+F5tJ1yxj1DTpyHEZcq0bodySxuhDRyowDLIhV1IBBBxXF6b4p1f4G3FvpvjDUJdc8O3dwttYeJpgqz2rSvtit9RVQFBJZUS6UBHJVZFjfa81Aen78v1ypyQcdT2/kTSRNxu+7x3/z/kfnTVcwSxrJu3HJ57HPNC5J2cbcDHP3h60gJUwF44zxj6U4Nk/N97OcZ7d6YC2Wyfu9c9v8/wAv1NwBznvx7/h+dIBxGN27jGdxzk0dAdxHrSHhcLt9qZs+Tb64A74/z/n2AHNjOePQ+/NEhwm0dW5H+fz/AM5pQTz03ZHHp/n+lKORzwyn/Ofp/n0oAUEHcfbseme+aQcfw45OMHp/n+lG7YvzfezyD/n/ADxQvA55PRh/nvQAOgJH3T3ye31/OkfDt+OCfT/CgncDlR64H8v8+lLuwTu+6vX1IoATpv253Y+uc/5/pTFXaOn1x7/5/QelOUZcj+Pk8e2R/jQ4Zm/HPXrQA0tvO3bgZycenT/P50KeUbd97nt/j9aWWPK/oSf880zcGDbuv3sZ61QCpNg7lXpzn0/z/nvSqfMT5erY759/8mox3Hy+npj0p4O4ZLdTgfqfz/8ArUWAf/Eq9mGPpRvBkwPvd/y/+vSF9zqfz9M9v6D8KACF+Xj0Prxn/PtUgKcbePujjGe1O3YLDt1+vqKaylQVbaMngHouabhpI9ysN2eD1H1oAm/5aYOBt4I/z+FND91X7uSP603aCeny4IwT1Hf+X405V7sffntx3/l/ngAcqbz6nlsdj/nNHGOcbs9jTcc/7S+v5/5+lCjdH7MMfT/PoKAHOcqf/HT149f50ZUnPp2J6f54H/66F4ftu6dc/wCf8+9NLbQv4fT/AD0oAfu3Bt33SeSfQdKcrZbHBbOef6VFnI28t6/yp2CoHopyO+KAHMdrlf4uPzqN0BP0HX164/l+tOc70/u8Y6859KGOSenz5OD34/rQBGvMXPp6/wCf8ntTl+fn8CB/n/OfrQvHt9R+f50f3W6cYHP+f8/jQAzzNrD7x5/Pt/hTQuVGc5xnr9f8/jUhT/AZHcf5/nRGCxZlywzjPr6UAIgw3f8APr/kf0pwQttJ/hzz2oC4kG3jtgf5/wD14pGVZIztX7w6565oAQHzI/73PTP5f5/pSE4cNuZt2Qee/FK+eoO0g5z9cH+lN3bzz8oIIz14zQAiN8meQq89c5H+H+H409W2n7rDn175/wDrfp9KGBUHPX6/d6UKu+RSq9+fx/8A159KYCKN6rjd1Bxj6f55oTc4DZz6HHX/ADmlYeWcD+Lrg5wOB/n8PwFUqu1l44OM++f0pABfbJj5m7Zz+n+etKFbPVvbH9KEG58tgc/n/wDW4pRxnjPHp0/z1/yaAAyEJ6rnpTSp+Y7mzz3702+vYdMs5bm6mht7WFTJNNK4SOJRyWZicAAZ5NeW+Nv2r9HsNHW48L6bq3jxpLiKFZdGgZtPId1Ulb5gLaRlz9yOR3J42jkgA9SV8xYy3XA5qn4n8VaX4M0W41TWtSsdH0y2XdPeXtylvbxDrlpHIUAepIrz/wANnx58TdLhvr7X/DvhrTbpmeCHw5F/aVyI/wCEG7uk8rd2YC14PAbIybtp8H/BvgLUP+Ek1CGC61Wz/eDXfEN419dWxxgmOa5Yi3U8krD5af7IGKdgIl/aDh8VoY/B3h7xB4uWQbhfRQfYNJPXDC7udiSp/tWwnOOxqJvCfxA8aN/xOfFmn+FNPzu+w+F7YXF2w4+V7+8Ugqef9XawuOCJB1rpT45fV3xo+m32pFhxcyqbS0zjIzJKA7qc/ehSUdM1m3813eXcltqOtNHIdxOm6HGfP2cH55Tul6EYdBBjd15BpoDO0n4T+Bfg/fw61Nb2q63ITHHrWtXb6hq1wcE+XHc3LPOR1xFG2Bk4X13pPFOq6vKq6ToV1Ish5udTkNjGVwCSI9rz7skja8aDr8w61W0PQbjTb2aXS9K0/R5JsLNe3rG7vrkdcPtfL+oLzsR/d4p+s6LoyQpD4gvv7R87LLbX0oMc4AH3bZAEkxyeUY89TQBmPP8A2pdst74g1DWpY2CNY+HYntoVbnAkkjZpEYYIO+4RDgZXkVoaF4avtKtpbXR9P0XwtYyHLGOIT3E3X5mVdiB++5ml6nitBNTvLmBIdL0lo4YyFjkvD9liVR2WMAyf8BKID69DTV8M32pSH+0tXunjYMDbWCfYoiCMcspM2eOolUHPI7BgUdW0fQdPu4o9cvG1W8kbzI4L9/tDuwPBitlATI7Mke7uSTk1fi1jVNS2Lp+lrbWqrtWbUJDBgYGNkCguQOhDmIjAwMYJ0NF8O2fhmIw6fZ2djHMcyeTEIy/qWI+8e/zZ/Wr4gIh+UbeR/X/E/wCeqAwv+EOk1OPbqmoXl8rDJhizaW/Y42od7L6rI7g5ORjArWstPt9Itvs9pbw20JJKxQqI1z34GBn/AD1qdJF3FflyPm255AJOM+mcfofwdIuCp9v/AKw/z/8AXoAaPl+b5lC5wVHWhhg7fvdTjPToSf8A6/v9RTtn/AdoyD6/5NMaMGdW2KPLye+ckcqfb+ZxxwKAHHhMseGBHTPHGf0pSrMBuyrAY/TH+fpTvKyPbIxnqx75+nWhsuq9h1A9fxpAK4HCn5s9R+Gf8/1pAMyBTnpyexyf8/5NOX7y49Bz0J/zij7seW5O0D03Y9PzpANBGW/Hv07f0pSmfm+brnOen0pznJw2PoD/AJ/yR+I5LH5R0HXPTvQAn3twGVXOcjv9KDxx8wXBP05/z+VLs2FWPoBn16//AF/z/GkX93t/u59KAFbhVb7qg888fzpud/qT2x2/+vx7UFFaTd1J5OP8/wCf0pfLZvu52/Ljn/P+TQAAsF53ZXnGe/8Ak/rQhyvcL6ev+cUSY2MxOFzj64oUbOCvyrx9e+MfWgAIw3O7J9D1H+f1/KoLy1+32lxbtkrMjoSfcY5qwBtRSfTI+vrSCLecBueo4+v+IoAjtY/s8EMePuxBeM4GB/n9amHyjHqCPbn/AOt/ntUNhcwahaQ3NrJHLb3CLJG6Hh0YAqR7EY59MVKGIXn8ufagBU4XC/Kvb26f555pqHeu5egyev4Dn6D/ADmncgenPrz1xQBu2gDDHnA/z/nNACqx+X7xwew5+n+eeO1Yt/ZXGgy/adMiaa1yTc2CttVhjloeyyd9mQjZPRjuN278QWlrdfZjMr3EZy0EQMsy+5jTLAdecYpiXuoXxxDZraoxxvunDN9RHGTkH3dTz0GOQCfTdSg1a38y3cyRnIYEMrIwPKsrYKsO6nBHcVV1y4029gl07UPJulnQCW0ZfNeVT0/djLEZxzjjHbArMmtbe+vDN9tutQumA8xLJdkLjkbGKED8JJTjB7Eg3o4pNJ09xFDp2i2ancWbG1f95V2ov13H+dMDC/tbVPCMbLKtxdaKpHl3l1l7ixBySZVXLSxj++drqOZMgNILeovp+v2ElteXja1b3kJSaztk8y3eORQCrLHk7GVukjlSPUZNTwyQ6mQ0a6nrTZXbn93b9uekcUi9DkByMZHIrC1DwTr2n6fcLoU1to9ndFnn062fzGy/MklrJIFSCUnnaUMRfLnazM5YHHfDy/uPAGteIpPC+i6leeCLG8EE9ioE1zbXS/up2siGYzQxhI0aHJKGNliJ2CGvYPD+vWfibSrfUNPu4b2zul3xTwvuWQZIPPqMEEHBBBBAIxWX8N7bSLDwnb2Oibo7HTf9EMEm8S2zKBlHVvmV+QSpAJ3bud241Nc8C3Ok63c614Xa3tdSujvvrGZ2jstWIz80m0Hyp8ceeikkBVdZAiBEB1bPvXbjv+dOVi7bcndzznkH/P8AnpWF4T8e2niu4uLaNZrXVNPwt7p1yAlzbBidrMoJDRvtO2RSyPhsMcMBtqMjau1lzxjvnr+fPpQAHggbeMcfn/X+lPxlurHkd/y7/jTM+ard1HIzzT04GdvvjPb/ADikAijdk/NyMc9PQg/jSFDvbr83v1pdvDHH0P6f40dGbgt90HnpQASScsWz+fT/AD/n0qQtsl3Nu9/emMCx3KvzY4/H/ClU7tuPr16fSgAV+eQTu9+1NXJDdc55z9P8/lSqpAB7c4P0/wA/54pSMD6cgHuO/wDn2oARhuJDbsZOOf8APp+NIyYVucenP+ff/wCtSh8gtjdhSAPX2/OlUL2/xz/nr+VADWYem5fr1P8An+VNK4XcSx9wfTn6fj9Kdk8dl56du1BbcOFO49qAIjG0Yw3O3v7e/wDntRIdxbqwHQk+o/z+VPdCX7dRyR/n8xTQn74KPp7/AOcVQDzIS+5STg4Pc+hP/wCqiJvkz83A3Hnvxz/L/OKRW80498YBPH+f8+lOiw6M3HTJ9uw/r+VSASHb1Ldx04/z+lNi6lW55z1/z/nNB+93656HPXp/L/OaM4Kkdsgn8B/9agByHcx+9yc59On88f8A6qcrZXoV3cEf5/zxTA+QPr0/Q/59qVl3Ky9F9SPx/wAf1+lACsfl564z9eh/x4/rSj5Rjknp1/z/AJ/UD7S3PQmhSMqVA64zQApHC8n3HYUgP3c56DPanD5sLTSpcn1bv+tABISAV3HoB6den9aXqeuQvT256Y7dB/8AWpXBk+6232x19fbpTSwRVOeFPA/l/j+NAADvU4Jbyzwc557/AOfenLwD97sP8/rTQPm64yfrj2/X+VC/KuG645A7dT/n0oAVW2oeccdevtmh/lU8fN0P+fwpAuf+A8k4xnj/APXTQS3od23kjrQA4urfdH4f3v8A9f8AWgr8rD2657/X/P4U2M7V9S3I560mzy1+XaoyBwOOh7fn/noASAnnOM9AaYCxH3Ru9+f8/wD1vWmXFzHbodzBEzgMTxn/AD6/zwDIDubb/e6f5/z06UANJbIOdrAfXH+eKVWGVUfQL1xjp/OmhfmGM9/x9fb0/Kmg75Dt3Y6qoH+famBI7ZO0j5ewx1Hp7UisRjucHJI6nr+tLGm5lH3uM/LzXI+I/jJouhavJpdvJc+INehXcdK0eH7Zdw4wAJdvyW4JPDXDxoSD83BpAdYzMefvc8Z/i5NOmk8qKRnZVjjUs7n7uBk5J6Yx6/8A6uFmk8e+Mn/cx6L4Jsm5D3B/tbU2U9QY1KW8EgySG8y6T/Z6irFt8CdDv3WTxA2oeM7hTu8zxBKt3CrZ4KWqqtrGwBxujhVsdSepAI5fj/od3KsPh2HVPG1w27C+HoBdW+4cMr3jMlpGwPG2SdWPOAcGnNbePfGR2TTaN4JsWjXd9j/4m2qDKgkB5EW2hdG45juVbrxiu0iGFRF+VVACqBgKPQDtx2pwGA2OvQ44/wA/5+tIDidN/Z/8OJdQXesw3XjDUrZhLFe+Irg6i0Mgz+9hif8AcWzHubeKMHAz0xUnxplzomhsSZGXxHpAyQXzm+hHT8evbGe1dlIFQcfdXvj/AD615T+2Lb69qHwTeLwtdWVj4luNY0qHSru8QtDZ3Mmo28ccrqAdwRpNxGOQMU1oHU4+1+N8Hiz9obxFb+GNQt9L0Pw7oElx4ivblhHZtffunKBiSiywQuDNKc7GMaESbZRH0/wL8YaH8WvCmneI9D064N3c2sd3Fea9LJcXcUci/JJF5jNJ5MikMpUxKwOQBnA+SdR/ZZv/AIU+KNC8I2K+OfFV1eWkt74i0O5O6z8Ust5Z5hDQ4jitZXPmzT3Dt8uUbezlE+j/AIQ6Xr/xe1nWNa8SeKr3SPFWnFbWTw7ZafHbJ4WBBaJQzqXu1dWJabJhmwRGIwm0GvN/XZDtoeu6tZQ20Pn6xqshhBKkeebODJzxhWBbdnG1mcdOMmn6bqe20Fvo+ktHb5OzdF9ht0yR0Urv79RGR785rF8KXn9i6xHaavaw2utSDEGob2kj1Hg58uSQl0bgkwsxx/CWHI67OwHHtgZx/n0qxFBNLvL5W+1XhwwwYrVTCo9csSXPYZBX6Va0rRLPSPMe1toY5pcCSQD95LjH3nPzN6/MSf0zZVfkxyc8DAx34FPi+ZA27r+Xp/n3/GgBdgdhj7uOCO4wP/18c06M7mP3Wwcrjv6Af40KuTtzzuxg/wAvzH6Uqp5g29CRweOcUgFAURqoC5PA/H/HNOjO07cFT1ye3+eP85prfInzN83fPbP0/wA/rTz86Z+6QaQCwsuzPK9yO4/zihX+XI/vAev/AOvv+VCLgnP3v502Rueh3dwO4/z2pALG2eG+73Hp/n+tKP3ceeOpznjHX/6wpBknuOeO+cjvS/6tBhenQd+3Gf8APWgADAptX5d3A55zk/5/D3pIwrBe+B26e5peWC/N8xB5/wA/y96XdhSF5XOSex9v/rUALK29MN07Dr/n/wCsaUsT9c/5/lSIv75R/CwHU53fj+FNPIKjPHQg9PpQAOxRw69OWxjr6fz7UoGEG3tx1/Gm+Zjk9Ocjt7/59qSNSV2lmPOcDn36/wCe9AEm7YMM34j601n+X/Zznj3phPyN2JwOv+f8/SnMMHKnO/JA9TjP/wBegBfNUL7gZI/SheV/hyv+f8/Q0Rn5m7cnHsP8/wBKaPlViOvQA9/b/PvQBIz/ACcfn64xxQW3jPPzZXI7j0pqnanHrkE/nSJ85yvPcAdh/wDX5/WgBxJZPc9Pb/P9KdDmO5G3cPm69cdKzrjxFZ20zwrMbmeMkPFboZnQ56OFB2892wB61G2oXzL5hih02JTlnu3EjL0xlUO0cnr5h6dOaAIfhv5h+HXh/cgjb+zbXIDbgP3KZAPJIB46n1q5c+JrOzlkjWRrieM/NBbRNNIpxwGVQdv1bAz3rD0w2MmlafY28d5rENnbR2waAFLORVG0kklYXHTgFyAOhq5fXc2lWcKXF3p+h2ufLiji2s7egQuAucfwrG2exOKALz3mo3J+W2hso1OXkunEjIcf3IyQRjuZAfY1mwz2+qx7vtV/rjcjZb4W2PByNy7Y2A/uuzHt16tEUdxPuh0261GReRcai/lRKw9FbcyN/uRAcHn10HsL29uN1xfyRx4/1NtEEz67nbcxwe67OnTpgQEMu7RtNC+Zpeg2OQq9MLuz0ztjVvbDg1E0ceoSH/Qr7Vsk/NeDyoAeoJR8D0+aOJu9aVnpNvp9wskUI89RsM7s0kxB7GRiXI4HU9varJKgEjd83TqMf560wKK2moXJbzLyOzhUDEdrEGZeOheQHI5xxGpGevpMmg2kFx53lb5gcLLIxlkTgj5WYkr16AgVYR+w4Zsn6H0/l7c+9Oxub5e4wTjp6f8A6qQGKmv3Phq8SHVmWSzkbbDqWAq7ieEnUDCMcgCQYjY8fISqtsEHdgfeXIBA79/8+/4gSITszMWYSJt8s4K4wfbvnnOaraPpA0geRCzLaouI4W5WLpgJ3VeuF5AGANoAFMCtrfhn7Zex31lN9h1ONRH9oVN6zRgk+VKmR5idcchlySrKSct0TxR9uv2s7yH+z9UjUyPbPLvWVOMyRPgeZH8w5ABGQGVSQDrYw31HHf8Az+FUtb0Sz8Q2YhuFysbiWJ43KSwOAcSI64KMASMg9CRyCQUBmeOfh9Z+Ore3kklvNN1OxZnsNStGCXVg7AqdpYMrKc4aORWjfA3K2BjF0j4l3XhLWLPQ/GRtbO/vphb6bqsMZj0/W3O0BBksLe4LcCB2O/GYmkwyprw+Irvw1ffZdaIktXYC31YKFikJICpOo4hkPQN/q3PQozLENfXvDlj4m0e603U7O11GwvEMVxbXUYlimU4yGVhg/j3x6ZoAsq3mRruDDcR15P8A+ulklwFHX2BzyMV5yt9rHwMutuoTah4i8DjAivX33WqaCMn/AI+Dy91bDgedzNHjMglUvNH32m6tba7p1veWdzb3lreRrPbz20gkjnjIBV1ZeGU5BBBxg5HXigLQly5+uN35/wCf88u34+9t3den+f8AIqAFt49WwcY69f8A69OQnHXjtnq2O/8An0pWAlbDKv0IHP501m+bvjq3tikdv3e1Qcds9BSKu8MR35Pv/nNIB45x+Rxzu6j8utKeXbv3B9T/AJzTd2Cx3fxYH+fXgnmgZRuvfp6f5/zxQA/77fh17CkYM33fvLzjHfr/AJ+lCfIy/wAPbgfX/wCvQPlDN6DgEZx2/wA+mKAEcYJH8Ld8dP8AP9PxpXTLbe/Tjtk00pmQemR9FPOP8/X8EIKLgZLbuvsf8igBXXj+70GMdfX8v8+xnA3H1zj2zTZPnXPReM8deB/9bpRH91j935vrnNADTzheG4AI/KnSHnJ7jqO3qf8APoKNnzH6Z47/AOf88ZppYon+1wDT3AdypLKQdo4zx9P89qc7r/wEHAOPrx/n3qPGD8vQ8cdKcGPl/LwO1IB33V+b2AHrz/8AXP8AnNEbNGTgbeje/SkHyDrxkfhxj/P0FIr4UfjjnOOT/T8OlADyoDbV9B/P0/A0/ewXPoM/QVFlsfU46d6X7r9WG3nPp7fX/PFAEmefVeM5PXnH9Pypqc446AHr94f5NIRl19B19D+n14pVyHX/AHs5x/n/APV9aAHKwjcc57dMf570qzFc+2SefT/9dMjXMX3t3AGfejbnc394/hQAhXeeucjHA4p+P4uOehx+X86j6J83r0B/z707c2cj6f59O9ADXc465yM8d/8AChnJAGe5zxj601TuB3NwCeg6U3liFzjnJAPT/PFMBc5b+9j0649B+PehX2NuZs/w+478fp/nFNLk4P8AdyenGf8AChW2j0/yB+f+fqwHqxccs27qf6frTlOVHPDE459DUZICYOVXoSR05xSq53Z+6cf1+lADic8rkHjoOtCyf3ic59Ovf/P+RTGXcQvzfL1OOn5/nSsfMAH4j3/zz+X1osBxms/ArRfFWq3l54gutb8SR3LswsNR1B20uFCciL7FHstpFXjDTRyP6ucmum8MeHNO8HaPDp+j6fYaVYW5/dWtlbLbwwnOfljQBRnrwPr7XopSx6/j6/Tj/P1oiYKP90fX2o5QDPIGeSQRn2P+f/r0R/vGLewHHHBpVG9s/wAOR1/z7fypAORuJbnk/l/OgCRuVA5/EdP8/wBKZOx8iXb8zMCMBu/Y55p+3b97noDx19aRTk/N95efp0qQFdSAy7gT1JHeuB/aD1OPTvDGhGSRY2m8V6FCoK7vMY6lbEKPQ4ycnoAa7xiB/F8wyM49q8z/AGqLGS88D6KsNzJZP/wlOjqLiNAz2pa8jjDqGBXcrOrDcMZHORkE6MOozxn4Zs/Evxy0SG4DIy+Hb6e3nhby5rV47qxG9H/hP7zngggkEEcGp408KwXupWMniK4uNI1izdYtI8W6YiwTIS3EM+VZArH70coa3kJGAr7VFHR/Fd5pP7QNrpviqWxi1C30EW9reQAx21/592OdvPlOxtwNjHllIQsMV6vNbLdRyQzxrJFMCkiOoZWGOQR7gdK0um3/AF0QbL+u55t/bs/iLU4vB/jy1g02/muElsrq1BGn+I1TL7YWcloZ14LQOd4ClonkXLpsR6xqHwwMcGoz3WreH1BRNUk+e6sPm+UXWPvx4+XzgARgF85LiPxL4ItrHw1No99pz+JvCNwNktnMnn3NgAQyNH/HIiHBG0+bHsUoWK4rH0bxnqHwf0xLjV9UbxJ8P5Iw1n4gJM15o6HI23xH+ugBAH2oAMgGJ1O17grzYHptjfR3drHNbyRyQzJ5kbowZXXsQRwR06ev0qdmIk2qSHB7Dvgf0wa4mPwhceAI1vfCR+3aXcjzX0Z7geTMCM+Zaytny3b7xUt5chJPysS56Pwt4msvFli0tnM0iwyeRPFLGY5bWQAFo5EPzI49DjrnkEGmBrQyBkzu2txkqfyqWLDDgnCnv+VQhsscenA/w/L9KkiODjPfAOOlSA5zvGR/EMYHYmjH3eTtbge4oYZ+U9skjHb1ppONrA/l+H6/57mkA/7zbcjPQ49ew/z+tCvuAH8PTJPUf/W/r+aPNn/aHB+vP+GKBkE/eZeO3XmgBzfKW+b/AGffJz+vP60HhGJ+Vev09f8APtTVG4Feze/X2/z/AI04kfxN0xg4pANY/vAfrgkYz6f5/wAhTINnPO7OPf8AyaSRdrx/Xt3/AM+n1oYlskZ5459MD+lMAMwIY/wjJI6ZH+RQ5wcZxhic+pNBLGX+83Y56+n+faoyA6/3h90cdR0A/wA+lADjhzu68g49McDnH69fSkZt3zHlWHQHrSr824btxb1GOlEhPzSdNoyR6DHP+fp16UwFeTb8xbk5OP6/n/nmlO1nz97kAcf5/KslfFlne4Fizakzc5tMSRj1HmEiIHqcFwx7ZqPUNVu7V0a8utL0eGRiqAt500w7bS21Vbp8u2QZPHuAbKFmRujbPn4z+P8An/69Z8PiyzvSy2rSak3IItU8yPPoZP8AVqeejODWSbGPVSFGm3+sZ5Muqfu4ScjH7txwc944dp65HFTy6xvvmt59Wj8+MqHs9OgMsyA84fh3C4GNwWPrQBavdVvktxPcvpuj2u8AvdSebIwOcg4Kojg4xh5FPPFVRFHe/MsWra51Cm4IgtQuP4lwkbjoAwjkNGn6dNG6zWOmR28xjx9r1CczXAB7DBd3UdwZE9Ppebw9NqB/07ULq4VhteGH/Roc+wT95j2aRh7VIFee+ksFhtbnULTS/LAMVrYxCaZR2CBlJYdeBEOn41WttIW7uUuLXR3uJlYMtzqtwSy8fejU+Y6nk/LtjH8xuabpVrpCtHb29varIwLCKMJvbPVsAbj3yev1qypPnKwz8pz06e3/ANf3oA5yTXEeKCW+1SV7a4UMJ7W3a3tWyeMuC7RnPcyKDkAZOcaWj2NnZxLcWaQK1yN3nxgM1xx95pOrdOpJ+tU/h9ut/CViuWVoVZWz/AwZwR9R0P0qZ/CNmZPOthJpdwzlmls28ku5A5dcFJDx/wAtFb2qugGlnbuKn1bn26f4flSs+PlU7sc+9Z8Lahp/zSeXqEUfRlAgnIwOoOUY++YwOmO4s2t6ksrRqWSQ/wAEi7CT7Z4b6jI9zQBOvyphdvy8j8Of/rU5/wDWDDfdH/fPemxD5Np6KME05Ceg7/xfyoAduy+7/a4GO/Xn/P8ALFCnaqjq3egSbwDwN3X2zzS+ZhVyuePT/PpUgIXwpOTtzk/SnA7fTpxj/P8An+ZjMjMTuOfy54pq/I3zdsj/AD9OlAGfrmm3TzfbNPulhvo0wsc+WtrgDtIo5XrxInIJGd4Gwu0PxDHqwkhkjks723VWns5T+8hByFORwyHBAdcglSPvAqLgHmAbv95u+P8AOahurBLyWOVh++iy0bjh06ZwfQ4GR0OBnpQBNPbpNbtHKiSRyBlkVxuV1PBUg8EY4x0xXP8A2S68DWxa0W41LR4xn7KimW6sxx/qT1ljUZPlnLgZCFvkiG7PeRW1xCrusb3B8uIEY3nGdo7ZPzHHUgHg4p6vhW3bcnv6elAENhqEGr2MdzaXEdzbzgFJIm3BgDjgjvnjtgjmuB1n4caj8PL641bwGtqsd1O91qXhuYiKy1J3IMktu/S0uTjdkZhlZn8xFeT7RH1eqeHZrO+kvtJaO3u5H33NvJxb35wBlyASknbzVBJ6MrgACzo3iCPXY5NqzW91CQLm2l2ia1bsG2kjnqGUlWHIJHNUBm/Dz4l2HxH0i4ms/tVre2ciwahpt7H5N9pc2A3kzx87WwchgWR1IdGdCrnfiGeN3zNyCB7/AOfWuU8f/CuHxfqlrrmn3kmh+KtNiMVpqsEYkYxHJNtcRkgXFsxOWiYjB+aNo5Asgp+DPirNPr8PhrxVZx6F4tdJGigVy9nrCRgF5rKUj94oDZaJ8TR87lKhZHQHcJLuTqNp6Y/SnLICq7ccnGT6f5/z6QsWCcnc2M/7x+vv/jT418sbVbcFwM4z602BJ94bv4l5yR3/AMjP9KUy7cbT82e3t/8Arpgby9vVuM/59KFyNvzYb1I9en+f/wBVIBzOSjbeOMAY5z6fpS52ooPRsDPr09veml+du7BUHbjjr/jj2pWb938pPuQPz/z9KQCZ3DuG2gHjOTn/AAoOAjem0k/57UAqq7ugxngUEkyKOcsemOn+f89aegBIeSx656Y/z/kUMBvzt656+2BQjllYKPp+AoALqyrxyCOc/wCf/r0ABJK7W6dOnvTXbB/HOMY/z2p2dyf3toyOPrn/AD7fjSTAsT229R/n6/rTARm4VVY9OnT+n1NO+8M92PTFNc8g/wAJ4/H/ADihE3NgnDdQMZz/AJxQA7epf1UkD+v9f89KAuY+dpxjHHHX/P8AniiI7uM7dxwKN5CenbH6f4UALncWO7jjB9xj/P0oYFEXbwwOBjoP/wBX9KU8MvU9+eMegoOVJyeVbg4AqQELEfKvA9h93/P6UiPtbLdBxnHTv/SnRxxxuwx33H1J6Z/Ifp+FNIZlXrngk+vr/n2/MAdu2RksSVx27d+KGfJHPUnt1x6D8qazEDDemc+h7/59KQDYNnPqc+wFAD2JCMrYyDnrgY5H+NBfLL1bd0yMZ9v0/X3zQR904+bsOnJ/z+n1pqHaV3emefQUANLb/wDeUYx0xyelDncP4tzH8u3+f6UJtAYf3gc8/e65/wA9KNwce4JAHqfT8P8APeq6gG0K27HzZI/w/wA+/wBKap+b/aJ59+efp0/zjNOSTJXbz7+nH8hT0AVvl428E96AIsKPl5wO56g/5/l3zSY3Sbem0dMdO3+fp+FSNhQG/hyNw9Bkf/W/L1prttXHyhiNw+b/AD6daEAZEp8wr94ZHA/X/P8AWpD80vynbj1HQf8A1sUxPk3blGWPGTn/AD3ozjkqCVwSM9ex/HmgBynB5DcnOfcUgO9lYK3HbPt+VMCsf0HXvUjMyk7hyxCnn+X0/r+QApP7xf7o6Y/P/CjZ8o7MtMUqgxke59/880533su4YXnPP+ew/Q0gH7QpbCnAHHtgen+elJH8rLw3c5Pft1/z1o3bztXacHBps85jiZgnmcZChhlvbrjnHfjmkA5iAobqQMj0rgf2hFEnhTQ0w37zxXoQO0c8anbMfoMA5rvGbA3NtO0EDn71cN+0BLJF4V0qRN3mx+IdIlUgrkhb6BiBn+8AV/H8DWvQDN8XaLa6j8f9Dsby2hubHVPCmrLdQzR71kMF5pXlk/T7TLjuN3BHNGueKW+AmmQzazeTX3hPzrexW7ly11p8s0whiSTvNGXeNd4G5erZAzU/iVtv7TPg8bQ3/FKeIfmz0xfaFx+P9KpftSJ5nwtsWXaRD4o8OypnjJXWrEgD3yBg9/xzT13A9Bs72HVbVJ7eWOeG4AeOSNw6yKe4I4IPXI9Kxr7wrcaLqk2paJsjuLphJd2Mh221797LDr5cx4/ecg7QGB+8MzVPCWpeCNWm1bw0qzQXDNLqGiSTCKG4Ow4kt2IIimLBQRwjjOcEA10HhLxlYeNdKW4sZGYK3lzRSr5c1tIMFo5Izyjj0PrxxgkA830mw1DwHdS6n4Ht5Lzw/GSdX8FygQXVg43DfYbmCwuSrDyGIgl27o3jO5peks10z4p2cfiXwnqwstTjP2eW4a2bDFSha1vbZijblHG1tsse7KlQcN0XiLwpFq93HqFq5s9ZtomS3vEUFwp25Rx0kjOFypOB1BUgNXEa/wCGri+8UfbtLmt/C/xEe2TMm1m0zxEka58qYfelRcsAwxPDkkbl4YA6vwl47k1fUm0vVrJtJ15V3NZvKsiXKr1lgccSx/gGX+NUPXooZQ6A/NjPB/n+WBXA6L4j0/4rCTQfEFhceH/FWmgXD2RucXFuVIAurO4UL50OSoEqAddkqIxMdWLfx1feA9SXTPFhRrW4ISx8QxR7LaZiyqsNyvIgmJYbT/q35xsPyUgO83YHXAbPJ6D/AD+X9Exh/mH1+uf/AK+aiZ9rouML7/w+/wD+v+dSedkleu7nJP8An1oAdIMfrz6+v8/0p0XU9+Sev3v89ajEpcqvVv5cf1z+tHmA428Bv0oAeh2wgndx2I5P+cUp4ibjBx+Z/wA5/Oo/OVl6YZuPp09/xpksqwwNIzLHGvLOzBVT6k0ATv8AM4HO3+P3Hr/n39soDtxzjbgj8ev154/E1hJ4/tdQO7TILzWCeQ9lGGhI9RO5WJv+AuTz0qHUtVvreXdfX2l6HHMcQxxH7RdSgAk7S4C54+6I36dc0Ab8jJGjSO3lxxqS7scBR3JJ7dev1rJ/4TS2u42/s2O41Vl4U2ihoCR/02YrFkHsHJHp1qoNFjvJvNXTZdRuIXV0n1WbaqEdWRCG8sgA/djQE+g5pTqq6wOdQuL3A2tHpaFYycAYMoJKtzx+9T6dcAEuq6jeQ7ftV9p+ixTAbQh8+duAfkZwq556eW+c5zVOHRrbVpEuF0u+1R2O9JtYZlRGyMFYpAWiYnn5IV+7z1Bq9ZadcRiRre10/SfOHzP/AMfE8vP8eNo3D1LSfQ1YXQI7vi6uLq9GMMs02I2H+1Gm2NvxU0AZ99qTaldGGbVJpJFBR7XSkMmzkfLJKAzoQcfNui7nAp9jp9xYzGSx0+z01pF/e3F0zXV2+OgfY3zd+TMx9jmtuELb24jjCxxqCsar91QPQfr07j3pwU9mx39e4x+n8vxoAz38Nx3kZN9c3l8Mf6t32Re4Mce1XHX7+8+/Wr1jp9vplv5drDDaxjPyRIEQEkc4HHb9aeDz93JXnGeueP8AP/16eJFO1uGLE5wf8/8A6qAGiPYY+wAww9Dxj9alz5n3g27qc9V/+vTGcNuzgc/lj/H/AD2w4/KMsGyw/Ltj/PvRqAuMFifbj14/yaMqxH90cnPHfrSyPtA49Ccn73+eO9MHzNt+Xcxx9O/+f84QHL+GNM1KHw9F9ju4o5I5rkGG4txLG3+kSYOVZWBxxncwx/DnJrTi1m5tRtvtNnjj5Xzrd/tUfQHnAEnf+5jjkjitKztY7G2ZI1O1pHk5PQu7M36k9PSnOdkZ2/e9z15P/wCuncBkU0V180ciyjPOw556/wBc46/SlV1ww64/TH/6jUmFEu7+8B8x6sB/n9fes+/j1JL7dZyWkkDEB4bgFSvAHySKD2BPzK2ScZA4BcC+RkhiM98k8eh/z+dYa+IdU0qdv7U0iRoWkk2XWmsblUj3NsEkRAm3lduVjSQZz8wAFXLPW9xIvLK6sHUZIkIkj7/8tEJHQd8dR06VoqxkXn23c0gKuia7Y+ILeWaxuYbqNZBHLsbLQPx8rL95X5GVYA89KuY3r3YdeT+I/nVHVfDlhrdzDdXFrG11brtjulJjuIlPVVlUh1HPIDDOe9O0+xks0XfeSTRDP+uVSw9gw28fUEnPWkBcG12Xr6AenPf8+9ITgFvb8s9aoaz4hs9AhilvJvssMjBPNdG8qNuT87gbUGBjLlRkgZyQKuRXMc0EckexkkAkRkO4MD0YHoQR+dMBwHl/LyOenJ/z/n3pyLsfO7gnr700hSfm42gNjrjH+f5UAgnHXAIIz3780gIr3T7fU7CSG6hjmt5hiSN/ukdf5/keR0rCju7vwVtjvpLi+0fcRHeud09iPS45y6A8ed94DHmZw0p6AzK8W7K7cDG05HY8H/P86r3ur2+kzBZplhmc4WNctK3+6i5ZuvYGqAsmRZQjK2d3PHI55/r+tZ2s+HIdaMMwkltb61LCC6h/1kQOCVwch0JAyjZBwDwyqRBaeekXlafYx2ds3zA3TYEXOTsiXJwT/CzR4PbrTL5YLKFW1bUmlZ+EgDeSjYPKLEhLyehDF6QENn41+yXzabqSKuqJ2tlMkd0MHlByVbAyUcgqATllG8weM/B8HxR8NtpeqafGtlK6yq00jC4glQho5YmidTDMjYZJEkDoQCMHpZ1SxTUfD7WdvpNrHYhdwa6P2eOHbgrIqp84ZWAYZ8sgjIYHBrBgvbjSBjUb++8Rab5YIu7X9xb2/Y+YVxuj65dpZMDO5RguzAwv+FqTfAvVLfRPHGqx6lpdwSLPxASizQICuF1GNceWfmUfa1AhbB8wQHb5nqhLISvRgQCCP8/5/XzX4a/AlvDPj3VPEmpXmn6nNq1obKOCG08uG3hdkZ0HJVlbaOAoGBjnccq/hfVPgW/neGbO51vwjGf3vhyIhrrSlyPm08scNEozmzY4AGICm0QSGwHpibR8i5Ucd+WOcdfXP55oV97dNu4jgH/P+RWP4N8Zab470O11bSbyG/sbrcY5oiV6NhkZSAySK2VZGAdGUhgpBA0vNCqcBVwOCcfrTAsZ7fe9Pc//AF+n/wCujOD97PByR7j/AD+RqONyzD7q456547/r/L1p4k3AckFuvqelIBVG8jgnjH8qcyb06khs5OO45xj86YGIfcF5XOMdD1/z+P0pVYJuz8wU4znpQA4HEh4+btkn9aCoCcs27jkDtRuyrbsZ6Y9f/wBdG3f/AIev+etICOQ/d2k+4xnj+vrTlGDtx97uT1OKWRcowChR0PPXn/P+c0nnYO77u0+v3T707gG/P+0o+b+f88ZoRCFU9dx4Pr/n2pqg+Z935fQ9yTz/AD/z3A/yN3DHH16/zo2AkO4Qc5Vh6dM8/wCfz+lOK/NwTnPT60wN8u3+L1H+fUClDYAONuw+vr/n/PSkABlkC56Ejt+n+fQ+lOI+ZmP3eOnp/nFDEx52/wAQA+gHFBwF9OeT6YzSANu1ec88HH+en50YxMpI/D26f4dKcOrce+c9P8/1pPu4VR78H2A/rQAwpjHzdzkjg9qcVU4GOwQ84xREMDPA3cdeopD85A+9tA753ZH+H+e9ACkBWbA+Venqen9eKPur3PpjsR059v8ACkjkDO3HUAg568Yz/nmmsSsTf3V5z+tACCPI+7z27en+fxpztg8j5jwR39/x6flShlG39OOnXv8A5/oCMttz+GD25/x/n9KYDNmxW+XqMEnv7fkaWbiJto5xnGcA9f8AOaV2Codv4Z68f/XxStPt+uOnXP8AnikAyZlSMsPu9enI6/j1poGJN3zbuw65Jx/9anM7Mv3tzLwB6mo3bAxu478f56+tUgFG0he6+3PtQr8bcnrt+uP8/wD66WE71DMevTjvikXgLweTgjPXp19+9ADwNy5bg9GGOV/z605fv5dWyvBx83fPX/PGKZHLhFzk9wP60qHb8vJ6D/631+vt9aADGzbn+EA4/L/CneZnb8uPTuBz/wDWpok5bb6An/69OSQgt1OOuO/r+X+NAAg3NgrwcHn+X/1/anAqQv8Adzxjk55/woSTjLH0x7Uebn5VbDEZ6fd71IDTIE2s2SykdO/T/GuF/aKGPh5Blivl67pD5BxtxqVsQOh6nC9O9d1JtZQcnjg44OP8/wA64n4+b5vBFrGu7zJPEGiKOCdp/tW0P16D8P0o6AV/E8Ui/tD+E5trbR4e12AgLx81zo7g/wDkPjr1rN/akYSfCqGHLL5niTQEUg9SdZsmUD8QP/rAEi54wPlftC+CSpYBtG1tTgcY8zTDz7/L/Oqf7UBmT4a6fcIA8Nj4o0G8uFBG5oY9VtWYDI9hxxkAgc1S2YdT0cfvRz9T+YNc94t8CHVdUj1rSbptL16FNnnqC0V4gx+5uI8/OvofvocFTxg9Ajc7SeVbBPXPOB/L9RUwl8yT/d4xnFAHM+E/iBHrup3GjX9u2la9YqZJ7GRt3mx7iqzQvgCWJsHDAAgghgpGK1te0G08TaXLa3itJGcMjoxSSBwQyyRsOUdWAZWHQgGofFvg+z8a6Z9nnaaCaM77e7gIS4s3/hkjbHBB5x0PQgjisXTvF194TvI7LxMYY/Pm8my1WJdtveFidiyL/wAspT0wflZuFIJALAy/HOjx3NrHY+JZpI7cTqdK8Q2b/Z7nTpicrubH7pshV38xy5Cuozh47Txxd+Hb6Pwx4/t7NotUc2lhrSwAadrOThYJ1Ixb3RGB5bZjlP8AqmJJhj9CmjS7ikWRAyMvlvGwyGHdTnt19q43WPDU3h7T7q2W1bxJ4V1D9zdaRcRJcPaxsfm8sPxLCMjMLZIAOzOAhVgK/wBg1f4Q3Ak02O81rwmoy9iSZr/SPmG7ySeZoAp/1ZPmJtwhZSEXrtE16y8VaJb32m3MV3Z3Q/cyxfdbnkY7EHgggFWUg4IIrz3TPEF18KdFhvtPlv8AxZ4BdcJJGHutS0BQxBGADJc26ZClSDcQ+W2fN+7H514g+Kd1qXiK+8beCL2x03wndXbaYjnzJW8c6pIFgX7JGqugCeXsWfY2+RXYqUjcOAfRl9qMOnWUlzdTw2trEPnnlcJEnTBLE4UfUj+tZifEGHUYlfSrS+1hZPlWS2jVLfgcnzZCiMvGD5Zc+2BXCeAtb0XUtUvFMEkfiDQY4DqUvie+E19pjSAkHaSyqpKnDReXE5UhT8mB2I1Ua0PMjm1LUlORi1T7LbMDkZDkqW6fwu3sKoA1K/1KUrHfalYaK0mcW9ov2u6lBx03rjjpgRN9aanh63vLhbg6TJfyRnzludZnLhMD7yK+4x45OAkYPOcZzVqz06+SOSKE6fosEn31tYRLM3bO5gEBx6o3fn0st4PsZ3je7V9RkiberXpM4Vwfvqp+RD15RV70AUv7dXV5mWO+vNX6hk0mIxwnHH+v3YDdf+WwJ9OuJ9P0q+gE32e103RTOP3hQG5nfk/fb5V3deSZOSevU7Mc+/cMZUHkH/P+eadn931O1f5en86QGefCdrcxub3zNUZjk/az5idcj92AI/xCg1pR8cDdjHIx06jFLuyRz90gnjn0/wA/5wM2BkN74x/np/nNADSPL+XJVuCG68j+frg1IoDO3+1kYPT0/wDr+9NK7GJAb5RjpnPYf/qp2Rllzy3GPX0pAIp3c8jJ3e/4/wCf60ozjbkDcQMntnj9ePzp7OuAf4evH5/5/wA4apwv+0q4z7cZ/lQA3+Nfl+Vu4HT/ADzQx4YBtv64HX/P+crLwintxgn/AD+FKTsXH3u307j+v+egA6NvmHHpnB/z/hQqZbHucfSmeZngfd6HPOOv+NPjA3Ec5PvkigBoB2rt4OMHA+7/AJxRt2/eXnA6f59T/nindWPzZXp7HpQG2suWAwT1/SgDI8Ea9N4h0me4n8vzI9Rv7QbBgbIb2eBcj1Cxrk9zn6VrwttI56c465H+fTr+dZHg/TP7G0iaFlP7zUL64Ab/AKa3k0o/PeCPw9a2Ml4/ywPTHHWl0ARYym07fmI49Px/Wm/dXcNwC+v+f8/pTmbcG7HOc+vQH+X+ex5mV9s4OOnf/OPegAC7FK9G6fh/n/Gns2Ov3m4xn8aaXAIPJbg9M49P5fp+FC/dPPB6n1/zikBl3VlrFtdzSW15Z3kMnzLbXcRhZTycCVONvbmNj3ye8trrbN8t1aXNnI2VGR5sfBOfnUkAf7+01oFyq4b727n2I7/5/rUM1zHaWskkjrHDGPMkdyFVeeST0H1P/wBamBJ5rBt2T8uWHv8A1rDn8GWcXmSWMlxo9xIWkaSwIjV2JyxaNgYnY92ZC3PUZzVyTxClyn+iw3F9xksibIGGevmNhWHOPk3HnOKxdeTxHawy3P8AaOmraK5aSFyLcwr/AHRcGN1KjpgxKxP8fqwLd1rWpeHRu1BdPu7ZX2iaKYWsgJJwvlyMUY9BkSjPOF/hp9l4wj1mZYbOCbzihfyr1Hs3AxzhHHmMBkcqhU9N1YNv8R9N04wyf2Vq1vcTEwpd3aboSvqbssyeXznIZic8AkHGlc6kdfiVJ9QtZIJFEv2XTYRds2c7SzsrfIR0bZH67ugoA0L9GtYfO1TVFtoHbYVjcW0bk443Z3liePldc8cc4Een3TRbl0vSZFMvJllT7Gjn3yplJ6DJjIORz2qr/Yl1bxSSaXb2OnX3l7Y7vUA+oT4zyHPmKxH3sfvjjIOOMGsbm4tj5fiHSry8VmbM9ux1C2wMgZhVFdW5PSFgveQ9aALy3bXgBe+kvtxKmHS08qPI7GXcSrL/ANdEzyMdqrS+F77b9q0s2eg3hHzkL9oN4nULN0G4Z+/+8ZSeGILK+7pWsWuuWvn2NzDc2/3Q0T7gpHRfYjpg8jv0qdTkDoowcjtj/I/U0AYvh4QarGsd7byf2pa4eaK8cTNE/Z06IUJHDxqo4xhWDKNnfjY7NznIJ9f8g0k9tHIyMwBaHLxv/EmcDj65wfXvmo7zUIbJoopJFR7g7Itx+WRv7uTxuI5C9TtPXBwAZI0WbwvPJLpimSwO55NPGMI3JJgPRSSTmM/ISQQUOd2jo+qW+rW/m27LLGrlGypVo2U4ZWVuVYdwQCOKssPkRd3zN0zySc55/L+dZuo6M09z9ss5vst/tCiTbuW4UdFkUfeHJwRhlydpxuBYHM+LPhddW3iK68TeEbm203xJcKrX9tcMy6b4hCgKq3SqGKShQFS6jUyoFQMs0aeUb3w8+KNt44udQ064tbzRfEGlrG+oaRer/pFmsjMiSKy5WaFykmyaMlG2sMhldF3NN10XUk1vJG1pewpueBjuyufvK2MOmf4h0PBCsNtZPxI+G1l8RIbeR7i80vVtO3nTdXsCi32ls4UOY2dWRkbau+KRXik2gOj4GF6AdJHz6denXJqTfn/gK9CO+a4Hwv8AEnUdB8R2XhvxhDbWetXhKadqFsjJp2vFVJKxbixhuNqs5tpGZsB2jeZUdk7hJssFU9sjjpk+lMCZPlfd26HP6/z/AM4pfm3bcKMDH/1/0/CmCRm24YquD+H4/hmnZ8sSE7vnOTu7Hjj2FIB7kmMsFxuHHHPTvSk7gpX5e3I4z2pqyYUMeWU5A9ef8/56ELkN8vUDHHegCQsF+7w2ORjrmopo8yHZuwfQE/5/z70q/vx656H/AA/WpFl8zLfw5we2KWwFeQFGYcrtOB3yM4z/AJ/rSxMQm3nGMfT/AD/9apnG8DnoOSf8+1RMuB83C+n+fxp7gPGSm0DHJxxu/wA+9KzbSvZcE4Hp0pqzN5x6seeM9R/kmnbj90Hjpx2/z/nNFgHKrB9p+8vf0/z/ACpOCm7+8Mjjp7//AFvekZ8/dwOxI7D/ADmjzFXjPfOe479P89KQBLwrZ6AfhTsMFX3JH0pGfb838K9c9v8APFDnnaOcYwfT/OM+1IBeSdvAPTHTFNPPzdN2Mfn/APW/zilDKWY9+pz2PP8An2pEYSO2445549CT/TNADthJb+Htj9Tj68/5zTTwv8PBznpQ0nns/Py8Ek9+/wDj+A60GbKdT/U/h2oAFTYfl27VOQe34f405Ts2/eO0Hr39vb6UCYRpu3BVxnr27n9P89KjkusMdow3Geenf9BxRuA/DF2x8rEjp6//AFvbrUZ+7/s4Bzjt9P8AP4UsZ80BTj0H+f8APakXIT7y+h56c5qgEJYEY3MemB+A/wA//Wpr4KjLcMOOP8/596HHK8ZbaSPy6fp3/WiOXe33jyfXp6D9P1oAB8sXy9hj8P6f/XpT/Fg89evT6UxWwgz6Ee5x0/r/AJ5pwJMat1wPTHT/AD+NMBzNgenPJ9Ocf5/zkB5xjoSMDtgf/r/Gjdt4yPTrinKGD8HcM8c9e9AAOD325O337f5H+QB9v8XGfTvQTuJ5AXHzH0oRiu7cPunBGfz/ACzSAcV2D5ejdPp25/z0+uXMPLZtp7ZJx/n1+lIT5g64445/Pj/PWkYl2G7HXkZ6VIAWLDK/dZs46YHGM/56iuO+NqAeHNLuG2tDZ6/pU8qn+JRfwAYOD0Yq3vsI4ySOw3LvZdy5643ckZ/yfeuM+PMgh+Ft4zSLG0VzYuGJABYXkBU88AlsDPb680WAoeNJQvxt8B7myWttWiPv8tuTz/wH9azP2upGH7OfiSRW2vB9knDBd20x3tu/81/A1tfEBEPxY8DszKmJNQRQc5ObXP8AJf0H489+2jJ5f7K/jiZjKqw6aZjsI8zaksbHac4B445GDjmqtowPVZiUlcH5SGJ6/d5z/n/9dOWRgBnbnGCDx3PP+f8A61NuJAt++7r5pwM8daI2AP0PPPpwP5fp+NMCRG2qqhuTwCf8/wCfzqvfadb6xYyW9zFHNbzLteN0DKQcHp+Gf1qbfz6YyBzj2/8ArH6UM2cjJ4A6Hnt+X+c0AcC76l8GTbxJHqGveFWIhwga4v8ASd0mE+UDdNbqHC8ZkjVQfmUMR2Wmatba5YW95aXEV1a3CCSOWJtySA+mOvII9QQRx0q6Fx5eD2xxx37fpXE634B1DwjfXOseDltYLu6k86+0maQw2OquWXc4YA+ROQDiRQVZiC6tyaQEHxU+EP8AwmOkaoulX0+k3GsGNdSihk8mHVoQV82N2UFo3kjBjMyfOFOORwPnjSf2fvFPijxrr13oH2X4e2vh6GXTrHwjpl2kN7bwSBA08MzI8VrLcBT/AKTEp3A7dwPmO/1D8P8A4jaf8QdPuXtFuLW80+TyL/T7xRFd6dMQP3cqAkA4IIZSysOVYirPibwfZ+J3t55vMg1Cz3m0vIG2XFoWHzBW7q2BuRso2BuU4FOwHl/w2+EHgbV/BtvH4TtLzwvrGgzbjcFXXW9PumO6T7YZCzzlzy3nM8coyVYjaw6fw58R77S9Wt9A8XQQ6frV4QLG8gLHT9ZPGRCTzHNwcwSYYjlDIobbl+INDfV9d09dauJPDfjKPdb6R4j07i3vhlsROhO1wwAY20+5STmM7sMtyHxLbeLY4fB3xB0rSYNY1BXjhtiTJp+ueX85ktGcbtwX5zE372IqxBcL5pAO/jZS5IO0dsDn/PWpQ+SpPRsAduf84NefS6jq3wd3fbJNQ1zwmFLC9bNxf6RyWPnfxTQBSMSDMibfmDKdy9zpupQalbR3FtcQ3FtMglilicPG6HkFWHDAjuKALSpsZ1LfNt+XjoM8fyFOxt+U4wD6f59z+FNQ7u+3nggjj/P9BQJMn0HHANMCR22Y/ibcVx68f/q/PtTuQp5IOMjHY/5FNSRtgOQG+v06Ur5RwvHzKOT/AC/nSAXkyM3RVyenb0/p/wDq4aMQ7v4j156CnMcOrFl5OOD0/L/PHrQmVX69f/rf5796AHD92v3ue+f8/wCcUZwMD5dp/wAjp7imqMouTjC7TjnNP37i394EDbnp/Tr/AD6+qARlUKvTGT0HUf57UuGdzn7zent/+r8aR3xjbgcev+fX070obcOO/LfpxSAWNNj/AHu+Bj8Rgfl3/wD1rEDGR825u3vSDOGwfvdz2/zj/PWmrxEcHr074HfP6/SkA5vlXP5//W/z6UjHIX5vm5HT1/8A1UueC559cn/PrQPlXbn5SB3/AA7ev+c0AY/hO6luv7TaaR5Gj1KaMFj8qKuNigdANuBxjJyTkkmtf7qn+HcPw6jn9e39BWN4TszbXWtIFKq2pNIgPTDRQk/+PbvzraLGRc7vm/hHo2c/0z/jVACjDFVbBB9OvejzNz7evPT1qlc+IbaK58hWkuLhW2tBApldGxn59vCexcge9MaXUr5l8tbewjyOZB9olYc9lYIp6HO5x7dDQBpEsU+XLMBgdTj/AD9fWs0eJbWVmitWe/kycra4dVIyCC2RGp4xhmB/Ks1rzTb4SR7rvxFMB8yDE8Rb+633bZG9m2np1qbU9WvLZIlmmtdJiYHbEM3V3MBnCxoMAMOOgmHOMcZqQLU7308bNM9vp8SAltpE0gUZJYswCL0/uuOeves2O80+4VZrWGfxDJkGO4QrMu4Y+dZHKxKQcZEZB9Bxwr6Yt4Y/9HbUGXY32rVnz82c71ixhW9gsXb8NGXT5ruRvtV5cScBgkbGBVPTgqd/PcFyDntVAUbvVbxrhI7u9tNLkYBxBaD7Xd45+Yblxjg5/dMME/NTLXSjNcJcQ2K+dxIl3qUrTSxFgeUTJKgBjlA0fPGAOmrYWEGn2rQ2sMNurEkRxKI1DeuFH5n/APXVg/6vK7V2/d5+o/z7n3zQBQfSGvI5BdXM11uA3R8Rx5/3V5YHphy/AHqSWQeD9PsZ5JLKE6fIzhmNqTErtjG5ox8jHAA+ZT0HtWmg+TqT+PbtTlG1vowz/gfrxTATHK7vu9D26/8A6sfh2rDX4iabb3bQ6g02jXClVC6lH9nSXP3Qkh/dOTjOEckdwDxW4h+UfNn3/LP6CnMglBVgu0jBVuQwOe34Hr/+pAU7rQrS+uvtE0H+kcYuEYxTbf7u9CG2+2cHuPWayt5LZdrTyTejOq7/AG6AD8x9STzWbaeB7HTlX+y2m0RVAxHYSeXAB6eScw88DOzOOhGARpWaXUVvtmkgmXs6jy2/Fcnn3yOc8UAV9a12x8OWsc2oXUNnDI2wSzNtjVsEjc5+VehxuIB4AJJAqfUbO21iwkguI4bq0uUHmRyKHilQ+x4I+vsfeoIvFFl/aItXuI4LqRiiwzq0LTkZzsVwN4OOq5GMHpVOTwRaWkrf2fJcaNJuyfsDiONm/iYwsGiLHuxjLdORgUkBRuby68AqzXT3OpaMpx9oIMt1pyY/5bHJaaIHjzAC65y4YB5F3rK5jvbeOaKRJoJlV45Y2DJIpHDK3IIIIORwQevrXSbULEf6R5N4B0e2HlOenVGJGfcMPYDvFpmgx6TdNJYsttbyMXltiCsSk7sug/5ZscgkAbWOTgMS5YEuraVDqtqqzbkkjO+KaI7ZoGxgMjY+U849CCQcqSDUh1abSJ47fUtmJnEcN2i4jlYn5UYf8s5DwMfdY/dIJ2DTWVGXKsDsba2Gztbg4Pvg9OvI9aZdLHNbtDNHFJFKpR0kXcsgPUMDwQf5fjVAVPFHhrTvGWgXmm6vZ2uo6feR+VcWtzGHilGc/MCOxAIPUEAjkCuFuNe1j4DY/tie88ReBo8n+2JN0+paEvAAuwFLXNsve5GZYwFM4kUSXI7JluPDsrGMXF5pvJaIZkuLTH9zvInT5eXGDt3DCrpWV7Hf2sc0EySxspZJYnyGyOCCPfv7GgCS0uUubeOaGWOWCZBJHIhDI6MPlcEZBB65BwRj1qSJt7bf4s88fTt+f5+1ed6r4D1b4bXr6p4Jjjm01nMt/wCFXlW3trjJy8tk7YW1uCfmKHFvMxO4RO7XA6TwB8S9L+JWhtf6XNM32eU215a3ETW93p1woBaCeFgGilUEHawGVZWGUYMUB0ZmAdcNkjDZA4pD8q8Y7Y59un6Gq8ku07WwvTPPft+X+e4p1tcK6/eC9D16jn/69AFrOHOPu56gHn+v4U5H3ljn5egx+FQrKTu9eA/PbjNSKGK7txBPq35f0pMCSJjg/wB04/H/ADmklAYdMsoz+FKsqpwzL2H1zj/GiTr/AHsg5BPXt/n/APXUgRoNrD+LHBB46f5/nTl/drjrk4zn1waE+Zwf4W464x60A43D72OMdm7Y/l+npTAao285x6n0JyKc7fus8cZ/If5/WlQfPuUg9Mc9T/nH1xSudqc4+9x81AB9+TGcKetNLYkbnHU57DH+f84ob5X257dM5pd2yRmLZC/MTnpSARj97gfd47Y6f5//AFUB2X1+Y554/wA96RgT8v3V25yD0/zyfwpWbbKTlRt/yf5UABIYHHBz/Xj/AD9aaSd3J5OM98H2px+VvxIHPXHb/Peml1MrL6jJA5/z6UwItrPIu77wOfr0yP5f54LI/u/h68kemP6f5CgeWSWHQ4HseD/n+lOMeEG7KquR+ef/ANf+RigJQjFP4T2ySeP8/wBacql8Z284B/U9fxFN5HzcnnHT/P8AkfU0MuG7t1Ix3x/kf5FLcBZH45/DntUaRmNSM/8A1vpUrx7ZGGPUH+Wf8+gpm3ZwfTP+fzxRcBiqXHHy7jjjGP8AOKdkqnPfnPf6frTmGQBz8vBz/n/OaRvlB7Eg847n39KADYVGG+8pwcfgcfy/KgHa+M+mSO/Tn/P+FEifvOh9f6n+n/6qVBkYX+7jjt/nHTvQAhdyv44/z/n/AApWLA/d+7zn0HWlQH+LsOBn+tG3hTzjAyOpx/n/AD1oAUqwPzH5Vz26U4liytx1P9f8/jTWfbs2/N8vX0+lOVAsn97tn09f8/SpAamUZsux28deScf48/4Vwn7RcrW/wf1ZuPlktny3RMXcHJ9h1z6DPSu97tj+E9P8/hXA/tG2sM/wT8QCSBLiOO1D+W67lJV1Iz+QqkB5p8Wf2qPDl/8AFTwnY+E49W8d6lper3sU1r4dtDcwrL/Z94oga7bbaJJuU5V5gVCliAATWT+1l+0d4d8Sfs1fELQ1kvNL8Qf8I1eXX9l6zbHS7xREjOxSK4ANyoKEb7YTJwPmwykw/t0RSfBTwh4S1LwZPPoNzBr72tsLZt1tZh9OvELJA+Y0wm5flCjAz1CkYnx3/Zltfh38CviPe6tYT+ONWv8ARLq1/tjVNRN5KS+4IZIZFUIFZlCBHkK9PlXJqle9h9Ln1pcsPtVxgfdkbJ9eSKFyHCjrjH9Ov+eteP8AgXwnb3dnCvgLxrqWh3kdurtoepM+rWMJIwN1pcst1DGB91bea3QgZAIwT0Vv8RvE3hRyvijwlNc26n/kJeGZG1KLaP4pLVlW6jY/3IUuR6ualPQTXQ9A+6jZO3fxn0/zx+H40KMyMrcnOCTzjA4/n/8Ar74fgT4iaD8Sba4k0TVrLU/sMmy6ihkHn2TnnZNEcPC/H3JFVh3ArcA8wA9BwMcY/wA8/p+NUAvJGPQevXoRTxu2/dwAM9evb/P1o27j93nHf8acmS/QngY9cf5/r+KA5Txz8LovFeoWep2N9NoniDTzm21G1A+dSU3wzr92aFwigq2cYBUqQDVbwz8R5P7YTQfEUMekeIJIw0UZc/Z9TXHzPaucb8HrGfnXKkggiu0C7WO7dx7f5/z+mZ4y8I6f458OzafqUP2i3mwRh9jxuMESIwwVcEBgw6HFIB2u6LZ+I9Gm0/ULeG8s7yMwzwyD5JEPUEdfxHIOCDmuD+IfhbGlTaX4mtJvFHgu+k8zeA323RWUqyMWQiR0R8ss0eJYcL95fnS23jC++D9xaWHiaS+1TRpGSCHxI6J+5djtVL0IBsJ+VRMF8tiw3bcmu4J3rC6nckiFhtwcjCnj1HP5UXA8y03xxqHwmsLf+3tT/wCEh8IumbTxV5iNNbfvCFF8EATbgqoukwp2nzVQ/O+je+B77wVqMmreDxC9ndSm4v8AQ2cJbXZbJea2bpDMSdxx+7kLMWAY760J/BN34Su76+8P7po76Q3Fzo8rKIJnIxI0DEfu5H4JBJjZskhSxauT8OWNx4BVrzwXbyaj4atz5N/4UZfLutHcZJNoHOEOD/x7NiN1UNEy9JKWgHdeBPiDYfETSJLrT2lElu/2e6tbhDFc2Eo6xTRnlXB/AjkFhgneT5mO3/DHv/n0rg5dH0r4sabb+KfCuqx2urRho4dUt037yvBt7qLguoJw0cmGQ9NjcjU8O+PWufEX9haxa/2TruHa3jLA2+pooyZLd8/MABkocOvzEgqN1IDq03K6ntk5/wA/ifpxT9xXd6bc8cZ/zj6c/nGNr7l2/e5H8/0pyxgplfYnjPoP8TQA5W2syk9wPqP880RqQfxOQDx7Z/z/AI03ZuXd3xkc9O3X8ql/iGOSoBA9gTQAqjPY8duMnkY/lijYVyuA3PI/z/n8qCmH/i+Y9u2D60rIF2+mOf8AOPekAiEr04ySQe3r/n6051ZeO69QP8/hQijJ6jbjPHTH/wCv/wDXRGMnDfNjOPbv/h+dSAEk+hyRz0wPX+n+c0khZpAfu7Rz7/5/p2xVbUtUtdFRTdXEVv5mVXzH2mQ9dqjqx4zgZOPxqrLq1xc/8eWnTbWziS7Y2yDn+6VMme+CgB9RzTA0yWY+6t0/z/nr61Wv9Yt9OKpNMscpAKwj5pG/3UALN+AP5Vl6idknl6pqkokZM/ZbFWhkcHoVVC07f8BYA4PyjtLalrCyY2On22m2zNukmusRD0DlF5YkdQ7I2T9cAE63+oXpH2ezFtHIN3nXR+c9ACIl5PfhmQjHTmqd09nJPJa3t9JqVyrBZLOEZEeR0aKLkKeP9aSo4571zPhBW13xL4uima/1SNdXjVPLk+z2bK2nWJzgMN6E5G3Mg4zg5JPXW2lTR2scKyQ6baoMrBYRKAmOSu5hgg/7MaHnr3D1Ajkv7izsVIWw0Wyi+VGumVsYPQRowQZ7HzCf9ntVVNNGpygta3mqLkfvNRbyYOOMeTtHzAdD5POfvVrWWi29hK0yw/vim0zH55ipHQyNliOBwT27VacYB/iO3PIwDx/9cfnQBRGl3V4i/ar2Ty8CPybNfs67ew3cyDGcZVlzjoKn0/TYdLibyYY0aQ5kcctJj+83Vuc9Sev1qyIto+XPbJIptyPKHy/xYIHX2z/P8qNAIpOvP8XP19P/ANdKg4yG27uhHY/59f1oRN5XdnJ6ZP3uh/z9evWpFTI3Hd028+nH+f5UwI1jwenXoM9O39f8inwj92oXvnt07/5/yaf5QZtyruX0P09Px/SmpCzLj5vmwR68f5/U+1K4CszYI3YViGyfTPP/AOv+tK/O3/ZHA7qScUE/KG29cdD0pypu9sHt+eP0/CgBrDy5OCrccD0pxBVvVR+uOtJGp37eueGwO/b/AD70oj+XOD0yOO+KQBEWZvvbWzkH1+lABKAdFOABn7w/zz70oG4bh/EcnpwOf8//AKqUkoO2cDA+vPNLcCvqVnDq1pJDcQw3FtMNskUqB0f6qR19M/r2zoPCi6Szf2feXVoARiIyGa3XnoI3J2rz0jKDp06VsPFmVcHjoMjpTBgrt2tyQAP8/wCf5VQFW1N1hVuVhbbgb4sqDx3U525443NUybsYzyp7/pSmMD5lXdt98f5/+tSSRrcRNG33XUhh7dCP8+n5MDltY8AXX9opeaPrF5pt2uBtuF+2W0yDOI5FYiRl5BAEgCZO0KWbdch8QXVjEv8AbFh9gwCHuYJftNqvqWbarovfc6BFHVs8VPJoV3p8m6x1G42gf6i8BuY+nZiRLk57yMB2Xk5ct3NJcLBdW/kzZU77ecSBDgbSOFkBP+5j1OCaQF0Ms0ayIwaOUBkZTkMp5yD3BrNutHmsbw3GntHHJIcywOSIrrPc4zsf/bAJ4+YNwRWvdLmu9O3aLZw6ffPKoMk4e3JA53skWGc9MJIVzk5IHXnda1KbQdS8i61oeJ9VjRTJpNuWtJlG0/P5MAkO1iDjzsJn+NcUwOqk8W29vY3TNHfGazK+dZpbNJdIWIAxGucg5HzqSnBO7Csw4/W/AGreOtcXxFpNm3gnxLDALeK+meO6kv4gSyW19axN5c9uCWK/vhLFvfymiLuWdqniO91+4to201PBMlvnyL7VUDzRbtpZE8lvs7BuMqbg5K8xsFFaFv8ADL+2I3j8VS3HiGRTjy7pwLGZDzzaIFiIwekqyMMEB2HJPILHyz8SviH8TvHvjG4sZPFEFvrWkyJNdaD4dnuovIjtxI0tzFPDFMkkAaW2bdMQ7KFjltw7CFvoL9mb4heIPEdvq2h+KBp02seG2iQ39lcGSHVYpkLxXG0jCllALBGdM9Co+QdZ46+E+j/EHw7a6XeW8lrHp7i40640+Q2t1pM4Uqs1rImDDIAzLlflZWZGDIzK3lfwd1mf4G/EvWvDPiuaCW31C6s47HxHDCsFpfXUimMW9yoYi1upGA2g4hmeTbEyu626LbUrc9+jJMILfez8w/nzU0Eu1D3xz1/zn/631zXYFFG5WjxxgrgkDHb/ACOPwqXb823G7sOOg/z/AJHSqJJ0ztH3evAz1qRGyM/3umep/wA/0qIsSR35/I+/6VJ0j/i9j9MdB7dP88wA5mKnd75bnHSkRSSzY5AGe3H+cn8qIxkEddxwf5/59aq6Rpsmj6ZHDLfXmpSRMzefc+WJXy5fB8tFXCghRhRwFzk5JQFl36qWzuHbt0pJFaNt39zkj09DTpH/AIfm9OelDPifcB/ESeM46f5/CmAxizP/AAnnA9s0b/3hbPsfYcULGoh5+fHTdxnHGaTLMW/2zjB/z7fnR6ADDbtX+JTjr/kUqM2xfvDnA+uaa/yox5+XoPrj/wCt/nilePeMKo2+mfx/n/k0AOC4O0fxHIx3xn/69I6ZVvU9TnpyKIhlV/i2g8dee/8An608kNnGSuePr/k/55oAgdf3vy4+90HboKUcrtxjPJIPT/P+fZqDeqnnrz/9b/P9adk7cevQZ6cGmA5omKr7EkDPf/P+e9O3gsN3Tn8elNkO6UDP3fmHuTTliLAKwxjjk+xoAYG2nP8Aeyc570rowPB+Yn8j0/z/APWoyZEk6fMwwf8AP4/z9qa27avPy5xjHrn+f+FAAR5v8Xfj3/z7+tPckbcY3f3fXt/9emMrBx8wXnnI69vb/OPSpRgyfKMLnr+XX68/jQAwruYd+On4/wCR9aNuB2bu2e3/ANbp+VIztbj3UevX8f8APHFOik5GW+XAOMnnp0P5UgEUcNuJ64J96C+4AMAFUHGDyp6/p603zpI4F5+YHjHH+f8A9XelZtv3R0BGB/n8fp7UwHscEcK2c5Hc9MULwq7cDAznP+femruJ2r1yDk9v8/8A1ulOA2r93cGB4Pf/AD/n3kBsi56bcMMnnoAeP51xH7QUG/4M+KGxlV06aY89Qg3n9AfzrtXbMWW+XjBz+Z/z7fnxP7RKvJ8CvGW3/WLot4y7mAGRA55zwPr9eO1UtgPMf2tfhHfeNNO8KaFp+s3U0mreJblbVdScSJayjSdTlx5gQybCI9vzbyN+cnG09H+0fd6hqXwS8TWmoaOytdW2Fkt5hcWzEOpyTgSKCR3TqOprf+LwNr40+HkvzKkXillb/gelalGM+nMn5kdM1V/aovW039mXx9d4/wCPPQLy66E/6uJpAcYJ7ZzzjihaMHsafgAaP8SvhXoomGn6tHDp9uG37Zfs8hhUnB6o3PUYIxxjirp8EanoKK2i6/NHbxtk2uqRtqMRGAMK5dZ1wQcEyOPmPynjCaH4A0mfw/phFmizQ2cMMd1CzQ3CqsaqB5qEP90Dvjj0q6mk65pY3Wt9DqVrtJMF+nlyqPVZox+jRsTkDcKIqysNu7ucz428NaT4rurefxh4Tma7sQ6Wut6d5k9xYqQSTDc2+28t+nJVUA6FiMEwaNpHia2tPtfgvxtpvizTY9qHT9fIuNu3/lkl/bgTRtg8tcx3Tk4PrnrovHK6dB/xOLS60Xg7ppv3lqCMc+cuVUc9ZNh68dan1XwhpPi26F9JDG1w6BRfWkzW9ztB7TxFX25A43YJHQ0WEczF8cf+EX8tPGWg6v4VaPAa9EZ1DSFwuS/2uEEQxjJAe7jtzkfd5Ge28OeIbPxZolrqel3tnqWm3oD293aTrcW86noyOhKsPTBPSsdNJ8ReH5Waz1G31iFiSkGop9nlj9ALiFSMezQsxznd68frfgvwjba7c6re6XefD/Xr13ln1nTpPsC3T4HzTTw5t5+i4W7DZx9zggAHqOSU6jrk+/8AnNIoLhs7dx5xuyD7E/WuHs18aeHrCOe01DSfHemsu6OaXZp2oOmOGEsSta3DHsBHbrg5zViD46aHBe21jrTXnhHUrgDZaa9ELPzXbjZHPlraZ88bYZXPQ9CMq/cDrpoxLFtKq24EY7H1A/DP+TXDQ+DtQ+FPlroTSan4f3qg0aQhpNPXDbmtpCclRlT5LEgBTsK8Cu5a2aGdmxLukUA/O2PwBOPy9PwpJsrgn5tpzn/P481SAyPB3izT/Hfhuz1XSrqG7sbyMOkinoCBwR1VhkAqcEVV8U+D/wC2pvt2m3H9ma1AhS3uwNyyjk+XMn/LSPcORww6qVI4r6v4Bk0/XG1rQGhs9SkjdbiEgraalk5BlA6OOSsgG4FjnIJq14T8bxeI5Li2khlsNWsiRcWU/wDrYv8AaUjiROhDrkc4ODxR6gcbqenzXniua60mW38NeOli3vbSkyaf4hhUsQHHR1zu/eLiaElwcpkPpWWp6J8Y4W0bXtL+weINHdbqbTLmX/SrBslUuYJUILRk7gs8eAc4O1iVrq/Enhy18U6atrdRsY0+eKSN/Lkt2wQskbD7jjJwR0OOtcR420JMWlt4oupIZrYsuj+LbYLBPYSv8oEpA2xux29R5MxAVlU7VIBas/FN98Lmjs/FV19r0ncILXXyu3YMKFW85/duTx53EbEDdtJNd5HKHC7Sp+h7Hpj2rhdG8cX2k3//AAjvjW1tbe4vmNtZ6jGM6drSkAbCGH7mc5IMLAq2PkZwxVKVzZah8Cis2n2t5qngluJdOt0aa68P/wC3boAWktxyWhGWTP7sbQUL2A9Lh+Tgnbj3+7/nPenxHeB0JPB5/T+v51maN4ks/EGkR6lY3NvdWb7gs0UoaPKkgjPQEYwQeQeCBzQfFEclusljb3WpDG3/AEZV2uOeRI5WMgEc4YkfjipA1Ov93144zx/+r8Kbd39vpNvJPcTW9vAPvySuI17fxHjkkf565N3qd0oaS8uLXRrMsACGVpHbJOCzDYuePlAYnk5HZtjbp9vjuLXTZp7lRhLq8JR1B+8oaQNKoI7BQvTtk0AWI/EbakF/s+zurxJBxLIPs8Ixxkl8MR3BRHH04JjvJ5Y5F/tLUrez87JS2tTh5Dk5UO2Xk9vLVDxUMd89+/lm/kuWU7ZINNTauRjKvISSrDP9+PPpjpPpmly27u0MFrpyXHMr7fOuZvd24G4HoWLjigBlpbizM09hppj3gmS6u3MbuBk8swaVtuejhRg8HHFNWX+00Ia7uNSZlBxp6/Z4DjHKybs55zt808HpV5NDhcL9oWS8ZTndcHzMNjhgv3VPJ5VV61eUEsVY5wG465z2/X+dAGRZaNNbw+TaraaPCSC62sYeQ9DncwC5bofkbuQcmrceh26zLMY/tEyjIkmcyMOp+UnIX1+XAGO1WkLEsuOo4x+f0NOKkI3GCcY9qAM3SNFOnatrFxt+XVLlJye7bbeKL/2T1z/Orypt+bgtw3X1rl/DdoJ/iz4uvJGmaSOOyt4t0rFI4zHvKhc45fJyBzk+9dVvy/qF68Z6ChAPK7/TBHUfxc0ixche4OMfnx/P8acyN83qBke5yCP5UkhZkx90feJI9uP/ANdL0ATHmqpyBk888DPr/n/Gkvo2kCFQPTnpg4x/kU/O5WPK/nzwf/1fhQS2T8u7t356/wAsUXAixvcfXcPxx/n/AA5FL9/LbuSOoznPP+fy7USLjgdMgA+h7fyGPr+NCv5Y5+de2O/TH9DxTAdnksF+XsM9qDxHjPDdz/F3/r/+ugnALfd5B/L/AD+v1pWHlnnHqOOnt/T8fagBADlfxH4YJ/z/APWpypuf17ZA/wA/h/jTXJLncOOhPp9fyoQ/M38IORn14z/Q0AOT7zD8D/tdT/n8KFbenHXGRyR9f6e3SiL52Ydvp1o+ZXwPvNg5z7/5/wDrVLAAwY/LtxjsTwP8gf5xRk7V7BQe9NUnyMcfNxg9qr6xrdroFr9qvbm3tIFOC80gRd3YAnqcg8DJ9BVWAtA8/wB7AABJ47f5/wA8NDBgenuAevBrAXxlc6qAuk6NqFzEyg/aLtTYQDj/AKaL5pHzdViI9+MU7VvEUPhSBbrxBq2nafDIxWNGcQK55O1Wc7pG7jYFJ/u0gN37+5Tj6+vb/GqGvtqAsV/s2OykumYKPtkjxxqD1b5QxbH93gH+8uM1jXHjLVtWhB0LQbidOAs2qyNpcDeuFaN58j0MIByMN1IlHhbVNWZW1TXbgR7ubfTF+wwnnPLgtOTkclZUDDqvamBma9JFps8cPiPxKzXVxhobCwV7M3HH8EMbPcScZ4DsMdsjNS6dqWovAsOi+H4tLs2BIudSYQhs4O5beMmVj6iQwtn1ra0Twzp/hqOSPT7G2sROS85hjCPOefmcgbnbn7zEk80mteJdP8LLH/aN5BaNdf6qJ2zJMfREGXfGOig8c8UAY978NV8Urv17ULzVGXIRLZm0+FAw2sFELCQqR1WSWQHAPYY0NI8MSeErCO10qSzjsIOEtHtUhVcYACtCFCgAdTG56cioY/FWp6w5bTdEuI1yP9I1SX7GhXOCVTa8pI9HSPPqBg1E3g7UNYgI1vW7y4jOM22nbtOt/XG5GM7D6y4IB+Ug4oAs6h43sNDljt9QuEs7yQHy7ZWM0s3BJ2Rx5kfgH+EHHasHVtI1TxAY5fDtre+HJlGEubi4+zQ4zk5sysiuTzzIkb4OQw4NW9f8deEPgrAsGoaho+gzXRG22BH2u9OMfLEoMspwOyseO+AKxP8AhbfijxkJF8L+CNUt4SpCah4nb+y4GbJxi2w12V4yd0cZ6YycgMDWPw6vddVofEOuXWpwNg+RZ7tNgbI5DrExkb1+aUr1+UcVx+o+Ifh/8KNW8Q+GdU/sKysr+CC3XQVtVne+ieFjJEtmis0ysGYsAhB3ktnJNbifCXxB4tkZvFnjTVLyFmJGnaEraNZqD/AXjZrmQcHkzDI4wO8nwp8BaP8ADvxp4os9D0uz0u3aG0kkaJMSSFhLuZ3OWYsRklickc5NGt7geXeDPBU1x4h0P/hCfhl4r8M+H7K/gea51vxhfaNaSQK+WMelRXEhmIGMLcxRKTgEFcivo+J/Mbc21SAMEfn/APWp9lD9pxuXjr/UD6f/AFqe1k0HT6EHt0pLQA8zAUj1zgHJOOf6d6kU4bcD6YJ7+1VY2Y7h15+uP8f61N5hI+6cZOR6j/IpgTlsoOR7+3b/ADmkVgUwW2q25ePQ5qOJiY1xnBPPOcjjp/ntTug57jgjPHYe/H9frSAcGXzNzAZx6+v+frQh565xyOTwR/j1pT5jYB+ZgOAff/P/ANalQkqx7EZ/X/P4UgFb5SduMZyD9O34mhIlRAOGXJz7f/r5oAxGx/i4HPfvz+v8qWOQhRj+I0gGtE2ePU8f5/8A1U0HCbN3y+uev+eR+P1pZflmx1wRx6f54/Oolnxk5+VT97t3PHH+femgHp8rFvbJ756f408E/Mc845Hr15P+FNi+Q7R8qk4Yen+en4GnKCEH159uP/r/AOcUAMU429G3EcHHt/j0pyfdz/Cex7euf69v1pokG5W/hb0HX/PrTtysyc57NxTATGJG+Zvm5P8AIn8/89qcx3HurA5Az93jjn3/AM+tCPuk3Z+9jBx2/wA8fhRvzGQPlVTkdwR0z+lSA1ztgbnttH+f0/P6U47UPPAAy3sO1CkFDtxuxjrQG3hdxHzHnFAAo2MwP3sduhOP/wBVKw8x/vH2/wAf5fl6UgbDLgY2jgY6d/8AP0pfNCbuMqp6A/5/z+oBHMvybV47fQf54/KkhjURsVYBW9OwA4P8qC29y3Xnp/T8/wD9VCN5aq+Rt428deOv5VXQAJyo4wrcnt/nufwp5PzbQu7jgE/rTZSq7cgA55zz07flj+VPZ/m4GVXpn15/xoAGGwZ67RubP40Rrwue/T/P1/8A1UcM4HVU7+2MH8qA3zbm2jcQQuOw4A/z+tSASgMv3s7uBj2rhf2kCqfs/eOJJG8uNdAvmclgF2iByckkAD1zgda7hdvljkEg4ODkdBj/AD9K4/8AaDj834D+Nl+YufD+ocKu5j/o0hxjBzz7VQbamP8AG29+yal4CkYllk8WWibh82N1tdAHJ9yoz1596k/aNtFvP2ePH0LZ2zeGtSUg472kvX/6+aq/G648zQPAk8e3b/wlekFSBwd0m3GB/v4/H0re+LFp/anwj8VWoba1xo17CDg87rdx256nt6+tVHVq/kEttSb4OXX9ofCfwvcL/wAttFspP7ucwRn8PX2rpozgD5vmHOcDPvx/nrivPv2YtSOo/s2fDm7MaxtceFNJm8sc7S1lCxAPtnH+ee9guOijbuBx/Q/5+nPQ1Mb8qKnpJk2MrsHfLYHvkY/P+dY9z8P9Ne8kurNZ9JvJFKG409/IZs85KcxsRxy6NjFbCuFbd8o579h/+v8AzzTg3z5X5T2HXH0/z1oJOfWLxJoKj57PxAigZLAWd3J0BIxmFj7YjBz2qa1+I+m280cd5JPot1M4jSHUAIDIc4AR8mOQn0RmPPrxW4doj6Lj68AdMZ/x/wDrU2+t4ry0kt7iOOa3uBseOVA6yg9mByCD+OfakBhv8NtLiuXubGObRbuQgtLpz/Z9xAwGaPmKTg4/eI3G30GK9/p2sJpdxa3sOl+JtPuAUkgkjFvJIh42srboZifQ+UvPSrH/AAgcGmPHLpd3d6MyNuaKB99s3TOYXzGOB1QKw9fWOTVtd0NG+1abBqkKhv3+nSCOVVHQtDKwH97O2RjkDjkgAHD6b4I0DQtUjt/Dupa58NdRuD+703cq6dcMSW2x2ku+0JJBLfZNjnklxkGugHiHxp4UVl1XQtP8RW6k4udCl+zXPX+KzuX24AOcpcuzdkHAO1p3iXQ/H1vNY7oboXEIaewvICkhQgH54ZQCRgg5Kke/GaqyfD7+zSg0nWtZ0ePD4t1kS6tl5HRJ1cqOcBY2QAcAY4pgN8HfFbw/411JtPs74w6qoy+m3tvJZahGAOptp1SXbwcPtKkcgmrXizwfa+LYLcyPPaXtmWa0vIG2T2TlSmVPf7xBVsqepBODWD4u8PXniLTPsHijwtoXjfSo5fMjSOONpQ3G1/s10fLUj5vmWbdxlV5wMnT9Ni0qdbPwz401DRb5o8QaJ4jV72A4bO5YrkpeFRyo8qcRgHAUgDDA3/Dvjm70LU7XR/FK21vqFw/lWV/CPLs9XIQMQiliYpMbsxMedhKkggV1V1aw3UMlvNGkkUg2PGwDK6kdCDwRx+tcVrWvaj/Ztxpvi7wjJeafOjRT3GiltTt2QhlJaDal0jEdFjjlwTgOTgmj4R+Idpo6tDbas3ibQ7WPdJPG5m1HRVH8F3H/AK3AAYbmQOpQq4J5CAk8S+Fm8I6c2m/YbvxV4Nuo5EvNOmiS5ksI8lv3WWEkiDO0RhWZQoKspXD8z4q+Ntr+zP8ADmTxFqeqN4o8BMuNNvEnEmo28mHK2zs5zOpZQiyHEqYIlDBWkHsVhewahZxzwTxTQyoJIpYm3pIp6MCDgg9cj2PpXn3xU+AWmeNta0rWLezgmu9L1aPWZLCZytpqMypsJcdFk2HIcYDMihwy7hT9APAPB+r+INO8X6X4yuH09viT8VLiC70vwxpkC3FqNIwuWvGYgJGq7H+1DEm/ORICbeP33wh8Wv8AhL9TvtP1C+utD13TNpvdBt7EyX1orHhywEvnQt/DNEqLjglWBA8M+Fv7OXjh9R8R+JbjXIdL8RarcRzav4f0kJYX3kByy2sdzMjLBEp3bEjHlTMpLTc5T1z4a/Bj4e6n4NXT/C9jceHbvS7rz5JY2kh13TLpjvJuHmLTMzYwRMXR0AUbkC4SuUeiaRaSSzJPb2rWcka7PtF/Ibi5KnBKqN5KqeBy45H3D3vt4ft7iHN20t+2Ok7Ax5zz+7AEZPTnbngc1xukfE278F6pFo/jQQ2s10whsNahQx6dqrkYCMeRbXB6eU52v/yzZs7F7xWVS24dOo5+n+T70ySZSqeyqANvoMcY9v5CnjAA9wcqO1MjfLqfvMx5HY/5/wDr0qso+UdFOPrjn/P+RSAkB2vlvqR3Hv8A/q/nR91sL9Oe3+cdKbkCTOR8w59//wBWP0pzlRD69v8AP+f50AGQycn73DZ+lK5DfNnCgZPGenP6YpJindh179yeg/l/kcjuHZfuhmz68/WhAZ9loi2Wu3155m5dQERKkfdMYI6985rRU8KG46nrzXHjxTY6T8YNWsZNQjkurjSLC4SyjLSTxr5t4nmtGoLKjEKu8jBZNuQcA9AurXV0qm2sX2no9y3kArgchcM+f9llX/EA0I/mX73YDA6c/wCev1qK91W3stizTRRyS5MaE5kkxjdtXqxHsCeRS2qSwL++uFkYdNkexOD25Y/qc4qUtsj27tu4HvwT/k/p+aAqHU5bs/ubORUX+Kf90rD/AHeXz2wVGcdehq2Axl+Zvm9QMDP0yff86Hby2BULnPp06f559KVFUFPRsn/e5/8A10gE3bXydp//AF/0P9aaP3b7fmZScNx1H+f5d+lOBDOy9mTIPvwD+uDSC4HlbuxGRz1Hr+vf1/NgKF2BmyG4OOfw/wA/XvSlgX/ixjIz2/8A102UCODt8uRyeP8A9VL5nndAPpQAkfzlfXGQR69vzxQHULgDj1oRvmX1AH4k5P61m+I7W6ms90Gqro9vCrPPMIEkfYMYKtJlExhslkYcjp1LAu3+p2+j2kl1dXEFpBGQrSyyCONfqTwKoweJYtSKrYw3F1Gxz53lmOEZxghmxuHPVAw69wa5SwvvDsNyl1pNlqXi/UN+Y71CbxUI4JW6mYW8eM/cjdT1whNa6WfibXZA11d6foNtjAjsl+13eSOG86RRGp6gqIZBjo/XIBvX+qW+iac91qFxa2dtCP3k0sgSGP6u2B68nHXtWGvxFOsLH/Yel6hqykblunU2dmAVyrCWUBpEOcb4UlFWNN8AaTZalDefZ2vtRhJMd5eyvd3EJIw3lySEmIHn5Y9oPpzWhrPiGx0K3WS/vLazWVsI08wj8w9cKD95ueAMnmgDFj0DXNaVjqWtLYw9RbaSnlnHdWuZMu/fDRrCee3Ob3h3wXpfg+5luLG1jhup8CS6dmmuZeAP3kzlpJOi/fY9APSom8Wz6qHXTdI1CY8FZLxDYQ+wPmDzfxETDtTY9D1XUWX7dq3lw97bTo/JVvZpWLSk/wC0hjP07gF3XPEWn+GII3vLuC1WRv3fmNhpf9lF6sfYAn8az/8AhKbzVEVtM0e8mjk5E+obtOjX6q6mcdv+WQB9e9ZXijxj4F+ASRT61qmh6DcXgG2W9ugb7UD0ABctPcHoONxPQdhWJP8AHfXvGAX/AIQvwDrupQuxUaj4h3eH7FFwMSKsyNcyAk8YgGdp+YZBouB10nhzU9Wnb+0NakigIA+zabEbRG9mlJeU4zwUaPtx3GVrnirwP8BrdptSvNI0CS+XK+bJuvr4jqqr809ww44AYgY9qxIfhj468Xqr+KvH0lhBg79O8IWQ0yI9OHupjLdNwOsTQZyeK6D4efBHwp8KfMfQ9FtLe+mYPcX0pa4vrpgoUtLcylppCQo5ZznFGoGGvxi13xlHu8I+C9SmhkIC6j4gLaPalCF/eLGytcyKdzYHlJnB5HBLpPhX4o8XXJk8UeNLxLc5xpnhyI6VAuTkq9wWa4k44yrxdfu16NFEdn6E56H+v/1qcFzLk464PtjtR6gc14F+Enhr4ZeZ/Yei2OmzXG1Z7iOHNzONxPzzHMj8kn5mPP1rohGMr05HDevH/wCr8qljVQ+BgnGc+h7f59KEIQj9Rj2z/hVAV8BIjxnnp69/6Vz/AIewPiX4mDqnyW1hhhglsift+YGa6cqrIo+62Bg/3fT/AD/+qub8MHb8T/FC7gx+y6a+0dj/AKQP/Zf85pXA6iEfufmbb8q5J/z9fx7VZJV5D8rbgSPXHX/A1HDx16jv6e/8hU0ICp/h+XH6VAEGpWgMaybfmByR69vz5qpjDYPUkge4xxWmzb42GT16+tUpY/LK7fun/OPanHYCONvvf3Vb/I/U89fwqRm+b7zcd8Yx15/HFQxtsZf9hcYH+fpUsUgBx/DkkKP8/rTAlZtm7A5HXH6UqyYj/u88cfn+maiU5Tpu3DPA/P8AWnhgUPPyg/Xnt+Z/r9KQCu3ykc5b3zk45/HiklmAPcnovrjj/OKSacIB834+vX/630qNyFyv9/r3/wA+lNIAeTaWVWwOhP5Y/wA/jTUKhWwM8dB/Fxn8/wAfSnOeT+HTjJH/AOvp9KFC44weRgAdvr/jTAdGu5VGRuPX2/zipA4Mvod2Tn35/D/PWo5CoHJwpPP06DP1p4ZQn+91APT6flUsCNlY/wAK7c5PHDDP589P8kFwjJbbn5m4z+p/PNBb/e+bp/s45/z3z+FKsmR6Y6nPtTAbktK3C+3oP8j+VKpDxd+Tznr/AJ6U9H2tjG0dcZPHQ/4Gmq7FGHXJ5546D/P50IA5T5urcdewzz+GM/n70ID8oVdze56en6U3zMY25DYGc498f5//AF0skmHC49QAD17/AK/0oAdhvMX0U5JPf04/z+NMcERvn+HGMdh/n+dOL7ZP73Xv1/z/AJxTkbfkfN0o2AhKNuOGHXuOg7fWnD5FXb97Azn/AD2/xpU+ZR8vYZOeg9f5fhSn/VenHUfmf8+9ACOhIUc9ckY/z/kUscRwcnaOctjpTWlEjfd4we/qQen4fr+T2bH3evfmgBpUuG+XA4+UjpkEn+dKsmwtt/i6dzj/ADn9KcXKp0JYdvT/ADzQTg5b5f6+v8qAGsmGZcE46c9Bx/8AXrkvj5G0nwN8bD5iJPD2oj5UBP8Ax6ydAePzwOldar/dBHyr6k9fX6+//wCo818X0Wb4TeKlPypNo16CTkbc27jP5HNGrE9jkPjCSPAXgeTfDu/4SXw+H2HEZBu4VbHqCCcAdeOnUdh41jkm8C6wisFaSwuEDMcYJjYZz+PvjrXF/Etjc/CrwDOo8xYte8OO5wD9+7t0B5/2mGCORkHr077xEvn6FfIvyGS3lAOTuGUPPHpVQ+JfIc9mcX+ySCP2U/hiVC/L4R0gDoMYsYB+HT/PFejCLym3Nwo44/z/AJ+teafsdNG37K3w3Ea7FTw3p8SqGyABboB046Dtx/T0uCVd6hTwBgt6e3vUx+FeiHLck27Plb6nI+6Pf2p0S53MxI/iPr1FJ5m1WwPmUc88f5HP/wBantIwOW+ZsnHt6Y46CgQ0fOm4bV4GPYf5zzT9hlOxv4u/t0/rSRsCu7+8Mj8/58/yqj4l8T2Pgzw3qGsajL9n03SbaS8u5gjSeTDGrPI21QWOFGcAE9cAmgDQ+ZnZvuhuSfT8PxpjQq8ZVgCCpJB59vfqKcXV1Vl2srfMCGyGB759CMc/Q0qv5n+0rcHnvx/WkBR1Hw3Za1FHDfWlrdLDKskQlQNsZSpDL/d7dPT8Kw7nwPd6dKkul69q9rGqYNtduNQt35P3vOzMOoHyyqOB+PUJOGX5f4ucnt0/z6frUdwdr9CRtXj1PzcdPemBzL+I9a0GEtqujm8hVj/pOlMZsKBnc0LASL3GEMp+Uc81ZstX0P4lWE1krafq0CsDNZzxKzxMuCBJBINyMMg/MoIyD6VtleMMpZSfTp/n+lU9f8L6b4niiXULGC6+zuHid1IeFh0KsPmU9uCPTvgsDFHgCTSXVdD1a80mNQSLWQfbLPPOP3ch3Io/uxSRjpWT4r8ON4je3bxJ4Wtdaa2IEOo6ZJ/pVsSSpdQxSeHg/wDLGR25IrbTwtq2iuzaTrs1xDnJtdWQ3UanP8MqlZl6dWaQDjC1G/j240b5Nc0TUtP+6GubRW1G1P8AwKNfMUepeJAOpOKLgcpoTReH5d3gu6/tHyArXvh6+neO4IAw0qCUebHKflJDjY5BzhjvruPB/jCz8baRHfWLS7W2rJFPEYbi1YgN5csbYZJAGBKnnn0INNktNC+JGkQyldN1uyRy0MyFZ1icd0cco4PdSGB9+nNeIPg3qUOutrPhvxFcWWsKjRgalGb22uYyY2EUhDJKyjy8K7O7IJGxkYAYG74w8B23izybhZJtP1W0BWz1G2wLm2BdSVyRho2ZV3RuCj45FcnrmlSaz4nsY9SuP+EZ8aW8QjsNZskxa6xGCN0GxyQ6EsP9HlO9SQ8TZUuu5p3j7XdG02NfE3h+W3m8sGa60dn1K034+bChBOoB55jIxyWOK1I9Q0P4naDcQrJY6xp8mFmjWQSKCMEBgOVdeCM4IODwaAMnR/E3/CRCTw34r0y1tNUuo2Rrdj51jq6Kfme3ZvvDAy0TgSIeoZR5hy1s9c+CsnmQf2l4m8JtMpS2A8/UtDQ7g2xjhri3XAO0lplBIG8KFqTxLYzaFbHSfEUM3iDwlMHZNUZ2N5o7KjMDcMoDFVUYW6QiRW2hxkmU2E8c3XwzNv8A2/cnUPDdyiNa+I+MQg9BebBsVW4K3CgRnI3bDhmVwOs0DxDZ+KNDt9Q0+6t72xvB5kUsDhkdRkHB9iCCDyCMHBFXuZJSp54yWA+g/qfrk159rnw4vvC2qNrvgUaZYXl07TalpMi+Tp+tl+S5ZFzDc7iGE4Vw3IdWBDpq+AfixafEPTrxLKG403XNN2RahpGpqI7vTHYceYqlgykZKOjNHIPuvjkAHXA4Rhn5uABxzjr+mabd6hHZRLJIwXdIEA27mYnoAoBLHjoATwT2NU7SymOftF5JNu/hiXyY147Yy/fuxHsO9+GX92Nu3p27D39c8dKAM59avr6VFstMaOJmyZ76XyF2+qxgNIW9nEf1qaKxuml3XN0zNyxSBPs8f4cl8/8AA8c9O1XY224K7mx+GPp/ntSp8zkfw5Pfj/PFICrd6Ha6jBcwyRKqXEYid0Jik28kfOpDrg5IwQQec5OazbXwxqWhs32HVZb632hVtNTPm7cZ4W4A83Jzy0vnHntg53A+R07ZwDyacJMgMPXII5z3NAGPF4ra1QjU7CbTWXGZgwuLWQ55IlUfKB/elWM57VrRTLLEkkZSRZMOjAgqw7EH6fzpyHaw46Ywc9P889P/ANRGyr8sa48wljjuepP1OaAAjAH0I6ev/wCujOCe/Tkfl/npWSj6xp9w3mfY9Vt9zN+7H2adFzkLgko7AcZJjzj8auWetQ3LlQJI5VwfJlUxuvY4/vYOeVJHoTQBaznnrxyQM4/xrAm+IVlK8i6atxrk8L7CmnqsiIw6gysyxKQQQQXByOnFZ/i6Dw/pLo/iS+kvmuAzW9pfTeYLrBztjtIwFlIyOBG7cDqeTLb+J9U1m2ij0fQ5NPt1zElxq7fZVCAYUx265lI7bJRAcc5oAtw/8JBq9wnmf2do9uRjbGTe3LHPXcQkaEDPG2QEnOeOaT+MNH0vVZrK3uLzXtWjcLLbWoN5NAx5USBP3dvkdDJ5anHXmnnwI2t+W2u6leasRgtbRE2Vixz0MMZy6/7M0ko59xW3bR2fhbRlhijs9N02x4CKFgt4R7DhVGT2/wAaYGOJPE2u4Cx6f4ft2U8yH7deYJwPlXEMbYyc7plyehGadF8OtPkmjm1HzdeuoG3pcamwm8txyHSIARRsPWNE6Cph41jv5GTSbO61ZGODNEBHbccZ818Kwz/zz3nPbOaj+x63rSsbnUIdKibGI9OQSSjuQ0sqkEHj7sSkc/MTzQBqa7rFroVoLnULy2srcsF825lWJM9gGbGT0rNbxdNqgVdL0u8vVJIM9wPsdtkd8yDzGz2KRspx1rN8Uax4P+C+m/25r2oaPoap8n9pateDznzn5RNMxdiegVWOegFc037SN54zkkj8CeBvE3ikJII/7Rv0OhaT1Ksyz3C+bKAyn/UwSDjryAyuB3TaHq2r3G6+1Y2sHP8Ao+nReUTzwHlfc57fcERz7VmeIvEfgv4FWLanrWpaL4d+0rt+2ajeBbi6AHIEkrGWU+wLH26Vzc/w2+IXj8sfEnjxfDdm3/MN8GWi27MM5+e9uRJK2cYzFHBjk9em94C+APg74bajLqml6BarrFxh5dXu2e91OdsfxXU5eZuv97096NQMFvj7rHjZF/4QnwF4k1mOYHytT1tP+Ef0sjnDf6QPtbqcDBjtmVgQQ2Duoj+FXjzx1Jv8V+PJtHt8k/2V4PgFjEwDcb7yYPctkYJ8owHORkjGfUI23HndnOfc+ufy+vFOyz/Lj7x6/SjUDj/h98CPB/wz1CbUNC8O6Zp+qXgC3OpCHztRuc8/vbp900nf7zkV1nl+b8zKCxHXHX/P+feQjncM8dOcUb/mYfr0/wA//W9BQBDt/i7N0O3nPenPEzrtwDn+R4z/AJ9Km3lCScdcn6//AFsUIdrfd9O/f/P8+/WgCu8bCT5flY8D/H6/41JF88nPB/z+lAOD36Zx29PTv/n0oL/dBUrt9+38ulMARd7eq9enTPP9P0p3I3Ej7rkeuTk/5/zy5ZNvUdSe/WhmwN3Q5yT6YpARyw4VQBwOBn1rm/D/APyVPxMGPzNaaccYPygi4AGenZjx6jOe3SOehVTuVcgZ6D/J/wA8VzPhiZj8VfFit5in7Pp+0845WcfL26hunehgdZAeOTnA5H06/wCf8iZSc9fTk+tQxsUib/Z/zmpFf0zliB1qQHEFj/uEdqZKmF2t04/Cns2UP1xkUruFb94MsvXHegDOeJg2WHcjpjP1/wA//XcBxhlClfu57D/ParEse9uOuMDnoarmXKH/AB7GqASOQhgP4So4/veoz/k0rA7cZ+ZsEDPT/PJoZ+itnbzwff8A/Wf096dI/B9V+9k9fXn39aYB1f8AvYJ/X/P0/lTNuc8entnnH+fp+FK1xvwT0xk/5/z6U5JNsn91Qfx/z/n2pgNxkf7WDjt/nihY/NRW/Mj8s/oB+HtUgOE3d1B+n+cfyoDALgDGeOvTFIBAGKhVIB7eg6dqVRub8Mj29KcZMkDH8WT79P8AP/6qCVA/3hkc9M0rsAPy4x1x1pY0Ld/vHd9CP8/55pCP3vy/e7Adfb8f8aaj/Jxwq/dHb2/xo9ABhuTHXnI47/570FsDj0zjv/n/ADzRKfnyrAbjzn+Lr/jQeIV527TgjHT2/DNMADANlmHXBz09P60bmDfMwP8Ad/z/AJ7elIWy2NwHbk5/z3/Whh5h745/Hj/P5UAPZtsn3ht3E+nFAXAHzfdyM46f5NN3dcnCseoGf85/rSI37tGb7xIJwO/+T1pAPYblCqeOxPOCeaa5BPuRkfTGPz6UFSP90ZwD2OaGwzcBdyj7x/Hr/n/6wA4/Mf4ct19/WgKSyn5d2PTpSRupkA/U/wCff9KNxyOmWPb+n54/GgBQuBu7BuPf0oJ+RV68ZyPrRnCfLt54B7D2/l/nNKfnY/8ATQc5PtSAYCcBvQ9M8/nWP8QYftPgjXI9qsG0+4TGOP8AVNxz/nntW08uAA23ggHd356Vl+J4zL4b1CMqH3Wsq49coen+fpVx3FLY8v8AiNL5/wCzt4GmhfO7W/BjcALuB1jTM5xwOGzjn+VepTx+baPG3MciEY9f8+leR+NXW/8A2VfAsnDKt74NmxnpjVtMbPTPYnoCcDGDyPYLaTFzGMbt7hSDUxdnf0Kktzyz9imd5P2Tfh6Nu1k0aGNgeMFRtIwenQ8dunOK9XVtr8EdP93b/wDr/rXkP7D8/nfss+D9rM2yG4QZTYU23k6hcf7P3ffB7V64hyn3R8xztB6Z6/1prawnuTIAy+i4wcD19acDjncDyOv8Q9Pz/wA96jALhjxuBzk1Ij5z25ySeo7f4/5FMBwAZPXsT07/AOfzpVkYup3EN1H16/rj9PrTV4wMgd8dqI8jaBy3Qe3+eP5VIDx+8zld397PU+tOQsJANxy2Of8APt/nNR8YPptPfgj/ADinQrvccgdj7evHtg/rQA1cLCASvyjaP8/jn/8AVTbgYK887PT3P/1/rQr8KxVcKoOCM+n8vSkI2z7DjKKF6/e4z/8ArpgKflKruwVzgUIm08hdvUD2+v8Anp2oAxIe7c846nP+fy/IXIfr1GeRzQAbSE/h3Zzz3wO/+ef0pxTHqy5B59f8mmpJtK7f06f5709f3acd+T7fX9aAMHXPhrpOs3xvGtWs9QbKm9sZGtLrn+9JGVZhz0YkcA4qo+meJfDduxtb218RrGCVhvwtrcv90ACeNfLJ4c/NEMkjJHLVs6r4o0/SLmOG4uoUuZl3R2yAyTyjOCViUF2AOeQp+tRR6vdagcQWUkMZyTNdnyyewIiGWP8Auv5bAe+RSAzbj4m2GkLjXIbzw+ihS819Fi1XODzcruhXHQhnXn1yDUPijSfDPiW8hmv0s7jUJFWS3ntWYXpQ4w0ckJ83b3ypwOfrXSWyTIdzzb2bptGxV5wcDk/gSetc6/wm0mwnmm0eObw3dXEhmkl0qT7OsshA+eSHBhkfjOZI36eppgUYNL8U6asf9k3/ANstwQxj19AJGXBwElhG9ecH96jEc98bfL9a8CyfCyS61az0zxD4dW7Mk2p2OiO1xp9wzY3TW8X7y3ViCcpcwKr5Yhozlm9cA8VaFKRJ/ZfiK13KFKf8S+8VMkEkZaGRgQOnkggngYG6a1+J+mPcRx3/ANo0G8nClYNUjFsdxUnasmTDIw5BEbtjB7clgeN+HfirceCb+Kx8G6lo/wARLG6gMy6BppeHUtPUsyqwQ71gjBwGWV4lyjCONWBVuum1bwl8bJbG4sdZl0PxdChTT9QW3NlfqVLholSZdtzCHLq8B8xFYMG2uuR3GrfDnSNVvZLn7GLS+kbzHvLNmtblmx1MkZVmyD0YnI4ORxWPq/gzxFaaRJafatL8YabIg8yx163SOSbGT/rolMZ7YDQEnu3U1KHoU/C/xau9G8UQ+GfGVtDpOu3DFbG6hRhp2tgHgwsc+XNj70Eh3gn5S6ncPQFOwf3gwIH0/wA4H4/n4/4lsNDtvD9zpusf254P02RSs1rqcf8AaGiTAqyqBKd6QqpBIWKW3YErwM8x6H4s8U/BCxt/7ajl8beCJv8AUa5p8jXV9p0RJ2GdCS08IBA8xGkkCjLs/JpiPZoT/ebOMcfjTocbxyOT2+lc/N8RtDh0S11L+1tPlsb6LzLOWGYSC8XGcxBcmTPPCAnjGM9ZYfEt9qb/AOhaTMkX/PW/Y2ikf7MeGlyCcYdEzzyOMsDfU7sjPcfy/wA/5zUF7fx2FnLcMJpEQbikMLSu3YAIoLHtwAT39TVEynR7FrzUtQhWOMFpHIW3t4/ckkn16uR7Cso/EZdXjX+wtMutcWQZW5Qi3sMZHzGd8b0J/ihWU9eDSA0P7X1jU4z9j0+Gxj4VZ9Qk3NjBywhjJLDpw0iHntjmDVriy8MQJca9rSneSqLNIsETnk7UjXBfO7hSXOQMc8lDpWtauYhe6pHYQqAWt9Mj+ZumQ08oJZc90jibj73arnh/wbpvh29e4s7Nftko2PdTSNcXUqjna0shaRgCSQCxAzwBSAz/APhL7/UolTRNBuDAAds+pMdNgXA4AjKtP2AwYlGOh9WP4K1nVYiNU8T30e5gvkaTbpYQleRgs3mzZ/2llU5UEBeRV6fxxpsbtHbySahMj4kjskNwyHJHzFcqp5/iI6VUN54k1MN9ns9L0uPkK11M1zIvAwTHHtXufl8084554AL+i+EdL8LLM2n2NvavcfNdXCjdcXGMfNJK2XkYDu5Y4x7ZwF+KiW8zW/2KbWpI+Hl0EfbkTv8AvOnlE9AmW/3utTeKNN0fQNEfUPFmrRyafbsWnudXuY7axg5DDK/JDxjgsGYeucmuab9qLQ9Yja38I6L4o8byRkon9jaVIthuHGBfT+VaEZGDslYj+6eaYHW6fqOreKkWS3m0/SrXfhwhF5cp/sseI4n65BEv1HaHxc3hf4eabJ4h8UalYWdvZDc2p65eIkVufVWkIjjJ9IwufTpnlv8AhDfiR8RbnzNZ8RaL4HtHjKm08N2ov9SVCTwdQul8tTjGRHaDBBw54I1/CX7OHg/wtrC6u2mtrmvK2Rq+uXEmqXytwSySTlvK7fLFsXjAUClqBkr+06PGUuzwL4S8VeNvMzt1IWx0vR+AcH7ZdBBKpP8AFbJP34OKa/gH4lfEFF/4SDxnY+D7FmJOm+ELXzLrb2D6hdKScHnMVtEflxkgkV3mpeM7PRNRaHUvtOnx5AjvLlMWk27BwJslFbPG2QoxPQEHJ1g6yxxMm3awEikdGB7g/Tp7UAcP4D/Zv8F/D/xAusWeix3mvbw761qk8up6oxwBkXNwzyLkL0RlXk8DnPeCMs7MzfeAzxk5xio4DscL1kB6jtkf59+RUyoN+Rj5umD/AJ/+tRsA1eWZh8w4yew4p2wsnlnPJ5XH9P8AP9KEZiu5v4jng9D1/wAP1o2nd68/99UANjPyqvTOe/14/Mfy6c1IyvKO6swzyPu//X4/DmmEYK88gdfyx+v+eaUtl9uBhRjr1/z/AFoAcvzggMDzk8dBjjn6f0o3tuYn7wOCfQ5oQKpO7btYnPy9Rn/9VNQcD7ucjjuf/wBf+e9ADmHP8OM9+3H+f/rUx1bdtLY56fl/XPX1pyptQY5CkcgdMdKY527VOPlxx60AEp37hyGYcL/+uljVi+ONq9ff/I5pHfDL97uGx1x/+s0bgzfL83H5kjP+fp2pgC53bsg4Ax2AHOfy/wA96d1CgnoM89fxpqP5aH3wRk+p/wD1frSOeVX6k578dfz/AJUAPf8A1m3P3c5z3x3+veuX8Mtv+LPipVP3bLTcjPHJuv8A6/5966YSbiD2zkfy5/H+tcz4fmA+LfidRuDLp2mEgjb1a9H9D/norAdUSr5+bPqQOevp+f8A9anbtvouO3p/n+v5RhiSuPXn360u3lflVlAGTigCdW3rxt7j8T7/AJfnSdT6YHGQPbn6f4VHv2tjOGPPrgdP8/4UqSck7e30xxUgOdwy8/dz1xmmp87/AN4ZA56H2/OmxsOmOBjAz1/z/nNTrJiLO0fKePb/AD/SjYCtNBtTj0NRbd7kk/Nnn8OP51cbkgZ+v06/5+lV5I8yE4+7nOPxz+IqkwIkTaGTsPvZHX/PtToztTdn5mO4e5oO7DKrYwePc/8A6gfrQACrNjoc8ce317foKYDk+WLb6en45P4f54pygL97aq+g/hpFO4/K3cnOKRpG+0bSNqNkhs/ePoO/A5pAORv7y/N0K0IQMZ+bnjHGTwP6f55qJm2tn5QVGdv909f8/Slil83Lbfurn8f6/wCfWgBykhvvN8vQ56+v86fHKd235l45GP8APBBpPunP8WO3+ff9TTUXao4VV+9ntj/JFAEiLld2T82Affp/n/Ipp3FAp9M/XvTUJ2gMpzkZ56e3+f8ACphMxHP5f5/z/OgBkmdyDLY6Z9T/AJ5/zikUdfRTjA7U5GDnoMN/49/nmmqG2fdx6kk9T/L6/wA+wAJHj0Vs54OB6UkuBwcr25PXp196eRtz/Dnt6Dp/XpQyklRt3DocZ9/8/jR1AQBk+7npnH5n/ClU5C5bPOQxOcnBP+f8KAcle7D3o2jOduVHJPPOOP8AH8qNQGxfKG5Pp9MDg/5/xoCYwMcc4HbjuacDjP8AvD146f5/Chht4Pp8o9hz1oAcI97d26Fu3+elA+YKf4TjqeP88mgfNuO3cc849f5f5/NWHKg4HUDg85H+fxH40gAsVGcleOvp6fz7enrjObrwX+ybhW3fvI2Hrj5T/nNaLXHDbWK8cVTviGtH67WQjP4dP8+tVHcHseI+LEFz+xZ4XZm8grF4bl6mQIUv7FwPf7vX8ea9otAwvl3bg3mDafYntXjPiTcf2I9K8uQsbfTtJPmKp5CXVscgdeQucfz7+0bt136fNgH8f/1etKJT3PKP2KGZv2c9GLfK323VtwEYRQf7VvONvYA8f1PU+theWC/Q8/57V5P+xRcyXf7P2n+YrebFq+tRujdYyNXvfkP0BC5/2e3SvV41BjX5crwD701sSPQeZn5W4Pyj0x/j9f8A60gcFGOdobJGPQ8fr/n1qMfcYbe+OR/n/Pb0kDE5ZvT7pJ/z+HtTAB94Hng+vtkfnTs8bfzJ9O3vzijcSVHocj65P+Ofw7UI2Sf72Rg+h7/0qQHCQozN3z39ecfyxTl5mG5v4/y/zj9aAdr7sDlcnGfqOajJ3H8MjP8An6frRuAI+E+bgtjIJ9cf4+nemkg3DN82Rwfpn6/54qROOD7ZBHTvz/n/AOvl6jPqT3ax2MFn5bLvaa4lbMbHoAij5vU5ZOoAzk4ANFZN6qmdxwc/Sqkmr22nyNA83+kbVYwIN8oXPB2Llse+MVRj8PTX0G7UNSu7jdyY7YmzgTjqAh8w/R5HGecDjGhpOk2ujWgis7S3tYc79kEQjVie5C4GTnk9z9eQCWzuWuBuMckS5/5aEKcdexPv1wfUU8nj+78oGB6cc/y6UmWKDC7dwz97/Pp+Q+op5UeYfkPPbk9f/rn9aAIwpRtw/jG0k9WGeB+HOPT060BAy7udvbIPPT+mB/8ArqSN9/8AD+HoKEO0bujd/Y4/z+VMBqtlFxu3K2Tz09P5GiRMEfe+X5cA9D0/z9KMAIAvOV6Zxnjj+n5UXDK3GNoJ4Hb/ACaQAVO5du7HJJHb0plxbx3VtLHIqyxupJRgGVz6Y6dalztf36gdz1GcU0nzNwAzkYOM+nagDl7j4ZWtlKzaHeal4cbzAxWxcG2bB6fZ5A0QBB5Kqrd8ggGpJ9V8Q+H5P9K0+31q3Q5M2mnybhRyeYJWIbovKykn+70B6VTg7vlbJA+v+c0pXgdRnvjkdP5f40wMPSvG2m6rqS2iXbW+oOpK2dwjW9ywGc4jcKzDjqAR7mvP/iV8H/D+vePtG01Y7vR49cgvJL06RdPYfbHi8hkaVIz5c33mz5iNnIBJBKn1DxDoVj4l05rPUrK1vrOT78M8QljJ9drAj8f5GvPfFPg1vDvxD8GyaZqF9a+ffXduLe4le7t491pLKdqSEsoxEVCo6KMjAwoAWoHKxfBbxt8EPEUms+BbrS9asbhyb7w3Ki6ZHdhmDNNCy7oY7o45ZFhik+Xem4B16D4V/Fe++POlSzWN3ZeG1ht7drqzU/adYsHlhSULLHKixwMNxALJMr7cggA12UGu6ppbL/amktcIMh7nSmMwKj+JoWxIpOT8qeYR69q8d8HeB9S8efCjwLf+GRa6F4g0fRrW1HiLz9rRlEVHtntVX/SoyUbdFMYlXcpRg2SAr1PTPCvgWxtfFWqXNzDJqV2s0M0F3qDfaJoyU58ssMRjK9IwoGBjGAB0Gp+MbHSr77PJcPNf7Q32O3jae4KnoxRQWUcH5mwPftXing34gSN8T9S8OfEvUhpvib+zIry3022le003V4o/OeWa0kVledFUhTFK3mAxysylCCvZeFPjh4Zn022s/Bek3niFJEV2g8O2qPYW7NhsPd5SzB9cSliQeDTEdlLf65q8C/ZrSDR4WHL6jiaXHoI4328jPJlGMfdPNQazo+n6ZpVxqXijVmnsLUGW4kv7hbXT4F5J3JlYwoHeUucDliea59NO+I3jxnaa/wBI8A2JY4TTMaxqrDBAbzZ41t4mP93yZgMH5jn5b2j/ALOvhOPUodQ1LT5PFOp25DRX/iCdtUmt2HIMIlJjhIJwDCiUtRGVbftGaX4isoo/Aei6z44UfLBPpVt9n0fGeSL+bZbMgwc+Q8zDHCE4BfceH/iX42VlvvEGjeB7Fv8AlhoFuNT1Ir/193SCBPl/hFq+DnDnv6YJPNG6Tc24DO4nP+f8RQysdq59Rn6/X/PNHqB5/oP7OfhHQdUt9TuNPfXtcs8NDqev3UmrXsbA/eSS4Z/Kyf8AnkEHGABxXeTZef52Zyp2nPbjr698/j9Kcv70fKvUZBBPrnp+NN4Y7eiqeBnoKYAiFF/2h973Pb2pwjLHb2I/M+vr7/h3pyN5nr2JOehpwXZH936e+Pp/L/HNADF3Bv4vUH/E9P8A9dZMPg+w0qfzdPjbS97FnFmfKilJHJaLBiLHu+3d6Gtdxh/7wyDnvQeJFXpz1/z/AJ96AEQtv+YN5mcMPf8Az9arWfiPT7jW5NNjvrd9Qg5a1EgE23GQ2z7xUj+Ice+c1ajOwk7eo6Dv/n1qvq2i2XiG0WK+s7a8jRg6rNGJAjD+Jc8q3uMEYo9ALS8n2Y7QQfvdBQD5nyj5sHvWTD4dutIP+g6ldNAMn7NqBa8XOP4ZWIlBJ7s7gD+GteMPty67HHDKGLhevQkAn8QOvalfuAq7iM7iex5zj/8AX/h60ZCZb2P4YB/z6U5XzGFAyCAeO+c/4frTVOOcHGSuQfvDt/n2pAIwzLty2N2doGc+mKGYeXux2xn8uf5U7G5c4+YHIPtx/wDr+tJL8gA6biST6YH+fzpgB+TbnPYEA9RmkZuG6/e59Pp+f6CleQhlbnd1GTjgf5/lQcDG3jGCDnv/AJ5/X6moEa5Yc5JPfOPX/GhRjPU+nOM/57e9MNz5M0cPltho3k3j7o2lBj1BO8+udpz2p+5ljA9j07dv8/Ue9MBHIx6nJGP73XP86VDk8/ezn60DK8n7uNp56dT/AJ/+tSk4Uhl9h78/59MZoAYWxJ9DgnjB6/zHp6fjXL6Gxb4w+J1OMf2ZpbjB6fPfAj8doPJ5yfQV1Uj7piu3O4kHJ9z1/wAK5Pw5cD/hcfihf7ul6Wj88g7r45/EMPTofwQHWZ2Kv3slcZ/n/n1qQfMV7gEHA71GW2ptCscH3GSc07/lrsHbHOOPy/CmAMu75dzdOSf4f8n/AD6jNkddv9725/8A10KxKtjb1PH4DFCvyzcfM3Oeh/yMUgFVsRH72fXPXtUsb5UnLKuORn/P+fpUQbA9MdB044/z+VSA7XAA7dOeDQwFZmDjaOnXH4f/AF/0ppTIb5uPU9iP8n8qcGLOuNy84z6f5/z1NR529CFzgjP8s/56VIDGQsWb5u468/56/l+NI20QbufmPY9KkaXKc9ufoPT/AD6U2M5OcY3YH4Zyf8n0qgGsC7L6g4/p/h+lEzMFXB+ZcYyf8+xpwO1unPp6Z6f1pt1kopGTjBxg0ARwYLsP4ere5x/h/LtToizBt2SAATz6/wAh1NRqdhYjqw6k+tTQ8qGx82cNxjjvj3/lntTABknsOCOv+f8AP6Em5Qx/hY8c9aHQldrfLkE8/wCfrTXdijdRznp1z/n/APVQBIw+782GPBA6H/OR/kU3YVwD8rNknPT/AD/h9KCdu4NxzknGcDB9vYj/ADy5flPHr39fXnmkA1kZSOfvcg/pk/p/MZpyoQM8dc5I654/nj6fzANit97r2/D/AD+VLy68feySF/LvRqAsUpaP+7uII/rj8f50KvyAbmbGD833j/n+nvUe7hscbeBx3zj+Y/z1pxBB79Mccfn/AJ9KAHRrgcdjxtOPU/0pQPlbON3TA7c9v8/zpVmILZ457Dv2/lj8KTcFCjgdunK5IOP1oAQjavp39jRzvVdwG0447/5z/nmiQ8Mf9rA/l/gM07bj5eVHbj73+f8APai4CKMn5sDA5/z/AJHX0oXLISfTrnH+eaeq5k3cYxjn8f8AP+eY9wb+9kkHHqf8/n/JAI8TNlfu46dKieDz8oW+U5XOeoJFWJVYS5A+Vjnk/wCfp/hSFsSx8/xDv9KcWG54N4tDS/sNN5iLut9Ltt6lgAwiuEDHPHGEJ7cY+te2MMX57Yc5Hvkn+eK8b8RwJdfsR6xDJH5ca6JdB4zldmx3JHqMbTzjj04wPZblgt5Mw/ikJ9+v/wBcURA8w/ZTtpLDwBq1pM26S18Ua1GxI25/4mE7c/8AfWeOOmPf09OPyyf6/rx+HavNv2bVa30fxiN0cn/FZauy+WchAZ920e/OCPXPHYelwrvIVfmVjjjsPp+IqteoDo9yv2G33/z7f5FPjVsNgDghh37dKz28R2v2mSKOUXU0LESRQAzMjYzhsDCHHHzlauW8s1xjdF5OMcOwZj+AyB9QT1pATKdx5zwOmevT8f8A9X5jFihkbk9Tgc9OD/n0ozuHHzFTg+/P/wBelwCdv3lIOce3v/n8aQFB7zULjaIbSG1j3bfMuZQzDHokZIYexdTTk0mR3b7Rd3E3U+WrCONPbauCR7OWq4QxXp/DyOn1/wAP88tf51Y7m5XOQORwf6c9qEAIFi2iMBQvIUcYxzwP8Krxjyok/wB0gEemP8/n3qchtu1W+baf5f5/L8aYr/u+u09v5f8A1qoAWNmzwvbjsB/n/PanRBgV3N83fAIBPXp+dNHzscDryBjtwf8A61Lb2ghjbbuO48kkse3c+tAD16Fie2Tz/n/P6Ky5Vh/Epx0/z6f5zT9291GVbJyOP8+gpI8+/YAnqPx/z1qQEVckheO68+gH/wBf8jTQu8f73bPb/OalH3SfcHkcEZxSDgqePvc57dc0ANblh3Ppn/P5UhO4beBgAj8v8/lTwN7/AHWw3BB65P8AjzSKQGb+6T2OB/kcf55oAaB83P0470wkum1sYJ+96/54qQuQ/wB0gkZ+vH+RTlUGL5v4uB39B+tAEaDeGbrzn/P51JguwX5fTr/n0/lQrsWVto9Px/z/AJ5oxsl5Bx1579vT/P4UbgNdN2B24B57VxfxOIi8WfDxt+FTxK4ORwwOlaiMH0+8D9cDvXavIysu3+IfgK4j40O0TeD5FUsyeKLNW4yVDiSPntzvAyf72fSjoHU7CEfvFPqwOM+n+RXGfAoMvws0uNo2t2s2ubdomPMbRXEsbKfoUrsX569RyT/n/PFcr8H3P/CDtznbquqr028DUrrHv0/P8aoB19oNnrHjy8W+trW+WGwsbiBZoVk+zyh75fMXOdrbXKhhyAT6kV0cdqLeOOJVURxoFCKAoUAYCgdF6dOP8Mrcy+PpF/56abGwJzjKyv8Ah/H9eTWtCSGbcflALn1xz1/WgCRVy7HcvU49s/8A6/1qSPALLlfmIz0yCR/nn3PXnKZ8sbedx+U/WnqrMq8/Nngjv2z+v+cUgHBcJn8Bn1/px/OhV3pubblcZ7Y9v1//AFU4AlTtX5fY9B/n+dL8wIU8Hnvz/nn/ACKVwGmPj3xtxnk8c0z+8Vz04OeQMf8A66kH3mZsfMOhHb/P8qauFPAJ4/THP+fbt1oAaAV9GI+X8P8AP9aH55+UHngY5/z/AIfib8Qrk5wMHA/z7f54qR22nJB6lj7j/OKYEciY+8drY2mgDYD/ALOcnONvNOZPKLbuV4GKdu+VueeuB3P+TigBqBizcbWbtn8P0NAYKN2Rhs/5/X+X4LGFzzkck4A+np+n/wBeljPybSv5D/P+frilcAKfKP5E9Px/z/WnZ+YD5eP88f5/nSA7Q3X15PH+TTnPzk/XqM0uoGT4n8JWviWW3mkmvLW6s1YW91Z3L280AfaWAKnDA7EJRwyHYMqcCobG21rRZtsl1Z6xaqo2tJGLW7H1ZMxSE9gEiAwOfTdAPzbvbPHGeo/z7UzBaPPXcMjnoO/+TSAhsrmS7jLNDNbsCcxy7dynvkqSp5/usRU8kW8DP4Z5+lOZ9wzyRnIP45zWfrOn3WoRQ/ZdQuNOlibdlII5Vl/2XV1J2+uwo3AAYd6uBc+Z9vzDD/4HGP8AH603G1c8cYJJH61gnXdY0KItqmmpeQJwbvSiWJGeS1u3zr3+WNpTx09NDSPENnr1m7WlwshTAkUqVkhbph42AdDweGAPFAF3BRufvHoPT/P9OnqzlAq9dvP1OKdJiNP9npgn/P8A9fj8GsTjb/eHT1700BI6kSIAewGe/wDn/PSmjgHLDd1P19Ppx/Wh/wB4nyn72G3enP8An8qaf3hJ/vZOOn1/l/nmkAsgJH1xgZ6+n8/1rlND/wCSveIl/d/8gfS34blv32o8kfQDBPv711anemN3fnI6VyWiRqvxy8TN5e0toWjZcrwf9I1Xjp26+nPT1GB1hDE/Lt7bj0xQ67G2nHB9P6fhUwjwW/2eBn/P+cVHNHldwUHdyQ3ft/jTAFOdzfd4AOccYH8qE5ToSD6HBP8An/DpTth3ZUDcDjgd/f8AL+X4CqVB4zj+fP4UgGuWPcbsn/63+fepGDbznaxYn8e3+evSoziMr/dxhv5fyA/KnN1XP1PHX/I/pQBIwbdn5cMfz5x/X+VMUE5bPbI+nHP40sx/eMcn04/z60eXuiK4PzH+Z/lz+WPajoA3ycSbv7wIB6e36Z7+lOERZdp/iOTTY5CenC5yDjoen51JGQdu3jgkjv8A56flSAjbcqKc/TpwOtN3fvNvCnr+P+c1YvB5cRbbuwwwP6f59aporOqnLNz1P5Z/z6+1OIBOhTGMYB28D/PvzSwHEf3uO/54/nUiJvX8DgD60oi2AH+6Nufbtg0wEPz7hyR1J/p+lKW+ZM/dzwR37UclPl4x17/5xx/9am/MH+XldvBB/wAf5/8A1qQDZseZ5eW2jjOP8+3504Nn/abP+FAG11A+Xacf5/z3pu/K+54x6npVAPf58dDt6ZHrSdVPzHqOnv14/D+dG4++f580IxXnbt54A7/5/M5FIBFbBz1zyPX8f8/pSBdzA9DjkgnI+ntjPA5/WhVyijscYGeCBRnyph/s8dfx/r/+ugBy/vEK9Dg7vb/P9KVG8yNvvBXG3tzkfzo3ZDbu2Sf6/wCe3tSMWyPm5U9ccA+uP0xSAkPynnjjPHRf8/0pyHb8uCvv1wP896az/Ljpxkc/57/5707ZgH5eV6YOfTP86AHDBdtvQdsd+lNLYfK44PIA9eabG7KDtX72CCe2cf4U6RsScsF4GOec8UgBkwvf5cAnH3vX/P09agvZ1tEaaT/Vxjc2ATgAZPTn8uaqSeK7SWaS3tfO1CaBtjLaoZFVgcFWfiNWGOjMCD+FNZtUumXYltYr2LnzpCPoCFU/8CcZ7GnEDx+TxLH4n/Yi8Q38azW8baPqx2yFQ4EUlypJwMfwH/D19el1iC61Sa3gka6mVnVkgUyYIOMMRkL26kHg/h5j47+AWrD4S+IPDeiahb3lrqWn3UFlDqhkhFg8yH5leDCsqyEsAY94LH94AAo43VvhdrHxQtodP+Iviy70yJWAudNjZobO5VyAIcxeVaSR+ZkRrLHLJt2hmLA5EB6B+z9f/aLvx1D5Jj+zeLLxoz5scqyxSJFIJFMbMMFi6kE7gyOCBgV2knhyPUruaTULi5v4XYtHbSlVt4h/dKIAJOxzLvOemBWP8LPgzofwY0SSz0O2lt4ZynmGR93mbV2rwoCjAyPlUcYHQDHVYI4CnCgkZ/ipoPQktbVLeFI41VYoxhVRdqp6cDgDpUyKMEenHHYf19aYj/vMgZ3ZOM9eh/lShfNfHOQMEHqf5elMCRhlt3447DrR6/xNz+lIvXAG4/e65x/nP+eyH5V+9wvJxSAkGGb73PHbgU1032zKRjcDgZ4H+fenAcEYPzDHXoP8mlI+Tdx83T8/WkBD8sYcj/a7Y7f/AKqiKYCZ7kgfj/8AWqZm3RynHVWAPTBxx+uKhGVk6DbgdPX6fr/hVADvt6ZXnJzx+f41IrbZB/cXJ6U2Nc7ckkdev9P8/wCLgm47e2OueoB6f59qAJNu487vlwMD157/AOf60rcnGSccj/P9famK3l7mxk9D78Y/+vTlUk9+/Q4GT/hz+eakBznnB+Yjpjtj/wDXQV2qvLfuyRk/yz+X5UhG+PcM7c4+n+f89qHUo5yPmPU56e/+fT60AKg+f1zgDPbrjimyN8jKvbJUHv0/xH19qd1k9ucj+Y/z1pp/dk7fvKMZz3GMZ/P+tAAqeZu/u4A+n+H/ANenA4y23Pzdf6/56Zpvl43Kc8nnn14/z78c05XIAwvUcfl/+ugA8vzAvbcPX9fT/I9aSQ/vWU9/6/5/z1p5DF128en+fxpuMkZX6DPXt/L+tADGY/Nj5VXtn3/z+tcZ8bmWLw1o91hV+zeItHcls4UHUIFY9OPlY9fXHFdooyCoB/A44+v+f544j9oK1e7+GUhVmVIdX0i4cr/Csep2khP/AHypPpjrjNEtg6nW7PLbj/lmeh7/AI+/J49/w5j4QuY/Cd6nH7rXtYUFe3/EzuiBjtgbeO2PTiuqbLr0288c9M9vz/yK5T4VqyHxFD/DD4hvMc9PMZZsj6+bn65680wLmo7U+IumoOPM0q7bGf7s1r/8X17fjzuCTL/L8zZA68E9P5D9axtSmYfEHSl3sytpl+xXbwxEtiAc9c8njocnPRcbKR7OmdrHHt9P5f56sBwIyqlhnoCe44/+t/kcTImUOPvM2Qe+O35f0qMJujPuc89B/nrUynEbL/eHY/5/+t/JAOA2RLz7D2P+J/z60848zb/tdu/+ef8AINM67fl29See3+eKcXbc3JXpketSA0PlNvTCkj344/U0xWXy+vIAGPx/r/n0K4/cPjuG/DA6/nxSFmydu4jG7rndjAH9KYA45POATgHscn9P8/i5m+ZdmV5+uRSbcSN/cz0z6f5/z0ocM8ee2cHnr/n/AApgNVVQ45Xtj9f8/wBacr7n+nX26f8A16COcHjB57Y/H2FNB2+7cZPQHv8A5/pSAei/uxnqpwvP3qXhU/u4zuOPunp/9agtkEjr6/kP8/5NKVJG4rhevHakARgqfl+XgEY7dzQhG3+6KTB8zHPGOMdBj1/OnYb+LP0z0/zx/kUANZuSy9s/TFGVAH+zySe34UE4bLcdz/s019yrnbx/n9KAHMnlrnacZ5AOSO3U/h9etNZi7gHtkeufwpzcKy8gg8A8cc1Gr579CMEf5/GmAD9/yOrds/XJ985qOe1juHWR44/Mi+47DJjznOD269u31pwXJ+7tz0wenHP8x/8ArpxJErfUnP1/z+lMDN1SDU/7QWexubXywoU2txEdsh3HlZFOUbBHJVxhR8o5NTWE8sq7Jbd7eRR03B4yec7XHUf7wU9OO1Wn+8WH3mBC89e3+frSt8vzfxD5SQe5z/n8qAGx8LhfusCFPr2/n/npSrJsHTIyM4PT/P5f1xtY8IR6lqX26C+1LTb1VCC4tJsBlxwGicNC454LISP4SM1DZXmuaW/2e8srbVolOBd2DrbyMO2+CVsDA7rK2eu0cAAG+8mY+Nvb/I/z9a5fw/N5Xxz8SLtbP9h6S33cBgLjUuh+ufy/PabxJYx6zBprzCPULy3NzBbtlZJUUgMVBA3FcgEDJGRkAEZ4/wAP/EXQdY/aO1jR7LWNNutVXQLKSW1t5hNJEEuLvO/aSEx5qYDEE7+/UHQD0RB8+07d/I9QOn/1qcAobC7iT3/l+Z/z6NjbIfnn274xT8bXb17VICqrbeeue3f2/wA/4UwoE5PGRzjkLn1/LrTmDBsHO046n9f5f/Wpof8Adr8oyPm+vIz/AJ/xpAJLFg/L8zZ47emR/X8T0qEsqSsrbgeT/PH+frVgFkwvp+YpyRCdVGT83p2zVXArtLuVsfMqnB9+f8//AKqdjPXDN93juP8AOfzqMo9vIqkboz6HOcY/xoXce57ZpgSZ3MP9peTn7o/zn8+2amQANtX+I4J/z+X41Hncfm75xz0PFEMSQQqIk8tVXCqoAAUdh7Af0qAJj88bZ2/MM8n8f545/wAir5fkscBtuenfHpVkMdvORzgkf5/z+VRznzH2++BnvTQEULfNnJJ42nGMDn/HP5fSnJjC+mPX9B7f4VGzscKuMkevNOQFZQo9Mj/65zz2qwHFtrc/w4z+hoaH5/m/H/635U3buQNj5vf3GadjcM/d7jsc/wCc/l7UgG7Sz/N06/T2/D/PNG3aGxzn34x2/wA//rAwDHtjJDdtxoUh1IYDtjPX64/AUgERV3qy/LjoPzpCuQcN93HH+f8APPtmiVB8vTaQBg/59+vt9KhG1e/Kjv2qgLA/1ob8vb/OaSMEgHOGB6f3eP5/59KRSA6457E7TxTkRSOmNvQ4/wA8Dj3+lABhcKv8DHketCjIKjAY8fif8/54w4qCpUj7xHLdv8/4U3ZkbTwuc4zyKAJBJvA/Tpxx/n8qXG/HVgen5E8fl/nrTAeRux9Oh/KgLt69eCfb/OKkB3Tcdy/LyT6j/P8AOnPEC43dO3+zng/jzTWVQnp1GefxoVzuyPvL3zx7f1oAWR9q/Nu9c55/zwaZIxD4/vE/nwP8aUgZ2r931z69f8mo2QMvHp8o/DOP50JAcf8ADeVJdW8aYZePEJGNuNv+hWmPr0zn6Dtk9QtnETI/kx+ZMojl+UZcDIAb1HJ4Pqa5jwUPL8Z+Ml3O27V4p8N90BtPswAPb5M9uT+fVo21Pm+8M5yeT6n+dUBjReBLbSl36PcS6KV/5Z24BtSRnAMByignqYwjHn5gaBqGqaOjLe2C30KjmfTz83Y5MLncvOflR5D+fHQBd7fwk9PSkC59xkYA4z2P6H+v0QGd4c8RWfiVJGsZ1naEgSxFTHNbMRnbIjAPG2P4XUHHYVoKAU/2Rzz37dP8/wBKzta8Jab4kKveWcE08Y2xz7dk8PX7kq4dD7qwI5OarDQNU0nH2HUTdQ8YtdQXfhRxhZ1+cZ5OZBKevrwAbZJw/Tpk5/r/AI0pGG/3hk1g2/jqG0uo7XV7aTRbm4bbD57q1vcvhfljmHykkkgI+xztYhMCtwxCJTkFWyeo7/4e38qAJFGx+D6cjt/kUuMxHs3b6Z9fw/l60mdob5fm449xz/n+VI3ETbe/GfTnNIBJl3xtjuCenY4qNxnnkjOQPUY/z/nFSyhUjbHbsO/TFQMGLBW+Xb0z/P17fp17UIBzn8dvTjg9KlHydDkYyOaikX930+X0J6Z/z+NPK5z7cgH39fxzTAWMev8ACMkZ5NDny41VfyHU8f5/Kkc/OV/P2z/n/OcUrr8nY7uxNIBw+Z0PGegI6/n6UBcEEfnjH+e35UbcL8xx3GD0Pp/n/CmgcbQO3Qd+vT+lADgm89f4+mOnTj/PpSohV2Y/ezx7dvxxUQSR5x8yLHjJGCSx4xz0x/n6yPtZT/Du6hj15A59fxoAI1Bj6fLgZI9MU5wZF3Hr0wfWh4wg9sZAPOPb3qMgkLzkjPfr/wDqo6gSEEt8pbP0/H+dAIkVsfKpzkjnp/n/AD0pqkb12r7dev8AnP607ZtO4dckigCPYEUZ7849ST/n8M/WuI/aRTZ8DPEkuGb7Lafa1xyR5TpLkf8AfGc8/Q9K7hx8oHy4yT+B5zXIfH60+2/A3xnG0YmX+w71whbG5hA7DnnuBzg4POD3Nw2OomUCVv8AZdv6iuP+GoZPEnjhVGCPEJOB2JsbIn8+vHHOeea6sTx3iLNEfMjuAJEbGCVIBBx7g9OK474bsG8cfEaPaf3fiSEHnqDo2ltn9SOKL7Aa+q4j+Iuhjj57G9TG3knfat17fc/HjuM1uxKV9S3r+f8An8O9c74lIg8ZeGZCVXzprm3xz8wNu7kcenlZx/sn2x0UYxn5fm4wPw5/OqAkVVKbt25eSufy/lTtrALHzn09/wDPOfr+LI0wi/iOvXt+nH6U9Tuf9Bk/55/xNICWNcv/ALKDj2/zkfrSqjKg+7uGAfxzTUUIRtxtU8HP+felYZTdxleuPXjj9B+dToAzYyeZ/dIOB6HmmfMA2CTgZA+p/wA//qp8uNj8ZUg89j36/wCeo/COQbVbhSy/w56gf/qP86aAlA2MB6evX2z/AJ/LpTtuWGP1/GmBFKbd3K5OQTz2/wAP88FQPLPGFUY78D0oAQZ2t6KMAeuOP8+mPyiCZZWwTu4I9+f8+/6VLt54+UenOR/+rmmvH8/bPp+WfyoAVSZF/i+bPI4+v+f/ANdSBd8nY5X8+P8AP51FGigZA47jPX/P9e9OJwB930Of8/WmA/K7lb3wD680jouNvtwB7f060bN49OMAdjSBsvn7zYJ6fp/n1pALI2/dge/Oev8AnmmlsSZG3/Z98f57e9ICd38PAA5zxSSnIb68f1/z/XigBzDLbfm2g9Af6/59+nCEeYCFbHHX1P8AkfypT82flzxwMkYpmQXLfeGcDnt/9fFFgEZRub+IKOg44Ppj/PBoRNxG4c9MY69Of500EEHowzgcZqj4g8T6b4WtmutU1Cz0+0B+aa6uFhjGMn7zED/CmBoZw67fruz1z/n9aCvyjvkEk4+vb/PSuEj+Ll34ojY+FfD2oaxE3KX94TpunD3EkimVxnvHEwPODxUp8AeJPFSMuu+J3tbVm/48vD8RsV245V7hmeZs+sZhPt1JANrxp8StD8ARxf21q1rYyz4W3gbMlzdHriKFAZJD04RSawV8e+KPFSldD8LzabbMQFvvEMotQ3P3lto90x7kCTys8DKg5rc8KfDfQvh6kjaPpdpYyTcT3Ea7ri5Jx/rJWzJIeBy7MTitpF3nkcfe/A9aYHAav8BY/iFGq+NNf1jxFCsgk/s+3c6XpyMucN5ULCV8HoJppAOO+SZ/hR4U03QfGviT+yNM0/Q7HTHg0dLW0hEYk8tPtRmbAABJutoGCf3RbcQwVeyVWIH8OB2Oe3f+X/165v4bJjxh4448vGur1PQfYLPnj3BOfzApaAdlGuFb+LbwB09P8/lTs4HJx+n+e/51GrFVLbOn8IPJx2/z/iKew2r8vrg4HH+f5YpAB/ut09P8+lOfJB6kL82PX1/wpgPLL8oKqDknkf55NSImW3MG64/Xj+f6/WgBY4iZd34D3/zzUwGB/FuyMe9MX5unXsMf5/z9aaXBDEHcucc+uSP8/jUgR3o3QKvsSfcev6/54zGn7vof9rp0J6/57fnTpTtHzdM7Tnnt/k/jTWj37jtXgEY/I/4flVIB6KpnjZmbKAhQGIBz1+v4/hinJIUbj5lUZHt0/wDr/nUUnLAY+bIwPUf5x/8AXpwHDeh79eP/ANX8hQA5eFx/Fn8QP8n9KD84Zl7EEk8/5/ye9Njk8w59/wDP8v6+tA+WM4Gfx/kf/wBVGoAyFfYHrj0A/wA/pQnT5vm5/Pt/n/61I4ynpkBuO3U/5FCw/Nhfu/dJHc0eoCuAWUbcbuevTP8A9Y/qO9HPX0OOfwH+fpTg3z/Lt7Z46n/P+fVuflODz2z0NGoDQcFs8nn5f7uef1okbMJUffU4II4/z+lNdE3Nu49M+/WlQ4C/3eeAPw/xpgPdf4lIyBuXPQnk/lVNBuQEZG4/Nngr/n/Ptc3YT5euD2/H+majeBS+Ad3PXpQA1FJTP8OAev8An/P6zINjbh8pJ3E59/8A6+c1D1X/ANm9B6//AKv/ANUqkKd3tnp/n2pgKfljUbcBcE5PX/PNGPfb2Jx+P9KaybmC5xzhcDPX+tN83DFc7vm5x/n2+lSBJz3HfgD8BSE7y3Hyt0A78YH5dP1+jWOCvzNwccDr/n/6/NCHMa+o65HamBIrArz19M9f8+n/ANelkUxttx8uMdc9qb95Ru+XnJwDk89/0/Kmytt2HPfsPb1pADyb2Hfbwffrx/n1pvWQd9uBjPX0+nr/AJIpyfInUH3x07fp/nvTXRXO3qfp/n/P4UAcl4TuAfiZ4wjbYQXsX4PrbAZx/wAB6+nqM11MJJHzL82MDHX8K43wyin42eMtqgBrDSJXGOSx+2KSfX5UX3/Cuwjbc3yn7mfx/wA5/wA8U0BYAVlzn7388c0M3RsZ3dc8Z/zn8M/lGqKse3I2rzjHHfp/ntUytn657jqP8/ligA2ADp8xGAfx9KdIRlh/FyB79ajBARR6cdOT0p54K9fmb0/z2pAQ3+l2+pWUkFzDb3VvIuJYpkEkbDg/Mp4I74wemfTGQfANvYLt0u6vtDKjaiWTr5IwM48iRXiUHuVQE8fNwMbrHc3Hp+h6/oaTdtx9dwz6f4fX/wDUAY8V7rOlH/TLS11KNek9h+5kHzEcwSMRgLj7srE4OFzgVZsPFmm6tcNaQ3SC+8vzjaTEw3CJuA3GJwHA68lcZx9a040Ee1cdgQSP8+lU9Y0a01/Thb3ltb3kCsrBZog6q2OCoPQj1GDzSAsSHbC25fmUDIz6Ff5f5xyaZGnA9D3Hb/OPxrGm8L3elW8jaXq11DGsZ2296DewldvXczCbIxx+92jPQ8YgHim/0gAarpF0sfKm604NfRenKKomXIHURsq/3sDJYG/nzgGONo5/p/n+tORsKQw+VvwGf8/56VS0XXLLxJY/aLG7t7yEMYy8LhxGw/hbHQ9Bg4NXcBxjov3cEdQPb60wHHawO7lWHPb2/wA/T25GyPvcEEZ9/f8Az7013wmc52jDfnz/AD/zmkK7nH95hjJ/p+R6fzzlALMQI1+83GQFHPvj/PbrmnMcOm1VzkE479R/jQg6jdubGBx15/z/AJxQNpixubkenT/P9PwpgLHkKehHOPfj/wDVRtVQPf8AT/OKA2YmY+4PHHFIWzwG4YbcY69P/rdKQDsZCjr/AA/hQ0mfnxwQCTnj/PSmHBb8Cef50ittP972PeiwEijL43bSmcHPJ7/59xSxqdvT7x4pjfMfxxzzn1/p/nmnFu+7a2eAR0oACfmXG3rxg/jXN/FiMz/CzxPHyxk0a8QdTjdbuO3JycV0BABk3NknHQfmKo+ILD+1tBv7TzPL+1W0sW7bnG5WHT8Sf88uK1sJ7EPhS4+0eFtNm+X5rOGT5ecZjU4HTjn27Vy/gRTF8VviDF0WS9sbgD0LWEEef/IXT2960PgnqB1f4MeD7ltitdaDYz7VGVUtbRnj2GcfhVPw6gt/jd4yX5V3afpNxnPY/bI+cn737r+XXkBdh9dDT8UfJ4g8LybQfL1KRSP7mbG759skAd/5kbqttHzN8uOP8f8APpXP+L9qa74T3YXbq7L83cmwvV49+e/HXvXQRjCKcnC5yMd/p+VUBMMjG3buYf4H/J9qcp8pAvzbV6Z5x0/p/Wo1IIXryOvr/nH+eKk6s3XqeB09ef8APNIB+5lUMvpng85Pp+RFO2hVYL35556/5JqOSTEfb5OpA7f5NPfB8zcPm569c+n8vwpANk4ib5WXau7Hrxn+X8vWox+82qc46cnp/nH+cVKThXPqOhXp7f8A6uaiU+U7devpjH+eaYDywD+wOFOeSP8AOKVV2Dt8uSD1/H9P/wBfZSu0Y6jJIB7UjAFe+0Hk+v8AnkUkA5gFQfw9z79KaBhMcFs5OOM8f5/Sgtjd9Off/P8AnrQVIbj5fU7f8/5FACEbkHpnIxn608bQw/i7A9v84/z0prnKYyRu46UZLhfu5U+mf8/4UAEAxt2nC4/w/wA/THegDcvPXHbpjj/6/wD9amu27nLfMuOnJ5/+vQsm7dnGMHJI4HbP86LdQHfxfd4bsOvt/T/OabJ/CevI9Oelcve/F3STO1rpgvfEV1H8rQ6TD9pCnpteXIhQ5OMO4x3wKrtL4y8UL8v9meE7dlwdyf2lfN16YZIImHykf68HJHHBIB1lzPDZ2hlkkjjhj5aV22qo9ST0/H+Vck3xgtdftt3hvT7/AMVM7YSSxVYrMnuftMpSJlyOsbOfY9KfZfCPS1nhm1RrrxJeQFWS51iQXBDBmZXWIKsKMCeGSNTgLzhRXUMN7Kzd+OfT09qYHGNofjDxQd15rNj4ctHxuttIh+0XK8nj7VOAvp923Hc5yQat6B8L9F8Oap9tjs2uNSUBft15NJd3Xf7sshZlGSThSByOOBXSKgPt8vGR0z/+vPNRs6713Nt3EAfU/wCODTAsw222MySNlh79QcD+vT6VLIPLDZ4Hp2qRiu3hgVK8cfnUMy55Py9e2OOv+H5VIAMM/P3eh9fy/GmliqBWHzH1P3f/ANXpRnJP8O7nGPz+n/1qaTuC5/Ids4/+t+VUA4jErfL7cfl/h+dcb8LJo5PE/j2ZCu7/AISHYceqWNmMHgdtp+hFde5Dx/NnaeSf8/5/mOM+GE3keJvHNmG3La6+ZgQpyPOs7WQj3wzNj8BQB3SHBK91OB/n8DTmGenPTHqf8n8qhTbGV7DkY68n/P61IznHONxOP8//AF6QEjx7M9PlPJ+tSFFB+XjPHPbP+f59KjjbEn3uO3t/n+ZHryKdrbu2cjA6YqQHK2Rj5cjge3+RTmAcDI7+v3QajAITc2c5OMD8f6/5zTs+Ux7dQM9+tICMsTuOfu8dOAO/+P5U1uNo6HI2kfwnv/X86kYKh2/3R0A6dD/n3xTX2iX/AHTwR/n/AB7VQA2BIWbbtXjP+fyph4KswG319AB/n8KR8rNuJHTBJ9uB/PpRnaG56HI9B/nrTAdnMLcqF5yfQ96GGyLB4ZQc8+lJtCL6d9uOh/z/ACp0SlQF3Yb1x/nqR+HFIB0nygdyOSfX0H8qJB+8xtHPAH+fekRdp2/wfeGBwT2/rQOF4x8vI4zj2/n9KAGS/ImWz+8YKSOf89f1pynaCC3OfwPrSMys7HnP6/5600DMZY/ewB0pgCHMjD2Gcd6ARszu+6egHTvx+n5UR/KF+bnrkHAyev6/54qMLtRewxjHoRTAmZ/LUsfQkn0A/wA5/wD109o9h77WJHXr/k8VEj7vlbHzZABHU8c/hn8akbhj7g/h1/8Ar/54EgNYblI/h9R2pxGE/U+v4f59etAKrluhPJ47f5zRs2qM7s89v8/5FMBrR5GPf9en+f8A9dM2gs33uCeg69P65p8wZWUfd6DP+HrTQdw2j5W5OOmMYPP+e9ADdnG0naSSCBzzzTh8o+9tX1x1NAGBx97gDP4/n26/40fMQT94qfzxTAcr5XCvjAOD/n04oX5Nv8RwRn2FNUdfr1x1NOyzj5Sd3I4H8v8APpSAHj3ELuY55HqTSOu7/gPI/GlmIP556dvWowy8AMOOoB5UHp/X8j6UwPCvjR+0dY/s3/FzXNQ1PQ/EWsaXdaXpEVxPpNv9oGnfv78KZAzD75k+XHJ8sjGdoatZ/wDBST4ULcrb6rq2r+G2ZA7DV9HuLdYgSR8xCsB909Tj5TzwcelaQ2742+KrWRWmjvdH059jkMhQPdoybfQ55z1/PHmvxB/4J9+C9X15dZ8L+d4R1RXDvHar5tjOQc58lj+6YdmiKhSASjYwZ5Wth6Hqfw4+OPg/4uQrJ4a8UaF4gWSJp1NhfxzF4wVDOADnaN6AnHBYA9RnrIGyn3sE8e/H+GMV85fAP9j3xZ8FbnVvEi+LND1Pxrrkim6W60uSfT4okG1LeGQyC5UAbizk/O7f6tQoWvTE+L2ueE2aPxZ4M1ezg+bOpaGf7Z08KuTuZUVbqPgA4NuQM43t1ov3F6HoYfcO7LwG/lSklnK9cisfwP8AEDQ/iLpTXmgatYaxbxMBK1pMsvkvtBCyAfNG2MfKwB56CthcSMdo3Z9D1H/6jj8BVAO3bh975W//AF0KflXcfwxzn/P+eaYrllO488HnnOKc6sob5vm75/z/AJ/WkA9TgYzjjj6etFwu63PLBlYHP4/0B/Q0xjsjb/a9P89sUkjGJ8HJ9x/n6f5zS1AcEUuq5/dkhT788/4VBEDg7mYYC7gAevX/ADj/AOvUrNllVR7Z/wA/5/OkVuGYdxg8Zzn9f89hQBlav4J0vxBdtd3FsPt2wRi7gZre5VePl81CH29PlJxkDI4FQiz1zReIb6HWIVypS9X7Pcev+tjXYeoGDGPdupraG3aF5+9kDng+/wCX+c0K37rd/DwPfpTAx18dWdqVj1JbjRWZggGoKI4ySTgLKpMTMewDls9q2gc/ePUA4wef88dKZcxLcK0cirJGww6MM5H/AOusRfANvpxX+xri40PaDtgttrWeMY2mBgUVckE+WEY8fNjimBv53v8Ae+9nt/n/AA/kGr8zK3PfnPNc+uva9oUjf2ppaalDvAF3pJy2MgZe3kO5evSN5eASccCrvhfxhpvi2Fjp9z5zQgNLbsDHc25xwskTAPG3B4YDofSpA1Fj+VvmP5fX+VOIDDrxjjHT0/pio9275fvcEE47YpxfM2Oev6/5/rTAd2POD1H+f8/yoJ2KxPQY7U2N9xXG4989xx/n6UifIFyOh59v/wBdMBdxUZ79D/n/AD0oK5AH+PrQXOehHP4UO+1Mbsf7R70AD4G0k8ZH5cZ/pz9OabFEHkWP72cA5zzng/5/yBflYkhunfjtz/n1pYCBcx4+Ybh2+lIDiP2fZZLj4D+DFkbEqaNawSj/AG0iVG+vzK3/ANamaI+349+K+Ru/sHRXxjpm41Yf5+hpfgHdyS/CPQ3l/wBYElViB/Es8i9AB3GOn59THp8Ri/aI8RFuRceGdIBOOfku9V79Okn60dPuDqanjqH59Bm+YC21iA5AGcOssXH/AH87c+neuhXlSSewGD+PH+eprA+IbtF4etWXIP8Aa2mr68HULdD+QOc9uvFdAq70AYcNj8DyMf57GmA/Iz64Ix2J7/yxT87B97uAfUfT8P8AIpozIx9M4Of0z/n+dLG7Lzz8pJwO/wDnn86AJWO7dz8ynIweB9KRwFTA6Z7f5+lIrqxLZIxgcduv/wBajduBVvm3Z3Y989/89elIBxIwDntjp0oZQwz93k/hgDP8v0prZ+6O59KcThvTaMntg5/z+dIA5O3+8e3WlRcHrnnoOP8AP/6qYFPJC/d6ZGMfX8qkz78sSOnpR0AbtyV6/Nnr2NDRqp3bj8vOSeCMdxnn8fWs3xN400rwbbJJqt9a2IncJEsjYedsniNOWc9RhQT7Vi3njbWtcO3QPD82zj/Tdac2Fvg45WLa1wx56GNAcfe6GgDqy2wbu+Rgdz2/rWF4h+Jug6Dqn9n3F/HPqMhAFjaxvdXTHqP3UYZwBg8kADGSQBms2X4bXniJ2/4SLxBfalC2AbCyj/s6zHOeQjGZvo0xU8Db1zveG/C+m+DtOW10nT7PTLU/MYbWFYUZs9SFHJOfvHnPNAHPza14w8WKv9m6bY+Grdj/AMfOtH7Tc4J+8ttA4QZHI3zA/wB5AQVpF+D9jqUyz+ILu+8UXEY4S/k/0NTgcrapiHPoWRmGfvV2OPnVf4VPPvxTlG4+x6HHT/P9aYFe0tYba3ihhCQwW4CxxooVEAPygAcDGOg4wacBj+LaT029B/nrTtnPHHH5dj/k+1G7ONv8Oc/nTAbjD8fT2H1/Wh492Fz14wT/AJ7f5NErh23csucg/UDB/wA//rHOE7t/nt/ntQA3bllYhi3Y46j/AD/Km7FLc7c8Efy/oKcX8tT9T+J6nn/PU9Kag3N8zFuOccY9qALKt5iL69CT2/yeaRhj+LqRnk88imxOWO0KWY/Lz16/z/8A1VzHiT4zeH/DmrPp51Aajq0bFRpunQtfXqkAHDQxBmTqOX2qCRzyKkDqUUFtp9QNvTBHH9K8k+MH7Z/w5+BPim60XxR4gn03VLG0jvJIf7Oupl8qTcUfzEjKDdscfMwGUI7HHRjxF408TFfsOhaf4XsWztuNauPtd4fTFrbt5fPJy1yCMgFOePlHxl/wTH1j9oH4963q3j3xR4kutDtZIra21C5uraW+1mHylaYQxRoY7OHzWmVOdypuBjORIByfQD0t/wDgqd8MdQ1210jQ7Xxt4o1i+ObWw0vRHkubobSw2KzKWBVd2AN2BnHDY7X9m74j6p8RfGXj241LwnrnhVft9rJGmpy2/nc2UICtHHIzxsVVHwwGA4HUNXRfBP8AZw8E/s7aF/Z3gvwzpOgwyIElktod1zdDOf3s7Zkk56B2O3oMYxU/w5VT8WfiJHuUn7ZYZK84zYQ8H8Bn33elGvUeh26fd4b736+n+e9TMpdF+YHvjpn/AA47VGowu5sdOc84/wAe/wCVSAYUN+hHTt/h/wDXFUIf/HuJ6nOPxzn/AD+lLjbj8z74H60knEmNxXryB3x/n/I4XovdVbIOf8/5/nIDlXLbd27n5Tnuefx7/jQw3u3zdDzx1/z+v40K+xD1PHYfgf60vlkAZ6rzkf55qQIpXCRr7EZ/z+NRj/WH5uOv1/z/AIUTH5Qp/h46fXmmgmQ/7SjoPy/z/WrAcdzSfL1Ynj+6P84/X2p0f3dv5Y5z/nFCDduI+gGOv+cH/PFKgGP4uM9uT7f56frQAixYTbu5Xgf5/wA/lzTio2tngd/8/pQp2leuWBPTP5//AK/zpy8fLyR14H+fSkAm1j1bdnjpxQqqsh/2vm91/D8vyo27t3XjngfeGccUqyKRgY4JXHTHP/1v89aAIEbDfzz3/wA/zoB529WJJx3P+FLhkXKn3AzwB/nNN+9hecA4z6k8VQDY22j733QM8dPT/wDV9PWhHD7fyHtz/wDq59qceVz6nJPvxyP88frTT++2n7u7sP8AP+f0oAfnJX0YkAY9hz/n1pW3Pxxz19v/ANVEinAz97B6evI69h0//XR5mEP8O3t6f5/rQAudqbiGVVGcH1H+f1px+8w9Pm4Hbt/n6UmMH+Ijuo6jkUKuwfd5z70gFcbx838XHHQCkMR3fdPp059v1/rTsgSE7dwJ59v8/wCelG3efm53Dntk4/8ArD8qYDdoP93Gcg44P+eKap3xZPCkdxzUgTKd2bB56Z7CjKuhB6N6f5/zx7UgE8zMZI655FIX+XPzH1p0Q2v6jGT+v/1qawG3vxgZ98f/AFqAEf5iF46hRzj3pgCh5Nqhd+Oi4Jxjnp2/pUjBsg9+g9/pTV6Y3bu4Pb/PT8B3pgcKIJLP48yS7n8u98PcrgBR5VwMHPXnzj9MH1JrtIU2n+LnjGOv+en9elUH8J2r+KIdYxN9uhtG08EyNtMTSLIQVzjduVfmxnA61p7MnngEen60PV3AIRtVcqRtAP1/yM/lTguWP/jv6f5/GnbMNubn+9xQOuMZbqR2Of8AJoA5fxl8G/DPjy+TUNQ0qFdWUALqtqz2eoxYzjFzCUlCjcfl3beeQaxv+EH8c+Dni/sPxVba7YqG3WHiW23T4IGAt7BtcYIIzLDKxDckkCvQx8g9cA84/wA/59KGBwVP8J2+p/zxUgedz/HlvCFs0ni/w3r3hmJBue+ijOqaagGSCZrcM0YwM5ljjAyATmuy8MeKdL8Z6JBqGi6hp+sabMPkurG4S4gfvw6EjPNaCptcsM/Kc9cfke3rXF+I/wBnjwl4o1eTVF0v+xtbck/2rossmmagcnq00BVnzzkPuB7g0ah6nZAYmKj+EYH4Y6fpQGEsef4sY+UdiOfz/wA9K87uPDnxI8H3Ekmk61ovjSxyzLY6/B/Z96owcIl5bIYz2A8y2J5OX7Ur/tFad4alkh8Y6TrvgiRQM3Go23naWSc9L6HfAucZxK0bkYOwdAAeh4ztQjceB0zkf/X/AM81y+s/ETfqEmn6HZ/29qEP7ufZOsVtZtjI86XnHYlVDPj+E8Ax+O9Gk+MHw3mh8O+JV0yPUVHlanYlbqKVM/ModGHysOMo4Yc89QfLfEl58WPB2nWHgvRNM+HVjeawk1vYXuli6jTSolA8y7kt3jKYTcnG87nZF6uBR5oLXPcNFW8i0mFdSmtZrwKBPLbRNHC79yiszMB6ZJJH6XfM/wAceg/ycVyfj/4z+FfhNtTxJrtnpe+3NxvuH2tIqsFOFGSWJJOFBOFY4wtdDDqdveXbW8VzBJMoEhjWQF1U9CV6gH6d6oC0uR97J45IH4f0p2f3R5UbuQfX3ppBcq3tgZ9/8/z9aegV17jvgH8x+n6YoAXO3a3PzN+IA7/nWfr3hTTvEsqrfWcV00PMMvKzQH1SRSHQ9eVIPX1xWgrMso/iwc9Pz/nQ33fTjJz1xj/P5VIHPnQdZ0RGbTtUXUIu1vqoLEHPRZ0G8DGB+8WQnrnrmNfiEunzGHWdPvtIcNgTyJ59mw4/5bx5VQeceYEOR93kZ6Qgr8xyu0jPv/n/AApsbEDI3KenB9hx/wDqpgRwXMdxaRyQyRzQ3CBo5VIaOUccqe456j1qVcH5scgED36/pWA3w20y1vXutOWfRbq4bfJJpzCFZW55ePBjcnOcspJI64oe68RaB801rb65arn57PFtdJ16xSP5bfUSIfRD0oA3x8rMp/h4ximiXZzjkc/pWZpPjLTdXv1sVl+z6ht3iwuVMFyQOCRG2CwHTcuV961D8zfN/ewT7+lMAVNox2Hf0poHK/j19hn/AOvUhTnbgtkfN7/X/P59Kjfc0rdd2eR2HU/57+mKAON+C8LW/gj7KyLDJbatqaMg7Y1G55+pDKfxpCq23x7ebcrLfeHBuQZyBDdnafcf6Q2AORz1yML8G4WstJ16Hay+X4k1d0BPOHvZZB/6GSM9jxxim6tEE+POh7fM/eeG9TyQeMJdadjj1y56+/tQtV/XdB1/rsaXxFiL+HrdSu7GsaW5HpjUbU5/ADP1HHat5PmiJKlm284Pp/8AqP8Ak1zvxTJj8D3EjNtW3ntp2IPJCXUTnn32kdz/ACrpF/dybu4PHt/n8+lLqA4/K/TcMn5hx/nk0eUyA5HyjknFCjjhenAA9akI+Xr8y85Pb0pgNLZ+oOMfp/X/ADzSofMj75x1x1/D/PWkdv3MjP8AKq5Zy3RRjkk9ABjH865tvinY6qso0K3vPEkiHG7TlDWxOQMfaHKwkjOSA5YbTx2KA6QbnXnjJ7c46Hr/APr6VDqusWvh6xkvL+4trK1jOWmuJBHGmBnlmwO2efSuf/sjxRroH2nULPQbfkmPT4RdXDZyBiaYbF4xkCFuc4bpVzTfhzpOm3q3v2VrzUIzlby9drq4U8fdaQkx5IzhNq57DswKbfEhtbiI8P6NqWsLj5bll+xWWe372XDOvP3okkHH0oPhfX/EMitq2uHT4sYay0ZfLHDE/NcSAyN2HyCPvxzgdQMNhydzHp15P+fWmhy278mPt3GKAMfwx4F0fwfM0lhYxx3Uy/vrp90tzNnk7pXJkYcDgnAxgADitdpOdyn5m5PH+f8AJp5+WVV5J/l/n/PeuZ+KfjKfwT4bWbT4EutXvriKw063cHy5biVwq78EYQZLMwPCqT2oA6LHllV42gfNn+f506MjzA2eDgmms2M7VO0Nhcnkgf1607dv/wB7qBn3/wDr/wD66AHAF0/A7vYU4DB4A+YZyP8AP1P400jY+4dP/QTzRu+Qcfu+5JPFIAB4UE+/1x3/AFqFRtHX5R7/AOf/AK9SN869MZxkevH+fyrI8aeOdE8BWsU2t6pY6Wlw2yAXEoSS5bOAsS/ekbkAKgLHIxzgUwNLazx7vyB7j/P4Uo5Rurbfm+vp/P8ASuLPxE1/xRD/AMUx4TuWjlG5b7xDI+kW7KTjiIxvdE7ckK0MY5A3gk4c/wAN9Y8QSs3iPxRqE0LkEWWih9Jt0x/00R2uWz3zMFPZR3QGt4z+J+gfDy4jh1bUre1vJxm3sow095cc/wDLK2jDTSdCfkQ4AJ4Gaxrjxl4s8RxxrofhuDTbeQKft/iGYwkKRnKWsW6Rj1BWV4CDk8gDO34M+HGg/Dq3mh0HRdM0lbj552tbdY3uT13SMPmkPu5JPrW0yFR3yOuev+ee/FMDiY/hPca8PM8UeI9Y1wFhJ9kt2Ol6epB3AeVAQ7qPSaWTJ6+ldJ4T8J6X4G0SPTdH02x0exj4S1s7dYYlx1+VQB9T1P550tuT79M4ySfp+vFOCZx0zjH48cfypANPDnLY7CoxHvPPDen6D8R6VOEPl/UcZ5J/zx/9alKfxfzpgRRxbAx68ZPHP4fpWPoHg7+wvGOvan9o8z+3Psx8ry8eQYovL67ju3AA9B6c8VvsnybeoQE9eSfT+tEaMwjyA24ZwBSARSerfQkj0/z/AJ5p/QD/AGsHjv8AX86YG3Drywwf0/z9Kftwy/pkf574pgAPyqwOFzg8UO+zdwdu0fh/nn8qDyCeMY5OO1H3QduV4xipAkjO4lefvd+1OQ5UH73GRz+tR/Mv17e3/wCrFPGNik/Nxnpn9KkCpdp5V00n8LYx6jjH1oQ7F46/z6/5/Gp5B8zfX8/85/8A1VE1t02g+mM9v8/zqgFflO21mwMHjrn/AA/+vSpyq54AHbqcen5f56ULHldvVGPBHOM/5/rTizeWPvbiBnn7tADgxAAH3v5H/P8AKjKxjdjnHy/XnA+vFNC/Keyjtg8Dt+lKE3Mvy7T3yOf8/wD1qAFyVPHTt6Dt/n/JpqDcMD8KEOU+g/KgDK9h7Z6/5/nQBC2F+bHygg9expnzI+3AHPHseOv+fT3pVk5X8fwH/wCugDcG27lPGW+p/TvVAAIlXJHynjHPJ/zj/wCtRMPkx6nGMZx/kf59VRNir167fujoOPpTPLBZV+9jpx9f8KAH42Oe7Dr7kDB/n/KnqVEjBflzkHvkHmo85fcG9+B1xx9O/wDkU5k2tt9wv0ye3+c8UAKoyjLjHAx/n8uvanHn73zMuduMjqeM/TH0OAcCmF90Q7g5I9OuR/kfWlOOMH35HQdv60gHAAtjH3vQ9OD/AIn86RXAfdkf7P8AXHt9fT8acBlto+bOcgj2/wAf8igDd/Fxu649f/1UANByGHXqBxjI6/4/56vbbtzj9McZ/wA+1I7bFB+U9xkcZ/z/ACpsfAX5m+bGNwxk/wCf60gJHJzxzz1B7/5zQeW6btxx9O+P8/rTdwVf7ze4wD/n+lOxuGV+Zgf16/0oAaTxu3fNwM/lTW+VS2O2CPX6DFPdfn+9yvHT/PfFMKMMEcMBwMf55HP5UwI96j5WVdzE/KT8xxjJ/lz649cAWJT/AHj9M9v8/hSsF8n5T24/XH6fz7d1ZMP/ALXBA6/Q/QZ/SmAqjB4VR2Pt/nj/AOtSkb3A6YXBz29Kcg2yfxc8+/8An/CkC8/e3bBjPtwP8/8A6qAFVhIzHueme/Hp/nPP4PG4Y2qo56fp/n8fWmZw6r0xzkjPuf8APsPWnN0/4FjHft+vX86kAZVZV/u9SD2x1/LI/wDr9KYpIfavRhk9eKd5nK/N8vU9PzpdwLY+6T+nH/6/89GA1tuC23rk/X/OKawOxuPvcZHfPb/PrTt2QGzjjPHpnH9AKasXmbh7cfTrTA881T9mXwnJqkmqaLaXPg3WpuX1HwzMdMlmbs0saDyZ+3+vjkHHSo4bH4meCdzR33h7x9Y7zuS6hOi6kqAnb+8j320rD/rlADzyM8ejnDFf4wwwcDr/AJ5pmAPlYnqAe3yj/J/WgDxXxfrngfxNf6g3iWy1j4c+J9esRo51HWbZYZI4CSDDb3u6WxDSDcCsUpdvlLK21K3fAH7NXh/4b/E6HxBoek6LpVrFpMtkjWsRa91HznjdpJ7lvmkUCNQqsX6AhkC7D6XeWsd9C8U8cc0MylJI5EDJIvcMp4IOM8+n0rgrf9nfT/DE7N4P1rxB4FRi2bPRnhbTnJz8wtLiKWGM55JhSMt3JBqbdQO+C5dmxnb8o4Pfk/y+tKRtXpubbg+3+cdvavPbm7+JngYFms/Dvj7TQBgWbnQ9VQDqAkrSW07k+stso3dBjNWdE/aL8L3eqw6bqs174R1i6by4tO8RWjabNO/zYWF5P3NwcKT+4kk4/GncDuizQzYx97leTyfT9acg+bhefXrn/PFJNCy7ywbzFG75h/n8/wBKUOoPykna2fqT0x/L/PIA0RlsBfmBx/8AX/xpysJGxhX25OB05J//AFZ/Gmqu9yv/AAInHXjimx7gPm+Zh2x+f+fWmBIr/KOcqOPr2/z35p0h3s3G5ueP7xxmo4ZV3HJYsvIP97HH6Z/nT2T95/ebkkY/T/PX9KAKut6LZ69p32XULW3v7dju8u4jEiBh0OGBAb0I5FY3/CGXmhjdo+s3kKfMfsmoE31sOvALnzlGcHCyYAGAoGMdEDuPzMS3fjP/AOs0iLuOfM+bHP68/wCfagDmpvHF5oUbNrmj3dtBHy17YFr+1AwDkhFEyj1LRbRjO48mtXQ/EGn+KbL7Vpt5a31s3HmW8yyrnOMEr3z265q+smwq/wAxYDOBwfX/AD+FYut+ANJ1rUftjwNDqLf8v9nI1rctjGAZEIZgOu1iy8YxgmgDD+Gt7suPGLXEkara+IJ90hb5UVooZAT2HyyAf5NYdp8TNL8Y/tH6Da6VeC+js/DutCeSJWMPmfatH2qr42uwAbJUnGRnk1jah+z7rFx4i1S81BrXxVpaaibu1sbq5NlNdBrW2jZpJIlEbNuicBGRRhclyGwuF8XPFOqWvxY+Gp0TQfEGif2JdXUep2kemsiyWjiKR0iMIeKVWNtkrGSwwvyjK0pB0sdh4v8AjboPjH4Z+LbKGa40/UrfR7ueO11GE20k6CF9k0ROVljbGQ0bNjo2CCK9WkYrcSLt+ZWI47c5/LpXDeLLK8+I/h/7DJ4YtZNPumMbNqrr5kKv8rypFG24fIWJxLHIM8DPFalp8OftbrJrWq6lrkikOEmk8i1VgDyIY8KevSQuc45Jp6gT3/xQ0m2uJLaxNxrV5F832bTI/tDg88M/+rjztPMjqOPXiopbjxVrqDZBpfh6Nj9+djf3A6jHlrsjXPH8b4GeM81v6bplvpFitraww29vEAEhijEccffAUcD8KsNGPL2/NtPUkds0AcvF8LbPUJVk1y6vvE7ryE1HY1qGzncLdFWLcMDBKkgLwckk9QqbYlUfwrsT2Hp+n6Ubf3at6nIP1pQvOd33hnn/AD6d/WkAjjKsv8WPXt/n/PFDjKfMvy49Ox9qVyDu5K98jnA9f5e/FOVMA88N6YGPx/Afn+NMBgG8/dGD/wDr/wA5/wDr09GLEfLtyefb/PtTIwcbslVzkEDHXPP8qd0GeVPdf8f0/wA80gGk+YQF3dwAD9415fcfEbRZ/E83jDXNSt9P0PSzLpegrI4MmpOXRLi5ijXLuWdVhjCDJAkOCJFNeoMgKFdzKehIODz7j8P8iuH8C/BTwt8H4f7StYna4sogn9p6ndNcz2sQXCqJpT+6QLxhdoIPOaQHP/Cr4p+IvHHwK8Q+I7yOOzvI5tVk0lpLXYoto2kNtuXI3bQFViQpJVh1G4+M6L8b/ix4u8G6baw6lbPqMPhmL4iz6lbaciy3VjNEZbfSkhUMrN5pMRYYaSOLqGBZ/bfB/jzQfD/hxdE8E6br3jS0824cPYxA2CebNJK4+2zGO2ZFd2XbG8jqMDYxGa1LDw9428TRIl1qGj+C9PjRI1ttBQX12qDon2m4iWJF6rtS2JAJw460Mfmdb4h8Wab4O0OTVdYv7HRdNhBMl1fXKwQxcEgM7kKMdOTk+lcqfjPceIYNnhHwvrfiTdjZe3Cf2VpY6fMZ51Ejp6NBFNntkdL3h34M+HfDmpQ6kLJtU1iEB11XVJ31C+X3WaYsyf7sexfQAHFdYzbyd3LH7x9e/wDLH50aiOLPgzxX4rmVte8TLpdoxBNh4et/s5cA52yXcu6Vuw3QrAeDzzWl4K+FXh34fXctxo+j21vfXAAuNQkZrm/uf+utzKWmk6n77k8n1NdCRtUbvmDcc/xE9vX3p+NzDOWDHOfbsf6//rpgR7chVHUHIz39P/1//qpD/DhcfN+dPZdo5bcwXIOPT/8AX/KnIvlkdeDjgfXj+VMCPncu3B3YOCPwpu4DDYYY6eo4/wA/5BqQKVVVXj/JpsY/1h+bHbnoP880AJ5e5uNvfBx1z0/DP8qXcGJxzwMAe2TTgGEnB5znp+BoKb1+VvvdeP8APPFACfeA+X5cYwBjOP8AOKe5YL6nBP0/zmhRhPlwc8/5+gx0pAjYXOep68/5/wDr/hQAucDdt+g/z/nimttKsvTPtnHbP/16cT/td+h/l+lJEMAZyNv+P9aAFXCsvHzNnH8v8/SjOTlfm3YI756mkjhZD1JJ9uPelWPcf4vmPReCe36ZpAAfDf7y5xnr/nFOUHKj+6cZ9h/9emxAnqRwcYHSlKhiO+Accevb/PpQApOxWbbkLg4z1/zxTm+QY67SMe3BppOwNyQSOOOlDjjG7hhz7UgBiM9CwHU/rzQDwT/EqnjGcGnMm9ju/jODx0701Wwdp+pOOmKAGFNkhyPTgdvenYDYwv3jtHbGcClHzBdvL9QP89s/ypo+VVDN369jQA1htAZfur/X/PNH3wq7emec8Dsf8/4U5sY3bvmx+f8An16USIGmPO78Pyz+H8z16FgKzYVj12g8/wCfxpTwD1yW3den+eKM4OWzx0yBkChhlW3dcZ6dPb/P/wCtAUhMIgw2/MF3ZznA9vy5p+0TpxnnoR3H+f8APSo5WMsbFWxztPy9xxz9entUkMsix42rhT8uO/f885H+NUBJHCHSNc7vU/59M0gUKuRz146f5/Wn4J2/L8vYEZ/z1/n604x85J+UryPw/wA9aAIXXcxPzNzn6/5/n+VG5mJ5/izjruqRYvLZifug8HH0HH+f06NAIHA27SAeOvOKAAtkccFs5P8An8fzofDq2N23kDHoT/8Aqo3ZA/ukcHb2zgf5/wD1U4f6zH944P8As/5NAAqFDux8y8kf3jTkOQP4ueCR0/z/AJ9mv8yyH64+v8qkclS23a3PQnrx/ge305pAMK+ZCpXO7ngfX+tLtYN7q2PalBI24Jc5wSR1/wA80EZl447DBH1/pQAjoBL/AHe45/z6frinfelOdvB5568ZxTVTHU4bPA/z9aCuH6/Nzn9f8+n4UgGu5I7846+tAPzc/eGByOf89OvejOA27rjnJzz/AJ7f5DfLzHlWLDOTnv6H/P8AOqAcn3k6fL/Pk/404NjkZ6j29P8ADn0zRt3svXPPfoef/r/l+TgF3fL8vQnPfn/9VADA+AvUcg4z0Gen+eaVn2s3589O/b8aEwDnB6ZJ74//AFUKuF2gH5uOTzQA2N9qj721R2P+ff8A+tThtDf73Q49CajI/d9+gzjueP6/z9qkAZgpPynj9P8A64H5Hr0pAIDvk3Ak7ffqP84H0x+KrwxY9ff/AA/Cmom5v7owAT+PX9KdHuLF8dcDH93n+lABy24845I5/wA//X/ClBbYMj5uhHv3/kaTO2Hp68+n+T6UNwmecjnoB3//AF/54oANi4G07QBjpQTubHdeE/Mf4foaHIVvn7Lgj/P+etBBjVSc9cD1z2H+B+lAEZOVU/whfu+v/wBfP86ckfm9hjr+vH1oZfk6ZGOo9Af8P0/CiNyvUZ9KYDgigsOOOgP4/wCFVtY0Oy8QaTcWOpWlrqGn3abLi1u4lmhmXnKsjZDDpwQashuy/dBJz69h/SiH5lUncvbjt/kZpAeet+znpPh35vCGra94FkRT5VvpN5u0yPrgDT5/MtFAzn93FGxwPmHGIZ9a+Jfghn+2aDofjzTw2RNos/8AZOpBdwGDa3LtBIwUn5hdR5xxGudo9I8vJb5RgkEZ9P8A63+eKVk9A3zH16emfypeYHn3h79pTwfrOuQ6PeahJ4Z1+bldJ1+BtLu5SOqx+cAk+P70DyKRggkYJ7xkKIwbcOmRjB/L1qr4g8Naf4u0WXTdX0+x1bT5xtltb22S4glGD1RwVPBOc8cn1rgx+zTaeE5d/gnxF4k8DbQNtlYzreaRwMBRY3KyRQoeQRbeST/ezijUD0gDBLKuH9MZokbEeCW5GR7YrzmHxN8RvA0BbXPDuj+MrGEH/TfDMxsr4gLk5sLpyhGR/BeOxz8qHHOp4T+P/hTxRrdvpH9qNpevXH+p0fWraXStSlwWzst7hUklXIPzRhlIGQWFFwO0U7W2r6kYHb/P8qjjGfugKDjHtn/DH+eae0bL8rKQV69upOPz5/zmmqBI2SfQDjr7f5/+tVAIWJ+bBO3p9Pb600jd/vEZPHbpx+GaceXP+zn/APX79f8APNN+7jPcY/pn9D+FAARgn+83UdecZ/p+OKaU3Kx7dMfU4Gf89fenkblb+I4wRnkcf/q/KuG+PMe7SvCkhkkjaPxbpDAL73SqQT6EMR6ZpdAO4AB+bA3duf6/nToxhGYDbtGcD0P+f89o4Tnn/npyB/n2/nU6fKxLZ9ORTATao+6pz2/z/Wnom0Y29Bnr3z0/z/WlIyPm+p+n+f8APajy8N8w789vX/69IBPmQL8vf1/T86XZhcdumMdf89KVzjgdsEHHTp/jmlKM5+VSzc4H6UgG7mkk+bOV5+tH/LMbe35f5/8Ar1x+t/HXwzo2tzaXb302u6ratsn0/RbWTU7m2bjiZYQwhznrKUHfIqgfEXjzxw3k6boMHgm1bh7/AF+WG/ux6eXaWszR89d0lwNueYm+6C4Hfuvyt0woJJ7KB3PsK4WT4/eH9Ukkh8NteeNrqGTymj8OxLeQo/QrJclltoyMciSVSPypv/DP2i6+yzeKJ9T8bzb9yrr04ntEOcgrZoqWgI7N5Jcd2J5rt4oVt7VY1VY44VCoijCxgdAAOgGOlGoHDLB8QPGT7pJNE8D2LHlIP+Jvqjrg9WcJbQOD2C3K9eehqxp/wQ0GK4S41SO88VXkbiUXOv3Lajsk4+eOJ/3FuflH+ojjHHTvXYJHhivPI5Gep/zj/wDXRt3Lncc4OT64qgDPmtuG48YGew9qI8Bfl4xgZHft+nXFOWPDt6jkAn/A/wCcUFDIqr/Fz+fQUAAbzY1+UnnBOc468/pSptdtw4zy36f5zTXKk5x6ZPpn/Ip4Ta/8TDpgf5/zwKQADtZvl4A656f5NAPy4yfckcgf5/WgDb6EKcjH+f8AOadzuHy45z/n/JoAYwZxt4HXnr2/kP60oj453fvDyDj0HNOVMbj6AAf1+vpTVPz/ADN/nr+NMBSuJ8f3QP8AgWaRR5shXr754H+cf55peSPukHgHIz9c+/8AhSqvmHlcqADj8P8AP4VIEan5VbAJx06Z6g0OvybcN97jFOiTEW1f1569M/pn+lKTkEj1yM/56dPz98UwEcEj5m7d/wAv8Kc3L57c5B9TQVyVbHY855H4/pSuNp9AOvsfT+VACOSGK5HzZxnt9f8ACmBQJN3zdOcj/P8Anvxmpc5P3WGeh9PYf5/wDVXB3eoByBj3pIAz1+8oHI+vT9On+eWuu7b8rdeffPb34704jtyrdDjqP88f56NjGzao+YdiP6dvT/IpgAUqf9rqCO9KrKjdW/Lt/wDW/pSMuThfvHuehI4/lmlIzFwPlyQAfof8P0pgLg5xg59B2/z+HajoFA9f++u9AfZlu+B+A5xj9aa3MhXOCoKkA9T1x9cGpAkX7ox97tz1HU/zzTVXDsfvdwf7wxx/T2/mULZKliN2M/X/AD/Pt2pcbEC5284BI7d/5H86ABX2I3sCc+vr/n/IQDah6t3570Bcx4Yc42ke/wDk0uWPfOMn/wDX/j9aYDEIXb355OOn+fypxbco9Rjt0P8An+VCco21SOg9Mev6/wCe9LEuR0bao+u4f5H6Z+jAU/KV9MZbH+f/AK1IfmYZ/wB3A5Ht/n+dLGzOpY/e9ailbcSOykDn1/zxUgQ9EC/dOBgc9Pr9M/kfSnHY8qjuv8HPP+cUgAByvsenX/Pb/wDVl8agSL6cZ9c+vX6+561QEn325zhgDj/P8+9CFWkO7+I9Qevf/H8j702N2Z/u4DDpnp0/xPNOhblv8Oo4NIBJcspLbdxJP4dv50ky/L06gZHp/n+tKx2RfN8xzj6f5FJKD5YXspySOh4//X+VIBpDKYy3XHPGef8A9ef196AF+X+I45/x/wA+lSP8+3puGDj/AD9RTSAH+mQSD/IflVAAb95htzKMZA9/8/UZpNm5QG27SMnAOD/nrSscEccscHsTg/5NLn90Mfdz0AxgdP8AD/OKQC5xuUDPTknoeOKHUhlP6+v4/wCelAB5+9kDPT8Tj/PahDtl6YJHJz0HT9f89aYDsc5HIIxzxjHH9abEd8Z/iwT9T7f59qF44x82AeB/n3pyDAZlXtg/Tp/n60gI/KbaV3bhimmPJGOw59WOf8P51Jhgm7uv+fWnMMEE/kP8/WgBNgTBDL16f59fX6Uq/vF5PysTSMWBxt78d/SlA/eD9eev+c/nmkA3Hy7sZY9fY/5zSFfMj2+4bnv/AJ/z3p29fIGfujv+PNI7YX5jjccnj60wGk/KvTdwFOeo/wA4p0aZ2HLfu16/1/8A10FSsm7G1jgEdM9P8/h+aoNu7ng8A+vfP+ff0pgNK4PJ7BTx0Hb8c5pQMJt6DvgdB1FKp8tPu9Ovpz7/AOevajdvTJwGAJGR/T/PQenEgJuCwjdz/n/P5U7AB+XG4ds9eaRRtA+UkD1H3cnn/PtSBtg5/iBOM/5/yfxpgK5Df8B6n69D+nHvSEkj+HpyOT24/wD1Uu7dJyPm6Z9f8/0puSG/HBGPTn/PfigBSMREL0U9euRyf6U0JkKBux/Fk9D/AJ9KRJB5Y3Hp3x0/zz+tP4Iz/Dg49uwoAYx2oP7q9MZ+bI4/z7/k9wAPXdnOOBnt/L9KApchieG4PH179u9KuFB9cjkjp9KAFLfPz0wDzxnBz+tG1RtPVc5we5/zxikV9w/u9AMmlyXX5R7Akde1IBu3lixOeu4de/8An/OaDECf0xnGOv8AjTpWU7j/AA5x+v8An9fems25mXG4/X9ev+c0ANjHyqzN9775H8v5/rVHxT4T0nx9ok2l67pun65pNxzJZahapdW8mP70bgqfxHGKuRkAf7THj0//AFf5+qpwAc9PXqQBn39D/wDrNMDzuL9ntfCKq3gnxR4k8HqCWGni4/tXSmIAwn2W78wxRj+5aSW/19QeL/iF4JkUa14T0/xdaDCte+FrkW9yowcu1heOAF6HbFdSueykgbvRVyuCew+bI/z/AJPrTm+Z16/KOh7/AP1/8+1KyA4/wl8b/C/jLXV0mHVBY63JlhpOqQS6bqL45JW3uFSV1BP30Vl56muqkPk/MzBFiXLFuNoHUnPp3HtVPxT4O0nxxoUmm65pWn6zp8jZa1v7dLmFj2OxwRx2PUH86+a/28vg74g8Ofs1a1pfw5i8aXkOsbLPUdIgu31KyW0eRVlBhlMl0iFGPyWRHCkbQDkmoH1AH3oCuBuOVX9cf0//AFVxPx7t2ufBOmMp4tfEOi3LNz8oTUrc5/MdPT64r4d8HftZ/FT9mTRrFta8VWfiCxOTHpWu6Zd26xx7PuNdXKRXNvtIbaWW5z8oIUZY+62H/BQb4cftKfBu+t9L1caH4oja1nbQdX2wXjMlzFKfJOdlwpCkhoixwOQGyoObQrlfQ+oY1EijB4XGB6VJH8zjtuJ4/wAK+Yf2qP8AgqV4F/Zz8S6h4d0mGTxh4t02V4Lu0hu47Cz0yQdrm6l+RD3wobO1h9/ap8j/AGfP2xfi7+0X+0R4bvLKSXUNAmkuUltdM0a7tfDmng2zhGuLho2uJ9sjIcSLAu/aVYJnA5JCSuffyDEX+0vAHr6n9a53xR8XfDvhDW20261JbjWlTzTpVhFJfaiUxw32aFXlCnj5ioHv6ZVl8LNR8RLu8VeKtU1cshRrHSg2i6cScgkJFI1w2RnKy3MidcKK6jwx4U0nwNoUem6Hpem6NpcZMq2thapbQgk5JCRgLk8knHOOaBHMS+JvG3iiUrpHh7T/AAza9ftniC4+0XA/2lsrVyrKePv3UTjunaiT4HW/iN/N8Xa1rHi7hs2V262+lAN1Q2cASOZfQXPnsAPvc89v0fv09+Mf5/znlekhAHyr82fSgCrpGi2fhvS4tO021tbDT7NQkFraxLDDCvYKqgKo+gAqwFypYHpyD/n/ADxTtrKW/PH49/5UKdwwBlSfy/z1/OgBP4ef4sg9vX/DFM278Kx3cYzg85zn/Pt2qQjI47gkHFOHzt+HX17/ANKoCMJmY8ruY4Bz9aahDRY24Vhn/D/P1pyZ9vl7dc0JyF5P4jOc/wD6v/1GgBFRnibvkc/j/nr/AJKnbtz0XJAP+fbFJ1i6ZbAAPuP8470spwF6Hofp/nFIACjcct3yRyfw/nSxpul7Lzk/Tp/T8v0VBy3X5uD+fTFCLt3blxklvqOKAGqqj7m35hwfTHP9cf5FCglemQf1pYwVDexweOp7f596Gfys5z2xn8P/AK3vQAqjDdfck57Y/wAf85ojVsds4+9+X6f59KcrbT3PP0xTQfnZTwAoJFIBGGxmYdehH+f88/Wli+V87vm5GQM9P8miNWd/u/fx0/z/AJz3pqsJTx8ynB/rz+dAAqiKJeMZ46HgD/OP0pWXKDP3umM9e/8An6UrDeuOc4H+f5fpQBlmPbjj2oAO5+bHPr1/z/hS5AP6deo7f5/nSAbj/dC9cDr/AJzTkJVyuBnsD7c0AMVcj5sdMNk9ee/6f5zSqfk25+n0HtQBs29fl9R3/wAilDbgVwCPr/h/SgBJCQvynheQT3Hb8P8APahl+UjPy44J79f6U05A6+3QH6596aPmdgu7pyM/5/yaYDwcdB8uf170LyOMYJzkjr/nmiMnBLc7hyf5n/P5UhO056EjoPX/AD/WkACPJVcfMRnr65GP8/rTiNxGW3bl75/z2/SkPzFcL93I9ABj/wDX/nmlXHXr9B0x/n9DTAap3MzZbao6jvx/+qjq21u3occjvj/HtjpQCQMfNu65wKD8iHA9c+1ADlIG5s/n29c/nR95l9/l+h/x5/l9aC20BfvdCM9D6/lx/k0knEYJ3N8pznqP/wBX9KQB/rD7N3x9P8/lSpyM577W9/8AP+cUbjGRnKt3IPf/AB/woUBozjoQccdBjn/PvTAklOLNmX7wGTg9P84qrFH8y9l9T2/z/hVonClccfTIzjFVwhzjpubpj8T/AEpRAcwyBkbuePb/AD/QdqB8j4X+Lp6en5/5+rmlMac9VHI/vYP9eKN212+XsMcdDxzigBi87m+bcTx9B/j/AF/JFXCYX5unWnfMC5+7z1Hpg/4/rTZF+ZR90lSDkdP8+3p+FMAMnB+XK459vQk/jz9KdjZNluo4P+f8/jmo5JN6/MPmYjIH1z/nHvSh859Tx+P+f89qYEiA5zknGDkH/P8A+qmKOGP3FxzjtThJmbHvjHvSZGwL+A/x/lQAhbg7R8vc9h/npT2O8qvK+vt/nmgNtVW9e/ue3+fQ0qvuI/h5ye4AH+f89KkAxlf7vIzjHJ9fw9qO+7tgk9PQGjJbaMMuG3Zz9f8AP4U0MCVb7obocflQAq4DsPmOCM+tKBiP0yc4/wAe3+cUFi8fopPAJ9x/9f8AT1o+868Enng/5/zigA4Yrtx9fU8c/X60hlVu3y4Oe2f/AK3BH/16SUlBuXLH+ft/n1oWXEq8HoDkdj3pgOPB6dSeT3poRcfKp2sP8/0/I/WgtznBXkAAfnj8f8+tBOSwHqeM4+n8qAF+8PmH3j0HpQEzuZfegrg7u4PcYyR/hz/nFIW3uv8AFtHTv9aAHF8Tbv4WwSvU/n+FJnaPwx9f89fwoH31X1PymlWTzN3uQMEfh/X9fzQAOASenGBjkfX/AD2pHGU5HDDJ56H3/E0A70YEfezj2pMl25yeuOOuKEAb8beMsuCSex//AFc//WoRf3vt057/AFP+e9OJwAfTnjpn+n+RTSfLl9jg/wCfpz+lUAMcIc85649P84/OkY/KccHn+n/6/Whjtj29G5OfT/P9KCQnmbdy5JP1P/68UgGEfvFA+Unk89O39f8A9WKbHdRxOo3dfQfdx/8AXI/SnMeT97rjHr6fl/Soottyhbbt5OMfU8+noaYEtrdR3J3K33sAZHTt3/z26jibJx059B/+v2qs0Sl2DfeUY5/z+H41ODuAXbg5Awe/+efwpAOUBScevzDP+eeaHZWf7o3DGPf/AD/nrSRybR3XjOevP+f5fmqt3B+6ew/L/PvSAGk+fb/CPu/l/wDrpM43E/MO49cUmdpYEnbg8+nWlH3OeS2fxFACKuU7ex4/z2H4/nRnA9h6Hvg4P65po+7j+92PQ/5/z7PYeZuVuuf++T/n/JpgIr5yoye47emPypSVMmRnafu59yP88/ypG4y27G3OWH0//VTim4qR1HGfr/k/hQA3BbkELkZx6/5/wqM7f4W+9xx3p+8DaRypGc9P89f1pifuiWGPl9scf5/pQA6OVwNiSSDdwpViM/r/AJH415Z+1P8ACLwv40+DviS41Dw3oOoXUFsbmKeewheZGUqSyyFdyvtBAYNu9xXqagDavPA6jP5fyrB+L0DX/wAKPFFvHuVpNIvFjKjJUmB8FfcEgjHei19AbtqcKv7FHwptvihqXi1vA+i6l4g1aX7RLe6iH1ANJ081UnZ41kPUyBd5yOcAAeqW0CIiQgFYo8KiL8qqOOAOwHGMetM0i6XUNJt5lbKzW6MGB+8GUEYP+fyqVE9u3HGB/n/PrSWw9tCbBMfPHGDwOvTj/P8A9YIO4/7K5+UfQjFBbYD/ALPQen+c/rRnLHK8jv6+n0o1EAGZPlHy9cH/AD/nn0oA2j2zj+Wc/wCe/wBaVUJKj7xzgf5/OlQr5bNuJGcH3x7/AOe1AArgH6HJz/n3pqnZEuW9/p/n/PSmx8Ln+8eW/wA/5/CnLtyf7vb60wDGCq7BluTg9Dxj/P5UAbjz/njj9KNzGUj+Lvx0zQNpbpu46H0Ix+NIAVQQynnrn2+vbsaGJJxgHcOQT3/w9/Sgtudsnv1x+H9f5UDhc46kgD16/wCFAAxHl/Mc7R1P16/nQ8YaT5uBz+B4pZGxGme/PPUnr/TNHBcD1PPue9ACNwm44+bp/P8Ax/KjdjczZOAOB/nr/n1ojbPA+XIxk9uP8mhW+8wBXnsPw/z9aABh8mMZ4IAz16cfl9TR91e57g/hS7/l3HBUcEe2P8/maZKjboyrY2Yz3z9f5/40ICQHcf4fmGcA/lTdpIbjb04zz/n9KM4X+LPfJ/D+n86UHB7fdBP6dKADrtI4DcKM+/8An86RjkZxngf4/wCH6UOwP55HHtj/ACKaj5j4XjhTz16DrQA5HGc/e2/qMdf8+lCKEIVefTPQ/wCeOaapUN6rkY4/L9MdfWlCbht5Xbz6kcev4/j1oAcq5ZuvsSe+T/n8fxpRhk+b5emMjGM+v8vyoVgWx90d8DpSEk5Xt79uT/k0AIy8fd+Vu2Op5/Xj/JoALn7oPpjnNHccH5sDvzk96azH5efvdsUWAcZA5zu65PPGOc/59MUwNlZIx8zZAYZ78df0P4inZ3tuOd3YY6f56UuDtA9s9OtABt3t+Pfv/nn8qTI8wdc8H6f5/wA+yKd8OeW4IpxYNITz8p5IH+f84pgBby23Z28nnpj/AD/WgkpJ/TPX2/pTYxuC/KNwx9D14/Q//X7KOYxjO7k+46UAKg2xKwH3RuHI5/zmjIxnjH06/T2/xoXay/Lnbjv29/0HNG0YbqdxGOM4oAQ9l6hue3Xr0/z+NKDngjB7e5/zj60FuSepYZFAOXbjjJHTrjt/T6UAD/KZPfOeenHNIx+9nByNze/p/n69eBSbi0WM/eHp2Gf8KA4B3ckH17nH9MUASJJkZ2/l3/z/AE9KAu8q3btz0pjgRsv95R6df8/59aUybmLfe4P8ulIBwKtFnl8Hj39qjxksWz8x5556f/WFMTaJ923nB7duAR+X5Y/ORJRK2CeoPXvnrQAuCAWxtJ6HPakkiw2P7uSQD/n/ADn0pQ27Hzfxdff/ADj6098AfeA3Y5PYf57/AEouBEUXKj+FcDHTHH9cD/JpqD9825slMA8cHt/9f8epqYnBx74+hH9elRhhnHZjwQfXn/P0HegBqtv/ANkE4Pf/ADj/AD0pcs7bm3bWycdSD/nt7fhTU5Qt/F1/z+FBkLocY5PIB659P/r0wHqdmewBJJ9PX/8AX6fhRGNg9Np7+v8AOk25PysDilbt13HI+n+f85oAcFJbbu5/hY+n+ScfSmquFbsMcY7fTFOWUb2VSC2eQO3+cGkj+7kY2N93tn/PH/1+tIBAcj7o+UcDNGdo+9u24P8An8v84pUfjPcEkj/H8s//AKqceT75wD3pgNDDadvqcnHX2x+VDjjkd+p7nNIgDjjGMZLY/wA/4UKcS7f+A+v+eooAc3znGVODjn8/8+tIqeUq7eGJGce2OP8APrQ2GVT03AgHPWlB+YAttH07dePwpAD7c7N3yk/Mcfdx0pjHI3Ebfm9e/b/P60uN23I7EHnkY/rmnbdz7ejdMe/+QaAGx8JtGVxjn/P0/SlY7F+nTHr/AJ/lTYpFkUyA/e5PXjv/AE/TFPVPlZv4l6/nx/KmAMNz+i4x7ZH+cU0cAN0UnnjpTm4b0x6dvSkZ9zdOMZHuO/8An+lIBQcpyPmOSc9v8j8s06Rcq3zfe4B+v/6qY5O3nv1yeeeD/P8AGnkMzjB+h9KAI5U8tFccc9z2/wA/59WP84b03ev5/wCf51YGEGc7cds+tRNGfMXvt7emM+3TFCAZt3Da2DjgDP1pIgqHCjbuGDnnrkk//q9fzbKGEZAYbscZHr1p1qGMRaQ/vFyOPXgf5/GqAcAHH3eXOT+Z4/z7fUu+Zl+Zu+Tx9OaUrhe3t6eo/wA+1MjOMNJtBJ+uev8AjSAUNtZjyduDk8Z/H/PSnouAMZPOfr/nH6U18A+px/PPf/P9aB06jnke5znP6ZoAcoZ41xx8o/D3/wA+tG8Mi4/hPp2Hr+P9aQKNpH3Sp+X8uP0p5OIwMd+5+n+f/wBWaQDViwNpzzyff/P9feleIH19M+5/T/8AXQBsO77vPQn/ADz+VPEa7z2HcY6e3+fWi4DACMnPzc9eM0PH8smfvKvGe4+v+NPDbe46E59P8/56cslk3Ljdt3EUagNY8dSvbB75H+enfmk8vn6c/XPI59eaVyPI9dvc9/anbtjbuOmfpk0AM3CTPGRgdRj/AD+P+NDn5xnO0cZ/X/H8vycT1HGM569PT+tNY7slei5J/LnNMAw2WyW+bGeecdvw/r9ac3+rz94njHQn/OP89KCAwK7l5wCD6/4U5WYpHjow4zSuA3Y27264/OgjcMkksvB/QUvl9fu7hwfYdKcpwSpPHTHr/n/GjoA0/fbdn2H+H/1/agD5G25+XofT1/L+lIMsD/n1waVR2U/e5b3/AMn+dACEZVT97HU9h/n/ABoDhW3c/MdxPoP8/wCRRu2Lj+Y9P8570Y2tj/gK+uf/ANYJoAAdg5PJHp+H6fpToz6H7wwcnpj/AD+lNY5BZemBtx+lOB2p6tgY9+cigBqNhP1xz6f/AK/8inbPkzwBz/n/AD6/WlDZX+E4znjp/wDr/wAfrTQuFX7vzcA59859/wD65oAUfO/8XzDse/8AkU0Btv3u2Afy/nx+tBbMnXcM8j1/z0pyvyVHysoJyB0/THf9fagBY8YAztbGOn+fb9aTgoF59Tj0+n+en5IxyFHp7/59qGbOcj1yfb/P8qAFbnG71/Pof6U3cUbgHcvcd+f/AK9Kz5wM45+XB6ev8qYcOOcFf5dP6mgBzcE85GQFx6f5/l+FHLDg5yRg9AT/AJIP+c0uf3ec87uOev8Annr6elJJGuBnndw2PXP+NADVGEVW7nHp9P6USBpI/vEbhjnsen9c8difwczMsSs33lOR+XT+f+erQNjqrN908n05/wDr/wA+9ADgctwPlXtn9P8AP+BoZmwSv3ugJ4z9P8f/AK9CjBw3y5x+H9c80mfMjYdNxwD6ZPP+PtzR6AKR0wG2qAB64xj/AD+f1Mso45b1Pb/Pv6U4FWbpjnBH9PzqM/LEN3O7IHv/AJx/+qgCRhjjsvXPekA78f4E9f6UhkUzld+0Fh1HTvQgyd2Nu0nP09v8/TNAAV8tf4vUZ9ff/PehkBY8bvT24/l/9b2pVbdHx+GD+H6/5zSOgVRuG3bjAJ9P/rUAClmj3Z/H9acygMGU/d7+n+cUKdjFuhUcDHTqP60A7SO3XI9On/6/w9KAGlWUbfXjI/L/AD+JoI8zd838R4B+vb6804knH8WDgn0prYWBdx+XB4+mKABV2+qq2RknOf8APp7ig4IXOfmHY+9KSFdm+U7ckd80obdJ8vzcjt157/TFADGPmSnJ9OvuPT6H/Ip5bjGMgnHH5frmkz5xYnnacZPPPP8AQD65/GlDH5TnBz6jHp+tADQPk+Yfd64P+fahVLMu77y88+vp9P8ADvQ7YgbB2tjgnjH+SM+2aGKo237vXH4f57+nvTAMHauT2C+vTH9eKbtJZfm6nrn9aPM3t83IGOAevp/n3+tOViDuXooDfUH2/wA9aQFdTnCr93PQ8Z7fywKdAnlvJ95u+Sfb/D8ASfwLiAo7EfdU8gH73+ev/wBbio0nGWA2++3nHvj/ACOD9KoC0vDMPvFjwAfTP+H8qeWVk7deR6f5/rUURxtXuTjrkc5/z+dDFZu5Crx9PT/P8qnqA5pMH3/h/wAM0AKHH3ecYPpj/wDX+v0ybsuqn2wB3/zz+dCfK7EewB7dOPyo6AM2YT6LwBxmkCb0xx9PTk05yqRlSDtAH+f1/XrTQmH2/wB0+vGDyP5/hQAhfKZHy5ODnuPT+v4/jSqSTyQDjtzxx/n8e2aE+X5uPlODg/09BTlO4Mo3fL0P6/4/rVAJgD5m2ruAyvX/APX1P4Gn/dT5h8zHgjn2/qf84oUADt83Q5465pDxtbDbsDv1/wA+tSAqPtJbFDDcMfe2jgjuM/p1HNRkqr8kYxyPQY/+sP8AOKdHLvKleuPUdeeP58UAAG0sM9sD6/5/yabGeN3uMZ7jr/n+lPAVRg9DznPQdf6/rUZUgN/Fnj07Z/rTAVV8v0bcOcdv8/0pzEqw6cZHA69On5/5601jlcZ9SD6f54pysoGcd/qR/nP60ALtxtA+XnIP5j/Gkb5ZDxnB9B8v+f8AH8URNp4/iHQnOKUOHUZxjufXuP6UAOSRgGbj5T2PXn/CjbtK8fKQSMdsf5//AFU0EqmOvZue2KPNX+L+Lpz1P/1utHmAIvcnOR/CPbuenXP+c047lY/mcnpx/n6Yoi+SZezZ9c4x/nj/ADhqOqydeWAxjjHrSAbtbY2MZXP4/wD6sVJH8v8As4z7475oJzzkqGY9P8fbn9KQDaBtVflHHt/nPagB7Dc+31Ofw4ppX5xk7tvTA/z/ADo+UyfNxkYGBnHT0+uP1oOO4PJwff8Azj9aADy8ovv2zxTYmyFbjHTIOfahhhTxwAP+BDvzTUXbGcr0wD83X/OKoBWG3C4yM59Mc/8A1qBGzKobDfN0PbNPEYU478g+/I/zx/8AXppVpsenoT16cfTr+VIBc/Mz8Y+nX/OB+lIHZzzg88nHX/J5FKsnzYHY5z7f5/l3pQdm4j8Gz37f/roAWNSo5A684Hc5pR8rcr97Jx057/5/nTdoK7ewxgevt/L8qkzyeCP8n+frUgMwxj3fePQ578/5/wA9ZFX5sAdOB/n8en8+7SwEm3nHAx6j1/nx/wDXp5k2SbsfMepz/n/P6AEQOS2R6tu/z+P50j8k9CR8v1PX/P8A9anKwC7l5HfP06/57Ux18kfgOT685/z7UwDG4Y2/L1HP9aU8n1C4IP4H8v8AP4NzsX/a459P8/8A16eqYyNxwvTjGP8APP8A+oUAIcqzYxuXn6/4UAYfp1xu9eo/x/z0oAXe3G3jHHUD/PFAcmMsF+bdwP8AP4frQAIjNGo9e5Gew/8ArU588duw9scf5/zhpG5Rub5ecHPTjB/kDn/Ghiwxu/iOfb/PWjqA4NmTGfcY78jP+f5U4/u2VuNvA6ZH+ev5+9NYjOQd24Ej+VOVsN2PfPrSAYg4OV7+vX/P9KOrBV74x6Dt/Lj8aM7F+8Pl+X0zn2/z19qazAIG5x0I/wA/lTAMc5X+ID/9X15/WlC4dl+82cce3T2/rQ2Ixt/u8k56f5/pSgbCq52nPI9PyoAQDewOd3PJz1H+T/nrTmJZePmK56DnP+f8+rHbaGHPy9BnrRJ8sfA3MPU8noR+X+fWgBS3HPY9fXgf4UDptLdAOf7vbNNcblwoHXBOcY56U7OxcbenBzxkjp+tADicHjAUD5SO1AyhHtx+R6f596bgqW7A4P1460B90jN8pzxx0X/P9aAAcgdMY/z/AF9P8XDg8Ybt0/z/AJ/Gmnn13Y79s/8A1v50Ngp7cYx74/r6dPwoAHy65+UtwwGOvv8ATpSOTs+nP69P8+tOU5ZQfvL156jPX6cA00IpVgT1wDzwMcdP1/GgBXBJb+9z+B9/r/n1oP3m7FskH09SPxx+tAzj5h83ft/n/wDV060FsKAOOg/pQAhBZxt27h056Hr/AEpFbfyMbVOR/wB85/n/AJ5pwHf7vH+T6fjQuDBxn5ec+vH/ANb+fTPAAfMoyo9Mc+5/z+BpxfaWxtyBx7fX19/6U3hmHVfmzz26dP8A6/p74pV3NwNw25x7f5/p3oARVO3/AHe3+fx6U2XhNv8AFj5snBx7/XpxSmQiPow3A4/Mf5/WnnH6cDutAEaZB5P3j2H+ffj/AOtTm+7uP8Ix9fTrQoJcj26ZppdfmJ/iIz7+n8/1oAkC4BH1/I/5H5U1izjt7c/l/WiR9qYGEbljz06dvy//AF01lZm6bfRfyzQgHJzjbx/SnMCHJPTPI9aQ/I6hfXP9abtwny9cYAPb/PP5UAPTP+e3qf0pCmUP8Puf64/L8KQ4DH06knsOn+fpSlf3J7FeB7n/AD/KgBCu9FOOFzjvgf40Fdp+X1wPXqKDxN/u8nn7vt+H58/SlJ2yfd249+n+f1oAMZA98kAfn/Uf/WpJFIiDfxZGP8/nSttC5K8KePfOcj9f89KTzhFGG9CD2570AOlXaV7Lnj8eP8+1NX5j+uexx/8Aro2/mOCT/k/X9fWlU5Pyn+HGe+Pb/P0oAQMVbd/Fx1zzx6fh9eDQoIUnb/CQRn/Oev8AnmhRkr2H04Azn+nT/wCvUcaZkZlz1yFz0Pr+gGf/AK+QB86qkW1VOF6DsBTLhfLjXjbkkHsc/T/Pf6VIZMqBj5sbh9f6f/Xo2fLtx8vTg9B2oArlNvyn659Ov8v6e9Pj/dSbfm7EcZxgn/P0pkg3E8bugPHUdqaB8/PVhznv2Hf0NUBY3bx8o2ttyOeM49e/Qfj9KAP7v3cgg+uf/wBf61Fu3DHoDnjqOtKJD827gLjB7+/1/rke1ICQL5m0YwOwA6YIpMsxBG5eMAn/AD9eaVTyox8zZVVz6daRjz1xjnryeKSAVWK4G35VUEn/AD+NOYeYjMPm4H0z/n/PFR7RjnndyQBnn3/X0604r5SlVOCzHB7e36/0oAcysBn5uFPA6N6f4daHzID8u32/D+X+NN3A9RhWJ4Hcdev+f60hkXG7rzn049utMBSu92H5ce2P8KgJ2/8AAm6f3eD/AIfjUu351GdueF7YP+TTZVExZf4VyrLjoMnr6/5/BAB7K2fxP3v84pVJLKrdTyOO/ekVXDMuM9eP7xxz/Q/hRGRz83uAB7/WmA45Y4565Oe3/wCrFJ5uzYrEbpBwvYnjj8qSP93tydq+w+h/yKAN02V6qO+ODTAevyE7fvYwOfu/5/z7IHLtn+6c8dabnavzfxD/AAyP8+tOAClQeGJwB3P4f56H3oAGOA2P4hj9OP8AH6Y/EIbKjp1IGf8AP+fWmJJtVdpyrHPHrnj/AD/9fErN83vGuOv+ev8ALntQAgUlsfMPXPHHb86TY27+8RnA9eD/AI9fehC7bgvQYA4xnn9KRZDu+X7vTPuf8/rQA/O1tq/wnbyf1o3NlSyYwcH9f/r/AORTTx8v+c8UL/q19uuMUgHEMFwflOMZHvTgWVd2Oh5z6dP8/lTcqzHOGDc49e/+fw/FsfyjP8JXGfTAI6fiTQBI4MkbLtbuePXj9R/nFNhh+zKsY3bUAwD1OMd/wpQdkOc4xw3P3R/9amRuZIQW28jOVOeD/TgUgJGZlLL1POeePb9c0MMnoMYx6Y9P8/8A6qCNzZ+nOewxSKMnaRg5yeOe1ACOo8tVX+LnGevr+X5dPxX5gufvHHH05OP6/h3pm35DxzjaBjO3nP48nH/66cxz7fN83fr/AJ/zjFADtvH+znrnk/406N8Hv1wTj3P/ANf/ADmoz/eb0GOe+f8A64NDSZ6/dXII9ef5dKAJEY5j454JPr/n/wCvTt2VbquBxj3/AP11GQSVbs3twP8APSlWTJbrwc5x19f5/rQAik4HXc/H/wCr/P8A9eTG9lyML1Jz1HP+cU1iyIeyjgDqfTj/AOtTVbHzbRgDnP4j/CgAiDKu7a3y+p9/8/jn3yE7eu7ap7fz/wA/pQ54HzYAPp69/wBP6c0ix7ucdD0H+f8AOaAFJK/RuefWgNsHH1Gfr/hikUYXduU84z6HHY/l3pWcr06tjI9CP89P5daYCgfd/h5yR0Lf5xSl+F7gc56ccfy/kaYyMm1cle5IH5//AKvelJLDt83APXt/n6/nlAOjLAMDywOQM9c8f5/yKMbnOOpyBzjJ+v65/wAluN/XcO5z/n2/yKFYhW3Llsc9+/IosAO2xVVTwfTjHPU/570khx8mO5bpjp/+v6cUFAEb+9jHTtzxSH7yrnvz/n/PWgBWyeP4sBeuT6/4UqSEfqDx78Z/SmJIzf7rYx7cUuF8psNtUjn/AGR0+n+fSmAK7bctwTwD6/560MmD90sewHUf1oI3bhtHzcDjqaIxtj5LEFe3+fxoAcg5C/3jj346f5FGOF4O7p6+/wDn6U3DInpnsB26f5/ClBzJ8zBRxxx68f4f4CkAAFArdCR8uO/+c/5NNDEL7E5x7n3/AM9aCNm5uOO5HHb/AD+NIsR2KMe+QOnbp/nrigBytnO5WU5wMds9f89eadu2sB+p9qjkDKjNuXoOPX/Jx7dac42D1C8jjn/OPx/WmA4HDL8p64x6HoKUO3ynH3hnr9Rn/PvTH4DZyW5xx1OfSjcULfxAEEAc+n8+lIBzbs7gPlbp/n/P68innO3oOufX+VNZ/LfcduB1Ud89O/0NCOWkXpjv0P50wHEA7ucH+H2PT+ef85oB/djn7o6E9B/kf5NDAMMdiOuc/X8ufzoV2A/iXIP1HelqA5flb/ZYY6dKRjhcYP0HscUgJz/CAx6HHHB/w/nTSWXHPAX+X+TQA5m/eleepyRxjp0/SkL/AC8fdPPrj/OMc+lI2Hjz95eo46cUAZIbP8XX165/SmA4tnszfp6D+tNJ2HP057n/APV7elNTJiHct69PxpXO5l5+VBjB78jr+v8AnqAK4MbfKPu56nsB/T/PpTj8w+b6YoUbZFP3sqM+/wDnmk3YCrz90/jgYH+e2c0tQFDFj+pz29P89P5UY42/xMcEk/p/n/61NU5kbrwM4xShCm3d94en50wAnCKp43Nn+97/ANaU8FgR93A/n2qMr+7VfcAHHvnOKfG7ZXHfJyccHn/63+eKQCmQlSPm6dD27/5+tLu28r/e+uOP/rf57RSPjKqNwxlaVUKs2c+m726f5/D6UwFk/wBXtHPI7/578UjzZG0q3QDGOvtTlG9PmP4Y680g5YfxY4/Hj/P4/hQAFyrL8u0NzjPT0qQrvQY+h/z/AJ6fSo24fHQ4yPy/rTo+dv8AD0HHY9aQAjFSWxwSMZOSVx/+qgAAN2wOATnvj8ep9/1pBwV/hGeR2A7ikIJUrz1wTjr6/wCH40AEbE4G37uM857mnIRnj+HggjjnP+IqGVm3fKeFOCP72eg/D/D8VB8w/e78EdKLAPkUbQemSCM9f84/lUKR7TtbdyQwyf4h/TpUxONrANxwCe/f/Hj2+lNIB3f3tvp9M+3SmgI9qjf+POOfr+tAcpbsMc4PBPX0z/8AW/XHD5Tgr97DZOeeRwf8/jTI9xHzNt2jBxzn1B/L+VMBsNwzxbmRlaRfuk9P8/T8jxVjJNwvXCjg/wCfw596hVinCluufx/z/nvS8KRtyVxj/P8An0oAldwrjt8+OO3QD+X+c01zsXd1GQR9P85/P3oeVtx+bjg7v1/z7VG8nHfnP4UrASl+Mclieg7ccfzpWYD5e3t6f1/+vTC3zAZ246ZHH+eRTvO2ZX1GMZ6dv8/WmA4rtPRuucD8c/1/KkDqw6N1OcdDz/n86QHy3XIx1B9v880h4bdkruYcHnHIz/n/ACJsAg+9ux+Hrkf/AKhj+uaWQYBbru4+Xn6fpn/INPV85+VvlXHXg/4f5602QeWG7t2Prj/OaAEK7i33vfPb/P8An1oKhmbOfUDP6f59KBkEDLd/w46/y5/lmhVydo3fQdzx+H+e2KYCk7Vx78nPX/OOtIPmlZSv+r6e/r/n/JSP5ZfLX/gJ3YPr/n6UIwdF6+gP9B+VAD3+dl9NpJP0/wA/oaRkUjnPcE/5/wA/Wl3bWj9MYz/n/PHvRGeOF3fxH6Z/njNADVTcxGeVHSnN8sm7n2yMc0gYPt+Y/L7Hn+vYf56uCqVxjhzkj/P+eKAEVAqZ+Y7Rk8YyOhoi+QKuWLYx/j/n0pu8spk/i6kf3ueO38vSjdjk5DY79D7/AM/yoAWSJd24feUN+Gf8/wD6qUSn7vt09P8APX8KRh02nJ9R2PXNIEw4X8uev+f89aQBK+1fmz6ZJ6H3/L/OaIlCW477QDgdPT/PsBTViwflGWQndn+Hsfy/T+UkW4BT8xzyO2Ppn6UAOEgdVb5sdz1OaVRuPf1Oe3f/AB9qYCBtz0z+X+c0hO0Ddnoe/wCP+fwoAXfub5txXPJHU8H/APX+X4A+RS3XaMqOn/1+xpm7+Hs3A54/L/P50qttHy/Pxzx1zkf5/wA5YEgUMnK/LjGB6Y9f89frQMsq9dx545/z/wDXppbduHU/w5HX/Oc0L8sm4fd2kkenP60gHZII7juB0P8An/PajaHix944wcjr/n9KApL/AMX1z+f4/p/QV/lK4+VjnHbg5oAczbnU/wAbdD/KgBWLd8jIJ/z/AJzTRwv8S4AJznP+f8/QA8zG7rnn9P8AP50APwGDejZx7/5/SkT5Tj72PmI9/wDP+fVoO4r/ALWTj+mfxpHkG7733mC4PfsB+dHQBQ+9S33uOuR065+nPWjG1fwxj0oeTO07jzzkfzoDYf0ZTxxzjn/6/FMAzkL97rx605YyxHddvBz1P+f8+rfM3Lj7oP5f5xTfNH3R16gd/wDP+PbugFJxL8vHfI79P/rfl3pw2qM7mz/Xv/k/pTA2RlfvYwO/b1/H9acDy2Oxzn8f8/nQAgONxOV3YP8Aun/P69KCvzbeeOpB69P/AK3+TRyyj5t3PXpx2Pv7/wBOlKh+baDwpzyOmf8AGgAJ/eN97k9uPU/1x+NLuyjdc4xkfr/X8qZGSSBtZeh6/T/J/wD1UrNjP0575oAXaq7vm9hk/X/OKEO4sDxuAOfQdv8AP/66HOC2fu46fzppf5mUjvzznOBkUAOzvI+9uXsBjccY/TmhNrP97cpA49abvzIY+evI/wA/Q/rRt+Zc8t19un+Qf50ADMApz831GPf8P/1ZpyDcOd2SSScdPb+dNQlvujrzjv0//V+VOcfJuU/MvOQOnTj8ev8ASmAFi3Xgqeue/p/n/CgH5m65zn69wPzFIWwPl6L8w/x/n+VJv2r8u7gZxnp/n+tIBWPmruGSfr/n/IP4rnKNuXgDp/n8KN2xmyzDbyfyx/j/AF9KCOOeMEjGef8APb8OtADQu7HB3EZ9ORTiQUPXaMdPX6e3H+RTXYfK3baTn0/zj/8AVxTvu/7zHPHemAMm/wCVtzccjjk8f5/yKAR83r7fh/n8aN247eRjj6dD/Ufl60gfcytj7o5/pSAcQMn7w3HJGenT8PSmKu4Llc8dc9/8/wA6ep2xtubG0EEj36n+f+eqZw2PoDz0yRn+ff1oQDX+bP3ty8k/j/8AW6+/0o+8c8jccEj/AD9aczfMGb3xx+f/AOum5+Yrt4wOc8D8P8KAFYgjOOmc8847k/lQCTuH3uhB/wA+/wDIfgP8/HzEdev1/wA/5FG7+H3/AA7n+ufzoAV2z8y9P5Dj+mfz+tIR8q7s44JB5x1/w/DFIp35POTnr/nPajdlNv3uex7c/wAueRQA5zuVevqSO/fGP896DjHAx3yfpnn/AD3poPmK271ySDxTs7j3+Xr157UADnaWyfl9v8/54xSFsJj+HOOO3b/Cm7vNfPPzcA564/zj8aUsUJ54Hp34zmmABsI2VbaCWH8/0oyFfd839OP/ANWaPNyg4GW6DGcDH+fz6U15wR+Ixn8cf15oAc2EG75uBzz1+tAOGXqDndjPAPf/ABxSh8q2Ox/T/PalDbd2M5yOPXpSADtdfT39OTx+H9aCzKuV+8wxg9vamxtgfL6HFDy7ZMfiQfT/APXQA6JudzblZeTg5/X/ADxQq4Q8lmBzwMZ9P6fjj60Fc+vp15PrRK5Z/wAOD/n/ADxQBXL/AN09sDnrznn9akjf6+v1qJn2YDbt2fyz/n8fbiljfAzj6fUVQE3LxHBB4yT+H+f84w2M7ivdmBOT2/z1/PpS4UScErjA6fr+FIW3Pt5zgZzx0/ljNIA2jc2O54A/z9P85pu7Ymd/bqO46d+n+fwCflI/hwMc8/r/AJ+nNOVAx2/N9TznHNADciKReTnqeM0ISy5bhvc9ePX8h0HfjigtuXk7Vz15GCf8KFbBVh8vJ4Hfp2z/APWoANuR+PHuO+PfnPH61DMGZGEeMsysc9/X8R6++KsEYQbmywGc+/I/QZqNR5i53bec/Tn179fxpgCt83VeOSvb/PAqTmVydpw3YdTULL5ZX+9njj+f/wBanlgp6kq2MnPb6/p+P4UAPd8lvu/Lnj2/w6ULhWOWyOpB9e3+FDRrtO3ge/Ht/kegppUyZ+Y4BLceuOn4UgHRnZGrLg4OCfU/55/Glzg+x5C+3P8AjTPMKDd97Lf/AF/546etOLbCp64PIz/n2/L8KYCffPYL6n2/z/OnoNoVvfP1H+f601EAZW+ZvbGe/wDn/OKDy3/18+vOf89aQDgflGCG6lTnpTGbJLbj1zkZ4H+f5Uobeu1f4m6Y6c9aakm5VZj8zHnnp6f0P5UwHYKhcfKRkA+3r6/5/MI/vHbwAO+P8+39aTbn5vu9Sx9DilH+uw35H/P1pAAZg5GWY47fj/j+QoU4boueS4z3zQBsGQDleMeuf89O9GfNUAds8DnPQ/rTAJG5A/hx6dOMf0prDEeN33uckZ/zyT+dOVPmwent29/856fWl8svHxnbjp6//qPFIAGXZv8AaIHTv2HuaR+VX7p5yo+n/wCv9aWMZI+bIYtjb3/yaVeqruPTIPqf8n/OaAI55AqbeeuScHnk9vWi3Km2X5l4HUHdj/Hryfeo762W7hZSW2yIUwP4QeP8/X6U61j+zQ+WNx2Dbg/7OP5D+dAEykJGP7v+P/66U/vG/vbie3+f/wBdNVQw2gfe6/zH+fenMNgKn5s5BK++P8/hSAYR83ygbWbp9Mf5/CmlBldxPzcNx/n2HtUp3Z647KP5/wCfxphgUthRtwegUY/z1/WmAAMZOOcHLDHfg+v8vb8SPlR04HUfT/PTpTd+RubcF6E9P845/Ojdhm3fxdfb/PP5UATK29edvynuOn+ev+eGFcH9c56UR7izY3H5uPfmhRnbtyQ6cn+v6/57ADt+P9nAweOmf8Mn8zTgWTjb8rH14/zzTPuIeeR1YDr+H+f6UFstgFsDOT6GkA1X2n72Tzz6/wCfz/OgbeV444Axjp2/T+tIy7SQudwHUHpSKucbjweANvrTAd52EZvlZmOcf3vT69vyoA/eLgdio479v89P0pFDIGzIx3nj2/H/AD/Klb96me/UD2/z/X0oAduDf7q9MduKUMYyzYKn0/pTI5BjP3t/J9/84/WjygJGb5sKc43HDZxnPOPzoAcw8gHb8yrwf8P509H2jcGB5/L/ADz+OPakB8sr8zYx6euP8/hTGXdH830znqBSAMFHUZ5xgd89qFbaWY/dIwcduD/n8qQlu38RHHr/AJz19qVRtIb5l44/z+XFMBygAFT83BOO9AbzF4I9OPf+h60xl279v8JxyaUFdnVuOnr0oAXZ8zY6npx2/r9P8k832HXjBycY/mOmO3FN3bFP06gevtTmPynk/h+v+f8A61AAxwWbjucZ/Q/lQXBOPvg8DjqPUfX/AD7pI2B3HTntUZDTHep27Tx049aAJTJv3ZYEDqR9O/0zn8KN+SqkDoRjPQdaYhUDcrZVsgd++Py/z24VjuVuemD+Hf8An+dADhwxbd/Fk8dcf5/l60HagUemCB7en9PzppOZPvFT24/PFBO47fmC4ween+eKAFZlCru+UYyR1PH/ANbvS72HVeQcn0//AFf568U1gYhl8r1Jx6f5z+VKikdflbAzz3zQApDHP0HJ7j1/l/nijfiLdkdznGP/ANf/ANftSKvloPUcf/r/AM96U8r8vfgYHJOe/wDnvTAH4JX+4MHv3BP170KA0jc4U4yff+g6fhTZOE6jcxHJ4B9h+dOLCKInr1yem73/AFJ/KpAczOV92wTz/n/JoKrjDcFR0HX/AD/L86YyLnn7vPB9v8P8+oXfsJwCeucjHsP8P8mgARgUXdzz1x1NIEZV69DgnPTH/wCqlO0j7x24BIz9aC2E+Xrx1HX1pgDLiTj+LJ47Hnj+dJGd3l5528nHYH/PahW3fxNhjx68/wD6utJubb7twQDjGOv+e2O3NAArZI+YcfhgEZ/D/AUAkordeMYJxx0/PgflSscOy9+56fj+n+elIzAu38S45Geox/n8O/SgBSu8ejYOB6c0qNwp2heenXPTj8KSJufqOvqaVWAO5vlYfpz/APWFIBudgG7+HPPril+4/HbHGOnr/L9aQKxXaOqrgfpj/PtSbGlA+Zto9OPT/P8AnhoBCS6dd3B78E9P8/5w4NuOf4VyfbP+ePzpxOS2eW4B45H+fSmqc7gu5ictjPsf5k/p+QAK7Z2jLEE8d88fh/n6UsRw6x53ZGAfXHB/Tv8AzppO6E/xDGcev+ePzp8iht3zf4n6flTAFYld2/kfMDjr7/p/nsLLub6HjnHfnv7H86SUbn53dfwpJGXB9F5PsP8AOf1oAdINqf3Vx+PrSkZmCgn5R+Z/ofb68UzkxfVRnHX1H9PegvuXlsZ+p7/560ANkjEkY3Kdyjb0/r9aFjBn2g7iOCfetJtBXO3zGxjAGPzpp0Ff+ejHb6j8Kz9oh8rKOFd9i/L/AAjPBB49qAylOMZAOOcd/wD6xq+NFVZS3mtjGOlIdAXkeY27BH3en+RxR7RByszQmZWYA55IA7Dr+HPb6fg7H7tSvUkZPouef0wfyrSOhoyjMjbhnkDFN/4R9XHMjNxxx36UvaIOVmccZ7huO/t/SnldzbWPydenb/Dirq+HsknzpCrdgABj+dOGhKvy7/v+3Jp+0QcrM/Zv2t93aM9eh/w/z6Uiw4OAvfP+9V5dCJiXdN+8OdxCYBOD05/r61INFUf8tG9uP8+1HtEHKzOYbF+Zhuzjpn/PcUksah1Zf4cZA9DV+XQ/MkXEgCLnPy+vp/jT/wCxFkf7/wBfl/8Ar/556Ue0QcrM9QuVycEHv+Xp9Py/MyBB6nJ+nOc/1rQ/sXAbMnXr8vT9aVNGx/y06Y6Lj+po9og5WZ0y73xjbu/n3/l/KmkCXb/C2M5XqM9Mf0rTbRFk3Ddjt93oKRtIVW4fH+zjil7RByszxhG/u8g8d/T60bdrBgVUDrxwOf61onRV3jDY5Jxj/wCvQNDUE/MeT2GOw9/r+dP2iDlZmYARRztxyW/w/D+f4iIoK/L2xjPTofwP5/l10n0MPkB2HTtTW0RW5DfXjr+tHtEHKyjjKf3eeB/n/PNOXMcv+6CB78/16c1fOjqDkNgZyeP/AK/r/Kj+xUA+8cA5HHA/Wj2kQsUNu51BzgYGD/F3/wAimqAw59evqK0Toy9d/OQc49OlDaKPlG7PXqPz/wA+5o9og5WZ2zf8zc7sgkjrjPP+f/1OY/wr/rG746enb8f88Xv7EXb8rfLjHTr+vvSNoas+RJ2x05/PNHtEHKyjuGG/udsDr/n9aRWKrjHzdOverw0MK/8ArMq3X5e/r/8AWpy6GvlbWkLdicdf8jil7SIcrMrzMpt/hYdfTj/69OL7wf7rA5A78A/1FX/7AUk/vs8f3e+c+tOGhjfuEuOOm3v69aftEFijE29exOOuO4AI/wA/WnZWNVP93HbrV4aLnpISOOMdB+dA0P73zn5hg4HUfn+GaXtEHKym5Uhv9k7T398fnj/PFBfIx/FnP58/j0x/k1afQ94Y+dj0+Tp1/wA/gKedGw/38egA7d6XOg5WUJBhVPXaO4/z/wDq4qCOXftU5IXqD2x/+rpWu2kq/wDy046fdqEeHlDcSHdztyvT9f8AOapVIhysojGR+TEjnPfH5/nTkGE3dvTGc88/z/mavJoKiLbvz77f/r05NFwvD8d8Dr+v1o9og5WZwVS+5un9085pIzlv1Of/ANX+fzrUGjK3O7cPpx/nj9KaNCCvy2d3Xjqfzo9pEOVmYxw3ct97OOh//V+tI4Ln8COnrwa0v7AV02mQnggYX/69C+H1G7azcnPTp+tHtIhyso7slWyV29j/AJ7+p9KaBsZs9FOemMdeP8+g6VpDQ1GRuPXjjp/nj8hQuhqp++ePQc5/Oj2iDlZnIMBlb6cfr+vr/Slkxu3bS3OfrwR/Wr39iL/FJnnI4xj9ac2iIyH5u2Cdv4dM/wCeaPaIOVlEnzB/e2jOew9eKCQ6Z6bv0/z/AJ9avDQ18xvmb6U6PRVwPmOP/wBXv7UvaRDlZnE7ZOn3QMAd8/05/wA8UjICzLuy3bjk8fr/AJ+taDaOrNu3449Ov+eacujLGoG47RnPHX0/pT9og5WZrHLZGCeuf73pQEXy/X0wMEA5H5VonRUORuO7tx0P+eaVtFR2OSzeoNHtEHKzMHEuONu3JwMe2KfGN42nbubPA6dq0F0hc/NIzdO3f1po0RQ4Kt93HUUe0QcrM4LvVsdyeSP8+3FJsyTnP3srntyMfru49/Trpx6MqLgMfbj8f8/5NC6Kqpt3exwOtL2iDlZmZATjnnKt/eB5oHB3Y6Zz27/5/StCTRo4gF3ONxwWH8JPT9f1IpzaGuF+Yrjr7+nen7RBYzl5j298gdP89QP505F/EtweOc/4/wA60ToyD/lowVvam/2Pgt8/ORjIJCjv37889s9+lHtEHKzPB/eMdvzKRnA6nt/L/PYHEY2+nOe/+elXxpEdtEP3m3kDcRye2OvfIp/9ir5eFb6ZHH86PaIOVmWkWw7lb/ZyP4APb86k3AfN94dTx0wM56dODV4aGpU5kZl3ZGR+ffr/APW/Ff7GQDhu2Bx0pe0QcrMyVM+X97dHnJ+v/wCv/GnCVVG4dAeu2rlzpKwRHHzbmC42/wB5sE/kc/hUp0SMj7xzjGcU/aRDlZQKhWT723geuev/AOv8vWmwLjGO3HH4f5/KtIaMm4EMR17U3+w0C8SMvTkUe0QcrKayc8H7oycDjGP8/pUcIyoHfaAeO5xV8aIm8N5jdc9Kf/Yy9NzdsjHWj2kQsZx2g4/EZ5/zjn8h+KF9rKDgeuDn36/5/CtBdFUr947upOOtL/YsZZmZtw7DFHtEHKzMDbFUD72MA/oPrzTlX5eOrHPH+P41onRUJ+Zm4II4/H1+n6+tKmjRxnIZuevvR7SIWZnjajK23cFOcD/P8qaRhvm4OB2644/z+FaK6MqNuVsEegofRI2x8zbRwOO3ej2iDlZQiPPTPrnjPFJImxVXHfI98VojR14wzH0yKaNGBUHzGDddwH9M0e0QcpQbaRgt/D8xI6HI6Z/H9KQYRFz95fb/AD/n8K0H0RWU7ZGXPXA6dP8AP40o0dF3AN945Bx0OT/9b8vwo9pEOVlAMBJu98Dn/Pt9aWM4OGPfnjoc4/8ArVf/ALHjV9wbHsabHoyoVO/7vt1HP/1qXtIhYoufmHy8t79Tx/j/AJ7ICrt2XjPHrxzV8aKp6sTnqfx44ofRxjhzn6U/aIOVlDGF5Dc8fhg+3+eaCq/LlccZwOw/z/P8KvJpMcuGSQFWUYwOCOMEc+n+fVf7Fjf+JscdsHj/ACfzo9ohF3H0/Kgc0uaZI+xGz/DWKiVdihufTHSnFqar7qdjFTZhcQHn6Ubfp+VIx20JyKrlYXFPFHT05/WmiTCigPgdKOULj6TFIrhtvH3qcVo5QuBHNNzTsZpCfmxQoiDO2jO3+ntS4xSM20UuVjuKAR+HSk/hpN27t0pVbcKfKHMITt989qUDI7UzzOenanb+OnSnyhzC4+n5UE4phYMQpX71ODbc+360uUVxaUcGm78dv1oD7j0o5dAuL/D+FLjP/wCqmodyUMSoocew7sCcnGacKjR923HSnFyHp8orju9IelMWQlRwDTt+O360co7it/SlIzTTJtj3YoVuV/2qXKIcCQevWm49P/102OTeBx96l38EkdO1HKx8w4nFB4H4Ujts7UKfmYelHKw5gd1jG5mCqO5pScNVUH7bKrEL5cTttHdiMqc+3Xjnt9Klt0MEW3O7HA+nb9OPwp8odCRFKoqltxUY3Ecn8uPypR1pu/2pd+R0o5QuLt+n5UdKQDd81CNu7UuVhcGVmXggHtxmmwSedArMu045Gc/ke496c/Ax602KRhGM9RweetHKHMSdP/1U0N8w9xxTRJuGdtO8z2/WnyiuKOtAPApu/P8ACPzpS2F3UuUB2KN3HXim7udv4U7mhxY+YOppOoppfb2zilDZY+1HKw5hQcmjHH/1qZ5mB07etKzbe3SjldxXH0m3nt+VIX+bp0oVsnpRyu1x3Y7GaM4P60wvsJ4pyLsUDr7nvRyhzCFcjHHr0p27PemtwQMdaUkijlYcwvejH+cUY4pivlunWjlDmH0Mc9eaahytHmfu91HKHML0peaRT8xHpSHhgPWjlDmFHJoHSkZtx2/rSE4yOtHKK44HNAORSB8leOuaEbf2o5WO47p/+qm7gV/+tRu/d7sU4jIo5QuGM/8A6qKM0VNmGoh9+9HU0ituXNKBtp8rC4ZzRuyKMYpc0WYXDk/14pvWlZtopFO4U+VhcM5NOx/nFIThvrTVX963XoBjt3/xo5QuKjbxu9aOAKU8UDrS5QQuDSA7hkUM20UxW2M33st2Pamo9xajwCB6+9LjFNMmO360F8bvaq5RH//Z[/img]
Dept : Oise
Env. 7000 message 06 (6)
Impossible de voir cette image !
De : 06 (6)
Env. 20 message Oise
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEBLAEsAAD/4RDqRXhpZgAATU0AKgAAAAgABgALAAIAAAAmAAAIYgESAAMAAAABAAEAAAExAAIAAAAmAAAIiAEyAAIAAAAUAAAIrodpAAQAAAABAAAIwuocAAcAAAgMAAAAVgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFdpbmRvd3MgUGhvdG8gRWRpdG9yIDEwLjAuMTAwMTEuMTYzODQAV2luZG93cyBQaG90byBFZGl0b3IgMTAuMC4xMDAxMS4xNjM4NAAyMDE2OjA1OjA2IDExOjE3OjUzAAAB6hwABwAACAwAAAjUAAAAABzqAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/4TGwaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wLwA8P3hwYWNrZXQgYmVnaW49J++7vycgaWQ9J1c1TTBNcENlaGlIenJlU3pOVGN6a2M5ZCc/Pg0KPHg6eG1wbWV0YSB4bWxuczp4PSJhZG9iZTpuczptZXRhLyI+PHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj48cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0idXVpZDpmYWY1YmRkNS1iYTNkLTExZGEtYWQzMS1kMzNkNzUxODJmMWIiIHhtbG5zOnhtcD0iaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wLyI+PHhtcDpDcmVhdG9yVG9vbD5XaW5kb3dzIFBob3RvIEVkaXRvciAxMC4wLjEwMDExLjE2Mzg0PC94bXA6Q3JlYXRvclRvb2w+PC9yZGY6RGVzY3JpcHRpb24+PC9yZGY6UkRGPjwveDp4bXBtZXRhPg0KICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgPD94cGFja2V0IGVuZD0ndyc/Pv/bAEMAAgEBAgEBAgICAgICAgIDBQMDAwMDBgQEAwUHBgcHBwYHBwgJCwkICAoIBwcKDQoKCwwMDAwHCQ4PDQwOCwwMDP/bAEMBAgICAwMDBgMDBgwIBwgMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDP/AABEIAm4CsAMBIgACEQEDEQH/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/xAAfAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/AP3gKY7fNghhn/P+fzoKs0mdueuB/n/OO1OQAzfj0/lQG43Dncc+5zz/AJ/+vXVczBurE8LjcPp/n8sU0HzAW+7z/wB9c8U4BnHl7sMxILY7HPamnaIlxj5jyAeh5H9KQAVwi/xc84PU4NDHyyB/EM0Owb5Tjpg+3+fSiQFWG7cx3cei/wCf60wAJllXb97GMt1/P/PFNX94/wAv8XGff/PPr0p0x8xmGcrxk4/z7/p9aReAOST+fv8A5/woAjYKisG+7g456/5/p3pCNwXj2P4dsf55qQA+Tu3bQo52nn/P+fXLDIQyjPXLcDrzx+WP6UAKMBsdFXHXvzmgL/pP5447f5/l60udo292BIHqfypjLkbQNy49OM4H8+KYDo1Bb5j8uM5/U/Q8UIWIbdwW7Y+ufzpXOZGbj5TgY579f8+opQNy7cHnAz/P+tACAMoUd+mR8wBHX+dOByV6dcnnj/P+fqkhOcN36+4/KlA2yY74x/u0gBcHouN3zA565NOI24xgsDwP8f0pnRf7xHI9/X8+PyoI2pk9hjr3HWgA3fIwGC2Mkfy/OnH5NrZX5sjr19DQ+1dvr09M0uzDdcr9P8/59aAEzsdflXcvQ47mmltrt/s9s/5/yacrMPm25IwQewpowA3PPU+9AB/rD6kn16cZ/nQxzGP4ehznr37fT8M0ONq+uc546c/40YycdARjPp0pgMY/px6f55OPwFK68L93OcgjtQvyp8w+6M47Af5zxQoZJDj8sdT/APr/AK0ARt0+7u6enFLEu7hsbj94k9+P68fhSvFklvu8cAetKynYvbjBHrTAVF4Ht0BoPMi7vTigj7v/ADz6n6f5/nShwrbduGYbjz9BSAQkGXop65J9f8iiTgk/d45yOvv+o/I03OyVVIBDd+5x/n9fycp387W2kY47j8vpTAcXVlx93sOf8+h//WaFADKvyj2PPHH8gf0pit8hZurH07nj/GlA5Y43dsevT8uf5delSA5hsfdjacY6df8AHvSPtDeu0Z4Pr/8Aq/z0p6MQvXr2x19umexFRyvtHBJ4yWAz7k/570ARseFHGVxg/wCev9c0xhuVsdj19P6VIF+Xd93nr/d+lKi4I/h6duuaoCLy1Yddu3jJ7cc/0p7x4KhR1HHHQf5A/I/Snj7+MHrzjjtn+dOQsuGbpjIP6E/59/rSAfEFjJY/xDJ7559fb/PSpIlBjH1J60yPJeNV55A6dOKcn3fvEHGM/l0/z+uakBHAYsuMZ5Pv1/z/APqpucbQ3y7cnnpj/P8AWpGB2Db8q4A6dPSmvtc4/n0xx+H/AOvFICPOZPmGSo5y3JI//V+tDKpclTg9B/n9PxpRulQgfNjIAx16EfnSIfMiByx4wBj/ADmqAVRg/MB1/Tj/AD+VKykIOpZQc89Mf5/z0pxO7ls7jnjr6n/JoZi6N3z0Gevt/SjUBsqKzMAvbPXoT/kUFfmz325PPv8ApRt2oF5DEY+vT/P86cRh9mPwGByfwoAaNuR/I/WhQMKT9c+maB8ygdCx546en+f50u1nG7DYz+JoAQA52/x45x+HP86WM/vOT2IHoKUBsDb1bnHqfajy8Fic56A4xj/Of5+9AAoBl+b06dz/AJyKRJM/7wGc9j0/x/WnlSWIzkNgHjpnP/1v89GvJtBbd90dTxge/wCX6UgDaob5h15PPTn+XIpq5cr/AAnjOR09/f1pQCzr9DjH6dv8+9IG3Fm+VmBz6ZPGKYD07ADocnn2x/iaepz838JyPX/Pf/PNM+bGeW25HI9M05WyDjpnB9fr/n1qQEcbFOfQkke3WopclVLbfmJB9OMHp0//AFflLJ8iKvK/x+uBnnn/AD/OmFWWVM5XOOnuaAIp3AVeuVIA5yRnj+tOiKgfNt9+2P8A9VOdA6tn5f4c44Bx3/EA02JmMbEZz1/zx7VQDo8qp3cbiPw/zz/ninbdgYD7x5+p7/n/AJ9KSQ+UC38DHZgDp2H+fQ0qEY3e2489PbP9aQBIoCK36E8NxSHlsZ2qvJ7+5/z7e+Q91/eYZfmYAYHTFG1hj2HOeNo7df8A61IBudrDdkZwfYfh+H6n1NJHFx03dMc/l/n/APVSghz0wpw2QOvbgf560it+63c+n6dvpz/+qmAuP3bBfz9P88U4hWjwPXpnODxQeu7+J8AZ600tgc5yfc9en19qACXgMv8Ae4PPT/PP5dqTyxEG/wCmYyoH4Z/lSj5lVd2ecgjt1B/p+tOaNmCdcLnPtwMCkA0D+HH4569cf1/OnKq7RwOWAOBxnOP/AK1KpZV+X72cDPuTxTDjPA+XoDjnjH/1vyoAEXzGAA29Mdx/n/CnIOg3fN3x37fT/wDV+NATy93X5Tx6jnk/l+ooxu3KqruHbHA9v5f/AFuaABvmP3fTPP8An/IprL5g/wBnPf3pzfKD/Fk5z/KkEeNuB8vGCT34/wA/nQAmG2huhznOe1CjySdx27eRjt6/0qT7x7rnAz+VJ8wGB67sY6c/5/SgBAVjOPlAxxj29vypQmT0+o+tKpKfKMrtxt745OaapYx9we4x3/woARRlAN2d3Qnt74/A+3WjdsbdtwGGeT2/z/nrTslZPr09j3pCpJ9VbB6/rQAu7Mi/Xn0/z/8AqpGHluuF4YMePwpyDMh3FSNo4AprthlbcG2nJI7k4HSgBGjwOM+ufrgfpiiUsFH+18p/Tv8AiaQnYg3fMyr09fanOvAB+8ePTp/h/nvQBD8zru+ZG7qRyP8AP+c0uDv/AIenQHGRjj+v4Up/1m07dy8cfz/SlTjLK3y9s9uf/wBX+eKq4DGHHy+nBP8AX8aGII+794DntjA/z+XvRIMv/s7SF559D/nuB+TslY+PvN146UAN2nG3GcHGAf5H/PWmyryd3tjJ7Zx/n6VIVWMKONq98/56+v8AkIf3T/NjgAEdM/T9aAE25/7559+4pR80rZ6Mefyyf5/rTMlQMEbcDgdTUjDI/hHIDZ54549/SgBoQ729WBJHT/PFOWPZu54yAOOv+cUjBlGfvHrz+H+FHl7F5H3Ox9R/k/hQArLtGW56cHHX/I/lSYbI+97ZA4GRn/PrThwHz+PH3gfak27UycbuMDv/AJ/+tQAZ+Xn0yR6/5x+vpQwLZ+8rd+c4/wA/5NNX/Vtnqrckc8j+v/1qdllVSNvBH4e38/yoAMFnXbleMnn3/wA/nQ3DDn5W9u/T/P0oCBtvquMD8PX/AD+lDDZJgevX9f60ANAEiryec9O3P/6z+HenI2c+559qaEVlbd/Fx9e9OJxD12seVx/P8qACRflP8X9MdM0rJ+8yfl28cf575NIw+X5vp9COv8qcRu3ceoI9OaAGFdrcDcevTI6f1pSuWYZ5/n9P89qcVBO35QD0/wA/570bs8KV3N36jFAEUgO3P3efTkn/ADmk++f9nHPSpD8ykLx6DP3e1NLgycZ/2f6f59zTAR9wYlevOaafmP8Augjn1yMfy/8A191cbW+9yuF49OD/AI/nTifmbH3lJwMdP84/z1pAQ/wsPur2+n+f1p4AXt9fTp1/z6fXLCoA3Agr1/Ad6Rvlb1bcPbn/ACB+nTswFJ27v4mXBPv+H+elSIdqbf4l4Hpwf5dOPxFRj5n5984P+f8AOfwRvlU7iAM+354/D+VMCWTdsDK23jpnp6f0/Gjyvkb5dv4enf8Al0pqjjI4PfHYjHr171IBuIHG4DJKnH+eaQAsO1em7aRwR3/yP5elHl/Mp7jA/wA/nTtu7np2PPp/+qhWxJt6HuP8/h1pAMDFsO3rx7D/AD/P2p2CifKDj+Rwf8O1MU79vA+XsOMEZ/zz/OnRuB93p0H+eo/z0oAmWMKR3XkdMZp4XK9/ugdOvH/66ijAi+9x6H/P+etS7WV4w2d3cfrUsBMDGfvc59fpj61GUYt24AB9D/n+tTYBK4PfPFRzISjbvlbqR6f5x+OaAIVKkNjqwGM/p/k+tKAMHGSG69OhJ/x/WmKwYmQcbOMH3/yT+dOxlCSvy/X/AD/j/SgHZ+7/AI9Kk2CTgfLzkHHSmpyduPuj8f8APOacF2O3Axkfh6/1/P8AGkAkfydto9P8/X9KGQKvP3n7H26f5/8A1U7kL/D6kn1/+vmkL/Kc/dHGD1P4UgIwu4An056dR/k0rKT/ADIHb0/pTlVS+5uvODjvz/8AqpHXYzEfeHCjPb/J/wA4qgHZXIZl7t1oG7dt/ixnkYGe/P8AnrTXiJBwx+o+lBXcP7oUcYHb/P8AkZpAO+bllGTjcATgZ4z/ACpGTKcDOB97/P1FLIVcj6UB1ifn+Lnk/n+v6/WkBGAQm3kLngf5+tOjjAfcPr079MfzpfI2Bh8o46E/qf8APanfdcA/e6r/AJ9v89TTAThhkYPGPr/nH605t3y7fm+YcHv2/wAP84oGf9nPPTt/n/D2w0xh06qd/B/ln/P/AOpALIN6cDcCuPrzTGb5mUDg9CR0P+Tinu/fvnOT796VQMqC23pjFADGX5u21c/h/nkUiReUv+zjH5U4HzMcck549+/+fSlUZUdflGM+3+RQA3y/3bBs/Nw2RzjPOfw/n60ihgxXtkd8f559KkUAR9eOQAPr/wDXpGXY+cY7ZoAaBsPcjrwOxp0q5KnrtIHA/CkxsfjG3sBSsnzD06Z9aYDAD5f3vu5wevP+fWnoMs3GBxx60mG+np7ev+P9KAOPc56jGff/AD70gDYGUfw7emKGHHH8Pb+lCx4k7dAB/LP+fT2pyfL6fgO3+c8UAI3zBiOpGf8A6/8AP9PxQDYxAB2tkZ/X+dEb4iPqD2P+fenEf5/P+dADfLztz26cfj/n6U5R8y9sAHOOlBUYX7uDxj170SHd09Dk0ACD1yu7IGOtIo+RSo5HQ8cn/OKUnDHuFPI9aRuv95jk/wCf/r0ANV8S7D94/d98DA/mafGP4eAMYHf6VFNGzEFWw24H1wO/+f8A9dPGAOR05xjp/nigBRwvO7gbgMdf8+1L8se7kDrzjtj/ADx/9agDjBI/ug0gG8nIHzc4/L/GgBQmEOPpjFNDZYbht64Xj5gDwfywae67oh833eTxSOMN8vRT19vf/P4UABU7h83+8QOM/wCT+vtQh+bPbqMc55H9KAAX7/iPTGaNn3gcdM+/tQAE7lXbu5J4H8VAwye2f5UY+Xpw3A75H+cf/WoT5lHv/n/P0oAaw3P/ALQHHqOvvTmCsc/e7j8M/wD1/wD9VKyg49PX0PH+f85oKMDwuGGMA+3NADGjy+7PPqeMD/61ARUk+U+314/zxUioFICjHXIxz1/yKaV8zqW6nv16f/W/KgBjjYODtXjn06c/zpAqsgzu3egHTvTwuFK/wn+tJ5WHX5efX+X1/wDr0ANY7l+Xk5znuM0mFdufutn2z3/z9Kfs3v0zz0J/z7UBdz/QYJx1/wAgimA0KGLc8AkYA6+o/pTfKDZ3YyenvUgXef4t3HTsf85/Klxvf7u7HT/a65/nQBEuCi5/3cDvx/8Ar6f4U8KpI46j+WP8Kds4+bJ29W/vf/qpxQ7hx82e46mlcCIruf5tpz1B/TmhTjnP4/dxz1/X+VP8nBPHXAx6/wCf8aRkzJuG7J4xT0AiQqD6DPTFDALF833ue3p/n/PWlZeGH049KbMxQcLy2CP68/rVAKjYk+gIPv3/AMKcMxv/ABZyBn1Hb/8AXQfkjI284GB26j/9X+FLGMYySq8EHGPx/n+XakA0dG/2uR/n8Kd8uCueV6HHf/P9acgwMY+buOOf85pVi+6F+o5B/wA//rpXAaNucjhWOSMdf8mg9FyN2Tg08LkY6nOB25/zn9aCpJ+90x26d6QDeDtHVj/n8OT/AJ4qMnzB7fTn/IqQR8fKCpbjHqP8/wAvwokiJyMkhRx9etADAFc/oAc/j/n6Uinc/wA248cDA6/15p6qXjzhvm6j/P5fl9KCrHdx8vv24pgMZQpUBuB1IHPr/n8aaECruBXcDjO3p2H8qm8va2Rn6f0/U/nTVjJOefqBRcCFk+Xk/Ljk/wCfamN/rTuXqf8AP+f071ZkiUqOMjgAe/XH8qhnjOBkFueOeo/yP89mmBHGVZAVbtjp0wPenMQFGedpwF/Ed/0/H8aaBvT26fTjj9al8nHXd1BGMfh+oNUAioFG35s9+OuP/wBX4U535wp6Y/D0/wA+1Oe33YHPynntn0/r+ZpQmRwvy9z6jp+H/wBepuAxei46EjHqT/8Arpy/Mf73AJ9vpUix7tvy/e4Hb2/z+NEceQWG7J6DHT+n/wCui4ETJtX5W3ck/T/OafGgRg3rnn/P+f1qRoNn+6en0+n+elDJuCt+vf2/z6UgD5SM5IPRTj0/p7U5dxuPRu31+n+f604pl8/Nt7/0qOYiH5m4Lfdx6kY/kcfiKQA1wm47fmPX8agI85COnVuBjBPP+PX3NKo8pT2wTx3PSpgpbry3X39aegEaRRoD6dPwpzR5AVuw6jt06U4LuCnHuMgYx1/pTim8/k2P1/OkA1eSG9AM+3pRnZ7dwMU8Rhnbjaeckjt1pUHybtu3PT2P/wCv+VADVC78EY5P+f8APpTeAM9sdMfpUiN/F90Dng9PSmyLwysG69emOR/h+nvQA0qHGD17HH4f4UHG7ueMEn+X8qc0efl2+wx24/8Ar/ypwXcehGQeMd8+v4/57gEYAHbrwaaFVXH8PBFSIhb1+XA47+n+elA5gH05JPT/AD/hQAm3Py/d9/Tp/n8KYAq7cDhie/oP61IEz2Xd0Pt3Hv8A59aUoW27d3qM98dKAIggB9WXOT69v6/rTpJNo+b5c9yOv4f5xmnJHubKjIx9fpSOc9sY9DjJ4/z+NACLhoepOccY4binRdV2888cdO36/wCfSgwsh/Edhx/k0OcHj7o565/z+lADSnTk5x/n/P0pxYBmx0zyOn+e1CAhsY6D8vaiIBI933tpH+f5UAJnj6ck/p/j+NIij09j3/z/APWpzLg7Wy3I9s47/wAqXDfMv4H5ev8AnH9KAGqvrnDdf9nP+cUp+bcud3Yj68j/AD2p3lfNtw3f8+lNHQN8wGc+uf8AOKAE2rnPcdz3/wA/56UihQMdehHv65qXZ5fyqO/pgDp0piJiL5h94c0ANxlE6evXr707pJ02/wAWMfl/SlEeT/eIJz3z/n/63WgnBLH5vcY/z/kUAMkVQu75sYxnPv8A5/KkIAyq4XqKeBuZuPm6E/SmqcKfpweOaAAOrg9P971/z/WlkVdv97rnnp/+v+nvSEZ29ev1x1/z+FPU7Jf7204/z+n50AJwz+pI5IHX0/wo6DOO/Y09I9yN/tfQcUqtu+goAhCARqB07UAZX9eew/z/ADqR4st+J6+nv/jTHwF+YfKuTjrwMf5/CgBAFyvO1e3U+9AIHfP1NCqWO306njPSmzzLaxSSMG+QFiQCxHBJwAMk9eAKAHlVHOfm78df84pSML06/N60J8wOfvZ9c4pX4T5gfm5JPb1/z6UAMKAKM87TgA9SR/8AX704KoO5hnacZ96ds/2crn1/z/kUbcnp16f5/wA96AGoNrfyP8qaiqsZx0weAOgP+R+VSLHu7dRge2P8ihRtjbjOBken5UARiQGMt0UjGePX/wCv+PFDLkn6dfy4oKbg3uOMdqGG4D65479f8/55ABm/yT/n/PtTnwCwYAhc9fT/ACKRT838JC9fY9P8/SiPjJ+Ze57YPp/n9aAEggjtbdYVUKkY2KM8KOmP6fn1p529Mt6f5/WkLjP8s9qduGPXd+n+elADX5U9GB5+n+c0HAH97sPc9RTgdkg7888f596afcfXuP8AOaAEZQfu/NjoT29KR1Ux7sjH3h6Dvn+tOxgH+JV6/rz+P6Yo+78pbPrx0NAEbRL1Cru5P+fSnMdo+vXPFSBtoXdgcc1EPujv04/z/n86AFkUFcFevbP+fypVIJ+bpnnvx/Okmkwm5VY7RwgPJPGBz/jTbN5J4f3i+W7EkJuDFR7kcZ6E4yASQCQMkAkT5jlvm7nn8f8AAf55aFHG4fQH+dOL5zzxjj2/z6UiDC9flVsdP8/5z70AI6fK2fm46H8/8KjkXll2/MORz36/TtmpSd65Xlm4z/n/AOvSfebdnvn6f54oAhLbTx8u7gD1NBby0Y5xt9Ovf/P41M8JUKCw6+nao3Xaqlfu8dT93r/nincA/wCWe3Od2QOMnI/wpxbYC3RiORnvUaECVQ2R/CePx/Men1p4k3p97oMkjoR7UgJSQz5I4XP8WT/nNEa4Xbxj1z0pA/G5do59OmO1KxwpILDbyccfT/P/AOugBrKpOe3QYPGKGXnkbgf84pyjaM8fLkgY96A+Pu5Pvj8c/wCf/rUABTAPOe/B/wA/1oK/OfQ8qPehG3KAR5fJ/LP6dP19eKGwqjdwPr09v8/TmgBoGPb/AD/+v8qaQAF527R0qQj5cdOv4f5zUU/VV9Tg5/H/AD+P5ACMMSfL93nr2AH+f88Ux1/d/wC0vPPbn/8AXT43A3dWCjIJ6Nye1LEMHI65+8RjH1pgMCkqflxjnGeR7e/rShdsTbV+YdBnvToEwn3T/e69D/8AWqUxjHbco5yfYH+lK4DWGD0Xd6Dt/nH8qcVy4xnkY+n+c0Hgrn5drcZ75/8A1H/JxQqbSvt8vP8AEf8AP86AEEeRxhRjGSenXv8A5607AU7gqqoPbsCcmk83ad34HJ/z/k0Kv3vl+8eo7Y4/pQA7Cx7flPYc9D9PzqMcYJwRnIHr1H+f606eTIZfXoBxxTG4b8PzGf0oAtGMhGX1AwarXbB93y/dOMg+nr+v51IlxlAvzZ4U+3b86a+12O3jjoD14qUgK5k3MTx8p6+h9f8APXFSxRmM/wC1/PFOSNYmVchhx/n+tO3A/wCzxg/h/wDr/wA9KoBTFz0yp9vy/Whmx6bu5B6+nb/PvRG2CozwCefTOcf/AK//AK9RmbAGPTAHYHGen+cYoAcVAj4XC9MZ7Uu7vjv379eaZHJgZ/p9fz/z+Ch9qDcN3f6f5/z3oAVF3ovygd8Z/wA+3+TTmUHaSNvXP0/z/OmhsMGGDnpz15H/ANenK67gxPXqCP8APrQADLce1AGN3y8+h/QU5unDcEc+3Xn+dN6xt3Xrz/n2/CkAgThfQcf0P9aeeVbj5sc/59/60H5MK3PTnp9fyoKYTaPfB25oAYy4De/P0xnH8qcr85I9x/8AWpAFRiTx7/59sUgX5WGe+Rx0oAXO4sSB8o55+tAQqF+Vt3/6qMgf7Xfj+I+lEh+X19f6UwEADPjpuH5DFK2euOgyMcf560Ejfy3X2pZMKf8AZOMgD6YoAjK7V564yOenXn/PrS9Iunrn9aD05yf1oBHljHO3HX1/zigBxGW/2SMD8c//AFv89HMchuV7EZ/OmL8srMwGOw75pQ3y8fxUAG3YqrjgD16D/P8AOkK7f9np1/z7/wCew+PM+7wvByP5j/P8qA204J65P5/5xQApHmAbe4wMc/5/z+AQo2nqx6fhQFDKvrz+P40obBK46Z569aAET5mz/kn/AD/ShvmTj73+cU5m3MTjuf8AP9f84pB9zbkqRxjP5f5FIBkqghWVtqrnI7fnSH5ZdpH3QM57YpwZSvJPzHP4f5/n7U3O1uDz9Mf57flTAAnzqT+R7nrT415O3twf0/z+NJtXH17emO3+fantuEmSx2t7feP+SKAG89+NwyeenX9adIcsMrtxkjPfp/8AWo569e+aavLAcjjJxSAc3yrjH3egz9P/AK35VHI3lqpbu20e/PTFOJyigcN2x2/zxTdvmkHuo4GOn096YDV6MfTPqff/AApxVSBu2jOD9e39KbGd47qpG4E9D/nj/wCvTgvdmxnB5HQcfl1zmgBVXYijHvyc4/zmnr9/39M9Rk1Hy0bKd2eR9P8AP9cU6R9y89MAevoaQDlHzH+9jGfrRn59wX5V5FJk78/UY9PT/P8AOlCLt64XpnHb3/z3oAaiBV5Hzc8E9DQAHH+PfmkV/MRl5Xgc9utOLg9Oxxj0pgMIyTxuz0z+P+cUMqnK9mXJyaCwwAdrbW7fT/62Kcf9bv8Al+U5/IUAJ8zvz/ESTz1pA2RxuOQAf8/rQwVywH3lORnuMf5/OgbZNp49QffOP6/5FAAq5T17n09f5/zoY7mzglcgA+gzj+eKYXzHz0Iyv+fb+tP2+WVHtx7en9OnrQBIoVDxkKo6e3Wo0+bdn6YHX+nr7U4MNo27eTnPp/n/ABpqBlUjgZznv+Xrxj9aAAjzOe3OCKCPOC5/i9D+f6/0qQybmJG3C8nnkU1I1wBwFXj8v8j/APVQA07UJPPynpnpQy/L6c4PP+f8inEjG7HocZ+lRI0j3W1o1WFfuv5nzOe/y44HvmgCQn7uV6duwpifKmMfMQSD6D1/WnN+8VvlB46A8DH+TQ22RexU5zz1/wA80AA4b5fTI569c0Km7d/u9/TrzTRwv+frxT85YMerfpQAjYY7tvuoPXt/n1pY+G7stI0WB93aVB5z2H+R+lC8sSOFxgnPY/5/I0AOxjav0AApzIB2zxyB9f8AH+ZoRPmH90EY9vp+NOJ9fx+tSBWubfEPuvzcd8U2Jcpgrt28gA9KlkPzuWOM8njjH+SP/rVGw2t/DyM89v8AINUAL1zg/M2MHnp/n6/WpN3GG+7kE/Tn/wDXUajKYb5VycYB45/z1pxOGHyjCnOPSgBxJUK3G5iM+3+eR+P4UMmxdvccfSmgZxlQc+/+evtTgAw9s4+g/wA4/wA9QBzDa/8AtFuR+v6UigMv3eowf8/iR/nhCd3zY4OD160sbZOfTnA75oAVU+8OucZB6jn/AOt/WqsmWnPGQT1z0/zxx3q4GDlgPp/Wo5IhMOPlYk9/r/n8KEBFEF3Z7ryPrzn/AD/jUqxiNdv8CgAkn6f59qaI9rbdvc80qORxjLY7Hp9Pz/zmgB6JtTaRhlBGc+3+fzpflZFOPlxuAx/npzQy5Yr/AJFI3UHPfJ5/AUgAje+NvPIPfHXjp9f88U1lX09CvNHVd3sAAPSmtzFt6cZ+lMBW45+6c9uM9jmhvmP3fmYcH6f5FJuDbuFz057f5/z3pOvPpwDn8P6n86AFlbDejHBx6Y/zn8Kbu3yKqqcIOOf0pdm5z9eR/Kmo2SCf4u/6f5+p68UAKf3bcL97PQU4PlMd+MAd/wDP9KYpyN3r1yvfp/nHekRVMbcEE989D/n0/CgCXKk47FsZH+fw/CmFvmDfe3YBH6Y/z6d6JGx/vKKV+DkY2jqSfSgB4Yufvfd/DPp+f+faJFJ+badynA54/wA8Cn8nHzd+T+WKaqhYuNqqePagABPlswX7pBwR605VEW3bg8kden+f89qSVtqN6N0BH3uhoOCCP73Unt/n/OOtACq3yquM7c/xd6cWG/5R/wDX/wA81HG/mSd255wOuOuPyxRu2yfKByfXqfT/AD60ASI3nbQBzg5x7/5/z2mXsV71HCwWNj+JPWns3b6A8+v+RUgJtwo44HAGenajH97p6Y60O+w/w99xHr2/r/kUyRhu3Hp2yfamA/cC3cNk9PajG1i23+Ln3oP7wsAO+CPeo1IdWXoeO/rg0AOKZ49euf8AP+eaV8A+3I/z/KheEfuucj8P/r0h+Ve20D8B6f4UwFThOnfnBz/np/nNIBuP3efX+9TmYLIM7c46/wA6HXYdre3BPv2pAN2/LnvnvQg6FV+6ePb/APUP5UA4O7aPXn/HFDAYZcZ2nH0//X/WmAFdx+72yOaMZkz/AA4z6jP+efyoUgtn056ev+f85oUKu0YUDoPYdf8AP+RQA7bgL8u7saaqjbhl+51546f5NNJ2ODxgDsec/WiJsP8Aw4X2AA/z/nrQAoYEZxyoHOfbNKx2vt56fl/nFRxuGDDGOcDPf/J/l06VMDz0x/Fj06igBCAu5tqjOcj+8RQefbPOT0Pr/jSkk+25c5/+v9cf56GFbgAZz0pAIcpIeD+XfkU0JjcPQ/l7/wCfenkbSx2jHof4v85/nSEfMG+8Gzn1P+f89aAEyE4xjufzzn+dOIG3cwzwR/n/AD3pqpld2AO4BI470J93p8o9+v8AnimAMwU9TwOo605zhhx90n6Y/wA/zpj/ALxfmU89yf8APak3Zz7EN07/AOQaAFKKn1+7nHbkf4mkPDDhvcDtzz/X8qMYUj5fl4NBbbn/AGv1oAFTMe3+EevbrinbcIB3X09j/n86bH36dT37cf5/Gnhv3jL/AAgY/lQAnC7cjJbB+pFOTI4P8OevXikBxJ688e3+ef8AJ5XO/oeRjp26f/XFIBv3W7Krc+vApwOwgY9ycdB/WkQ7n7fUUqjaOPvfT/D86AGtgrlunXGc05hypX6fXFBAI2j6j29/0ojUl+AMcbf8/wCeKAI3UK2Md8E+n+fSkbht34jjv/nNI4yflzxyO/T+v+fahU3c9OcfQUwHoPLT5jhsZyP8/wCf0pszZgH+zwR/d7f0pSGdl78naDxz/kf55qORjt45PQD9KAHO/mRhcjqc/n/+r/69Ijb/AKdP8/lTNvmr2Zv59B/nvx2pxIUncCvOOvPGCfp1H50ASb1ycj5TyaGbaM/d56D8/wDChOCeCowAe3+f8+tIeD+WAD/n1zQArJtBB6qcg+2f8acvTr82Rn6U1mIHyjOcEf5/z/ijfIPl/l0oAUPnnn5egA/z3o2hFb/a449P/wBVBYHHGMdgf8/5NNJ2Ocheh49qAJFXKNz1A2/5/Oo0G89vmwOO/wDnOPxpQVT6Y5/nSbcArt/h/L/Jx9Me1ADg5Vvl+bHP+f0oVtse3qdvXGcfWk++M55bp/n86QHen3e2Sc9c+p/r9KAJN3l4H939P8/zoJwu3nr09PxppGF9e2fbinBtsp/vZ6j/ADjnpQAqtuOR2/LtSbvMXn8qBu2njsOvemudzYxkdcHj8qADbuOc8/X9ajEgP+6owOP6U5jgbfT07/T60pJUbuvr7/5xQAwndJtOcdOO3H/1xQG2jI54yMfnTSuwHoo4AP5UobzF3bfTqOf8/wD1qAHMFckf3T19OCKR9oXdjqe/bt/hQp3Nj+H69qNwcZ7k9PTr/wDX/wA9QBxfA3Huc5xRJIGUe555Iyev9Kb95tuM7eRTmPPTjrkn6frmgBVk3qp3fLk59geKQNlfvbQQOR9aaGLFvmzzkZ7/AORQw+6f7o6Hr2x/kfkaAHBuRt/h/lRGvlHsu4Hp9TzRnMvQKVHGPxpvmccD8zyvFAD1k2EDnvxnr0/z/k0wtsYj2wMd+P8AP5U1nym78AT0I69Pwp2z94v5ZJx360ACS/Lu7juf8/5/A0ZxGreg6/j/AFz3p0a7Rnhdx/L/APV0/wA8tIyq9l5A4/z6fpQA3OVUYw38sc0K+WC575A67ff/AD/jT/lx8y9CP5f5+vNRgsyfd27QDnPt/n86YCh1BGPzwf8APTFJFtUfiOAOP8//AF6JCud3Ge60n3/mK7S2ST157/lin0AcnKdT9evQZoBKKr/eZjzjv+X9KGOf73zAY5ojbJ284AOB6dKkBzt8y7vmOeQKbkpJtHYYOOnfP4U1f9aFxna2e3Tt7f8A6q85+PP7U3hb9m77BJ4m/taH+1Fk+xG3smljnmR4kW2EnCLNIZQUVmAIRzkYAZ6WA9HL8Nxwpzk/5/GnnjIIHP3ff/I615/F+0Ro+vz/AGXwpbal42uMsvm6LD5mnxsMg776QrbDkYKrIzjP3DUyWfjrxcsf2y+0jwhayAlotNT+0r0emLiZFhQ4JyBA+DjDEHJQHZ6zq9n4c0iS+1C7tdPsbYb5ru6mWGKFR3Z2IA57kio9I1uy8RaZb32n3Nve2N5GJIbiCUSRyoejKwyCPcGua0T4LaBpt5b3V5b3XiDUoHMyX2t3L6hcQu23LR+YSkPA+7CqKMnAGTnrzuDhtx45bd1OR/n+VAD1OOe1IEJZudu04GB1z1J/Pp70qjaGbA3dsetSKpz8q/dOQc0AERCxN26Hbjp7f59aQHCtt/i5z+IpUcbefT5e+Cf1/wD10qDhdvGP8igBJGwf0xjrQV5PoVwKAA0nC/TnrSqMFuc9M4zQA0rgsvC5zj696R33KvOM4/Dv/SpIuCOPmIxx7cCmmH5cfd52/pj8qADep9umB7f5zQXydx59/wDPtUZDRnb/ABD0/KkHJb8+nWgCR2O7tnr69D3pyEH5e3T+fNRbsk/3c8fyzSsePx5z0x/n+VAEjvnJ7e/TFMDKR9Rz70q8r7sQeD/n0H50wsAn8Xy4yT2HP+FADi2SP9k8Z/ioR9mOO2QSMY7Ub8SZx9RmkZt3/wCr9P60ABCiFgOq8r+Oe351Ek5O3+9n0qRlbHPQ9v1pi5Zt23kDoOgP+T+n5ACl03emeRx/n/JqRG+b5j97n36f5FNXg+nt3H+fSkY7Arc7RjJI7f1/+tQBL91MfLu+lC8bW9jxmmnAXnsccnng/wBad/rH5O084z3oARxtYnPv9PX/AD/9al2LkqMnI9en501jxk8bcE+2T/n/ADmnE4yBn/ZHp60AC8pjHDc59PT3oVlkix27D/D9fypGyo68gDp39KRm+f8AIfrigAd8KMn5h/nP+f6UfeJ/P86aH+b8jijd8vzfw9cdRnH+NADmwSOfl5zj/P8A+ukU8bTx8xI56f5H+etIFwF2rjIzwaApEfA+6f8AP86AF3fKWHvkD/PX/Gl6L+eOajXBVVb5t2f88fzp+diMwPfn60AOb5gNuOOnH+enenFsn6g5HrTYztPI+ZeBz9aQHGP4eOv9aAHAhifTPHPX1oZsY3Dd7n/P+cUOuDtxgfqP84/WiQ7V2/dI756Y6f5/+vQABcH5sce2MH/69O3fvNox9M9T1prHacldpxzn17f4Zp2/DfN0b147f/qpAQsNrehxk4/GiIl3b+HGMY+lSD525GVIxzTCuSxzjucd/wDIx27DrTARducfw4x07Y/w/wA9aaVP3e+COnU5/wA/lTjy+fXoP8/l/nNMaEPOhDN8q4AB+9yP19/8aAECbvlPIbvnkZH+GKcEMYGFzjgADp/k/wCeaGT96DuPX5T6e/65zQGDfd+91x6/5FADnBZgeOeP8/jQDx93bz+dNxk/MOMY/wA/ypepb/aAxjuf/wBeKAH+Z+ZPX0ppXLZ+7xjB+tNU/L971J/x/XpTsiR/7o549f8AGgBwVjx74/z+lCfKu78P949qHyx+np/n8abuVt23PzcY9OOv+f60ACrg44+YHnt/n/PakypPT73I9V9f6ClHzH2yOTzx/n+v1pCVGePYgcD3/l/nnAApGMNx0x16+lOI2lh2x342+9Rq6srf3gMNyVP+ef6Uv8/f6cfyoAfj5sn64P6f5/8A1UBwSv8ACPypHGH3bu2Sfp/kUbcIfXHY+v8An9aAFHyqVx9RSEkr7AZBFIG4Yd/b/PtTmIwcntgHr/nNACPz83r/ACx/n9aVl3KPwB59cf4/5NNJ578+g5PU4/z70uMn5fvex6fT+dACMNx6c9Oecn1P+e/0ppjww/LHp3/rUjbRuA+Xr04A4oHLbcdP0oAjjURL+p9zTcFB36EjjvTlOVGBluuCeuSaaBgkrnn5s4xkdR+X+NAA64IXH3e/59P5U4sQ3A+Y8Yzx/n/PvTSCjKMDbk/1x/n/APVQBuRtvzcE5HYd/wDP/wBcUAO2/M319fX/APWaI0KJ0+6cg59fw+lG0RbueO3+fxoQsxHB5+XoQKABujMo+bAB6fh/n1ph5TB5x17cU4ttUN0Of8Mc/rSEYC9iQcf5/wA9KYBnLtj0+Y59/wDGgL8/HU8cfl/9b8R+LSQ4bnp0z9KkVD8v8OAMe2R1pgOzsXA+92Hp/np7UKOVC8nr9e/9R/nFNQ4QY6Y4A7e355pu7e33fmOM44z2P4dOtSBIp/u9jnj16/5+lN2fPwvoM56H/JP5U0DbJ/eP3up5/wAj+feg5LcAsW7qPegAL4k4+6vzev0+vb8qjGQdvb3PXFcJq37SvhKDVptL0u+m8Wa1bLul07w9A2pTRcgfvGj/AHUPXP72ROPWqEuofE7x2UFvp3h/4e2MknzS6lKda1SRPl6QwslvC/3hlppgOCVOStUB6UzbYWbOFjG4sf4Rg8nsB9ffrXDSftHeHb2eS38OtfeNr2GRo2g8Ow/b0ikUKWR7nK20bDcMiSZCM1jav+z54V1BY5PH2pal46k3KRB4iuRJYu4+6U06NUtDgnI/cs+dvJIFd1ZXkzW0dvpulNb2sICx/aF+yQqvcLGF8wd/lZEGeh5zQBzc0XxE8aKoR9D8C2bEA4X+2dRZfbOy3hboOlwOe1cj8XPgD4J1nQ2tvF0moeLrzUZra1mOtXbahMizSrCXgtMGCEnzMEwwJuBIzzXomsXtvp975Gsa5M9wxVlsrBHhkYE4DCOItcN7kNtOPu+nM/EvWX0TwTHNBpNr4c0ePV9NnuL7UGWBYSNQgbzGhTquRljK8RALHk8EA5/RvFfin9nS3htPEUd/4i+H1sNqeIJ5Xl1PRos/L9qi+d5rddwHnFjKirul3gs6ew6Nrtj4j06O60+6s7+3lVZUltp0mjkDqHUhlJBBVgwI4KsCODXjn7T+gS+ItK0Hwvf6te3EfifVIZdQfzFs7LT7C2eOW4k+TBwW8qMea74M2QQQCNVPDd18J9Qnvvh3pd1qmh3Unn33huJVtrTcQu6fTpJNqRyEDJgUmCUjIMLs8jgHrpdvM9d3I+v+f88cyBcP8yjjqB/L6dK534efEPSfih4e/tLRbnz4VkEFzC6mK4spwqs0E8TYeGZQwLRuAw3DjDAnoEYZHU+nv+FSA5FMi/dPTJ46GnKdsTfL93jGetNCbeGB44wfw/8A10u75lx1OCT+n+frQA8cIx/ED09qG5dQB3596YckcewJ+o/wpFP7z+JR+RHT/P40APkOD83+Hp/iKXcN3pycfT/OKIsoBxjaf8/1psZyvJ+XjjOP8/8A16AHLlY8beo6Hr9D/ntTvw+UEfhTQ2FOeRnp6Uf6x9p5OeD/AD/z6UAOZM7iflPTPp/j1qE53/d9AT6f54/SpTwvfcuR9f8A9dM6/wDAccdyOf8AP40ANBLnd2BOcHj2/n+tOcZTC/dIx8v401gE+XgYBPPA/wA/5706RW3NkHcB78n/AD/OgBANh3YGRj6Hp/n8qT+Bt33eAOPpRncrbeA3Tnp6UN8x6Hr3OOP/AK3FABwy/dGG7E9PY/y/GmhsuF9Rj1oHt8pA4569v8/hRJ8sbHq3sP1oAJOU6fj/AJ+tNY4f+8Wz36dM/wD6/pTgGwR8yrxjnkcetNPyL7emfxoAE5T028jn8j+FSIMBRx6HPfPFMxs3NnnPDEcY/wA/zpQDuz1578e9ADx8xx7+nA/Cn7d/I9eT/n2qM4X8jnJp2drYb0Bwf88dqAANkE9u/PT/AD/npRnYOx/Dgf5zQDgE+nf370jKAN2c7T39OT0oAUjC7dvBGAD345pH4duc46nGKTuG6+/XNAXYwXkenPPH/wCqgBfvPnbk80iptUfdw3TnOaB7gfMen1H+fyoUcjvtxnjtx/SgAU8jPB4xn/P6U1RgMvtgZ7+v+fencZ9Mfp/nP86QMSu7kZHHtxQA4sHbbtOGGRnj/PUf5zSIMN83XI564+n1oYfOW75xj6Hj8qQpkn34NACrnyxkbcjkHtjFB4H/AAIc9P8APajbtB/2sZyPr/P+tOKZAz/Fk+/b/wCuaAFRTsH8OeB7j6Ug+bGMdc//AFqCu5AAdvY47f8A1+PpRy65x06Dn/P50AIMFmzjA5yP4qceSBjluVGOtIq/d/2jk498f405P73dl6e/P/16AEVuM5P4jH+e9I8gbapbg5Of6/h/n1pN252yT0z9e4pUfav+197HYf55oAHGCWUEbeBn/Pt/nsx8s3Tbk5wfy/yKe3yEYXnn8aQrt+YH1GfSgBjH/eII446YoG3zOGwQxH1/z1pwbD+p9fT/AD6Ux2AGe/GMnr/+qgAjbzQuf4OeRx0H+fxp+dpHzfXP+f8AOaijcIfTnOPwPT+X50/gHGee3oCcZ/PpQAqAg53N1wPxHXHb1pN/zN6E7uvb0/z/ACoUqT75JPqR1oU7Ttz079M9f8+nNACjkZ+96E/5/wA/gRSq2e30Pr1GaGkIDc9Djn1/+t/nFG75/lb0zz9cZ/z6+2AAJwTjoT359aRhledvUdecD/8AWKVJFY/LnryP8/0oXa+3cd2RjPrx/X+lADY8Bdv3twG737D/AD/+ugqePm3dV+tAIUBst/j3OB3PtR5gkVecbeuD0/8A18/55oAcXGGY9QO/BoL7TnuhBOB6f/Wo2/KO56HHX/P/ANam7g5Xjvk/4foP1/AAcx2huflU8MBx/nihH+bOPu9veoyyyKFX0yuKeCp5B3L1BP8An60AKF8wL/FxjkfT/OKPMyFYntz7/wCetLvznnnAJHqf8/y70rYK4bHGRz37/wCfagBpHIK/LnB6dOh/z9aaSsZ/2egHYY/yP/r07cpLD7xzjjtn/P8AKmq4kXdy3OP8/XigAPz/AC7scjtyOKU8svZv6UifKqlfmbt7nj0/p60L6DlgOo7en070AO4f3wM9Px/TP+c03e2w/NjpyacpVjxy2B+H+elN4ZOu7jIIHagA3qOdzDGOcZ6ew9v8igoWmXn2IPQcjv8A56n60CRRJ16dVB54/wA9fag4QY25zwcdc/5/z6gC7t5zz6Zxx9abHJuJbpt5I/z9KA+wsq9P885/z0pQ4yu35izcAd6YDGbYn93+nTp+P8qUMpUEfxc5H+fY1w/jX9obwj4B1ubR7rWFvvEEcXmjQtIt5NT1bHP/AC626vKF6YZlVQOS2M4ybnx58SvGkrLoPhPSfCNmpKjUPFV2Lq6ICEh0sbNyCN20YkuomwGO3gbjcD1AJkBVySMnAX9K4HxR+054N8P63caPb6nJ4i8QW+fM0jQLZ9Wv4iM8SRwBvJ54zMUXjqOtY+tfs/2OvWEtx8QvFOveKLNY/wDSbe4vf7K0VVyM7rW3MaOntcPLxwScmum8L6hpfhvRrfS/CegqumW4xBFYWsen6dEOilWYIrLxjMKyY6Y9UBiW/iv4keO1R9P8PaT4FsWdcz+IJ/7R1AxbhnFpauIo5CMgF7ltpI3IeVNS9/Z/0WYSXnjzxRr/AI0SbMZi1q/W10kglDtFlbiG2fGwYMqSPjI3fM2es1zUbjTY45db1yz0e3lfbDDaAebI3PyCSQEybuMCONW46+lbTblvtbTaL4cnMuNp1HV5XtWkXuMyCS6OP7roi/7VOwF7R7qPSNNj0/QdF+z2duAsKeSNPs4sY4VNu8dOCkRX364qa/q8Wn3NrDrfiJLCW6z5Wn2OIprv1CjDXEhGODDsPt2Fh/C99qEDPrGuztGAd8GnIdPgxyfmcM0/AzyJVU91puiTaToKzJoOmm6eYfv5bOABZz03PO5CSn1+dm68GmBFpzXFvI39ieHRalmKyXuoOIGmxwGwN87kY6SCPtz6XE8PXc6GTWdZluEQZZbRDp9quDns7S4IwCGlZT6dqtpa6peyOJri109Og8lftEpzzks4Cr9Njexqaz8M2cMvmSLJeTLhvMun85hjnjdwuCeiADP6AGdo13pWmWrRaFpyzW87b3NhCkUDk9XMhKq/qSrM2c8Gsz4iWurah4bt1kntrFF1HTpDHbL58ilb+3bIkkULgYzjyj0zk9+2Zd6lju3Y9eQf8/pWX4ttmu9BdVzvWaGTluFWOVHJ6jjCn9aAOdtvh1D4L1SLUNLs/t62sflJaSspktVIGfsrOQseQOYuEOBtMYyr9bYarb6zaia1k8yPcVJKlWRh1RlIDKw7qwBB6gGpcKELLyvLLyPmB5/lis/WfDLT3zX1jN9j1LGxmKlorlR0SZM/MB2YYdeisFLKy03A5b4k/B6fVdc/4SXwrqSeG/GUSIhu2iMtnq0S9La+hBHnR8kI4IliJyjAFkeX4a/GaPxbrNx4f1rT5fDPjDT4RPcaPPMJfOh3MouLaYALcQEofnUBk4EiRsQD1OleIl1C5ktpo2tdQjBaSB23Bk/vo2AHjOfvDpnDBW+UZXxM+Fuk/Fzw8LHVluYprWX7RZ31nO1tfabMPuzW8yfNG4OOR8rYwysrFSgOkWQn/wDVyp/z/OiQ459sdPxrzPSPiVq3w116z8P+PGtnhv5vJ0rxPBF5NlqLcLHBdL922u3LHAH7mUg7CjEQj0rdtfH3mXIPt/n09aYEjy7WU9xyQDz1/wD1f/rpWXqCTtYfNx7DP8qj3hTjrzu/D+nHf/8AVSh8vj5sgEfWkA8Nk9M7iTkD2/8ArUoH7sduevrTEbAzub5STnI/z/8AWpSyl+O/XB+v/wBegBwmzzjqOn94U5m+Xp2zj+VNLq3/AALOfegyZ+ZueccfT/P5UAO3DcuOueppvmbg3+zzigSbl4/iP19KHKoeM+p49TQA0ncv8ROcZH1Hb9KcwwW56dD9aEO1G/yTSblxj+7jjHQ//XoAN2Fz83zfKBj0/wDr5/z1Rjj3IIzj9KHlVUYj2Ye3J/w9KdJtCA7vqTzt5/x/nQBG7bmGOSSeo7H/AD+tCMv8I+Zu35f4UucKMZG4dR65BpFkH3f19O39P5UARhi0XU/KeT2JP+f19qkY4ZeOuTj6/wCf/r0KNm4bh2/CiUjb/u8g+3+R/WgBAQijHzbm/Ppj9P8APWlZRlvmxu/M/wCf85pryhlJGM8Dp0H+RS+btTsrdDz9B+f9KAHeYCeOOeQO3+ev060ikM+PTnv/AJ70L8rqB6bc++R/h+lIjMy5A/3T0A/zigBysCAqn/EUofdtBYs306GgfP7DjHH+fpSR442+3PXIoAchyB0zkj+X+fypFZfLPzc/1/zxRv3vjPp/h/n0pSd0ny9emP1/n/P6ZAFLbn4/IduhpC3DH7ozzSEqrcFmVeTgdf8APH5d6C/7j5uNuBjPTnNAAMFMdiMH25xRJIo/3V6n+vv396B84wuSe9Kx3jrnp3/pQAhKv1bnrj16fyxTgQcZ+UL8x9qbHLt55bsD+X/1qcjbATz17H0oAaR/wHd+Hbp+ppynpkbQMke+TQFGFz1xx+dBYKccEt6n2oAM7lz/ABN39/5dM0I+5hn154/z70OA3T3A57/5z+lOJ+YMO3X/AD9f89aAGB8DnqwwMDp/k0u7LemDn/H+lMZwkqgN93qf73+T/wDqpYm3jc23OfzoAdHj+8STjGRTcbQuercD5fu/5/z2oVWICjrjg9Pr/n0pFVo12s27knJGOCTj8hx+A75oAXKvLtz82D2z/n8f6077wH8J6k47c0IfmZ/l+XHPr+Pb8ajLeWiuwbucdSp9KAB228e/PH8/yqPaZBk/w5wMdP8API/+v1abr97tYSIwJwpA9PUZH9eDUv8Ay2Ydf/1UwE+4g59SeMAjn+dOiRivoc//AKv1/wA96jblm+XJzk/n/wDr/KnbdsTbvpyRyT/jx/k0gFBULj14OO+OP/r0uWDFe3Y47/8A16RlwpHXHU9M5pFbnPzeucnjpQA5Ccbj6HPH5U4ltgY+m3/P5fjTEKouG6Hktj/Pv/8AXpzNw3Y9evXPr/n9KAFbcfzJ/wDr/qaSQA7f4lGO3Xr/AJ/x7qF3D+7uPANCOQqtt/P/AD9KAADfx/Cevt/n+lNjXbn0xgcdMf5/T8ac3PBwOMn8f8g0LwWGMbRzg/p/OgBCu4Zzy3Of8/54psbLu+Xp1xj/AD/nFORdo2jbwSvByP8AP1pC+OM7cYP4f5H+eaAHOSsuMndnj3odmdl+b5ecHH3f/r/5+oUKkjIwpHOOg/z/AJ70MrY+VtrEYz1xx+v+NACgfN8v4fT+nGKRjtXYefTj/PXI/KlbcT6cdB6f5/z1prNtPI7ngnpz1oAY2WZfmb5TyQOvOefb1/pUgCqu0/dzkcden4f5NRycNz944289O39aAMKQDjIwaAHLweeTkZIz/n/PvQfunb129cdOf8/99Uxs8gDcfqP8/wCfejILtuO319j/AJxQBIoyu3rz6f59cUm/cN+5snn7vXv+dct8QvjL4X+E0VuviLXtP0ma/IWztZZN11et/dhgXMsp68IrGsO4+K/i3xfax/8ACJ+A7qFZDgXniu7/ALGhA6ZWBEmumYZJ2vFCDx8wzkAHosifMq8/n39K5D4h/Hnwh8MNSj0/Wtds7fVpgHg0qEPdapcr0Bis4VeeQH/YjIrEb4OeIfG7y/8ACX+ONYurS4Kk6X4cU6HaIoVwymaNmvGDblJPnoPkHygFgbngnS/A/wAJLibS/Cmi6TYXkz4urfQ9PVpSx+YG4eMfKTuzumYZyOcmgCnH8TfGfjiRV8O+CZtFs5BzqXiub7JlduQ0dlEXnbnAImNuQCTzjBjT4Eal4suI7jxt448Qa9HHuLabpmdD0cDkHdFC5nlUc5We4kQ8/LXRaprmqQ2Ul1eTaT4X09Vwbm9uElmHfkZWGM8Zz5ko4PFY8UGm69JHJBpuueMHxvS71JhHYIf4XVJdkXpiSCBzz3FFgLHgNfCvw78PDS/BOh2a2e/JtvD1lHFalwPmJl+SEtxzufecZwTmtDVdS1SC0a41XVNJ8MWPK7o28+YnqMSyqI1bg/L5T84IJ72G0vXtYEbX2qQaamObfTYvMcY7GeYHK9fuxRtjHI709H07w/ol+s+n2ranqQHlm6QtfXYB6hriQsVHB4Z1Ax2wBVAU9Le3vb2O70vQdQ1q6iyY9S1ffbrE3qjzqZVVsnmCIoc8Zzxsf8I/q2szZ1DWGtYcZa20qPylIOch533SH/ejMRx2q/nUru4JVbSzhbgs5M8rD+7tAVV7HO5+/HGabH4WtZXzdmbUGZs4unMkf/foYjBHqFB/WgDO0FND8PSTS6Hp4vLy44mns4/PluW7+bcucMwzk+ZJng9+K0Hj1TU4mHm2umxnAGxftE3r1YBFPPTa4+taipst89NoKgAcEDpgelIT8qfeGTv+gz1NAGfb+GbQTLJMst9IvIkuiZSPoD8idP4VH41oKpQKWZssM5PPX/P609IeFzu+b1HQijpKu0cqM/ln/P8AnJAGg4U/N9PQdv8A9dTFcNnJJII+uen58U3GSy8n14+pp2zcOfugYwB261IAdpyd2VyMHHpnj/PtWb4yvZtL8JaldWzeXcQ2zyRkqGG5VyOCDkcAfjWpuCxs3tn/AD+VVNfsTqWjXlp/FdQSRenJQgZ9KAMxPD0ngydP7HjjOlRZVtKVVRYh2a3JwEI6eWSIznI2HJbZs7qO+t1ljZvLPqpUgg4OQRkEEEcjI5FPZtwIXtxkj15/z9DSAZHy9W5yB/n6fQCgCrrWi2+twLHcBvMhfzIZIztltnAxvRhyGxn6gkHKkg53/CRS+GJIrbWJAY5pBDb6gibYpnONqyjpFIT8o/gdtoUqzrGNpJGJfO7A4Az93rUNxDHeWrxzRxzRzJ5ciuAVZTwQQeMEcHtjPUdQCLXtEs/FGi3mmalZWt/p99E1vc2tzEssM6MMFHRgQynoQfT3rzKS01z9mwNJbnWfFnw/UD/RUV7zV/DQ3DJjJzJd2aq2fL+a4iCYTzlISPs/sV/4LmLWyXGpaQvC2u7zLqwHAPlE8yx99jEyKAQhcbIh0Ol6nDrFnFdWc0c9vMNySI2VYZI6+oIII6gg55zQxlPw/wCJNO8W6BZ6xpGoWmqaZqEXn2t7ZzLNBcxnoyOpKsPcHGau7j+p6DGf89a8+1v4Uah4G8TXHiHwG1taSahMJdX0Cdtmn6weS00Zx/ot4ck+aoKS4CyqTtkj3vhz8TdP+J2lSSWsd1Y6hYuLfUtKvlWK+0mYjiKaMEgEjlXVmSRSHRnQhjQjpGbzpCBuG/GRjqf85/zxT2J29Pm69OuP8j8PSoy2+Re4I5OP8+lKgZixX+LqR0PAqQJiBt3Z+XrnH+ff/JpI/mbb6H09MimI4L/7XHHTI/z/ACp27n+I7sf/AK/0PH+NADkPy4/AZ/XtTZPnUHdzk8Y6f55oBz0PQZzuHHHH0pAevHbjJ9T/AJ/OgB6knjOPTj/P6+9JwPl5b6fwnPNIoy+7Jbdzx6f5/maC4x7YB+n+f6UAHWPbu9un+fT9KGVnixuHynPTp/nmjPy/Mfm9+vY/5/yabkzfMejZHr1/+tQAp3MpJGMnbgjJFBzgj+Fjxx2oY5GTnrycc9c/jSxrtBz82D+XuPbr+v1oAbswP4jjJx69c/zpDnK5bnHpwP8AOcf404k7McjdkYJx6/8A16bzEO59OfrQAjjI4PG/gen+eaRroRHeVlKk7dqRsxPfoAT+Xp9ae3PJ/h6c98fzqOQ7QMDgUwHxONzH7wYZ5HTIH9KVFJHoV6/0poODtY+n5n/IpyHK/MD8vT1pAOByvU8/jn/PNDDL+pz7800NsI3buCO3QU0N5iru98/X/DigCQZ6s/Pc460FMq3twR6en5/590UsqfP977pOcD0/U8+2aXb97IPTH5df59KAHA7ZP4cYOSe3f/GmsTsbrn6c03cGfd75bjqadgom1QenY5/zn+tABINozz37c9etO27j68AZx1poGV9NoJx6f5/z3oBCN225wvP0/wDrfl+FADiM9SDxzx+o/KggZ2nsOT6D/OKaE8zj+HpnPf8Aw6ev+Lg/y+5/z/n6UAB6ncW/Adfp70Y2rzgewHAofcP+BjjjOR/k/wCe4Tjrzz64I/zxQA5WXavOPTvg/wCf5U9B8v8AF+IxUcfyt3z2xT4iYgHx6Dr7dvzpAU2bdMwX064xjk8Y9v696lQhk9uwx/n3NLNASWI6/wAPPT/PT8qarCM/N6dx1+v6fTNMBwbduPt8v+f8aOQPX+L8Pb/OaFHQtj2/z70E8/e9x7D/AD/nvQA0sT93kKO2O3/6j/nNIJMhuOn3uM/578fn60hYkk8Er6Hj0/z9Ka4/eFuOCCPbH+f50ABGQrZPmKQQT0PAH6/nTo0b5uOw4PJ78Z7/AOetNA+T5m+Xk9ev+ev+eJBF87Z7nHv3pgAXyz933LevpzQwLONuA2NvA65oyRjJUfNyPftTSdwX+6TnP49v89qQDlbax429vX/PWnEqO/PQg9uuP8n+lNAygBxwO/1/pTS3ckcZHPvx/WjcBY5P5/8A6/50o+b5vfPr+dNHyj5mztJIUew/z+dOZtnTrk4x2z0/z0p6ALnA2rxtOMnt/j/n6UobZz054+v+f600bgB0zknilJ8wDGMdPUYpAIHwGG3HHX07n/P/AOqlUZ5bvgbc9P8APJ/KkMfzHawG7B68Z+tAfADZ9ep9TQAuc46bexpZG4P3vl564ycf5/yc00N8q8DptORyf88/lTkOVX5vz/z/AJ/WgAU+WO3cemARRG/qu7nGe/P/AOqkByFLFcbuR6cj+lQ7+ey4IJOfw/w/L6UASD5gv8SZxnB/zzTWf9zjjJz3xgdcf59azPF/jbSPh9pa32uaxpei2f3RPfXUdtExxnAZyAT14B7dK4t/jpqHiyML4N8G69ryyAmPUdTVtC0wZ6Ze4Q3Lqf70NtKvvyMmgHojlSoHqemfw/rmsnxp4/0P4beH5NU8RaxpPh/S0IH2vUruO0gJPRd8hAyegHU9q4a68G/FDxe6/wBpeNvDvhm0k4ltvDuiNNdL838N5dyspOMgN9lAJOSpHFT2fw+8B/CDxLDqU8K3XiuSHYl9fvLq2vXCDr5ZbzLgjnOyIBRn7ozVAEfx7vvGsLL4H8H654iXcvlanqIOh6U4JxvEs6efKuCSGgt5UbHDHIy63+HfjTxoobxZ4wOmw+YrDTPCMLWMYXdkRyXkhe5k7ZaL7NkY+XBIO+fEeva3M/8AZ+i/YI1JButYnEeQP40hiLuwOOkrQNg1hpd2+tSSCbWta8YSSDcbbSE+z6amVwV8yMqnOeUuLiQ9PaheYFnwr4d8D/A7U57XQdJs7PWLxV+2LYWj3mq3eOj3Mqh53z8o8ydiOB82MZ1tQ8Qa1JZzXRttO8NWNuC0l1q8yzPEo7tHFII1B/vGfjuvpX0nQdWGkx2djHpHhPTFb5Lewt1nmA46ZVYYye42Sf7xzUd1onhrT9aRr5W1zWbeQSx/ai+pXUDAcNHFhhAfeNUHfiiwGa82l+Jo9y2+v+PFYMr7di6W4YH5QHaG0mTquR5rdiTjNbeg6RrMVvFawppPhnSbdSsFjpsCzSQr2+cgQp15RYnUEnDnrVtNW1jWCGsrGKxjZgTcak5347kQocn/AIE6EZ6Y5p0fhVrv5tRvrjUd3PlY+z2w5zwinLduJGf24oAzYrHw3ouvtNt/tbWrfIMxL6he2/TIB+YwA5HyjYvOcCtaWfWNTb93b2ulxkhnN03nyjjpsjYIv18w/TvWnbWMVhaLBDGkUCcJEiBI0HbAHHf2p4i+VV6bhnpQBmDw5HKq/bJ7nUuOftDAR9c5MShY+3UqT79TWjbhYY1ijRY41XACD5UAPYen6Y/AVIQpG4/dGSTnrzSDh1HG49ef89z/AJzQAqAKzM2MDt3+n9Pw/AO+83Tc3HH/ANemhSp3bu3p056f5/WlTM5PpjHHrznH+e9IBy4VRt+6xGB+n9OgFCScbiuDkfj7mjzPLkXaq8nnn2/yKav7w7gwZWI5J9f8RQA/dsKrjgAcntinKpz83y+/qTimqx7Y3bhuGeMHH9KN/wBMg9vy/TFIB2/zT/vDjjr607OD0+6c8Hp3/wA/5FNRfKT5SNy/oP8AP+etJjc2FYcDHHf8fyoAcvyyblAXB44656fyx+PeqWs6lFo2j3l7NuaG1heeRVA3bUUs2M4HQHqRz3FWt2fmPVuR7j/9VZfj2JpvA+uKv3msLhRtOGz5TDr7ZoW4Gpv3p9T+H/6zzxTt5O0df/1Y/wA/5zX0+Rri0g/vMitzx1APTPFTcMMdl4+v+etAMhu7Nb+IoJpomB3B4pNrKR09mHqGBU9weRUcd39mnWOYBZJGxGeiyH+6OeG6nBP0zzVpV6euc9M88/5+tNeITRMGCsrcbW7jrz9PWgB6qoH94Yx9RWRqXhuaz1KbUtIkjt9QuFDTRSEi1vyBgGQDJV8LtEqgsBjcHCha1o4iqsu5iD0J6/5+tODblVgyssgBGDxz0x9c0AZ+jeJIdcaWHy5rW7tSDcWk4Cy2+c4JxkMhIOHUlTg4JIYDm/il8HrXx7cW+sWN3JoPi/SYyuna1bpukjUkEwzpkC4tmIIeFzgg5UxuFkXpPEHhi310wSMZLe8s9wtruIhZrXPB2k5BU4GUYFGwNynAqjY+J7iz1CHT9ZWG3vJ2KW1xGNttfnGfkySUkwCfKcknDbGkCsQAc/4S+LdwvitfDHizT4/DviaZj9iKzGSw15QhYvZysAS4AYvA4EqBScOgEp7hnxGxX3IGev8An/H8cfxz4C0f4l+F5tJ1yxj1DTpyHEZcq0bodySxuhDRyowDLIhV1IBBBxXF6b4p1f4G3FvpvjDUJdc8O3dwttYeJpgqz2rSvtit9RVQFBJZUS6UBHJVZFjfa81Aen78v1ypyQcdT2/kTSRNxu+7x3/z/kfnTVcwSxrJu3HJ57HPNC5J2cbcDHP3h60gJUwF44zxj6U4Nk/N97OcZ7d6YC2Wyfu9c9v8/wAv1NwBznvx7/h+dIBxGN27jGdxzk0dAdxHrSHhcLt9qZs+Tb64A74/z/n2AHNjOePQ+/NEhwm0dW5H+fz/AM5pQTz03ZHHp/n+lKORzwyn/Ofp/n0oAUEHcfbseme+aQcfw45OMHp/n+lG7YvzfezyD/n/ADxQvA55PRh/nvQAOgJH3T3ye31/OkfDt+OCfT/CgncDlR64H8v8+lLuwTu+6vX1IoATpv253Y+uc/5/pTFXaOn1x7/5/QelOUZcj+Pk8e2R/jQ4Zm/HPXrQA0tvO3bgZycenT/P50KeUbd97nt/j9aWWPK/oSf880zcGDbuv3sZ61QCpNg7lXpzn0/z/nvSqfMT5erY759/8mox3Hy+npj0p4O4ZLdTgfqfz/8ArUWAf/Eq9mGPpRvBkwPvd/y/+vSF9zqfz9M9v6D8KACF+Xj0Prxn/PtUgKcbePujjGe1O3YLDt1+vqKaylQVbaMngHouabhpI9ysN2eD1H1oAm/5aYOBt4I/z+FND91X7uSP603aCeny4IwT1Hf+X405V7sffntx3/l/ngAcqbz6nlsdj/nNHGOcbs9jTcc/7S+v5/5+lCjdH7MMfT/PoKAHOcqf/HT149f50ZUnPp2J6f54H/66F4ftu6dc/wCf8+9NLbQv4fT/AD0oAfu3Bt33SeSfQdKcrZbHBbOef6VFnI28t6/yp2CoHopyO+KAHMdrlf4uPzqN0BP0HX164/l+tOc70/u8Y6859KGOSenz5OD34/rQBGvMXPp6/wCf8ntTl+fn8CB/n/OfrQvHt9R+f50f3W6cYHP+f8/jQAzzNrD7x5/Pt/hTQuVGc5xnr9f8/jUhT/AZHcf5/nRGCxZlywzjPr6UAIgw3f8APr/kf0pwQttJ/hzz2oC4kG3jtgf5/wD14pGVZIztX7w6565oAQHzI/73PTP5f5/pSE4cNuZt2Qee/FK+eoO0g5z9cH+lN3bzz8oIIz14zQAiN8meQq89c5H+H+H409W2n7rDn175/wDrfp9KGBUHPX6/d6UKu+RSq9+fx/8A159KYCKN6rjd1Bxj6f55oTc4DZz6HHX/ADmlYeWcD+Lrg5wOB/n8PwFUqu1l44OM++f0pABfbJj5m7Zz+n+etKFbPVvbH9KEG58tgc/n/wDW4pRxnjPHp0/z1/yaAAyEJ6rnpTSp+Y7mzz3702+vYdMs5bm6mht7WFTJNNK4SOJRyWZicAAZ5NeW+Nv2r9HsNHW48L6bq3jxpLiKFZdGgZtPId1Ulb5gLaRlz9yOR3J42jkgA9SV8xYy3XA5qn4n8VaX4M0W41TWtSsdH0y2XdPeXtylvbxDrlpHIUAepIrz/wANnx58TdLhvr7X/DvhrTbpmeCHw5F/aVyI/wCEG7uk8rd2YC14PAbIybtp8H/BvgLUP+Ek1CGC61Wz/eDXfEN419dWxxgmOa5Yi3U8krD5af7IGKdgIl/aDh8VoY/B3h7xB4uWQbhfRQfYNJPXDC7udiSp/tWwnOOxqJvCfxA8aN/xOfFmn+FNPzu+w+F7YXF2w4+V7+8Ugqef9XawuOCJB1rpT45fV3xo+m32pFhxcyqbS0zjIzJKA7qc/ehSUdM1m3813eXcltqOtNHIdxOm6HGfP2cH55Tul6EYdBBjd15BpoDO0n4T+Bfg/fw61Nb2q63ITHHrWtXb6hq1wcE+XHc3LPOR1xFG2Bk4X13pPFOq6vKq6ToV1Ish5udTkNjGVwCSI9rz7skja8aDr8w61W0PQbjTb2aXS9K0/R5JsLNe3rG7vrkdcPtfL+oLzsR/d4p+s6LoyQpD4gvv7R87LLbX0oMc4AH3bZAEkxyeUY89TQBmPP8A2pdst74g1DWpY2CNY+HYntoVbnAkkjZpEYYIO+4RDgZXkVoaF4avtKtpbXR9P0XwtYyHLGOIT3E3X5mVdiB++5ml6nitBNTvLmBIdL0lo4YyFjkvD9liVR2WMAyf8BKID69DTV8M32pSH+0tXunjYMDbWCfYoiCMcspM2eOolUHPI7BgUdW0fQdPu4o9cvG1W8kbzI4L9/tDuwPBitlATI7Mke7uSTk1fi1jVNS2Lp+lrbWqrtWbUJDBgYGNkCguQOhDmIjAwMYJ0NF8O2fhmIw6fZ2djHMcyeTEIy/qWI+8e/zZ/Wr4gIh+UbeR/X/E/wCeqAwv+EOk1OPbqmoXl8rDJhizaW/Y42od7L6rI7g5ORjArWstPt9Itvs9pbw20JJKxQqI1z34GBn/AD1qdJF3FflyPm255AJOM+mcfofwdIuCp9v/AKw/z/8AXoAaPl+b5lC5wVHWhhg7fvdTjPToSf8A6/v9RTtn/AdoyD6/5NMaMGdW2KPLye+ckcqfb+ZxxwKAHHhMseGBHTPHGf0pSrMBuyrAY/TH+fpTvKyPbIxnqx75+nWhsuq9h1A9fxpAK4HCn5s9R+Gf8/1pAMyBTnpyexyf8/5NOX7y49Bz0J/zij7seW5O0D03Y9PzpANBGW/Hv07f0pSmfm+brnOen0pznJw2PoD/AJ/yR+I5LH5R0HXPTvQAn3twGVXOcjv9KDxx8wXBP05/z+VLs2FWPoBn16//AF/z/GkX93t/u59KAFbhVb7qg888fzpud/qT2x2/+vx7UFFaTd1J5OP8/wCf0pfLZvu52/Ljn/P+TQAAsF53ZXnGe/8Ak/rQhyvcL6ev+cUSY2MxOFzj64oUbOCvyrx9e+MfWgAIw3O7J9D1H+f1/KoLy1+32lxbtkrMjoSfcY5qwBtRSfTI+vrSCLecBueo4+v+IoAjtY/s8EMePuxBeM4GB/n9amHyjHqCPbn/AOt/ntUNhcwahaQ3NrJHLb3CLJG6Hh0YAqR7EY59MVKGIXn8ufagBU4XC/Kvb26f555pqHeu5egyev4Dn6D/ADmncgenPrz1xQBu2gDDHnA/z/nNACqx+X7xwew5+n+eeO1Yt/ZXGgy/adMiaa1yTc2CttVhjloeyyd9mQjZPRjuN278QWlrdfZjMr3EZy0EQMsy+5jTLAdecYpiXuoXxxDZraoxxvunDN9RHGTkH3dTz0GOQCfTdSg1a38y3cyRnIYEMrIwPKsrYKsO6nBHcVV1y4029gl07UPJulnQCW0ZfNeVT0/djLEZxzjjHbArMmtbe+vDN9tutQumA8xLJdkLjkbGKED8JJTjB7Eg3o4pNJ09xFDp2i2ancWbG1f95V2ov13H+dMDC/tbVPCMbLKtxdaKpHl3l1l7ixBySZVXLSxj++drqOZMgNILeovp+v2ElteXja1b3kJSaztk8y3eORQCrLHk7GVukjlSPUZNTwyQ6mQ0a6nrTZXbn93b9uekcUi9DkByMZHIrC1DwTr2n6fcLoU1to9ndFnn062fzGy/MklrJIFSCUnnaUMRfLnazM5YHHfDy/uPAGteIpPC+i6leeCLG8EE9ioE1zbXS/up2siGYzQxhI0aHJKGNliJ2CGvYPD+vWfibSrfUNPu4b2zul3xTwvuWQZIPPqMEEHBBBBAIxWX8N7bSLDwnb2Oibo7HTf9EMEm8S2zKBlHVvmV+QSpAJ3bud241Nc8C3Ok63c614Xa3tdSujvvrGZ2jstWIz80m0Hyp8ceeikkBVdZAiBEB1bPvXbjv+dOVi7bcndzznkH/P8AnpWF4T8e2niu4uLaNZrXVNPwt7p1yAlzbBidrMoJDRvtO2RSyPhsMcMBtqMjau1lzxjvnr+fPpQAHggbeMcfn/X+lPxlurHkd/y7/jTM+ard1HIzzT04GdvvjPb/ADikAijdk/NyMc9PQg/jSFDvbr83v1pdvDHH0P6f40dGbgt90HnpQASScsWz+fT/AD/n0qQtsl3Nu9/emMCx3KvzY4/H/ClU7tuPr16fSgAV+eQTu9+1NXJDdc55z9P8/lSqpAB7c4P0/wA/54pSMD6cgHuO/wDn2oARhuJDbsZOOf8APp+NIyYVucenP+ff/wCtSh8gtjdhSAPX2/OlUL2/xz/nr+VADWYem5fr1P8An+VNK4XcSx9wfTn6fj9Kdk8dl56du1BbcOFO49qAIjG0Yw3O3v7e/wDntRIdxbqwHQk+o/z+VPdCX7dRyR/n8xTQn74KPp7/AOcVQDzIS+5STg4Pc+hP/wCqiJvkz83A3Hnvxz/L/OKRW80498YBPH+f8+lOiw6M3HTJ9uw/r+VSASHb1Ldx04/z+lNi6lW55z1/z/nNB+93656HPXp/L/OaM4Kkdsgn8B/9agByHcx+9yc59On88f8A6qcrZXoV3cEf5/zxTA+QPr0/Q/59qVl3Ky9F9SPx/wAf1+lACsfl564z9eh/x4/rSj5Rjknp1/z/AJ/UD7S3PQmhSMqVA64zQApHC8n3HYUgP3c56DPanD5sLTSpcn1bv+tABISAV3HoB6den9aXqeuQvT256Y7dB/8AWpXBk+6232x19fbpTSwRVOeFPA/l/j+NAADvU4Jbyzwc557/AOfenLwD97sP8/rTQPm64yfrj2/X+VC/KuG645A7dT/n0oAVW2oeccdevtmh/lU8fN0P+fwpAuf+A8k4xnj/APXTQS3od23kjrQA4urfdH4f3v8A9f8AWgr8rD2657/X/P4U2M7V9S3I560mzy1+XaoyBwOOh7fn/noASAnnOM9AaYCxH3Ru9+f8/wD1vWmXFzHbodzBEzgMTxn/AD6/zwDIDubb/e6f5/z06UANJbIOdrAfXH+eKVWGVUfQL1xjp/OmhfmGM9/x9fb0/Kmg75Dt3Y6qoH+famBI7ZO0j5ewx1Hp7UisRjucHJI6nr+tLGm5lH3uM/LzXI+I/jJouhavJpdvJc+INehXcdK0eH7Zdw4wAJdvyW4JPDXDxoSD83BpAdYzMefvc8Z/i5NOmk8qKRnZVjjUs7n7uBk5J6Yx6/8A6uFmk8e+Mn/cx6L4Jsm5D3B/tbU2U9QY1KW8EgySG8y6T/Z6irFt8CdDv3WTxA2oeM7hTu8zxBKt3CrZ4KWqqtrGwBxujhVsdSepAI5fj/od3KsPh2HVPG1w27C+HoBdW+4cMr3jMlpGwPG2SdWPOAcGnNbePfGR2TTaN4JsWjXd9j/4m2qDKgkB5EW2hdG45juVbrxiu0iGFRF+VVACqBgKPQDtx2pwGA2OvQ44/wA/5+tIDidN/Z/8OJdQXesw3XjDUrZhLFe+Irg6i0Mgz+9hif8AcWzHubeKMHAz0xUnxplzomhsSZGXxHpAyQXzm+hHT8evbGe1dlIFQcfdXvj/AD615T+2Lb69qHwTeLwtdWVj4luNY0qHSru8QtDZ3Mmo28ccrqAdwRpNxGOQMU1oHU4+1+N8Hiz9obxFb+GNQt9L0Pw7oElx4ivblhHZtffunKBiSiywQuDNKc7GMaESbZRH0/wL8YaH8WvCmneI9D064N3c2sd3Fea9LJcXcUci/JJF5jNJ5MikMpUxKwOQBnA+SdR/ZZv/AIU+KNC8I2K+OfFV1eWkt74i0O5O6z8Ust5Z5hDQ4jitZXPmzT3Dt8uUbezlE+j/AIQ6Xr/xe1nWNa8SeKr3SPFWnFbWTw7ZafHbJ4WBBaJQzqXu1dWJabJhmwRGIwm0GvN/XZDtoeu6tZQ20Pn6xqshhBKkeebODJzxhWBbdnG1mcdOMmn6bqe20Fvo+ktHb5OzdF9ht0yR0Urv79RGR785rF8KXn9i6xHaavaw2utSDEGob2kj1Hg58uSQl0bgkwsxx/CWHI67OwHHtgZx/n0qxFBNLvL5W+1XhwwwYrVTCo9csSXPYZBX6Va0rRLPSPMe1toY5pcCSQD95LjH3nPzN6/MSf0zZVfkxyc8DAx34FPi+ZA27r+Xp/n3/GgBdgdhj7uOCO4wP/18c06M7mP3Wwcrjv6Af40KuTtzzuxg/wAvzH6Uqp5g29CRweOcUgFAURqoC5PA/H/HNOjO07cFT1ye3+eP85prfInzN83fPbP0/wA/rTz86Z+6QaQCwsuzPK9yO4/zihX+XI/vAev/AOvv+VCLgnP3v502Rueh3dwO4/z2pALG2eG+73Hp/n+tKP3ceeOpznjHX/6wpBknuOeO+cjvS/6tBhenQd+3Gf8APWgADAptX5d3A55zk/5/D3pIwrBe+B26e5peWC/N8xB5/wA/y96XdhSF5XOSex9v/rUALK29MN07Dr/n/wCsaUsT9c/5/lSIv75R/CwHU53fj+FNPIKjPHQg9PpQAOxRw69OWxjr6fz7UoGEG3tx1/Gm+Zjk9Ocjt7/59qSNSV2lmPOcDn36/wCe9AEm7YMM34j601n+X/Zznj3phPyN2JwOv+f8/SnMMHKnO/JA9TjP/wBegBfNUL7gZI/SheV/hyv+f8/Q0Rn5m7cnHsP8/wBKaPlViOvQA9/b/PvQBIz/ACcfn64xxQW3jPPzZXI7j0pqnanHrkE/nSJ85yvPcAdh/wDX5/WgBxJZPc9Pb/P9KdDmO5G3cPm69cdKzrjxFZ20zwrMbmeMkPFboZnQ56OFB2892wB61G2oXzL5hih02JTlnu3EjL0xlUO0cnr5h6dOaAIfhv5h+HXh/cgjb+zbXIDbgP3KZAPJIB46n1q5c+JrOzlkjWRrieM/NBbRNNIpxwGVQdv1bAz3rD0w2MmlafY28d5rENnbR2waAFLORVG0kklYXHTgFyAOhq5fXc2lWcKXF3p+h2ufLiji2s7egQuAucfwrG2exOKALz3mo3J+W2hso1OXkunEjIcf3IyQRjuZAfY1mwz2+qx7vtV/rjcjZb4W2PByNy7Y2A/uuzHt16tEUdxPuh0261GReRcai/lRKw9FbcyN/uRAcHn10HsL29uN1xfyRx4/1NtEEz67nbcxwe67OnTpgQEMu7RtNC+Zpeg2OQq9MLuz0ztjVvbDg1E0ceoSH/Qr7Vsk/NeDyoAeoJR8D0+aOJu9aVnpNvp9wskUI89RsM7s0kxB7GRiXI4HU9varJKgEjd83TqMf560wKK2moXJbzLyOzhUDEdrEGZeOheQHI5xxGpGevpMmg2kFx53lb5gcLLIxlkTgj5WYkr16AgVYR+w4Zsn6H0/l7c+9Oxub5e4wTjp6f8A6qQGKmv3Phq8SHVmWSzkbbDqWAq7ieEnUDCMcgCQYjY8fISqtsEHdgfeXIBA79/8+/4gSITszMWYSJt8s4K4wfbvnnOaraPpA0geRCzLaouI4W5WLpgJ3VeuF5AGANoAFMCtrfhn7Zex31lN9h1ONRH9oVN6zRgk+VKmR5idcchlySrKSct0TxR9uv2s7yH+z9UjUyPbPLvWVOMyRPgeZH8w5ABGQGVSQDrYw31HHf8Az+FUtb0Sz8Q2YhuFysbiWJ43KSwOAcSI64KMASMg9CRyCQUBmeOfh9Z+Ore3kklvNN1OxZnsNStGCXVg7AqdpYMrKc4aORWjfA3K2BjF0j4l3XhLWLPQ/GRtbO/vphb6bqsMZj0/W3O0BBksLe4LcCB2O/GYmkwyprw+Irvw1ffZdaIktXYC31YKFikJICpOo4hkPQN/q3PQozLENfXvDlj4m0e603U7O11GwvEMVxbXUYlimU4yGVhg/j3x6ZoAsq3mRruDDcR15P8A+ulklwFHX2BzyMV5yt9rHwMutuoTah4i8DjAivX33WqaCMn/AI+Dy91bDgedzNHjMglUvNH32m6tba7p1veWdzb3lreRrPbz20gkjnjIBV1ZeGU5BBBxg5HXigLQly5+uN35/wCf88u34+9t3den+f8AIqAFt49WwcY69f8A69OQnHXjtnq2O/8An0pWAlbDKv0IHP501m+bvjq3tikdv3e1Qcds9BSKu8MR35Pv/nNIB45x+Rxzu6j8utKeXbv3B9T/AJzTd2Cx3fxYH+fXgnmgZRuvfp6f5/zxQA/77fh17CkYM33fvLzjHfr/AJ+lCfIy/wAPbgfX/wCvQPlDN6DgEZx2/wA+mKAEcYJH8Ld8dP8AP9PxpXTLbe/Tjtk00pmQemR9FPOP8/X8EIKLgZLbuvsf8igBXXj+70GMdfX8v8+xnA3H1zj2zTZPnXPReM8deB/9bpRH91j935vrnNADTzheG4AI/KnSHnJ7jqO3qf8APoKNnzH6Z47/AOf88ZppYon+1wDT3AdypLKQdo4zx9P89qc7r/wEHAOPrx/n3qPGD8vQ8cdKcGPl/LwO1IB33V+b2AHrz/8AXP8AnNEbNGTgbeje/SkHyDrxkfhxj/P0FIr4UfjjnOOT/T8OlADyoDbV9B/P0/A0/ewXPoM/QVFlsfU46d6X7r9WG3nPp7fX/PFAEmefVeM5PXnH9Pypqc446AHr94f5NIRl19B19D+n14pVyHX/AHs5x/n/APV9aAHKwjcc57dMf570qzFc+2SefT/9dMjXMX3t3AGfejbnc394/hQAhXeeucjHA4p+P4uOehx+X86j6J83r0B/z707c2cj6f59O9ADXc465yM8d/8AChnJAGe5zxj601TuB3NwCeg6U3liFzjnJAPT/PFMBc5b+9j0649B+PehX2NuZs/w+478fp/nFNLk4P8AdyenGf8AChW2j0/yB+f+fqwHqxccs27qf6frTlOVHPDE459DUZICYOVXoSR05xSq53Z+6cf1+lADic8rkHjoOtCyf3ic59Ovf/P+RTGXcQvzfL1OOn5/nSsfMAH4j3/zz+X1osBxms/ArRfFWq3l54gutb8SR3LswsNR1B20uFCciL7FHstpFXjDTRyP6ucmum8MeHNO8HaPDp+j6fYaVYW5/dWtlbLbwwnOfljQBRnrwPr7XopSx6/j6/Tj/P1oiYKP90fX2o5QDPIGeSQRn2P+f/r0R/vGLewHHHBpVG9s/wAOR1/z7fypAORuJbnk/l/OgCRuVA5/EdP8/wBKZOx8iXb8zMCMBu/Y55p+3b97noDx19aRTk/N95efp0qQFdSAy7gT1JHeuB/aD1OPTvDGhGSRY2m8V6FCoK7vMY6lbEKPQ4ycnoAa7xiB/F8wyM49q8z/AGqLGS88D6KsNzJZP/wlOjqLiNAz2pa8jjDqGBXcrOrDcMZHORkE6MOozxn4Zs/Evxy0SG4DIy+Hb6e3nhby5rV47qxG9H/hP7zngggkEEcGp408KwXupWMniK4uNI1izdYtI8W6YiwTIS3EM+VZArH70coa3kJGAr7VFHR/Fd5pP7QNrpviqWxi1C30EW9reQAx21/592OdvPlOxtwNjHllIQsMV6vNbLdRyQzxrJFMCkiOoZWGOQR7gdK0um3/AF0QbL+u55t/bs/iLU4vB/jy1g02/muElsrq1BGn+I1TL7YWcloZ14LQOd4ClonkXLpsR6xqHwwMcGoz3WreH1BRNUk+e6sPm+UXWPvx4+XzgARgF85LiPxL4ItrHw1No99pz+JvCNwNktnMnn3NgAQyNH/HIiHBG0+bHsUoWK4rH0bxnqHwf0xLjV9UbxJ8P5Iw1n4gJM15o6HI23xH+ugBAH2oAMgGJ1O17grzYHptjfR3drHNbyRyQzJ5kbowZXXsQRwR06ev0qdmIk2qSHB7Dvgf0wa4mPwhceAI1vfCR+3aXcjzX0Z7geTMCM+Zaytny3b7xUt5chJPysS56Pwt4msvFli0tnM0iwyeRPFLGY5bWQAFo5EPzI49DjrnkEGmBrQyBkzu2txkqfyqWLDDgnCnv+VQhsscenA/w/L9KkiODjPfAOOlSA5zvGR/EMYHYmjH3eTtbge4oYZ+U9skjHb1ppONrA/l+H6/57mkA/7zbcjPQ49ew/z+tCvuAH8PTJPUf/W/r+aPNn/aHB+vP+GKBkE/eZeO3XmgBzfKW+b/AGffJz+vP60HhGJ+Vev09f8APtTVG4Feze/X2/z/AI04kfxN0xg4pANY/vAfrgkYz6f5/wAhTINnPO7OPf8AyaSRdrx/Xt3/AM+n1oYlskZ5459MD+lMAMwIY/wjJI6ZH+RQ5wcZxhic+pNBLGX+83Y56+n+faoyA6/3h90cdR0A/wA+lADjhzu68g49McDnH69fSkZt3zHlWHQHrSr824btxb1GOlEhPzSdNoyR6DHP+fp16UwFeTb8xbk5OP6/n/nmlO1nz97kAcf5/KslfFlne4Fizakzc5tMSRj1HmEiIHqcFwx7ZqPUNVu7V0a8utL0eGRiqAt500w7bS21Vbp8u2QZPHuAbKFmRujbPn4z+P8An/69Z8PiyzvSy2rSak3IItU8yPPoZP8AVqeejODWSbGPVSFGm3+sZ5Muqfu4ScjH7txwc944dp65HFTy6xvvmt59Wj8+MqHs9OgMsyA84fh3C4GNwWPrQBavdVvktxPcvpuj2u8AvdSebIwOcg4Kojg4xh5FPPFVRFHe/MsWra51Cm4IgtQuP4lwkbjoAwjkNGn6dNG6zWOmR28xjx9r1CczXAB7DBd3UdwZE9Ppebw9NqB/07ULq4VhteGH/Roc+wT95j2aRh7VIFee+ksFhtbnULTS/LAMVrYxCaZR2CBlJYdeBEOn41WttIW7uUuLXR3uJlYMtzqtwSy8fejU+Y6nk/LtjH8xuabpVrpCtHb29varIwLCKMJvbPVsAbj3yev1qypPnKwz8pz06e3/ANf3oA5yTXEeKCW+1SV7a4UMJ7W3a3tWyeMuC7RnPcyKDkAZOcaWj2NnZxLcWaQK1yN3nxgM1xx95pOrdOpJ+tU/h9ut/CViuWVoVZWz/AwZwR9R0P0qZ/CNmZPOthJpdwzlmls28ku5A5dcFJDx/wAtFb2qugGlnbuKn1bn26f4flSs+PlU7sc+9Z8Lahp/zSeXqEUfRlAgnIwOoOUY++YwOmO4s2t6ksrRqWSQ/wAEi7CT7Z4b6jI9zQBOvyphdvy8j8Of/rU5/wDWDDfdH/fPemxD5Np6KME05Ceg7/xfyoAduy+7/a4GO/Xn/P8ALFCnaqjq3egSbwDwN3X2zzS+ZhVyuePT/PpUgIXwpOTtzk/SnA7fTpxj/P8An+ZjMjMTuOfy54pq/I3zdsj/AD9OlAGfrmm3TzfbNPulhvo0wsc+WtrgDtIo5XrxInIJGd4Gwu0PxDHqwkhkjks723VWns5T+8hByFORwyHBAdcglSPvAqLgHmAbv95u+P8AOahurBLyWOVh++iy0bjh06ZwfQ4GR0OBnpQBNPbpNbtHKiSRyBlkVxuV1PBUg8EY4x0xXP8A2S68DWxa0W41LR4xn7KimW6sxx/qT1ljUZPlnLgZCFvkiG7PeRW1xCrusb3B8uIEY3nGdo7ZPzHHUgHg4p6vhW3bcnv6elAENhqEGr2MdzaXEdzbzgFJIm3BgDjgjvnjtgjmuB1n4caj8PL641bwGtqsd1O91qXhuYiKy1J3IMktu/S0uTjdkZhlZn8xFeT7RH1eqeHZrO+kvtJaO3u5H33NvJxb35wBlyASknbzVBJ6MrgACzo3iCPXY5NqzW91CQLm2l2ia1bsG2kjnqGUlWHIJHNUBm/Dz4l2HxH0i4ms/tVre2ciwahpt7H5N9pc2A3kzx87WwchgWR1IdGdCrnfiGeN3zNyCB7/AOfWuU8f/CuHxfqlrrmn3kmh+KtNiMVpqsEYkYxHJNtcRkgXFsxOWiYjB+aNo5Asgp+DPirNPr8PhrxVZx6F4tdJGigVy9nrCRgF5rKUj94oDZaJ8TR87lKhZHQHcJLuTqNp6Y/SnLICq7ccnGT6f5/z6QsWCcnc2M/7x+vv/jT418sbVbcFwM4z602BJ94bv4l5yR3/AMjP9KUy7cbT82e3t/8Arpgby9vVuM/59KFyNvzYb1I9en+f/wBVIBzOSjbeOMAY5z6fpS52ooPRsDPr09veml+du7BUHbjjr/jj2pWb938pPuQPz/z9KQCZ3DuG2gHjOTn/AAoOAjem0k/57UAqq7ugxngUEkyKOcsemOn+f89aegBIeSx656Y/z/kUMBvzt656+2BQjllYKPp+AoALqyrxyCOc/wCf/r0ABJK7W6dOnvTXbB/HOMY/z2p2dyf3toyOPrn/AD7fjSTAsT229R/n6/rTARm4VVY9OnT+n1NO+8M92PTFNc8g/wAJ4/H/ADihE3NgnDdQMZz/AJxQA7epf1UkD+v9f89KAuY+dpxjHHHX/P8AniiI7uM7dxwKN5CenbH6f4UALncWO7jjB9xj/P0oYFEXbwwOBjoP/wBX9KU8MvU9+eMegoOVJyeVbg4AqQELEfKvA9h93/P6UiPtbLdBxnHTv/SnRxxxuwx33H1J6Z/Ifp+FNIZlXrngk+vr/n2/MAdu2RksSVx27d+KGfJHPUnt1x6D8qazEDDemc+h7/59KQDYNnPqc+wFAD2JCMrYyDnrgY5H+NBfLL1bd0yMZ9v0/X3zQR904+bsOnJ/z+n1pqHaV3emefQUANLb/wDeUYx0xyelDncP4tzH8u3+f6UJtAYf3gc8/e65/wA9KNwce4JAHqfT8P8APeq6gG0K27HzZI/w/wA+/wBKap+b/aJ59+efp0/zjNOSTJXbz7+nH8hT0AVvl428E96AIsKPl5wO56g/5/l3zSY3Sbem0dMdO3+fp+FSNhQG/hyNw9Bkf/W/L1prttXHyhiNw+b/AD6daEAZEp8wr94ZHA/X/P8AWpD80vynbj1HQf8A1sUxPk3blGWPGTn/AD3ozjkqCVwSM9ex/HmgBynB5DcnOfcUgO9lYK3HbPt+VMCsf0HXvUjMyk7hyxCnn+X0/r+QApP7xf7o6Y/P/CjZ8o7MtMUqgxke59/880533su4YXnPP+ew/Q0gH7QpbCnAHHtgen+elJH8rLw3c5Pft1/z1o3bztXacHBps85jiZgnmcZChhlvbrjnHfjmkA5iAobqQMj0rgf2hFEnhTQ0w37zxXoQO0c8anbMfoMA5rvGbA3NtO0EDn71cN+0BLJF4V0qRN3mx+IdIlUgrkhb6BiBn+8AV/H8DWvQDN8XaLa6j8f9Dsby2hubHVPCmrLdQzR71kMF5pXlk/T7TLjuN3BHNGueKW+AmmQzazeTX3hPzrexW7ly11p8s0whiSTvNGXeNd4G5erZAzU/iVtv7TPg8bQ3/FKeIfmz0xfaFx+P9KpftSJ5nwtsWXaRD4o8OypnjJXWrEgD3yBg9/xzT13A9Bs72HVbVJ7eWOeG4AeOSNw6yKe4I4IPXI9Kxr7wrcaLqk2paJsjuLphJd2Mh221797LDr5cx4/ecg7QGB+8MzVPCWpeCNWm1bw0qzQXDNLqGiSTCKG4Ow4kt2IIimLBQRwjjOcEA10HhLxlYeNdKW4sZGYK3lzRSr5c1tIMFo5Izyjj0PrxxgkA830mw1DwHdS6n4Ht5Lzw/GSdX8FygQXVg43DfYbmCwuSrDyGIgl27o3jO5peks10z4p2cfiXwnqwstTjP2eW4a2bDFSha1vbZijblHG1tsse7KlQcN0XiLwpFq93HqFq5s9ZtomS3vEUFwp25Rx0kjOFypOB1BUgNXEa/wCGri+8UfbtLmt/C/xEe2TMm1m0zxEka58qYfelRcsAwxPDkkbl4YA6vwl47k1fUm0vVrJtJ15V3NZvKsiXKr1lgccSx/gGX+NUPXooZQ6A/NjPB/n+WBXA6L4j0/4rCTQfEFhceH/FWmgXD2RucXFuVIAurO4UL50OSoEqAddkqIxMdWLfx1feA9SXTPFhRrW4ISx8QxR7LaZiyqsNyvIgmJYbT/q35xsPyUgO83YHXAbPJ6D/AD+X9Exh/mH1+uf/AK+aiZ9rouML7/w+/wD+v+dSedkleu7nJP8An1oAdIMfrz6+v8/0p0XU9+Sev3v89ajEpcqvVv5cf1z+tHmA428Bv0oAeh2wgndx2I5P+cUp4ibjBx+Z/wA5/Oo/OVl6YZuPp09/xpksqwwNIzLHGvLOzBVT6k0ATv8AM4HO3+P3Hr/n39soDtxzjbgj8ev154/E1hJ4/tdQO7TILzWCeQ9lGGhI9RO5WJv+AuTz0qHUtVvreXdfX2l6HHMcQxxH7RdSgAk7S4C54+6I36dc0Ab8jJGjSO3lxxqS7scBR3JJ7dev1rJ/4TS2u42/s2O41Vl4U2ihoCR/02YrFkHsHJHp1qoNFjvJvNXTZdRuIXV0n1WbaqEdWRCG8sgA/djQE+g5pTqq6wOdQuL3A2tHpaFYycAYMoJKtzx+9T6dcAEuq6jeQ7ftV9p+ixTAbQh8+duAfkZwq556eW+c5zVOHRrbVpEuF0u+1R2O9JtYZlRGyMFYpAWiYnn5IV+7z1Bq9ZadcRiRre10/SfOHzP/AMfE8vP8eNo3D1LSfQ1YXQI7vi6uLq9GMMs02I2H+1Gm2NvxU0AZ99qTaldGGbVJpJFBR7XSkMmzkfLJKAzoQcfNui7nAp9jp9xYzGSx0+z01pF/e3F0zXV2+OgfY3zd+TMx9jmtuELb24jjCxxqCsar91QPQfr07j3pwU9mx39e4x+n8vxoAz38Nx3kZN9c3l8Mf6t32Re4Mce1XHX7+8+/Wr1jp9vplv5drDDaxjPyRIEQEkc4HHb9aeDz93JXnGeueP8AP/16eJFO1uGLE5wf8/8A6qAGiPYY+wAww9Dxj9alz5n3g27qc9V/+vTGcNuzgc/lj/H/AD2w4/KMsGyw/Ltj/PvRqAuMFifbj14/yaMqxH90cnPHfrSyPtA49Ccn73+eO9MHzNt+Xcxx9O/+f84QHL+GNM1KHw9F9ju4o5I5rkGG4txLG3+kSYOVZWBxxncwx/DnJrTi1m5tRtvtNnjj5Xzrd/tUfQHnAEnf+5jjkjitKztY7G2ZI1O1pHk5PQu7M36k9PSnOdkZ2/e9z15P/wCuncBkU0V180ciyjPOw556/wBc46/SlV1ww64/TH/6jUmFEu7+8B8x6sB/n9fes+/j1JL7dZyWkkDEB4bgFSvAHySKD2BPzK2ScZA4BcC+RkhiM98k8eh/z+dYa+IdU0qdv7U0iRoWkk2XWmsblUj3NsEkRAm3lduVjSQZz8wAFXLPW9xIvLK6sHUZIkIkj7/8tEJHQd8dR06VoqxkXn23c0gKuia7Y+ILeWaxuYbqNZBHLsbLQPx8rL95X5GVYA89KuY3r3YdeT+I/nVHVfDlhrdzDdXFrG11brtjulJjuIlPVVlUh1HPIDDOe9O0+xks0XfeSTRDP+uVSw9gw28fUEnPWkBcG12Xr6AenPf8+9ITgFvb8s9aoaz4hs9AhilvJvssMjBPNdG8qNuT87gbUGBjLlRkgZyQKuRXMc0EckexkkAkRkO4MD0YHoQR+dMBwHl/LyOenJ/z/n3pyLsfO7gnr700hSfm42gNjrjH+f5UAgnHXAIIz3780gIr3T7fU7CSG6hjmt5hiSN/ukdf5/keR0rCju7vwVtjvpLi+0fcRHeud09iPS45y6A8ed94DHmZw0p6AzK8W7K7cDG05HY8H/P86r3ur2+kzBZplhmc4WNctK3+6i5ZuvYGqAsmRZQjK2d3PHI55/r+tZ2s+HIdaMMwkltb61LCC6h/1kQOCVwch0JAyjZBwDwyqRBaeekXlafYx2ds3zA3TYEXOTsiXJwT/CzR4PbrTL5YLKFW1bUmlZ+EgDeSjYPKLEhLyehDF6QENn41+yXzabqSKuqJ2tlMkd0MHlByVbAyUcgqATllG8weM/B8HxR8NtpeqafGtlK6yq00jC4glQho5YmidTDMjYZJEkDoQCMHpZ1SxTUfD7WdvpNrHYhdwa6P2eOHbgrIqp84ZWAYZ8sgjIYHBrBgvbjSBjUb++8Rab5YIu7X9xb2/Y+YVxuj65dpZMDO5RguzAwv+FqTfAvVLfRPHGqx6lpdwSLPxASizQICuF1GNceWfmUfa1AhbB8wQHb5nqhLISvRgQCCP8/5/XzX4a/AlvDPj3VPEmpXmn6nNq1obKOCG08uG3hdkZ0HJVlbaOAoGBjnccq/hfVPgW/neGbO51vwjGf3vhyIhrrSlyPm08scNEozmzY4AGICm0QSGwHpibR8i5Ucd+WOcdfXP55oV97dNu4jgH/P+RWP4N8Zab470O11bSbyG/sbrcY5oiV6NhkZSAySK2VZGAdGUhgpBA0vNCqcBVwOCcfrTAsZ7fe9Pc//AF+n/wCujOD97PByR7j/AD+RqONyzD7q456547/r/L1p4k3AckFuvqelIBVG8jgnjH8qcyb06khs5OO45xj86YGIfcF5XOMdD1/z+P0pVYJuz8wU4znpQA4HEh4+btkn9aCoCcs27jkDtRuyrbsZ6Y9f/wBdG3f/AIev+etICOQ/d2k+4xnj+vrTlGDtx97uT1OKWRcowChR0PPXn/P+c0nnYO77u0+v3T707gG/P+0o+b+f88ZoRCFU9dx4Pr/n2pqg+Z935fQ9yTz/AD/z3A/yN3DHH16/zo2AkO4Qc5Vh6dM8/wCfz+lOK/NwTnPT60wN8u3+L1H+fUClDYAONuw+vr/n/PSkABlkC56Ejt+n+fQ+lOI+ZmP3eOnp/nFDEx52/wAQA+gHFBwF9OeT6YzSANu1ec88HH+en50YxMpI/D26f4dKcOrce+c9P8/1pPu4VR78H2A/rQAwpjHzdzkjg9qcVU4GOwQ84xREMDPA3cdeopD85A+9tA753ZH+H+e9ACkBWbA+Venqen9eKPur3PpjsR059v8ACkjkDO3HUAg568Yz/nmmsSsTf3V5z+tACCPI+7z27en+fxpztg8j5jwR39/x6flShlG39OOnXv8A5/oCMttz+GD25/x/n9KYDNmxW+XqMEnv7fkaWbiJto5xnGcA9f8AOaV2Codv4Z68f/XxStPt+uOnXP8AnikAyZlSMsPu9enI6/j1poGJN3zbuw65Jx/9anM7Mv3tzLwB6mo3bAxu478f56+tUgFG0he6+3PtQr8bcnrt+uP8/wD66WE71DMevTjvikXgLweTgjPXp19+9ADwNy5bg9GGOV/z605fv5dWyvBx83fPX/PGKZHLhFzk9wP60qHb8vJ6D/631+vt9aADGzbn+EA4/L/CneZnb8uPTuBz/wDWpok5bb6An/69OSQgt1OOuO/r+X+NAAg3NgrwcHn+X/1/anAqQv8Adzxjk55/woSTjLH0x7Uebn5VbDEZ6fd71IDTIE2s2SykdO/T/GuF/aKGPh5Blivl67pD5BxtxqVsQOh6nC9O9d1JtZQcnjg44OP8/wA64n4+b5vBFrGu7zJPEGiKOCdp/tW0P16D8P0o6AV/E8Ui/tD+E5trbR4e12AgLx81zo7g/wDkPjr1rN/akYSfCqGHLL5niTQEUg9SdZsmUD8QP/rAEi54wPlftC+CSpYBtG1tTgcY8zTDz7/L/Oqf7UBmT4a6fcIA8Nj4o0G8uFBG5oY9VtWYDI9hxxkAgc1S2YdT0cfvRz9T+YNc94t8CHVdUj1rSbptL16FNnnqC0V4gx+5uI8/OvofvocFTxg9Ajc7SeVbBPXPOB/L9RUwl8yT/d4xnFAHM+E/iBHrup3GjX9u2la9YqZJ7GRt3mx7iqzQvgCWJsHDAAgghgpGK1te0G08TaXLa3itJGcMjoxSSBwQyyRsOUdWAZWHQgGofFvg+z8a6Z9nnaaCaM77e7gIS4s3/hkjbHBB5x0PQgjisXTvF194TvI7LxMYY/Pm8my1WJdtveFidiyL/wAspT0wflZuFIJALAy/HOjx3NrHY+JZpI7cTqdK8Q2b/Z7nTpicrubH7pshV38xy5Cuozh47Txxd+Hb6Pwx4/t7NotUc2lhrSwAadrOThYJ1Ixb3RGB5bZjlP8AqmJJhj9CmjS7ikWRAyMvlvGwyGHdTnt19q43WPDU3h7T7q2W1bxJ4V1D9zdaRcRJcPaxsfm8sPxLCMjMLZIAOzOAhVgK/wBg1f4Q3Ak02O81rwmoy9iSZr/SPmG7ySeZoAp/1ZPmJtwhZSEXrtE16y8VaJb32m3MV3Z3Q/cyxfdbnkY7EHgggFWUg4IIrz3TPEF18KdFhvtPlv8AxZ4BdcJJGHutS0BQxBGADJc26ZClSDcQ+W2fN+7H514g+Kd1qXiK+8beCL2x03wndXbaYjnzJW8c6pIFgX7JGqugCeXsWfY2+RXYqUjcOAfRl9qMOnWUlzdTw2trEPnnlcJEnTBLE4UfUj+tZifEGHUYlfSrS+1hZPlWS2jVLfgcnzZCiMvGD5Zc+2BXCeAtb0XUtUvFMEkfiDQY4DqUvie+E19pjSAkHaSyqpKnDReXE5UhT8mB2I1Ua0PMjm1LUlORi1T7LbMDkZDkqW6fwu3sKoA1K/1KUrHfalYaK0mcW9ov2u6lBx03rjjpgRN9aanh63vLhbg6TJfyRnzludZnLhMD7yK+4x45OAkYPOcZzVqz06+SOSKE6fosEn31tYRLM3bO5gEBx6o3fn0st4PsZ3je7V9RkiberXpM4Vwfvqp+RD15RV70AUv7dXV5mWO+vNX6hk0mIxwnHH+v3YDdf+WwJ9OuJ9P0q+gE32e103RTOP3hQG5nfk/fb5V3deSZOSevU7Mc+/cMZUHkH/P+eadn931O1f5en86QGefCdrcxub3zNUZjk/az5idcj92AI/xCg1pR8cDdjHIx06jFLuyRz90gnjn0/wA/5wM2BkN74x/np/nNADSPL+XJVuCG68j+frg1IoDO3+1kYPT0/wDr+9NK7GJAb5RjpnPYf/qp2Rllzy3GPX0pAIp3c8jJ3e/4/wCf60ozjbkDcQMntnj9ePzp7OuAf4evH5/5/wA4apwv+0q4z7cZ/lQA3+Nfl+Vu4HT/ADzQx4YBtv64HX/P+crLwintxgn/AD+FKTsXH3u307j+v+egA6NvmHHpnB/z/hQqZbHucfSmeZngfd6HPOOv+NPjA3Ec5PvkigBoB2rt4OMHA+7/AJxRt2/eXnA6f59T/nindWPzZXp7HpQG2suWAwT1/SgDI8Ea9N4h0me4n8vzI9Rv7QbBgbIb2eBcj1Cxrk9zn6VrwttI56c465H+fTr+dZHg/TP7G0iaFlP7zUL64Ab/AKa3k0o/PeCPw9a2Ml4/ywPTHHWl0ARYym07fmI49Px/Wm/dXcNwC+v+f8/pTmbcG7HOc+vQH+X+ex5mV9s4OOnf/OPegAC7FK9G6fh/n/Gns2Ov3m4xn8aaXAIPJbg9M49P5fp+FC/dPPB6n1/zikBl3VlrFtdzSW15Z3kMnzLbXcRhZTycCVONvbmNj3ye8trrbN8t1aXNnI2VGR5sfBOfnUkAf7+01oFyq4b727n2I7/5/rUM1zHaWskkjrHDGPMkdyFVeeST0H1P/wBamBJ5rBt2T8uWHv8A1rDn8GWcXmSWMlxo9xIWkaSwIjV2JyxaNgYnY92ZC3PUZzVyTxClyn+iw3F9xksibIGGevmNhWHOPk3HnOKxdeTxHawy3P8AaOmraK5aSFyLcwr/AHRcGN1KjpgxKxP8fqwLd1rWpeHRu1BdPu7ZX2iaKYWsgJJwvlyMUY9BkSjPOF/hp9l4wj1mZYbOCbzihfyr1Hs3AxzhHHmMBkcqhU9N1YNv8R9N04wyf2Vq1vcTEwpd3aboSvqbssyeXznIZic8AkHGlc6kdfiVJ9QtZIJFEv2XTYRds2c7SzsrfIR0bZH67ugoA0L9GtYfO1TVFtoHbYVjcW0bk443Z3liePldc8cc4Een3TRbl0vSZFMvJllT7Gjn3yplJ6DJjIORz2qr/Yl1bxSSaXb2OnX3l7Y7vUA+oT4zyHPmKxH3sfvjjIOOMGsbm4tj5fiHSry8VmbM9ux1C2wMgZhVFdW5PSFgveQ9aALy3bXgBe+kvtxKmHS08qPI7GXcSrL/ANdEzyMdqrS+F77b9q0s2eg3hHzkL9oN4nULN0G4Z+/+8ZSeGILK+7pWsWuuWvn2NzDc2/3Q0T7gpHRfYjpg8jv0qdTkDoowcjtj/I/U0AYvh4QarGsd7byf2pa4eaK8cTNE/Z06IUJHDxqo4xhWDKNnfjY7NznIJ9f8g0k9tHIyMwBaHLxv/EmcDj65wfXvmo7zUIbJoopJFR7g7Itx+WRv7uTxuI5C9TtPXBwAZI0WbwvPJLpimSwO55NPGMI3JJgPRSSTmM/ISQQUOd2jo+qW+rW/m27LLGrlGypVo2U4ZWVuVYdwQCOKssPkRd3zN0zySc55/L+dZuo6M09z9ss5vst/tCiTbuW4UdFkUfeHJwRhlydpxuBYHM+LPhddW3iK68TeEbm203xJcKrX9tcMy6b4hCgKq3SqGKShQFS6jUyoFQMs0aeUb3w8+KNt44udQ064tbzRfEGlrG+oaRer/pFmsjMiSKy5WaFykmyaMlG2sMhldF3NN10XUk1vJG1pewpueBjuyufvK2MOmf4h0PBCsNtZPxI+G1l8RIbeR7i80vVtO3nTdXsCi32ls4UOY2dWRkbau+KRXik2gOj4GF6AdJHz6denXJqTfn/gK9CO+a4Hwv8AEnUdB8R2XhvxhDbWetXhKadqFsjJp2vFVJKxbixhuNqs5tpGZsB2jeZUdk7hJssFU9sjjpk+lMCZPlfd26HP6/z/AM4pfm3bcKMDH/1/0/CmCRm24YquD+H4/hmnZ8sSE7vnOTu7Hjj2FIB7kmMsFxuHHHPTvSk7gpX5e3I4z2pqyYUMeWU5A9ef8/56ELkN8vUDHHegCQsF+7w2ORjrmopo8yHZuwfQE/5/z70q/vx656H/AA/WpFl8zLfw5we2KWwFeQFGYcrtOB3yM4z/AJ/rSxMQm3nGMfT/AD/9apnG8DnoOSf8+1RMuB83C+n+fxp7gPGSm0DHJxxu/wA+9KzbSvZcE4Hp0pqzN5x6seeM9R/kmnbj90Hjpx2/z/nNFgHKrB9p+8vf0/z/ACpOCm7+8Mjjp7//AFvekZ8/dwOxI7D/ADmjzFXjPfOe479P89KQBLwrZ6AfhTsMFX3JH0pGfb838K9c9v8APFDnnaOcYwfT/OM+1IBeSdvAPTHTFNPPzdN2Mfn/APW/zilDKWY9+pz2PP8An2pEYSO2445549CT/TNADthJb+Htj9Tj68/5zTTwv8PBznpQ0nns/Py8Ek9+/wDj+A60GbKdT/U/h2oAFTYfl27VOQe34f405Ts2/eO0Hr39vb6UCYRpu3BVxnr27n9P89KjkusMdow3Geenf9BxRuA/DF2x8rEjp6//AFvbrUZ+7/s4Bzjt9P8AP4UsZ80BTj0H+f8APakXIT7y+h56c5qgEJYEY3MemB+A/wA//Wpr4KjLcMOOP8/596HHK8ZbaSPy6fp3/WiOXe33jyfXp6D9P1oAB8sXy9hj8P6f/XpT/Fg89evT6UxWwgz6Ee5x0/r/AJ5pwJMat1wPTHT/AD+NMBzNgenPJ9Ocf5/zkB5xjoSMDtgf/r/Gjdt4yPTrinKGD8HcM8c9e9AAOD325O337f5H+QB9v8XGfTvQTuJ5AXHzH0oRiu7cPunBGfz/ACzSAcV2D5ejdPp25/z0+uXMPLZtp7ZJx/n1+lIT5g64445/Pj/PWkYl2G7HXkZ6VIAWLDK/dZs46YHGM/56iuO+NqAeHNLuG2tDZ6/pU8qn+JRfwAYOD0Yq3vsI4ySOw3LvZdy5643ckZ/yfeuM+PMgh+Ft4zSLG0VzYuGJABYXkBU88AlsDPb680WAoeNJQvxt8B7myWttWiPv8tuTz/wH9azP2upGH7OfiSRW2vB9knDBd20x3tu/81/A1tfEBEPxY8DszKmJNQRQc5ObXP8AJf0H489+2jJ5f7K/jiZjKqw6aZjsI8zaksbHac4B445GDjmqtowPVZiUlcH5SGJ6/d5z/n/9dOWRgBnbnGCDx3PP+f8A61NuJAt++7r5pwM8daI2AP0PPPpwP5fp+NMCRG2qqhuTwCf8/wCfzqvfadb6xYyW9zFHNbzLteN0DKQcHp+Gf1qbfz6YyBzj2/8ArH6UM2cjJ4A6Hnt+X+c0AcC76l8GTbxJHqGveFWIhwga4v8ASd0mE+UDdNbqHC8ZkjVQfmUMR2Wmatba5YW95aXEV1a3CCSOWJtySA+mOvII9QQRx0q6Fx5eD2xxx37fpXE634B1DwjfXOseDltYLu6k86+0maQw2OquWXc4YA+ROQDiRQVZiC6tyaQEHxU+EP8AwmOkaoulX0+k3GsGNdSihk8mHVoQV82N2UFo3kjBjMyfOFOORwPnjSf2fvFPijxrr13oH2X4e2vh6GXTrHwjpl2kN7bwSBA08MzI8VrLcBT/AKTEp3A7dwPmO/1D8P8A4jaf8QdPuXtFuLW80+TyL/T7xRFd6dMQP3cqAkA4IIZSysOVYirPibwfZ+J3t55vMg1Cz3m0vIG2XFoWHzBW7q2BuRso2BuU4FOwHl/w2+EHgbV/BtvH4TtLzwvrGgzbjcFXXW9PumO6T7YZCzzlzy3nM8coyVYjaw6fw58R77S9Wt9A8XQQ6frV4QLG8gLHT9ZPGRCTzHNwcwSYYjlDIobbl+INDfV9d09dauJPDfjKPdb6R4j07i3vhlsROhO1wwAY20+5STmM7sMtyHxLbeLY4fB3xB0rSYNY1BXjhtiTJp+ueX85ktGcbtwX5zE372IqxBcL5pAO/jZS5IO0dsDn/PWpQ+SpPRsAduf84NefS6jq3wd3fbJNQ1zwmFLC9bNxf6RyWPnfxTQBSMSDMibfmDKdy9zpupQalbR3FtcQ3FtMglilicPG6HkFWHDAjuKALSpsZ1LfNt+XjoM8fyFOxt+U4wD6f59z+FNQ7u+3nggjj/P9BQJMn0HHANMCR22Y/ibcVx68f/q/PtTuQp5IOMjHY/5FNSRtgOQG+v06Ur5RwvHzKOT/AC/nSAXkyM3RVyenb0/p/wDq4aMQ7v4j156CnMcOrFl5OOD0/L/PHrQmVX69f/rf5796AHD92v3ue+f8/wCcUZwMD5dp/wAjp7imqMouTjC7TjnNP37i394EDbnp/Tr/AD6+qARlUKvTGT0HUf57UuGdzn7zent/+r8aR3xjbgcev+fX070obcOO/LfpxSAWNNj/AHu+Bj8Rgfl3/wD1rEDGR825u3vSDOGwfvdz2/zj/PWmrxEcHr074HfP6/SkA5vlXP5//W/z6UjHIX5vm5HT1/8A1UueC559cn/PrQPlXbn5SB3/AA7ev+c0AY/hO6luv7TaaR5Gj1KaMFj8qKuNigdANuBxjJyTkkmtf7qn+HcPw6jn9e39BWN4TszbXWtIFKq2pNIgPTDRQk/+PbvzraLGRc7vm/hHo2c/0z/jVACjDFVbBB9OvejzNz7evPT1qlc+IbaK58hWkuLhW2tBApldGxn59vCexcge9MaXUr5l8tbewjyOZB9olYc9lYIp6HO5x7dDQBpEsU+XLMBgdTj/AD9fWs0eJbWVmitWe/kycra4dVIyCC2RGp4xhmB/Ks1rzTb4SR7rvxFMB8yDE8Rb+633bZG9m2np1qbU9WvLZIlmmtdJiYHbEM3V3MBnCxoMAMOOgmHOMcZqQLU7308bNM9vp8SAltpE0gUZJYswCL0/uuOeves2O80+4VZrWGfxDJkGO4QrMu4Y+dZHKxKQcZEZB9Bxwr6Yt4Y/9HbUGXY32rVnz82c71ixhW9gsXb8NGXT5ruRvtV5cScBgkbGBVPTgqd/PcFyDntVAUbvVbxrhI7u9tNLkYBxBaD7Xd45+Yblxjg5/dMME/NTLXSjNcJcQ2K+dxIl3qUrTSxFgeUTJKgBjlA0fPGAOmrYWEGn2rQ2sMNurEkRxKI1DeuFH5n/APXVg/6vK7V2/d5+o/z7n3zQBQfSGvI5BdXM11uA3R8Rx5/3V5YHphy/AHqSWQeD9PsZ5JLKE6fIzhmNqTErtjG5ox8jHAA+ZT0HtWmg+TqT+PbtTlG1vowz/gfrxTATHK7vu9D26/8A6sfh2rDX4iabb3bQ6g02jXClVC6lH9nSXP3Qkh/dOTjOEckdwDxW4h+UfNn3/LP6CnMglBVgu0jBVuQwOe34Hr/+pAU7rQrS+uvtE0H+kcYuEYxTbf7u9CG2+2cHuPWayt5LZdrTyTejOq7/AG6AD8x9STzWbaeB7HTlX+y2m0RVAxHYSeXAB6eScw88DOzOOhGARpWaXUVvtmkgmXs6jy2/Fcnn3yOc8UAV9a12x8OWsc2oXUNnDI2wSzNtjVsEjc5+VehxuIB4AJJAqfUbO21iwkguI4bq0uUHmRyKHilQ+x4I+vsfeoIvFFl/aItXuI4LqRiiwzq0LTkZzsVwN4OOq5GMHpVOTwRaWkrf2fJcaNJuyfsDiONm/iYwsGiLHuxjLdORgUkBRuby68AqzXT3OpaMpx9oIMt1pyY/5bHJaaIHjzAC65y4YB5F3rK5jvbeOaKRJoJlV45Y2DJIpHDK3IIIIORwQevrXSbULEf6R5N4B0e2HlOenVGJGfcMPYDvFpmgx6TdNJYsttbyMXltiCsSk7sug/5ZscgkAbWOTgMS5YEuraVDqtqqzbkkjO+KaI7ZoGxgMjY+U849CCQcqSDUh1abSJ47fUtmJnEcN2i4jlYn5UYf8s5DwMfdY/dIJ2DTWVGXKsDsba2Gztbg4Pvg9OvI9aZdLHNbtDNHFJFKpR0kXcsgPUMDwQf5fjVAVPFHhrTvGWgXmm6vZ2uo6feR+VcWtzGHilGc/MCOxAIPUEAjkCuFuNe1j4DY/tie88ReBo8n+2JN0+paEvAAuwFLXNsve5GZYwFM4kUSXI7JluPDsrGMXF5pvJaIZkuLTH9zvInT5eXGDt3DCrpWV7Hf2sc0EySxspZJYnyGyOCCPfv7GgCS0uUubeOaGWOWCZBJHIhDI6MPlcEZBB65BwRj1qSJt7bf4s88fTt+f5+1ed6r4D1b4bXr6p4Jjjm01nMt/wCFXlW3trjJy8tk7YW1uCfmKHFvMxO4RO7XA6TwB8S9L+JWhtf6XNM32eU215a3ETW93p1woBaCeFgGilUEHawGVZWGUYMUB0ZmAdcNkjDZA4pD8q8Y7Y59un6Gq8ku07WwvTPPft+X+e4p1tcK6/eC9D16jn/69AFrOHOPu56gHn+v4U5H3ljn5egx+FQrKTu9eA/PbjNSKGK7txBPq35f0pMCSJjg/wB04/H/ADmklAYdMsoz+FKsqpwzL2H1zj/GiTr/AHsg5BPXt/n/APXUgRoNrD+LHBB46f5/nTl/drjrk4zn1waE+Zwf4W464x60A43D72OMdm7Y/l+npTAao285x6n0JyKc7fus8cZ/If5/WlQfPuUg9Mc9T/nH1xSudqc4+9x81AB9+TGcKetNLYkbnHU57DH+f84ob5X257dM5pd2yRmLZC/MTnpSARj97gfd47Y6f5//AFUB2X1+Y554/wA96RgT8v3V25yD0/zyfwpWbbKTlRt/yf5UABIYHHBz/Xj/AD9aaSd3J5OM98H2px+VvxIHPXHb/Peml1MrL6jJA5/z6UwItrPIu77wOfr0yP5f54LI/u/h68kemP6f5CgeWSWHQ4HseD/n+lOMeEG7KquR+ef/ANf+RigJQjFP4T2ySeP8/wBacql8Z284B/U9fxFN5HzcnnHT/P8AkfU0MuG7t1Ix3x/kf5FLcBZH45/DntUaRmNSM/8A1vpUrx7ZGGPUH+Wf8+gpm3ZwfTP+fzxRcBiqXHHy7jjjGP8AOKdkqnPfnPf6frTmGQBz8vBz/n/OaRvlB7Eg847n39KADYVGG+8pwcfgcfy/KgHa+M+mSO/Tn/P+FEifvOh9f6n+n/6qVBkYX+7jjt/nHTvQAhdyv44/z/n/AApWLA/d+7zn0HWlQH+LsOBn+tG3hTzjAyOpx/n/AD1oAUqwPzH5Vz26U4liytx1P9f8/jTWfbs2/N8vX0+lOVAsn97tn09f8/SpAamUZsux28deScf48/4Vwn7RcrW/wf1ZuPlktny3RMXcHJ9h1z6DPSu97tj+E9P8/hXA/tG2sM/wT8QCSBLiOO1D+W67lJV1Iz+QqkB5p8Wf2qPDl/8AFTwnY+E49W8d6lper3sU1r4dtDcwrL/Z94oga7bbaJJuU5V5gVCliAATWT+1l+0d4d8Sfs1fELQ1kvNL8Qf8I1eXX9l6zbHS7xREjOxSK4ANyoKEb7YTJwPmwykw/t0RSfBTwh4S1LwZPPoNzBr72tsLZt1tZh9OvELJA+Y0wm5flCjAz1CkYnx3/Zltfh38CviPe6tYT+ONWv8ARLq1/tjVNRN5KS+4IZIZFUIFZlCBHkK9PlXJqle9h9Ln1pcsPtVxgfdkbJ9eSKFyHCjrjH9Ov+eteP8AgXwnb3dnCvgLxrqWh3kdurtoepM+rWMJIwN1pcst1DGB91bea3QgZAIwT0Vv8RvE3hRyvijwlNc26n/kJeGZG1KLaP4pLVlW6jY/3IUuR6ualPQTXQ9A+6jZO3fxn0/zx+H40KMyMrcnOCTzjA4/n/8Ar74fgT4iaD8Sba4k0TVrLU/sMmy6ihkHn2TnnZNEcPC/H3JFVh3ArcA8wA9BwMcY/wA8/p+NUAvJGPQevXoRTxu2/dwAM9evb/P1o27j93nHf8acmS/QngY9cf5/r+KA5Txz8LovFeoWep2N9NoniDTzm21G1A+dSU3wzr92aFwigq2cYBUqQDVbwz8R5P7YTQfEUMekeIJIw0UZc/Z9TXHzPaucb8HrGfnXKkggiu0C7WO7dx7f5/z+mZ4y8I6f458OzafqUP2i3mwRh9jxuMESIwwVcEBgw6HFIB2u6LZ+I9Gm0/ULeG8s7yMwzwyD5JEPUEdfxHIOCDmuD+IfhbGlTaX4mtJvFHgu+k8zeA323RWUqyMWQiR0R8ss0eJYcL95fnS23jC++D9xaWHiaS+1TRpGSCHxI6J+5djtVL0IBsJ+VRMF8tiw3bcmu4J3rC6nckiFhtwcjCnj1HP5UXA8y03xxqHwmsLf+3tT/wCEh8IumbTxV5iNNbfvCFF8EATbgqoukwp2nzVQ/O+je+B77wVqMmreDxC9ndSm4v8AQ2cJbXZbJea2bpDMSdxx+7kLMWAY760J/BN34Su76+8P7po76Q3Fzo8rKIJnIxI0DEfu5H4JBJjZskhSxauT8OWNx4BVrzwXbyaj4atz5N/4UZfLutHcZJNoHOEOD/x7NiN1UNEy9JKWgHdeBPiDYfETSJLrT2lElu/2e6tbhDFc2Eo6xTRnlXB/AjkFhgneT5mO3/DHv/n0rg5dH0r4sabb+KfCuqx2urRho4dUt037yvBt7qLguoJw0cmGQ9NjcjU8O+PWufEX9haxa/2TruHa3jLA2+pooyZLd8/MABkocOvzEgqN1IDq03K6ntk5/wA/ifpxT9xXd6bc8cZ/zj6c/nGNr7l2/e5H8/0pyxgplfYnjPoP8TQA5W2syk9wPqP880RqQfxOQDx7Z/z/AI03ZuXd3xkc9O3X8ql/iGOSoBA9gTQAqjPY8duMnkY/lijYVyuA3PI/z/n8qCmH/i+Y9u2D60rIF2+mOf8AOPekAiEr04ySQe3r/n6051ZeO69QP8/hQijJ6jbjPHTH/wCv/wDXRGMnDfNjOPbv/h+dSAEk+hyRz0wPX+n+c0khZpAfu7Rz7/5/p2xVbUtUtdFRTdXEVv5mVXzH2mQ9dqjqx4zgZOPxqrLq1xc/8eWnTbWziS7Y2yDn+6VMme+CgB9RzTA0yWY+6t0/z/nr61Wv9Yt9OKpNMscpAKwj5pG/3UALN+AP5Vl6idknl6pqkokZM/ZbFWhkcHoVVC07f8BYA4PyjtLalrCyY2On22m2zNukmusRD0DlF5YkdQ7I2T9cAE63+oXpH2ezFtHIN3nXR+c9ACIl5PfhmQjHTmqd09nJPJa3t9JqVyrBZLOEZEeR0aKLkKeP9aSo4571zPhBW13xL4uima/1SNdXjVPLk+z2bK2nWJzgMN6E5G3Mg4zg5JPXW2lTR2scKyQ6baoMrBYRKAmOSu5hgg/7MaHnr3D1Ajkv7izsVIWw0Wyi+VGumVsYPQRowQZ7HzCf9ntVVNNGpygta3mqLkfvNRbyYOOMeTtHzAdD5POfvVrWWi29hK0yw/vim0zH55ipHQyNliOBwT27VacYB/iO3PIwDx/9cfnQBRGl3V4i/ar2Ty8CPybNfs67ew3cyDGcZVlzjoKn0/TYdLibyYY0aQ5kcctJj+83Vuc9Sev1qyIto+XPbJIptyPKHy/xYIHX2z/P8qNAIpOvP8XP19P/ANdKg4yG27uhHY/59f1oRN5XdnJ6ZP3uh/z9evWpFTI3Hd028+nH+f5UwI1jwenXoM9O39f8inwj92oXvnt07/5/yaf5QZtyruX0P09Px/SmpCzLj5vmwR68f5/U+1K4CszYI3YViGyfTPP/AOv+tK/O3/ZHA7qScUE/KG29cdD0pypu9sHt+eP0/CgBrDy5OCrccD0pxBVvVR+uOtJGp37eueGwO/b/AD70oj+XOD0yOO+KQBEWZvvbWzkH1+lABKAdFOABn7w/zz70oG4bh/EcnpwOf8//AKqUkoO2cDA+vPNLcCvqVnDq1pJDcQw3FtMNskUqB0f6qR19M/r2zoPCi6Szf2feXVoARiIyGa3XnoI3J2rz0jKDp06VsPFmVcHjoMjpTBgrt2tyQAP8/wCf5VQFW1N1hVuVhbbgb4sqDx3U525443NUybsYzyp7/pSmMD5lXdt98f5/+tSSRrcRNG33XUhh7dCP8+n5MDltY8AXX9opeaPrF5pt2uBtuF+2W0yDOI5FYiRl5BAEgCZO0KWbdch8QXVjEv8AbFh9gwCHuYJftNqvqWbarovfc6BFHVs8VPJoV3p8m6x1G42gf6i8BuY+nZiRLk57yMB2Xk5ct3NJcLBdW/kzZU77ecSBDgbSOFkBP+5j1OCaQF0Ms0ayIwaOUBkZTkMp5yD3BrNutHmsbw3GntHHJIcywOSIrrPc4zsf/bAJ4+YNwRWvdLmu9O3aLZw6ffPKoMk4e3JA53skWGc9MJIVzk5IHXnda1KbQdS8i61oeJ9VjRTJpNuWtJlG0/P5MAkO1iDjzsJn+NcUwOqk8W29vY3TNHfGazK+dZpbNJdIWIAxGucg5HzqSnBO7Csw4/W/AGreOtcXxFpNm3gnxLDALeK+meO6kv4gSyW19axN5c9uCWK/vhLFvfymiLuWdqniO91+4to201PBMlvnyL7VUDzRbtpZE8lvs7BuMqbg5K8xsFFaFv8ADL+2I3j8VS3HiGRTjy7pwLGZDzzaIFiIwekqyMMEB2HJPILHyz8SviH8TvHvjG4sZPFEFvrWkyJNdaD4dnuovIjtxI0tzFPDFMkkAaW2bdMQ7KFjltw7CFvoL9mb4heIPEdvq2h+KBp02seG2iQ39lcGSHVYpkLxXG0jCllALBGdM9Co+QdZ46+E+j/EHw7a6XeW8lrHp7i40640+Q2t1pM4Uqs1rImDDIAzLlflZWZGDIzK3lfwd1mf4G/EvWvDPiuaCW31C6s47HxHDCsFpfXUimMW9yoYi1upGA2g4hmeTbEyu626LbUrc9+jJMILfez8w/nzU0Eu1D3xz1/zn/631zXYFFG5WjxxgrgkDHb/ACOPwqXb823G7sOOg/z/AJHSqJJ0ztH3evAz1qRGyM/3umep/wA/0qIsSR35/I+/6VJ0j/i9j9MdB7dP88wA5mKnd75bnHSkRSSzY5AGe3H+cn8qIxkEddxwf5/59aq6Rpsmj6ZHDLfXmpSRMzefc+WJXy5fB8tFXCghRhRwFzk5JQFl36qWzuHbt0pJFaNt39zkj09DTpH/AIfm9OelDPifcB/ESeM46f5/CmAxizP/AAnnA9s0b/3hbPsfYcULGoh5+fHTdxnHGaTLMW/2zjB/z7fnR6ADDbtX+JTjr/kUqM2xfvDnA+uaa/yox5+XoPrj/wCt/nilePeMKo2+mfx/n/k0AOC4O0fxHIx3xn/69I6ZVvU9TnpyKIhlV/i2g8dee/8An608kNnGSuePr/k/55oAgdf3vy4+90HboKUcrtxjPJIPT/P+fZqDeqnnrz/9b/P9adk7cevQZ6cGmA5omKr7EkDPf/P+e9O3gsN3Tn8elNkO6UDP3fmHuTTliLAKwxjjk+xoAYG2nP8Aeyc570rowPB+Yn8j0/z/APWoyZEk6fMwwf8AP4/z9qa27avPy5xjHrn+f+FAAR5v8Xfj3/z7+tPckbcY3f3fXt/9emMrBx8wXnnI69vb/OPSpRgyfKMLnr+XX68/jQAwruYd+On4/wCR9aNuB2bu2e3/ANbp+VIztbj3UevX8f8APHFOik5GW+XAOMnnp0P5UgEUcNuJ64J96C+4AMAFUHGDyp6/p603zpI4F5+YHjHH+f8A9XelZtv3R0BGB/n8fp7UwHscEcK2c5Hc9MULwq7cDAznP+femruJ2r1yDk9v8/8A1ulOA2r93cGB4Pf/AD/n3kBsi56bcMMnnoAeP51xH7QUG/4M+KGxlV06aY89Qg3n9AfzrtXbMWW+XjBz+Z/z7fnxP7RKvJ8CvGW3/WLot4y7mAGRA55zwPr9eO1UtgPMf2tfhHfeNNO8KaFp+s3U0mreJblbVdScSJayjSdTlx5gQybCI9vzbyN+cnG09H+0fd6hqXwS8TWmoaOytdW2Fkt5hcWzEOpyTgSKCR3TqOprf+LwNr40+HkvzKkXillb/gelalGM+nMn5kdM1V/aovW039mXx9d4/wCPPQLy66E/6uJpAcYJ7ZzzjihaMHsafgAaP8SvhXoomGn6tHDp9uG37Zfs8hhUnB6o3PUYIxxjirp8EanoKK2i6/NHbxtk2uqRtqMRGAMK5dZ1wQcEyOPmPynjCaH4A0mfw/phFmizQ2cMMd1CzQ3CqsaqB5qEP90Dvjj0q6mk65pY3Wt9DqVrtJMF+nlyqPVZox+jRsTkDcKIqysNu7ucz428NaT4rurefxh4Tma7sQ6Wut6d5k9xYqQSTDc2+28t+nJVUA6FiMEwaNpHia2tPtfgvxtpvizTY9qHT9fIuNu3/lkl/bgTRtg8tcx3Tk4PrnrovHK6dB/xOLS60Xg7ppv3lqCMc+cuVUc9ZNh68dan1XwhpPi26F9JDG1w6BRfWkzW9ztB7TxFX25A43YJHQ0WEczF8cf+EX8tPGWg6v4VaPAa9EZ1DSFwuS/2uEEQxjJAe7jtzkfd5Ge28OeIbPxZolrqel3tnqWm3oD293aTrcW86noyOhKsPTBPSsdNJ8ReH5Waz1G31iFiSkGop9nlj9ALiFSMezQsxznd68frfgvwjba7c6re6XefD/Xr13ln1nTpPsC3T4HzTTw5t5+i4W7DZx9zggAHqOSU6jrk+/8AnNIoLhs7dx5xuyD7E/WuHs18aeHrCOe01DSfHemsu6OaXZp2oOmOGEsSta3DHsBHbrg5zViD46aHBe21jrTXnhHUrgDZaa9ELPzXbjZHPlraZ88bYZXPQ9CMq/cDrpoxLFtKq24EY7H1A/DP+TXDQ+DtQ+FPlroTSan4f3qg0aQhpNPXDbmtpCclRlT5LEgBTsK8Cu5a2aGdmxLukUA/O2PwBOPy9PwpJsrgn5tpzn/P481SAyPB3izT/Hfhuz1XSrqG7sbyMOkinoCBwR1VhkAqcEVV8U+D/wC2pvt2m3H9ma1AhS3uwNyyjk+XMn/LSPcORww6qVI4r6v4Bk0/XG1rQGhs9SkjdbiEgraalk5BlA6OOSsgG4FjnIJq14T8bxeI5Li2khlsNWsiRcWU/wDrYv8AaUjiROhDrkc4ODxR6gcbqenzXniua60mW38NeOli3vbSkyaf4hhUsQHHR1zu/eLiaElwcpkPpWWp6J8Y4W0bXtL+weINHdbqbTLmX/SrBslUuYJUILRk7gs8eAc4O1iVrq/Enhy18U6atrdRsY0+eKSN/Lkt2wQskbD7jjJwR0OOtcR420JMWlt4oupIZrYsuj+LbYLBPYSv8oEpA2xux29R5MxAVlU7VIBas/FN98Lmjs/FV19r0ncILXXyu3YMKFW85/duTx53EbEDdtJNd5HKHC7Sp+h7Hpj2rhdG8cX2k3//AAjvjW1tbe4vmNtZ6jGM6drSkAbCGH7mc5IMLAq2PkZwxVKVzZah8Cis2n2t5qngluJdOt0aa68P/wC3boAWktxyWhGWTP7sbQUL2A9Lh+Tgnbj3+7/nPenxHeB0JPB5/T+v51maN4ks/EGkR6lY3NvdWb7gs0UoaPKkgjPQEYwQeQeCBzQfFEclusljb3WpDG3/AEZV2uOeRI5WMgEc4YkfjipA1Ov93144zx/+r8Kbd39vpNvJPcTW9vAPvySuI17fxHjkkf565N3qd0oaS8uLXRrMsACGVpHbJOCzDYuePlAYnk5HZtjbp9vjuLXTZp7lRhLq8JR1B+8oaQNKoI7BQvTtk0AWI/EbakF/s+zurxJBxLIPs8Ixxkl8MR3BRHH04JjvJ5Y5F/tLUrez87JS2tTh5Dk5UO2Xk9vLVDxUMd89+/lm/kuWU7ZINNTauRjKvISSrDP9+PPpjpPpmly27u0MFrpyXHMr7fOuZvd24G4HoWLjigBlpbizM09hppj3gmS6u3MbuBk8swaVtuejhRg8HHFNWX+00Ia7uNSZlBxp6/Z4DjHKybs55zt808HpV5NDhcL9oWS8ZTndcHzMNjhgv3VPJ5VV61eUEsVY5wG465z2/X+dAGRZaNNbw+TaraaPCSC62sYeQ9DncwC5bofkbuQcmrceh26zLMY/tEyjIkmcyMOp+UnIX1+XAGO1WkLEsuOo4x+f0NOKkI3GCcY9qAM3SNFOnatrFxt+XVLlJye7bbeKL/2T1z/Orypt+bgtw3X1rl/DdoJ/iz4uvJGmaSOOyt4t0rFI4zHvKhc45fJyBzk+9dVvy/qF68Z6ChAPK7/TBHUfxc0ixche4OMfnx/P8acyN83qBke5yCP5UkhZkx90feJI9uP/ANdL0ATHmqpyBk888DPr/n/Gkvo2kCFQPTnpg4x/kU/O5WPK/nzwf/1fhQS2T8u7t356/wAsUXAixvcfXcPxx/n/AA5FL9/LbuSOoznPP+fy7USLjgdMgA+h7fyGPr+NCv5Y5+de2O/TH9DxTAdnksF+XsM9qDxHjPDdz/F3/r/+ugnALfd5B/L/AD+v1pWHlnnHqOOnt/T8fagBADlfxH4YJ/z/APWpypuf17ZA/wA/h/jTXJLncOOhPp9fyoQ/M38IORn14z/Q0AOT7zD8D/tdT/n8KFbenHXGRyR9f6e3SiL52Ydvp1o+ZXwPvNg5z7/5/wDrVLAAwY/LtxjsTwP8gf5xRk7V7BQe9NUnyMcfNxg9qr6xrdroFr9qvbm3tIFOC80gRd3YAnqcg8DJ9BVWAtA8/wB7AABJ47f5/wA8NDBgenuAevBrAXxlc6qAuk6NqFzEyg/aLtTYQDj/AKaL5pHzdViI9+MU7VvEUPhSBbrxBq2nafDIxWNGcQK55O1Wc7pG7jYFJ/u0gN37+5Tj6+vb/GqGvtqAsV/s2OykumYKPtkjxxqD1b5QxbH93gH+8uM1jXHjLVtWhB0LQbidOAs2qyNpcDeuFaN58j0MIByMN1IlHhbVNWZW1TXbgR7ubfTF+wwnnPLgtOTkclZUDDqvamBma9JFps8cPiPxKzXVxhobCwV7M3HH8EMbPcScZ4DsMdsjNS6dqWovAsOi+H4tLs2BIudSYQhs4O5beMmVj6iQwtn1ra0Twzp/hqOSPT7G2sROS85hjCPOefmcgbnbn7zEk80mteJdP8LLH/aN5BaNdf6qJ2zJMfREGXfGOig8c8UAY978NV8Urv17ULzVGXIRLZm0+FAw2sFELCQqR1WSWQHAPYY0NI8MSeErCO10qSzjsIOEtHtUhVcYACtCFCgAdTG56cioY/FWp6w5bTdEuI1yP9I1SX7GhXOCVTa8pI9HSPPqBg1E3g7UNYgI1vW7y4jOM22nbtOt/XG5GM7D6y4IB+Ug4oAs6h43sNDljt9QuEs7yQHy7ZWM0s3BJ2Rx5kfgH+EHHasHVtI1TxAY5fDtre+HJlGEubi4+zQ4zk5sysiuTzzIkb4OQw4NW9f8deEPgrAsGoaho+gzXRG22BH2u9OMfLEoMspwOyseO+AKxP8AhbfijxkJF8L+CNUt4SpCah4nb+y4GbJxi2w12V4yd0cZ6YycgMDWPw6vddVofEOuXWpwNg+RZ7tNgbI5DrExkb1+aUr1+UcVx+o+Ifh/8KNW8Q+GdU/sKysr+CC3XQVtVne+ieFjJEtmis0ysGYsAhB3ktnJNbifCXxB4tkZvFnjTVLyFmJGnaEraNZqD/AXjZrmQcHkzDI4wO8nwp8BaP8ADvxp4os9D0uz0u3aG0kkaJMSSFhLuZ3OWYsRklickc5NGt7geXeDPBU1x4h0P/hCfhl4r8M+H7K/gea51vxhfaNaSQK+WMelRXEhmIGMLcxRKTgEFcivo+J/Mbc21SAMEfn/APWp9lD9pxuXjr/UD6f/AFqe1k0HT6EHt0pLQA8zAUj1zgHJOOf6d6kU4bcD6YJ7+1VY2Y7h15+uP8f61N5hI+6cZOR6j/IpgTlsoOR7+3b/ADmkVgUwW2q25ePQ5qOJiY1xnBPPOcjjp/ntTug57jgjPHYe/H9frSAcGXzNzAZx6+v+frQh565xyOTwR/j1pT5jYB+ZgOAff/P/ANalQkqx7EZ/X/P4UgFb5SduMZyD9O34mhIlRAOGXJz7f/r5oAxGx/i4HPfvz+v8qWOQhRj+I0gGtE2ePU8f5/8A1U0HCbN3y+uev+eR+P1pZflmx1wRx6f54/Oolnxk5+VT97t3PHH+femgHp8rFvbJ756f408E/Mc845Hr15P+FNi+Q7R8qk4Yen+en4GnKCEH159uP/r/AOcUAMU429G3EcHHt/j0pyfdz/Cex7euf69v1pokG5W/hb0HX/PrTtysyc57NxTATGJG+Zvm5P8AIn8/89qcx3HurA5Az93jjn3/AM+tCPuk3Z+9jBx2/wA8fhRvzGQPlVTkdwR0z+lSA1ztgbnttH+f0/P6U47UPPAAy3sO1CkFDtxuxjrQG3hdxHzHnFAAo2MwP3sduhOP/wBVKw8x/vH2/wAf5fl6UgbDLgY2jgY6d/8AP0pfNCbuMqp6A/5/z+oBHMvybV47fQf54/KkhjURsVYBW9OwA4P8qC29y3Xnp/T8/wD9VCN5aq+Rt428deOv5VXQAJyo4wrcnt/nufwp5PzbQu7jgE/rTZSq7cgA55zz07flj+VPZ/m4GVXpn15/xoAGGwZ67RubP40Rrwue/T/P1/8A1UcM4HVU7+2MH8qA3zbm2jcQQuOw4A/z+tSASgMv3s7uBj2rhf2kCqfs/eOJJG8uNdAvmclgF2iByckkAD1zgda7hdvljkEg4ODkdBj/AD9K4/8AaDj834D+Nl+YufD+ocKu5j/o0hxjBzz7VQbamP8AG29+yal4CkYllk8WWibh82N1tdAHJ9yoz1596k/aNtFvP2ePH0LZ2zeGtSUg472kvX/6+aq/G648zQPAk8e3b/wlekFSBwd0m3GB/v4/H0re+LFp/anwj8VWoba1xo17CDg87rdx256nt6+tVHVq/kEttSb4OXX9ofCfwvcL/wAttFspP7ucwRn8PX2rpozgD5vmHOcDPvx/nrivPv2YtSOo/s2fDm7MaxtceFNJm8sc7S1lCxAPtnH+ee9guOijbuBx/Q/5+nPQ1Mb8qKnpJk2MrsHfLYHvkY/P+dY9z8P9Ne8kurNZ9JvJFKG409/IZs85KcxsRxy6NjFbCuFbd8o579h/+v8AzzTg3z5X5T2HXH0/z1oJOfWLxJoKj57PxAigZLAWd3J0BIxmFj7YjBz2qa1+I+m280cd5JPot1M4jSHUAIDIc4AR8mOQn0RmPPrxW4doj6Lj68AdMZ/x/wDrU2+t4ry0kt7iOOa3uBseOVA6yg9mByCD+OfakBhv8NtLiuXubGObRbuQgtLpz/Z9xAwGaPmKTg4/eI3G30GK9/p2sJpdxa3sOl+JtPuAUkgkjFvJIh42srboZifQ+UvPSrH/AAgcGmPHLpd3d6MyNuaKB99s3TOYXzGOB1QKw9fWOTVtd0NG+1abBqkKhv3+nSCOVVHQtDKwH97O2RjkDjkgAHD6b4I0DQtUjt/Dupa58NdRuD+703cq6dcMSW2x2ku+0JJBLfZNjnklxkGugHiHxp4UVl1XQtP8RW6k4udCl+zXPX+KzuX24AOcpcuzdkHAO1p3iXQ/H1vNY7oboXEIaewvICkhQgH54ZQCRgg5Kke/GaqyfD7+zSg0nWtZ0ePD4t1kS6tl5HRJ1cqOcBY2QAcAY4pgN8HfFbw/411JtPs74w6qoy+m3tvJZahGAOptp1SXbwcPtKkcgmrXizwfa+LYLcyPPaXtmWa0vIG2T2TlSmVPf7xBVsqepBODWD4u8PXniLTPsHijwtoXjfSo5fMjSOONpQ3G1/s10fLUj5vmWbdxlV5wMnT9Ni0qdbPwz401DRb5o8QaJ4jV72A4bO5YrkpeFRyo8qcRgHAUgDDA3/Dvjm70LU7XR/FK21vqFw/lWV/CPLs9XIQMQiliYpMbsxMedhKkggV1V1aw3UMlvNGkkUg2PGwDK6kdCDwRx+tcVrWvaj/Ztxpvi7wjJeafOjRT3GiltTt2QhlJaDal0jEdFjjlwTgOTgmj4R+Idpo6tDbas3ibQ7WPdJPG5m1HRVH8F3H/AK3AAYbmQOpQq4J5CAk8S+Fm8I6c2m/YbvxV4Nuo5EvNOmiS5ksI8lv3WWEkiDO0RhWZQoKspXD8z4q+Ntr+zP8ADmTxFqeqN4o8BMuNNvEnEmo28mHK2zs5zOpZQiyHEqYIlDBWkHsVhewahZxzwTxTQyoJIpYm3pIp6MCDgg9cj2PpXn3xU+AWmeNta0rWLezgmu9L1aPWZLCZytpqMypsJcdFk2HIcYDMihwy7hT9APAPB+r+INO8X6X4yuH09viT8VLiC70vwxpkC3FqNIwuWvGYgJGq7H+1DEm/ORICbeP33wh8Wv8AhL9TvtP1C+utD13TNpvdBt7EyX1orHhywEvnQt/DNEqLjglWBA8M+Fv7OXjh9R8R+JbjXIdL8RarcRzav4f0kJYX3kByy2sdzMjLBEp3bEjHlTMpLTc5T1z4a/Bj4e6n4NXT/C9jceHbvS7rz5JY2kh13TLpjvJuHmLTMzYwRMXR0AUbkC4SuUeiaRaSSzJPb2rWcka7PtF/Ibi5KnBKqN5KqeBy45H3D3vt4ft7iHN20t+2Ok7Ax5zz+7AEZPTnbngc1xukfE278F6pFo/jQQ2s10whsNahQx6dqrkYCMeRbXB6eU52v/yzZs7F7xWVS24dOo5+n+T70ySZSqeyqANvoMcY9v5CnjAA9wcqO1MjfLqfvMx5HY/5/wDr0qso+UdFOPrjn/P+RSAkB2vlvqR3Hv8A/q/nR91sL9Oe3+cdKbkCTOR8w59//wBWP0pzlRD69v8AP+f50AGQycn73DZ+lK5DfNnCgZPGenP6YpJindh179yeg/l/kcjuHZfuhmz68/WhAZ9loi2Wu3155m5dQERKkfdMYI6985rRU8KG46nrzXHjxTY6T8YNWsZNQjkurjSLC4SyjLSTxr5t4nmtGoLKjEKu8jBZNuQcA9AurXV0qm2sX2no9y3kArgchcM+f9llX/EA0I/mX73YDA6c/wCev1qK91W3stizTRRyS5MaE5kkxjdtXqxHsCeRS2qSwL++uFkYdNkexOD25Y/qc4qUtsj27tu4HvwT/k/p+aAqHU5bs/ubORUX+Kf90rD/AHeXz2wVGcdehq2Axl+Zvm9QMDP0yff86Hby2BULnPp06f559KVFUFPRsn/e5/8A10gE3bXydp//AF/0P9aaP3b7fmZScNx1H+f5d+lOBDOy9mTIPvwD+uDSC4HlbuxGRz1Hr+vf1/NgKF2BmyG4OOfw/wA/XvSlgX/ixjIz2/8A102UCODt8uRyeP8A9VL5nndAPpQAkfzlfXGQR69vzxQHULgDj1oRvmX1AH4k5P61m+I7W6ms90Gqro9vCrPPMIEkfYMYKtJlExhslkYcjp1LAu3+p2+j2kl1dXEFpBGQrSyyCONfqTwKoweJYtSKrYw3F1Gxz53lmOEZxghmxuHPVAw69wa5SwvvDsNyl1pNlqXi/UN+Y71CbxUI4JW6mYW8eM/cjdT1whNa6WfibXZA11d6foNtjAjsl+13eSOG86RRGp6gqIZBjo/XIBvX+qW+iac91qFxa2dtCP3k0sgSGP6u2B68nHXtWGvxFOsLH/Yel6hqykblunU2dmAVyrCWUBpEOcb4UlFWNN8AaTZalDefZ2vtRhJMd5eyvd3EJIw3lySEmIHn5Y9oPpzWhrPiGx0K3WS/vLazWVsI08wj8w9cKD95ueAMnmgDFj0DXNaVjqWtLYw9RbaSnlnHdWuZMu/fDRrCee3Ob3h3wXpfg+5luLG1jhup8CS6dmmuZeAP3kzlpJOi/fY9APSom8Wz6qHXTdI1CY8FZLxDYQ+wPmDzfxETDtTY9D1XUWX7dq3lw97bTo/JVvZpWLSk/wC0hjP07gF3XPEWn+GII3vLuC1WRv3fmNhpf9lF6sfYAn8az/8AhKbzVEVtM0e8mjk5E+obtOjX6q6mcdv+WQB9e9ZXijxj4F+ASRT61qmh6DcXgG2W9ugb7UD0ABctPcHoONxPQdhWJP8AHfXvGAX/AIQvwDrupQuxUaj4h3eH7FFwMSKsyNcyAk8YgGdp+YZBouB10nhzU9Wnb+0NakigIA+zabEbRG9mlJeU4zwUaPtx3GVrnirwP8BrdptSvNI0CS+XK+bJuvr4jqqr809ww44AYgY9qxIfhj468Xqr+KvH0lhBg79O8IWQ0yI9OHupjLdNwOsTQZyeK6D4efBHwp8KfMfQ9FtLe+mYPcX0pa4vrpgoUtLcylppCQo5ZznFGoGGvxi13xlHu8I+C9SmhkIC6j4gLaPalCF/eLGytcyKdzYHlJnB5HBLpPhX4o8XXJk8UeNLxLc5xpnhyI6VAuTkq9wWa4k44yrxdfu16NFEdn6E56H+v/1qcFzLk464PtjtR6gc14F+Enhr4ZeZ/Yei2OmzXG1Z7iOHNzONxPzzHMj8kn5mPP1rohGMr05HDevH/wCr8qljVQ+BgnGc+h7f59KEIQj9Rj2z/hVAV8BIjxnnp69/6Vz/AIewPiX4mDqnyW1hhhglsift+YGa6cqrIo+62Bg/3fT/AD/+qub8MHb8T/FC7gx+y6a+0dj/AKQP/Zf85pXA6iEfufmbb8q5J/z9fx7VZJV5D8rbgSPXHX/A1HDx16jv6e/8hU0ICp/h+XH6VAEGpWgMaybfmByR69vz5qpjDYPUkge4xxWmzb42GT16+tUpY/LK7fun/OPanHYCONvvf3Vb/I/U89fwqRm+b7zcd8Yx15/HFQxtsZf9hcYH+fpUsUgBx/DkkKP8/rTAlZtm7A5HXH6UqyYj/u88cfn+maiU5Tpu3DPA/P8AWnhgUPPyg/Xnt+Z/r9KQCu3ykc5b3zk45/HiklmAPcnovrjj/OKSacIB834+vX/630qNyFyv9/r3/wA+lNIAeTaWVWwOhP5Y/wA/jTUKhWwM8dB/Fxn8/wAfSnOeT+HTjJH/AOvp9KFC44weRgAdvr/jTAdGu5VGRuPX2/zipA4Mvod2Tn35/D/PWo5CoHJwpPP06DP1p4ZQn+91APT6flUsCNlY/wAK7c5PHDDP589P8kFwjJbbn5m4z+p/PNBb/e+bp/s45/z3z+FKsmR6Y6nPtTAbktK3C+3oP8j+VKpDxd+Tznr/AJ6U9H2tjG0dcZPHQ/4Gmq7FGHXJ5546D/P50IA5T5urcdewzz+GM/n70ID8oVdze56en6U3zMY25DYGc498f5//AF0skmHC49QAD17/AK/0oAdhvMX0U5JPf04/z+NMcERvn+HGMdh/n+dOL7ZP73Xv1/z/AJxTkbfkfN0o2AhKNuOGHXuOg7fWnD5FXb97Azn/AD2/xpU+ZR8vYZOeg9f5fhSn/VenHUfmf8+9ACOhIUc9ckY/z/kUscRwcnaOctjpTWlEjfd4we/qQen4fr+T2bH3evfmgBpUuG+XA4+UjpkEn+dKsmwtt/i6dzj/ADn9KcXKp0JYdvT/ADzQTg5b5f6+v8qAGsmGZcE46c9Bx/8AXrkvj5G0nwN8bD5iJPD2oj5UBP8Ax6ydAePzwOldar/dBHyr6k9fX6+//wCo818X0Wb4TeKlPypNo16CTkbc27jP5HNGrE9jkPjCSPAXgeTfDu/4SXw+H2HEZBu4VbHqCCcAdeOnUdh41jkm8C6wisFaSwuEDMcYJjYZz+PvjrXF/Etjc/CrwDOo8xYte8OO5wD9+7t0B5/2mGCORkHr077xEvn6FfIvyGS3lAOTuGUPPHpVQ+JfIc9mcX+ySCP2U/hiVC/L4R0gDoMYsYB+HT/PFejCLym3Nwo44/z/AJ+teafsdNG37K3w3Ea7FTw3p8SqGyABboB046Dtx/T0uCVd6hTwBgt6e3vUx+FeiHLck27Plb6nI+6Pf2p0S53MxI/iPr1FJ5m1WwPmUc88f5HP/wBantIwOW+ZsnHt6Y46CgQ0fOm4bV4GPYf5zzT9hlOxv4u/t0/rSRsCu7+8Mj8/58/yqj4l8T2Pgzw3qGsajL9n03SbaS8u5gjSeTDGrPI21QWOFGcAE9cAmgDQ+ZnZvuhuSfT8PxpjQq8ZVgCCpJB59vfqKcXV1Vl2srfMCGyGB759CMc/Q0qv5n+0rcHnvx/WkBR1Hw3Za1FHDfWlrdLDKskQlQNsZSpDL/d7dPT8Kw7nwPd6dKkul69q9rGqYNtduNQt35P3vOzMOoHyyqOB+PUJOGX5f4ucnt0/z6frUdwdr9CRtXj1PzcdPemBzL+I9a0GEtqujm8hVj/pOlMZsKBnc0LASL3GEMp+Uc81ZstX0P4lWE1krafq0CsDNZzxKzxMuCBJBINyMMg/MoIyD6VtleMMpZSfTp/n+lU9f8L6b4niiXULGC6+zuHid1IeFh0KsPmU9uCPTvgsDFHgCTSXVdD1a80mNQSLWQfbLPPOP3ch3Io/uxSRjpWT4r8ON4je3bxJ4Wtdaa2IEOo6ZJ/pVsSSpdQxSeHg/wDLGR25IrbTwtq2iuzaTrs1xDnJtdWQ3UanP8MqlZl6dWaQDjC1G/j240b5Nc0TUtP+6GubRW1G1P8AwKNfMUepeJAOpOKLgcpoTReH5d3gu6/tHyArXvh6+neO4IAw0qCUebHKflJDjY5BzhjvruPB/jCz8baRHfWLS7W2rJFPEYbi1YgN5csbYZJAGBKnnn0INNktNC+JGkQyldN1uyRy0MyFZ1icd0cco4PdSGB9+nNeIPg3qUOutrPhvxFcWWsKjRgalGb22uYyY2EUhDJKyjy8K7O7IJGxkYAYG74w8B23izybhZJtP1W0BWz1G2wLm2BdSVyRho2ZV3RuCj45FcnrmlSaz4nsY9SuP+EZ8aW8QjsNZskxa6xGCN0GxyQ6EsP9HlO9SQ8TZUuu5p3j7XdG02NfE3h+W3m8sGa60dn1K034+bChBOoB55jIxyWOK1I9Q0P4naDcQrJY6xp8mFmjWQSKCMEBgOVdeCM4IODwaAMnR/E3/CRCTw34r0y1tNUuo2Rrdj51jq6Kfme3ZvvDAy0TgSIeoZR5hy1s9c+CsnmQf2l4m8JtMpS2A8/UtDQ7g2xjhri3XAO0lplBIG8KFqTxLYzaFbHSfEUM3iDwlMHZNUZ2N5o7KjMDcMoDFVUYW6QiRW2hxkmU2E8c3XwzNv8A2/cnUPDdyiNa+I+MQg9BebBsVW4K3CgRnI3bDhmVwOs0DxDZ+KNDt9Q0+6t72xvB5kUsDhkdRkHB9iCCDyCMHBFXuZJSp54yWA+g/qfrk159rnw4vvC2qNrvgUaZYXl07TalpMi+Tp+tl+S5ZFzDc7iGE4Vw3IdWBDpq+AfixafEPTrxLKG403XNN2RahpGpqI7vTHYceYqlgykZKOjNHIPuvjkAHXA4Rhn5uABxzjr+mabd6hHZRLJIwXdIEA27mYnoAoBLHjoATwT2NU7SymOftF5JNu/hiXyY147Yy/fuxHsO9+GX92Nu3p27D39c8dKAM59avr6VFstMaOJmyZ76XyF2+qxgNIW9nEf1qaKxuml3XN0zNyxSBPs8f4cl8/8AA8c9O1XY224K7mx+GPp/ntSp8zkfw5Pfj/PFICrd6Ha6jBcwyRKqXEYid0Jik28kfOpDrg5IwQQec5OazbXwxqWhs32HVZb632hVtNTPm7cZ4W4A83Jzy0vnHntg53A+R07ZwDyacJMgMPXII5z3NAGPF4ra1QjU7CbTWXGZgwuLWQ55IlUfKB/elWM57VrRTLLEkkZSRZMOjAgqw7EH6fzpyHaw46Ywc9P889P/ANRGyr8sa48wljjuepP1OaAAjAH0I6ev/wCujOCe/Tkfl/npWSj6xp9w3mfY9Vt9zN+7H2adFzkLgko7AcZJjzj8auWetQ3LlQJI5VwfJlUxuvY4/vYOeVJHoTQBaznnrxyQM4/xrAm+IVlK8i6atxrk8L7CmnqsiIw6gysyxKQQQQXByOnFZ/i6Dw/pLo/iS+kvmuAzW9pfTeYLrBztjtIwFlIyOBG7cDqeTLb+J9U1m2ij0fQ5NPt1zElxq7fZVCAYUx265lI7bJRAcc5oAtw/8JBq9wnmf2do9uRjbGTe3LHPXcQkaEDPG2QEnOeOaT+MNH0vVZrK3uLzXtWjcLLbWoN5NAx5USBP3dvkdDJ5anHXmnnwI2t+W2u6leasRgtbRE2Vixz0MMZy6/7M0ko59xW3bR2fhbRlhijs9N02x4CKFgt4R7DhVGT2/wAaYGOJPE2u4Cx6f4ft2U8yH7deYJwPlXEMbYyc7plyehGadF8OtPkmjm1HzdeuoG3pcamwm8txyHSIARRsPWNE6Cph41jv5GTSbO61ZGODNEBHbccZ818Kwz/zz3nPbOaj+x63rSsbnUIdKibGI9OQSSjuQ0sqkEHj7sSkc/MTzQBqa7rFroVoLnULy2srcsF825lWJM9gGbGT0rNbxdNqgVdL0u8vVJIM9wPsdtkd8yDzGz2KRspx1rN8Uax4P+C+m/25r2oaPoap8n9pateDznzn5RNMxdiegVWOegFc037SN54zkkj8CeBvE3ikJII/7Rv0OhaT1Ksyz3C+bKAyn/UwSDjryAyuB3TaHq2r3G6+1Y2sHP8Ao+nReUTzwHlfc57fcERz7VmeIvEfgv4FWLanrWpaL4d+0rt+2ajeBbi6AHIEkrGWU+wLH26Vzc/w2+IXj8sfEnjxfDdm3/MN8GWi27MM5+e9uRJK2cYzFHBjk9em94C+APg74bajLqml6BarrFxh5dXu2e91OdsfxXU5eZuv97096NQMFvj7rHjZF/4QnwF4k1mOYHytT1tP+Ef0sjnDf6QPtbqcDBjtmVgQQ2Duoj+FXjzx1Jv8V+PJtHt8k/2V4PgFjEwDcb7yYPctkYJ8owHORkjGfUI23HndnOfc+ufy+vFOyz/Lj7x6/SjUDj/h98CPB/wz1CbUNC8O6Zp+qXgC3OpCHztRuc8/vbp900nf7zkV1nl+b8zKCxHXHX/P+feQjncM8dOcUb/mYfr0/wA//W9BQBDt/i7N0O3nPenPEzrtwDn+R4z/AJ9Km3lCScdcn6//AFsUIdrfd9O/f/P8+/WgCu8bCT5flY8D/H6/41JF88nPB/z+lAOD36Zx29PTv/n0oL/dBUrt9+38ulMARd7eq9enTPP9P0p3I3Ej7rkeuTk/5/zy5ZNvUdSe/WhmwN3Q5yT6YpARyw4VQBwOBn1rm/D/APyVPxMGPzNaaccYPygi4AGenZjx6jOe3SOehVTuVcgZ6D/J/wA8VzPhiZj8VfFit5in7Pp+0845WcfL26hunehgdZAeOTnA5H06/wCf8iZSc9fTk+tQxsUib/Z/zmpFf0zliB1qQHEFj/uEdqZKmF2t04/Cns2UP1xkUruFb94MsvXHegDOeJg2WHcjpjP1/wA//XcBxhlClfu57D/ParEse9uOuMDnoarmXKH/AB7GqASOQhgP4So4/veoz/k0rA7cZ+ZsEDPT/PJoZ+itnbzwff8A/Wf096dI/B9V+9k9fXn39aYB1f8AvYJ/X/P0/lTNuc8entnnH+fp+FK1xvwT0xk/5/z6U5JNsn91Qfx/z/n2pgNxkf7WDjt/nihY/NRW/Mj8s/oB+HtUgOE3d1B+n+cfyoDALgDGeOvTFIBAGKhVIB7eg6dqVRub8Mj29KcZMkDH8WT79P8AP/6qCVA/3hkc9M0rsAPy4x1x1pY0Ld/vHd9CP8/55pCP3vy/e7Adfb8f8aaj/Jxwq/dHb2/xo9ABhuTHXnI47/570FsDj0zjv/n/ADzRKfnyrAbjzn+Lr/jQeIV527TgjHT2/DNMADANlmHXBz09P60bmDfMwP8Ad/z/AJ7elIWy2NwHbk5/z3/Whh5h745/Hj/P5UAPZtsn3ht3E+nFAXAHzfdyM46f5NN3dcnCseoGf85/rSI37tGb7xIJwO/+T1pAPYblCqeOxPOCeaa5BPuRkfTGPz6UFSP90ZwD2OaGwzcBdyj7x/Hr/n/6wA4/Mf4ct19/WgKSyn5d2PTpSRupkA/U/wCff9KNxyOmWPb+n54/GgBQuBu7BuPf0oJ+RV68ZyPrRnCfLt54B7D2/l/nNKfnY/8ATQc5PtSAYCcBvQ9M8/nWP8QYftPgjXI9qsG0+4TGOP8AVNxz/nntW08uAA23ggHd356Vl+J4zL4b1CMqH3Wsq49coen+fpVx3FLY8v8AiNL5/wCzt4GmhfO7W/BjcALuB1jTM5xwOGzjn+VepTx+baPG3MciEY9f8+leR+NXW/8A2VfAsnDKt74NmxnpjVtMbPTPYnoCcDGDyPYLaTFzGMbt7hSDUxdnf0Kktzyz9imd5P2Tfh6Nu1k0aGNgeMFRtIwenQ8dunOK9XVtr8EdP93b/wDr/rXkP7D8/nfss+D9rM2yG4QZTYU23k6hcf7P3ffB7V64hyn3R8xztB6Z6/1prawnuTIAy+i4wcD19acDjncDyOv8Q9Pz/wA96jALhjxuBzk1Ij5z25ySeo7f4/5FMBwAZPXsT07/AOfzpVkYup3EN1H16/rj9PrTV4wMgd8dqI8jaBy3Qe3+eP5VIDx+8zld397PU+tOQsJANxy2Of8APt/nNR8YPptPfgj/ADinQrvccgdj7evHtg/rQA1cLCASvyjaP8/jn/8AVTbgYK887PT3P/1/rQr8KxVcKoOCM+n8vSkI2z7DjKKF6/e4z/8ArpgKflKruwVzgUIm08hdvUD2+v8Anp2oAxIe7c846nP+fy/IXIfr1GeRzQAbSE/h3Zzz3wO/+ef0pxTHqy5B59f8mmpJtK7f06f5709f3acd+T7fX9aAMHXPhrpOs3xvGtWs9QbKm9sZGtLrn+9JGVZhz0YkcA4qo+meJfDduxtb218RrGCVhvwtrcv90ACeNfLJ4c/NEMkjJHLVs6r4o0/SLmOG4uoUuZl3R2yAyTyjOCViUF2AOeQp+tRR6vdagcQWUkMZyTNdnyyewIiGWP8Auv5bAe+RSAzbj4m2GkLjXIbzw+ihS819Fi1XODzcruhXHQhnXn1yDUPijSfDPiW8hmv0s7jUJFWS3ntWYXpQ4w0ckJ83b3ypwOfrXSWyTIdzzb2bptGxV5wcDk/gSetc6/wm0mwnmm0eObw3dXEhmkl0qT7OsshA+eSHBhkfjOZI36eppgUYNL8U6asf9k3/ANstwQxj19AJGXBwElhG9ecH96jEc98bfL9a8CyfCyS61az0zxD4dW7Mk2p2OiO1xp9wzY3TW8X7y3ViCcpcwKr5Yhozlm9cA8VaFKRJ/ZfiK13KFKf8S+8VMkEkZaGRgQOnkggngYG6a1+J+mPcRx3/ANo0G8nClYNUjFsdxUnasmTDIw5BEbtjB7clgeN+HfirceCb+Kx8G6lo/wARLG6gMy6BppeHUtPUsyqwQ71gjBwGWV4lyjCONWBVuum1bwl8bJbG4sdZl0PxdChTT9QW3NlfqVLholSZdtzCHLq8B8xFYMG2uuR3GrfDnSNVvZLn7GLS+kbzHvLNmtblmx1MkZVmyD0YnI4ORxWPq/gzxFaaRJafatL8YabIg8yx163SOSbGT/rolMZ7YDQEnu3U1KHoU/C/xau9G8UQ+GfGVtDpOu3DFbG6hRhp2tgHgwsc+XNj70Eh3gn5S6ncPQFOwf3gwIH0/wA4H4/n4/4lsNDtvD9zpusf254P02RSs1rqcf8AaGiTAqyqBKd6QqpBIWKW3YErwM8x6H4s8U/BCxt/7ajl8beCJv8AUa5p8jXV9p0RJ2GdCS08IBA8xGkkCjLs/JpiPZoT/ebOMcfjTocbxyOT2+lc/N8RtDh0S11L+1tPlsb6LzLOWGYSC8XGcxBcmTPPCAnjGM9ZYfEt9qb/AOhaTMkX/PW/Y2ikf7MeGlyCcYdEzzyOMsDfU7sjPcfy/wA/5zUF7fx2FnLcMJpEQbikMLSu3YAIoLHtwAT39TVEynR7FrzUtQhWOMFpHIW3t4/ckkn16uR7Cso/EZdXjX+wtMutcWQZW5Qi3sMZHzGd8b0J/ihWU9eDSA0P7X1jU4z9j0+Gxj4VZ9Qk3NjBywhjJLDpw0iHntjmDVriy8MQJca9rSneSqLNIsETnk7UjXBfO7hSXOQMc8lDpWtauYhe6pHYQqAWt9Mj+ZumQ08oJZc90jibj73arnh/wbpvh29e4s7Nftko2PdTSNcXUqjna0shaRgCSQCxAzwBSAz/APhL7/UolTRNBuDAAds+pMdNgXA4AjKtP2AwYlGOh9WP4K1nVYiNU8T30e5gvkaTbpYQleRgs3mzZ/2llU5UEBeRV6fxxpsbtHbySahMj4kjskNwyHJHzFcqp5/iI6VUN54k1MN9ns9L0uPkK11M1zIvAwTHHtXufl8084554AL+i+EdL8LLM2n2NvavcfNdXCjdcXGMfNJK2XkYDu5Y4x7ZwF+KiW8zW/2KbWpI+Hl0EfbkTv8AvOnlE9AmW/3utTeKNN0fQNEfUPFmrRyafbsWnudXuY7axg5DDK/JDxjgsGYeucmuab9qLQ9Yja38I6L4o8byRkon9jaVIthuHGBfT+VaEZGDslYj+6eaYHW6fqOreKkWS3m0/SrXfhwhF5cp/sseI4n65BEv1HaHxc3hf4eabJ4h8UalYWdvZDc2p65eIkVufVWkIjjJ9IwufTpnlv8AhDfiR8RbnzNZ8RaL4HtHjKm08N2ov9SVCTwdQul8tTjGRHaDBBw54I1/CX7OHg/wtrC6u2mtrmvK2Rq+uXEmqXytwSySTlvK7fLFsXjAUClqBkr+06PGUuzwL4S8VeNvMzt1IWx0vR+AcH7ZdBBKpP8AFbJP34OKa/gH4lfEFF/4SDxnY+D7FmJOm+ELXzLrb2D6hdKScHnMVtEflxkgkV3mpeM7PRNRaHUvtOnx5AjvLlMWk27BwJslFbPG2QoxPQEHJ1g6yxxMm3awEikdGB7g/Tp7UAcP4D/Zv8F/D/xAusWeix3mvbw761qk8up6oxwBkXNwzyLkL0RlXk8DnPeCMs7MzfeAzxk5xio4DscL1kB6jtkf59+RUyoN+Rj5umD/AJ/+tRsA1eWZh8w4yew4p2wsnlnPJ5XH9P8AP9KEZiu5v4jng9D1/wAP1o2nd68/99UANjPyqvTOe/14/Mfy6c1IyvKO6swzyPu//X4/DmmEYK88gdfyx+v+eaUtl9uBhRjr1/z/AFoAcvzggMDzk8dBjjn6f0o3tuYn7wOCfQ5oQKpO7btYnPy9Rn/9VNQcD7ucjjuf/wBf+e9ADmHP8OM9+3H+f/rUx1bdtLY56fl/XPX1pyptQY5CkcgdMdKY527VOPlxx60AEp37hyGYcL/+uljVi+ONq9ff/I5pHfDL97uGx1x/+s0bgzfL83H5kjP+fp2pgC53bsg4Ax2AHOfy/wA96d1CgnoM89fxpqP5aH3wRk+p/wD1frSOeVX6k578dfz/AJUAPf8A1m3P3c5z3x3+veuX8Mtv+LPipVP3bLTcjPHJuv8A6/5966YSbiD2zkfy5/H+tcz4fmA+LfidRuDLp2mEgjb1a9H9D/norAdUSr5+bPqQOevp+f8A9anbtvouO3p/n+v5RhiSuPXn360u3lflVlAGTigCdW3rxt7j8T7/AJfnSdT6YHGQPbn6f4VHv2tjOGPPrgdP8/4UqSck7e30xxUgOdwy8/dz1xmmp87/AN4ZA56H2/OmxsOmOBjAz1/z/nNTrJiLO0fKePb/AD/SjYCtNBtTj0NRbd7kk/Nnn8OP51cbkgZ+v06/5+lV5I8yE4+7nOPxz+IqkwIkTaGTsPvZHX/PtToztTdn5mO4e5oO7DKrYwePc/8A6gfrQACrNjoc8ce317foKYDk+WLb6en45P4f54pygL97aq+g/hpFO4/K3cnOKRpG+0bSNqNkhs/ePoO/A5pAORv7y/N0K0IQMZ+bnjHGTwP6f55qJm2tn5QVGdv909f8/Slil83Lbfurn8f6/wCfWgBykhvvN8vQ56+v86fHKd235l45GP8APBBpPunP8WO3+ff9TTUXao4VV+9ntj/JFAEiLld2T82Affp/n/Ipp3FAp9M/XvTUJ2gMpzkZ56e3+f8ACphMxHP5f5/z/OgBkmdyDLY6Z9T/AJ5/zikUdfRTjA7U5GDnoMN/49/nmmqG2fdx6kk9T/L6/wA+wAJHj0Vs54OB6UkuBwcr25PXp196eRtz/Dnt6Dp/XpQyklRt3DocZ9/8/jR1AQBk+7npnH5n/ClU5C5bPOQxOcnBP+f8KAcle7D3o2jOduVHJPPOOP8AH8qNQGxfKG5Pp9MDg/5/xoCYwMcc4HbjuacDjP8AvD146f5/Chht4Pp8o9hz1oAcI97d26Fu3+elA+YKf4TjqeP88mgfNuO3cc849f5f5/NWHKg4HUDg85H+fxH40gAsVGcleOvp6fz7enrjObrwX+ybhW3fvI2Hrj5T/nNaLXHDbWK8cVTviGtH67WQjP4dP8+tVHcHseI+LEFz+xZ4XZm8grF4bl6mQIUv7FwPf7vX8ea9otAwvl3bg3mDafYntXjPiTcf2I9K8uQsbfTtJPmKp5CXVscgdeQucfz7+0bt136fNgH8f/1etKJT3PKP2KGZv2c9GLfK323VtwEYRQf7VvONvYA8f1PU+theWC/Q8/57V5P+xRcyXf7P2n+YrebFq+tRujdYyNXvfkP0BC5/2e3SvV41BjX5crwD701sSPQeZn5W4Pyj0x/j9f8A60gcFGOdobJGPQ8fr/n1qMfcYbe+OR/n/Pb0kDE5ZvT7pJ/z+HtTAB94Hng+vtkfnTs8bfzJ9O3vzijcSVHocj65P+Ofw7UI2Sf72Rg+h7/0qQHCQozN3z39ecfyxTl5mG5v4/y/zj9aAdr7sDlcnGfqOajJ3H8MjP8An6frRuAI+E+bgtjIJ9cf4+nemkg3DN82Rwfpn6/54qROOD7ZBHTvz/n/AOvl6jPqT3ax2MFn5bLvaa4lbMbHoAij5vU5ZOoAzk4ANFZN6qmdxwc/Sqkmr22nyNA83+kbVYwIN8oXPB2Llse+MVRj8PTX0G7UNSu7jdyY7YmzgTjqAh8w/R5HGecDjGhpOk2ujWgis7S3tYc79kEQjVie5C4GTnk9z9eQCWzuWuBuMckS5/5aEKcdexPv1wfUU8nj+78oGB6cc/y6UmWKDC7dwz97/Pp+Q+op5UeYfkPPbk9f/rn9aAIwpRtw/jG0k9WGeB+HOPT060BAy7udvbIPPT+mB/8ArqSN9/8AD+HoKEO0bujd/Y4/z+VMBqtlFxu3K2Tz09P5GiRMEfe+X5cA9D0/z9KMAIAvOV6Zxnjj+n5UXDK3GNoJ4Hb/ACaQAVO5du7HJJHb0plxbx3VtLHIqyxupJRgGVz6Y6dalztf36gdz1GcU0nzNwAzkYOM+nagDl7j4ZWtlKzaHeal4cbzAxWxcG2bB6fZ5A0QBB5Kqrd8ggGpJ9V8Q+H5P9K0+31q3Q5M2mnybhRyeYJWIbovKykn+70B6VTg7vlbJA+v+c0pXgdRnvjkdP5f40wMPSvG2m6rqS2iXbW+oOpK2dwjW9ywGc4jcKzDjqAR7mvP/iV8H/D+vePtG01Y7vR49cgvJL06RdPYfbHi8hkaVIz5c33mz5iNnIBJBKn1DxDoVj4l05rPUrK1vrOT78M8QljJ9drAj8f5GvPfFPg1vDvxD8GyaZqF9a+ffXduLe4le7t491pLKdqSEsoxEVCo6KMjAwoAWoHKxfBbxt8EPEUms+BbrS9asbhyb7w3Ki6ZHdhmDNNCy7oY7o45ZFhik+Xem4B16D4V/Fe++POlSzWN3ZeG1ht7drqzU/adYsHlhSULLHKixwMNxALJMr7cggA12UGu6ppbL/amktcIMh7nSmMwKj+JoWxIpOT8qeYR69q8d8HeB9S8efCjwLf+GRa6F4g0fRrW1HiLz9rRlEVHtntVX/SoyUbdFMYlXcpRg2SAr1PTPCvgWxtfFWqXNzDJqV2s0M0F3qDfaJoyU58ssMRjK9IwoGBjGAB0Gp+MbHSr77PJcPNf7Q32O3jae4KnoxRQWUcH5mwPftXing34gSN8T9S8OfEvUhpvib+zIry3022le003V4o/OeWa0kVledFUhTFK3mAxysylCCvZeFPjh4Zn022s/Bek3niFJEV2g8O2qPYW7NhsPd5SzB9cSliQeDTEdlLf65q8C/ZrSDR4WHL6jiaXHoI4328jPJlGMfdPNQazo+n6ZpVxqXijVmnsLUGW4kv7hbXT4F5J3JlYwoHeUucDliea59NO+I3jxnaa/wBI8A2JY4TTMaxqrDBAbzZ41t4mP93yZgMH5jn5b2j/ALOvhOPUodQ1LT5PFOp25DRX/iCdtUmt2HIMIlJjhIJwDCiUtRGVbftGaX4isoo/Aei6z44UfLBPpVt9n0fGeSL+bZbMgwc+Q8zDHCE4BfceH/iX42VlvvEGjeB7Fv8AlhoFuNT1Ir/193SCBPl/hFq+DnDnv6YJPNG6Tc24DO4nP+f8RQysdq59Rn6/X/PNHqB5/oP7OfhHQdUt9TuNPfXtcs8NDqev3UmrXsbA/eSS4Z/Kyf8AnkEHGABxXeTZef52Zyp2nPbjr698/j9Kcv70fKvUZBBPrnp+NN4Y7eiqeBnoKYAiFF/2h973Pb2pwjLHb2I/M+vr7/h3pyN5nr2JOehpwXZH936e+Pp/L/HNADF3Bv4vUH/E9P8A9dZMPg+w0qfzdPjbS97FnFmfKilJHJaLBiLHu+3d6Gtdxh/7wyDnvQeJFXpz1/z/AJ96AEQtv+YN5mcMPf8Az9arWfiPT7jW5NNjvrd9Qg5a1EgE23GQ2z7xUj+Ice+c1ajOwk7eo6Dv/n1qvq2i2XiG0WK+s7a8jRg6rNGJAjD+Jc8q3uMEYo9ALS8n2Y7QQfvdBQD5nyj5sHvWTD4dutIP+g6ldNAMn7NqBa8XOP4ZWIlBJ7s7gD+GteMPty67HHDKGLhevQkAn8QOvalfuAq7iM7iex5zj/8AX/h60ZCZb2P4YB/z6U5XzGFAyCAeO+c/4frTVOOcHGSuQfvDt/n2pAIwzLty2N2doGc+mKGYeXux2xn8uf5U7G5c4+YHIPtx/wDr+tJL8gA6biST6YH+fzpgB+TbnPYEA9RmkZuG6/e59Pp+f6CleQhlbnd1GTjgf5/lQcDG3jGCDnv/AJ5/X6moEa5Yc5JPfOPX/GhRjPU+nOM/57e9MNz5M0cPltho3k3j7o2lBj1BO8+udpz2p+5ljA9j07dv8/Ue9MBHIx6nJGP73XP86VDk8/ezn60DK8n7uNp56dT/AJ/+tSk4Uhl9h78/59MZoAYWxJ9DgnjB6/zHp6fjXL6Gxb4w+J1OMf2ZpbjB6fPfAj8doPJ5yfQV1Uj7piu3O4kHJ9z1/wAK5Pw5cD/hcfihf7ul6Wj88g7r45/EMPTofwQHWZ2Kv3slcZ/n/n1qQfMV7gEHA71GW2ptCscH3GSc07/lrsHbHOOPy/CmAMu75dzdOSf4f8n/AD6jNkddv9725/8A10KxKtjb1PH4DFCvyzcfM3Oeh/yMUgFVsRH72fXPXtUsb5UnLKuORn/P+fpUQbA9MdB044/z+VSA7XAA7dOeDQwFZmDjaOnXH4f/AF/0ppTIb5uPU9iP8n8qcGLOuNy84z6f5/z1NR529CFzgjP8s/56VIDGQsWb5u468/56/l+NI20QbufmPY9KkaXKc9ufoPT/AD6U2M5OcY3YH4Zyf8n0qgGsC7L6g4/p/h+lEzMFXB+ZcYyf8+xpwO1unPp6Z6f1pt1kopGTjBxg0ARwYLsP4ere5x/h/LtToizBt2SAATz6/wAh1NRqdhYjqw6k+tTQ8qGx82cNxjjvj3/lntTABknsOCOv+f8AP6Em5Qx/hY8c9aHQldrfLkE8/wCfrTXdijdRznp1z/n/APVQBIw+782GPBA6H/OR/kU3YVwD8rNknPT/AD/h9KCdu4NxzknGcDB9vYj/ADy5flPHr39fXnmkA1kZSOfvcg/pk/p/MZpyoQM8dc5I654/nj6fzANit97r2/D/AD+VLy68feySF/LvRqAsUpaP+7uII/rj8f50KvyAbmbGD833j/n+nvUe7hscbeBx3zj+Y/z1pxBB79Mccfn/AJ9KAHRrgcdjxtOPU/0pQPlbON3TA7c9v8/zpVmILZ457Dv2/lj8KTcFCjgdunK5IOP1oAQjavp39jRzvVdwG0447/5z/nmiQ8Mf9rA/l/gM07bj5eVHbj73+f8APai4CKMn5sDA5/z/AJHX0oXLISfTrnH+eaeq5k3cYxjn8f8AP+eY9wb+9kkHHqf8/n/JAI8TNlfu46dKieDz8oW+U5XOeoJFWJVYS5A+Vjnk/wCfp/hSFsSx8/xDv9KcWG54N4tDS/sNN5iLut9Ltt6lgAwiuEDHPHGEJ7cY+te2MMX57Yc5Hvkn+eK8b8RwJdfsR6xDJH5ca6JdB4zldmx3JHqMbTzjj04wPZblgt5Mw/ikJ9+v/wBcURA8w/ZTtpLDwBq1pM26S18Ua1GxI25/4mE7c/8AfWeOOmPf09OPyyf6/rx+HavNv2bVa30fxiN0cn/FZauy+WchAZ920e/OCPXPHYelwrvIVfmVjjjsPp+IqteoDo9yv2G33/z7f5FPjVsNgDghh37dKz28R2v2mSKOUXU0LESRQAzMjYzhsDCHHHzlauW8s1xjdF5OMcOwZj+AyB9QT1pATKdx5zwOmevT8f8A9X5jFihkbk9Tgc9OD/n0ozuHHzFTg+/P/wBelwCdv3lIOce3v/n8aQFB7zULjaIbSG1j3bfMuZQzDHokZIYexdTTk0mR3b7Rd3E3U+WrCONPbauCR7OWq4QxXp/DyOn1/wAP88tf51Y7m5XOQORwf6c9qEAIFi2iMBQvIUcYxzwP8Krxjyok/wB0gEemP8/n3qchtu1W+baf5f5/L8aYr/u+u09v5f8A1qoAWNmzwvbjsB/n/PanRBgV3N83fAIBPXp+dNHzscDryBjtwf8A61Lb2ghjbbuO48kkse3c+tAD16Fie2Tz/n/P6Ky5Vh/Epx0/z6f5zT9291GVbJyOP8+gpI8+/YAnqPx/z1qQEVckheO68+gH/wBf8jTQu8f73bPb/OalH3SfcHkcEZxSDgqePvc57dc0ANblh3Ppn/P5UhO4beBgAj8v8/lTwN7/AHWw3BB65P8AjzSKQGb+6T2OB/kcf55oAaB83P0470wkum1sYJ+96/54qQuQ/wB0gkZ+vH+RTlUGL5v4uB39B+tAEaDeGbrzn/P51JguwX5fTr/n0/lQrsWVto9Px/z/AJ5oxsl5Bx1579vT/P4UbgNdN2B24B57VxfxOIi8WfDxt+FTxK4ORwwOlaiMH0+8D9cDvXavIysu3+IfgK4j40O0TeD5FUsyeKLNW4yVDiSPntzvAyf72fSjoHU7CEfvFPqwOM+n+RXGfAoMvws0uNo2t2s2ubdomPMbRXEsbKfoUrsX569RyT/n/PFcr8H3P/CDtznbquqr028DUrrHv0/P8aoB19oNnrHjy8W+trW+WGwsbiBZoVk+zyh75fMXOdrbXKhhyAT6kV0cdqLeOOJVURxoFCKAoUAYCgdF6dOP8Mrcy+PpF/56abGwJzjKyv8Ah/H9eTWtCSGbcflALn1xz1/WgCRVy7HcvU49s/8A6/1qSPALLlfmIz0yCR/nn3PXnKZ8sbedx+U/WnqrMq8/Nngjv2z+v+cUgHBcJn8Bn1/px/OhV3pubblcZ7Y9v1//AFU4AlTtX5fY9B/n+dL8wIU8Hnvz/nn/ACKVwGmPj3xtxnk8c0z+8Vz04OeQMf8A66kH3mZsfMOhHb/P8qauFPAJ4/THP+fbt1oAaAV9GI+X8P8AP9aH55+UHngY5/z/AIfib8Qrk5wMHA/z7f54qR22nJB6lj7j/OKYEciY+8drY2mgDYD/ALOcnONvNOZPKLbuV4GKdu+VueeuB3P+TigBqBizcbWbtn8P0NAYKN2Rhs/5/X+X4LGFzzkck4A+np+n/wBeljPybSv5D/P+frilcAKfKP5E9Px/z/WnZ+YD5eP88f5/nSA7Q3X15PH+TTnPzk/XqM0uoGT4n8JWviWW3mkmvLW6s1YW91Z3L280AfaWAKnDA7EJRwyHYMqcCobG21rRZtsl1Z6xaqo2tJGLW7H1ZMxSE9gEiAwOfTdAPzbvbPHGeo/z7UzBaPPXcMjnoO/+TSAhsrmS7jLNDNbsCcxy7dynvkqSp5/usRU8kW8DP4Z5+lOZ9wzyRnIP45zWfrOn3WoRQ/ZdQuNOlibdlII5Vl/2XV1J2+uwo3AAYd6uBc+Z9vzDD/4HGP8AH603G1c8cYJJH61gnXdY0KItqmmpeQJwbvSiWJGeS1u3zr3+WNpTx09NDSPENnr1m7WlwshTAkUqVkhbph42AdDweGAPFAF3BRufvHoPT/P9OnqzlAq9dvP1OKdJiNP9npgn/P8A9fj8GsTjb/eHT1700BI6kSIAewGe/wDn/PSmjgHLDd1P19Ppx/Wh/wB4nyn72G3enP8An8qaf3hJ/vZOOn1/l/nmkAsgJH1xgZ6+n8/1rlND/wCSveIl/d/8gfS34blv32o8kfQDBPv711anemN3fnI6VyWiRqvxy8TN5e0toWjZcrwf9I1Xjp26+nPT1GB1hDE/Lt7bj0xQ67G2nHB9P6fhUwjwW/2eBn/P+cVHNHldwUHdyQ3ft/jTAFOdzfd4AOccYH8qE5ToSD6HBP8An/DpTth3ZUDcDjgd/f8AL+X4CqVB4zj+fP4UgGuWPcbsn/63+fepGDbznaxYn8e3+evSoziMr/dxhv5fyA/KnN1XP1PHX/I/pQBIwbdn5cMfz5x/X+VMUE5bPbI+nHP40sx/eMcn04/z60eXuiK4PzH+Z/lz+WPajoA3ycSbv7wIB6e36Z7+lOERZdp/iOTTY5CenC5yDjoen51JGQdu3jgkjv8A56flSAjbcqKc/TpwOtN3fvNvCnr+P+c1YvB5cRbbuwwwP6f59aporOqnLNz1P5Z/z6+1OIBOhTGMYB28D/PvzSwHEf3uO/54/nUiJvX8DgD60oi2AH+6Nufbtg0wEPz7hyR1J/p+lKW+ZM/dzwR37UclPl4x17/5xx/9am/MH+XldvBB/wAf5/8A1qQDZseZ5eW2jjOP8+3504Nn/abP+FAG11A+Xacf5/z3pu/K+54x6npVAPf58dDt6ZHrSdVPzHqOnv14/D+dG4++f580IxXnbt54A7/5/M5FIBFbBz1zyPX8f8/pSBdzA9DjkgnI+ntjPA5/WhVyijscYGeCBRnyph/s8dfx/r/+ugBy/vEK9Dg7vb/P9KVG8yNvvBXG3tzkfzo3ZDbu2Sf6/wCe3tSMWyPm5U9ccA+uP0xSAkPynnjjPHRf8/0pyHb8uCvv1wP896az/Ljpxkc/57/5707ZgH5eV6YOfTP86AHDBdtvQdsd+lNLYfK44PIA9eabG7KDtX72CCe2cf4U6RsScsF4GOec8UgBkwvf5cAnH3vX/P09agvZ1tEaaT/Vxjc2ATgAZPTn8uaqSeK7SWaS3tfO1CaBtjLaoZFVgcFWfiNWGOjMCD+FNZtUumXYltYr2LnzpCPoCFU/8CcZ7GnEDx+TxLH4n/Yi8Q38azW8baPqx2yFQ4EUlypJwMfwH/D19el1iC61Sa3gka6mVnVkgUyYIOMMRkL26kHg/h5j47+AWrD4S+IPDeiahb3lrqWn3UFlDqhkhFg8yH5leDCsqyEsAY94LH94AAo43VvhdrHxQtodP+Iviy70yJWAudNjZobO5VyAIcxeVaSR+ZkRrLHLJt2hmLA5EB6B+z9f/aLvx1D5Jj+zeLLxoz5scqyxSJFIJFMbMMFi6kE7gyOCBgV2knhyPUruaTULi5v4XYtHbSlVt4h/dKIAJOxzLvOemBWP8LPgzofwY0SSz0O2lt4ZynmGR93mbV2rwoCjAyPlUcYHQDHVYI4CnCgkZ/ipoPQktbVLeFI41VYoxhVRdqp6cDgDpUyKMEenHHYf19aYj/vMgZ3ZOM9eh/lShfNfHOQMEHqf5elMCRhlt3447DrR6/xNz+lIvXAG4/e65x/nP+eyH5V+9wvJxSAkGGb73PHbgU1032zKRjcDgZ4H+fenAcEYPzDHXoP8mlI+Tdx83T8/WkBD8sYcj/a7Y7f/AKqiKYCZ7kgfj/8AWqZm3RynHVWAPTBxx+uKhGVk6DbgdPX6fr/hVADvt6ZXnJzx+f41IrbZB/cXJ6U2Nc7ckkdev9P8/wCLgm47e2OueoB6f59qAJNu487vlwMD157/AOf60rcnGSccj/P9famK3l7mxk9D78Y/+vTlUk9+/Q4GT/hz+eakBznnB+Yjpjtj/wDXQV2qvLfuyRk/yz+X5UhG+PcM7c4+n+f89qHUo5yPmPU56e/+fT60AKg+f1zgDPbrjimyN8jKvbJUHv0/xH19qd1k9ucj+Y/z1pp/dk7fvKMZz3GMZ/P+tAAqeZu/u4A+n+H/ANenA4y23Pzdf6/56Zpvl43Kc8nnn14/z78c05XIAwvUcfl/+ugA8vzAvbcPX9fT/I9aSQ/vWU9/6/5/z1p5DF128en+fxpuMkZX6DPXt/L+tADGY/Nj5VXtn3/z+tcZ8bmWLw1o91hV+zeItHcls4UHUIFY9OPlY9fXHFdooyCoB/A44+v+f544j9oK1e7+GUhVmVIdX0i4cr/Csep2khP/AHypPpjrjNEtg6nW7PLbj/lmeh7/AI+/J49/w5j4QuY/Cd6nH7rXtYUFe3/EzuiBjtgbeO2PTiuqbLr0288c9M9vz/yK5T4VqyHxFD/DD4hvMc9PMZZsj6+bn65680wLmo7U+IumoOPM0q7bGf7s1r/8X17fjzuCTL/L8zZA68E9P5D9axtSmYfEHSl3sytpl+xXbwxEtiAc9c8njocnPRcbKR7OmdrHHt9P5f56sBwIyqlhnoCe44/+t/kcTImUOPvM2Qe+O35f0qMJujPuc89B/nrUynEbL/eHY/5/+t/JAOA2RLz7D2P+J/z60848zb/tdu/+ef8AINM67fl29See3+eKcXbc3JXpketSA0PlNvTCkj344/U0xWXy+vIAGPx/r/n0K4/cPjuG/DA6/nxSFmydu4jG7rndjAH9KYA45POATgHscn9P8/i5m+ZdmV5+uRSbcSN/cz0z6f5/z0ocM8ee2cHnr/n/AApgNVVQ45Xtj9f8/wBacr7n+nX26f8A16COcHjB57Y/H2FNB2+7cZPQHv8A5/pSAei/uxnqpwvP3qXhU/u4zuOPunp/9agtkEjr6/kP8/5NKVJG4rhevHakARgqfl+XgEY7dzQhG3+6KTB8zHPGOMdBj1/OnYb+LP0z0/zx/kUANZuSy9s/TFGVAH+zySe34UE4bLcdz/s019yrnbx/n9KAHMnlrnacZ5AOSO3U/h9etNZi7gHtkeufwpzcKy8gg8A8cc1Gr579CMEf5/GmAD9/yOrds/XJ985qOe1juHWR44/Mi+47DJjznOD269u31pwXJ+7tz0wenHP8x/8ArpxJErfUnP1/z+lMDN1SDU/7QWexubXywoU2txEdsh3HlZFOUbBHJVxhR8o5NTWE8sq7Jbd7eRR03B4yec7XHUf7wU9OO1Wn+8WH3mBC89e3+frSt8vzfxD5SQe5z/n8qAGx8LhfusCFPr2/n/npSrJsHTIyM4PT/P5f1xtY8IR6lqX26C+1LTb1VCC4tJsBlxwGicNC454LISP4SM1DZXmuaW/2e8srbVolOBd2DrbyMO2+CVsDA7rK2eu0cAAG+8mY+Nvb/I/z9a5fw/N5Xxz8SLtbP9h6S33cBgLjUuh+ufy/PabxJYx6zBprzCPULy3NzBbtlZJUUgMVBA3FcgEDJGRkAEZ4/wAP/EXQdY/aO1jR7LWNNutVXQLKSW1t5hNJEEuLvO/aSEx5qYDEE7+/UHQD0RB8+07d/I9QOn/1qcAobC7iT3/l+Z/z6NjbIfnn274xT8bXb17VICqrbeeue3f2/wA/4UwoE5PGRzjkLn1/LrTmDBsHO046n9f5f/Wpof8Adr8oyPm+vIz/AJ/xpAJLFg/L8zZ47emR/X8T0qEsqSsrbgeT/PH+frVgFkwvp+YpyRCdVGT83p2zVXArtLuVsfMqnB9+f8//AKqdjPXDN93juP8AOfzqMo9vIqkboz6HOcY/xoXce57ZpgSZ3MP9peTn7o/zn8+2amQANtX+I4J/z+X41Hncfm75xz0PFEMSQQqIk8tVXCqoAAUdh7Af0qAJj88bZ2/MM8n8f545/wAir5fkscBtuenfHpVkMdvORzgkf5/z+VRznzH2++BnvTQEULfNnJJ42nGMDn/HP5fSnJjC+mPX9B7f4VGzscKuMkevNOQFZQo9Mj/65zz2qwHFtrc/w4z+hoaH5/m/H/635U3buQNj5vf3GadjcM/d7jsc/wCc/l7UgG7Sz/N06/T2/D/PNG3aGxzn34x2/wA//rAwDHtjJDdtxoUh1IYDtjPX64/AUgERV3qy/LjoPzpCuQcN93HH+f8APPtmiVB8vTaQBg/59+vt9KhG1e/Kjv2qgLA/1ob8vb/OaSMEgHOGB6f3eP5/59KRSA6457E7TxTkRSOmNvQ4/wA8Dj3+lABhcKv8DHketCjIKjAY8fif8/54w4qCpUj7xHLdv8/4U3ZkbTwuc4zyKAJBJvA/Tpxx/n8qXG/HVgen5E8fl/nrTAeRux9Oh/KgLt69eCfb/OKkB3Tcdy/LyT6j/P8AOnPEC43dO3+zng/jzTWVQnp1GefxoVzuyPvL3zx7f1oAWR9q/Nu9c55/zwaZIxD4/vE/nwP8aUgZ2r931z69f8mo2QMvHp8o/DOP50JAcf8ADeVJdW8aYZePEJGNuNv+hWmPr0zn6Dtk9QtnETI/kx+ZMojl+UZcDIAb1HJ4Pqa5jwUPL8Z+Ml3O27V4p8N90BtPswAPb5M9uT+fVo21Pm+8M5yeT6n+dUBjReBLbSl36PcS6KV/5Z24BtSRnAMByignqYwjHn5gaBqGqaOjLe2C30KjmfTz83Y5MLncvOflR5D+fHQBd7fwk9PSkC59xkYA4z2P6H+v0QGd4c8RWfiVJGsZ1naEgSxFTHNbMRnbIjAPG2P4XUHHYVoKAU/2Rzz37dP8/wBKzta8Jab4kKveWcE08Y2xz7dk8PX7kq4dD7qwI5OarDQNU0nH2HUTdQ8YtdQXfhRxhZ1+cZ5OZBKevrwAbZJw/Tpk5/r/AI0pGG/3hk1g2/jqG0uo7XV7aTRbm4bbD57q1vcvhfljmHykkkgI+xztYhMCtwxCJTkFWyeo7/4e38qAJFGx+D6cjt/kUuMxHs3b6Z9fw/l60mdob5fm449xz/n+VI3ETbe/GfTnNIBJl3xtjuCenY4qNxnnkjOQPUY/z/nFSyhUjbHbsO/TFQMGLBW+Xb0z/P17fp17UIBzn8dvTjg9KlHydDkYyOaikX930+X0J6Z/z+NPK5z7cgH39fxzTAWMev8ACMkZ5NDny41VfyHU8f5/Kkc/OV/P2z/n/OcUrr8nY7uxNIBw+Z0PGegI6/n6UBcEEfnjH+e35UbcL8xx3GD0Pp/n/CmgcbQO3Qd+vT+lADgm89f4+mOnTj/PpSohV2Y/ezx7dvxxUQSR5x8yLHjJGCSx4xz0x/n6yPtZT/Du6hj15A59fxoAI1Bj6fLgZI9MU5wZF3Hr0wfWh4wg9sZAPOPb3qMgkLzkjPfr/wDqo6gSEEt8pbP0/H+dAIkVsfKpzkjnp/n/AD0pqkb12r7dev8AnP607ZtO4dckigCPYEUZ7849ST/n8M/WuI/aRTZ8DPEkuGb7Lafa1xyR5TpLkf8AfGc8/Q9K7hx8oHy4yT+B5zXIfH60+2/A3xnG0YmX+w71whbG5hA7DnnuBzg4POD3Nw2OomUCVv8AZdv6iuP+GoZPEnjhVGCPEJOB2JsbIn8+vHHOeea6sTx3iLNEfMjuAJEbGCVIBBx7g9OK474bsG8cfEaPaf3fiSEHnqDo2ltn9SOKL7Aa+q4j+Iuhjj57G9TG3knfat17fc/HjuM1uxKV9S3r+f8An8O9c74lIg8ZeGZCVXzprm3xz8wNu7kcenlZx/sn2x0UYxn5fm4wPw5/OqAkVVKbt25eSufy/lTtrALHzn09/wDPOfr+LI0wi/iOvXt+nH6U9Tuf9Bk/55/xNICWNcv/ALKDj2/zkfrSqjKg+7uGAfxzTUUIRtxtU8HP+felYZTdxleuPXjj9B+dToAzYyeZ/dIOB6HmmfMA2CTgZA+p/wA//qp8uNj8ZUg89j36/wCeo/COQbVbhSy/w56gf/qP86aAlA2MB6evX2z/AJ/LpTtuWGP1/GmBFKbd3K5OQTz2/wAP88FQPLPGFUY78D0oAQZ2t6KMAeuOP8+mPyiCZZWwTu4I9+f8+/6VLt54+UenOR/+rmmvH8/bPp+WfyoAVSZF/i+bPI4+v+f/ANdSBd8nY5X8+P8AP51FGigZA47jPX/P9e9OJwB930Of8/WmA/K7lb3wD680jouNvtwB7f060bN49OMAdjSBsvn7zYJ6fp/n1pALI2/dge/Oev8AnmmlsSZG3/Z98f57e9ICd38PAA5zxSSnIb68f1/z/XigBzDLbfm2g9Af6/59+nCEeYCFbHHX1P8AkfypT82flzxwMkYpmQXLfeGcDnt/9fFFgEZRub+IKOg44Ppj/PBoRNxG4c9MY69Of500EEHowzgcZqj4g8T6b4WtmutU1Cz0+0B+aa6uFhjGMn7zED/CmBoZw67fruz1z/n9aCvyjvkEk4+vb/PSuEj+Ll34ojY+FfD2oaxE3KX94TpunD3EkimVxnvHEwPODxUp8AeJPFSMuu+J3tbVm/48vD8RsV245V7hmeZs+sZhPt1JANrxp8StD8ARxf21q1rYyz4W3gbMlzdHriKFAZJD04RSawV8e+KPFSldD8LzabbMQFvvEMotQ3P3lto90x7kCTys8DKg5rc8KfDfQvh6kjaPpdpYyTcT3Ea7ri5Jx/rJWzJIeBy7MTitpF3nkcfe/A9aYHAav8BY/iFGq+NNf1jxFCsgk/s+3c6XpyMucN5ULCV8HoJppAOO+SZ/hR4U03QfGviT+yNM0/Q7HTHg0dLW0hEYk8tPtRmbAABJutoGCf3RbcQwVeyVWIH8OB2Oe3f+X/165v4bJjxh4448vGur1PQfYLPnj3BOfzApaAdlGuFb+LbwB09P8/lTs4HJx+n+e/51GrFVLbOn8IPJx2/z/iKew2r8vrg4HH+f5YpAB/ut09P8+lOfJB6kL82PX1/wpgPLL8oKqDknkf55NSImW3MG64/Xj+f6/WgBY4iZd34D3/zzUwGB/FuyMe9MX5unXsMf5/z9aaXBDEHcucc+uSP8/jUgR3o3QKvsSfcev6/54zGn7vof9rp0J6/57fnTpTtHzdM7Tnnt/k/jTWj37jtXgEY/I/4flVIB6KpnjZmbKAhQGIBz1+v4/hinJIUbj5lUZHt0/wDr/nUUnLAY+bIwPUf5x/8AXpwHDeh79eP/ANX8hQA5eFx/Fn8QP8n9KD84Zl7EEk8/5/ye9Njk8w59/wDP8v6+tA+WM4Gfx/kf/wBVGoAyFfYHrj0A/wA/pQnT5vm5/Pt/n/61I4ynpkBuO3U/5FCw/Nhfu/dJHc0eoCuAWUbcbuevTP8A9Y/qO9HPX0OOfwH+fpTg3z/Lt7Z46n/P+fVuflODz2z0NGoDQcFs8nn5f7uef1okbMJUffU4II4/z+lNdE3Nu49M+/WlQ4C/3eeAPw/xpgPdf4lIyBuXPQnk/lVNBuQEZG4/Nngr/n/Ptc3YT5euD2/H+majeBS+Ad3PXpQA1FJTP8OAev8An/P6zINjbh8pJ3E59/8A6+c1D1X/ANm9B6//AKv/ANUqkKd3tnp/n2pgKfljUbcBcE5PX/PNGPfb2Jx+P9KaybmC5xzhcDPX+tN83DFc7vm5x/n2+lSBJz3HfgD8BSE7y3Hyt0A78YH5dP1+jWOCvzNwccDr/n/6/NCHMa+o65HamBIrArz19M9f8+n/ANelkUxttx8uMdc9qb95Ru+XnJwDk89/0/Kmytt2HPfsPb1pADyb2Hfbwffrx/n1pvWQd9uBjPX0+nr/AJIpyfInUH3x07fp/nvTXRXO3qfp/n/P4UAcl4TuAfiZ4wjbYQXsX4PrbAZx/wAB6+nqM11MJJHzL82MDHX8K43wyin42eMtqgBrDSJXGOSx+2KSfX5UX3/Cuwjbc3yn7mfx/wA5/wA8U0BYAVlzn7388c0M3RsZ3dc8Z/zn8M/lGqKse3I2rzjHHfp/ntUytn657jqP8/ligA2ADp8xGAfx9KdIRlh/FyB79ajBARR6cdOT0p54K9fmb0/z2pAQ3+l2+pWUkFzDb3VvIuJYpkEkbDg/Mp4I74wemfTGQfANvYLt0u6vtDKjaiWTr5IwM48iRXiUHuVQE8fNwMbrHc3Hp+h6/oaTdtx9dwz6f4fX/wDUAY8V7rOlH/TLS11KNek9h+5kHzEcwSMRgLj7srE4OFzgVZsPFmm6tcNaQ3SC+8vzjaTEw3CJuA3GJwHA68lcZx9a040Ee1cdgQSP8+lU9Y0a01/Thb3ltb3kCsrBZog6q2OCoPQj1GDzSAsSHbC25fmUDIz6Ff5f5xyaZGnA9D3Hb/OPxrGm8L3elW8jaXq11DGsZ2296DewldvXczCbIxx+92jPQ8YgHim/0gAarpF0sfKm604NfRenKKomXIHURsq/3sDJYG/nzgGONo5/p/n+tORsKQw+VvwGf8/56VS0XXLLxJY/aLG7t7yEMYy8LhxGw/hbHQ9Bg4NXcBxjov3cEdQPb60wHHawO7lWHPb2/wA/T25GyPvcEEZ9/f8Az7013wmc52jDfnz/AD/zmkK7nH95hjJ/p+R6fzzlALMQI1+83GQFHPvj/PbrmnMcOm1VzkE479R/jQg6jdubGBx15/z/AJxQNpixubkenT/P9PwpgLHkKehHOPfj/wDVRtVQPf8AT/OKA2YmY+4PHHFIWzwG4YbcY69P/rdKQDsZCjr/AA/hQ0mfnxwQCTnj/PSmHBb8Cef50ittP972PeiwEijL43bSmcHPJ7/59xSxqdvT7x4pjfMfxxzzn1/p/nmnFu+7a2eAR0oACfmXG3rxg/jXN/FiMz/CzxPHyxk0a8QdTjdbuO3JycV0BABk3NknHQfmKo+ILD+1tBv7TzPL+1W0sW7bnG5WHT8Sf88uK1sJ7EPhS4+0eFtNm+X5rOGT5ecZjU4HTjn27Vy/gRTF8VviDF0WS9sbgD0LWEEef/IXT2960PgnqB1f4MeD7ltitdaDYz7VGVUtbRnj2GcfhVPw6gt/jd4yX5V3afpNxnPY/bI+cn737r+XXkBdh9dDT8UfJ4g8LybQfL1KRSP7mbG759skAd/5kbqttHzN8uOP8f8APpXP+L9qa74T3YXbq7L83cmwvV49+e/HXvXQRjCKcnC5yMd/p+VUBMMjG3buYf4H/J9qcp8pAvzbV6Z5x0/p/Wo1IIXryOvr/nH+eKk6s3XqeB09ef8APNIB+5lUMvpng85Pp+RFO2hVYL35556/5JqOSTEfb5OpA7f5NPfB8zcPm569c+n8vwpANk4ib5WXau7Hrxn+X8vWox+82qc46cnp/nH+cVKThXPqOhXp7f8A6uaiU+U7devpjH+eaYDywD+wOFOeSP8AOKVV2Dt8uSD1/H9P/wBfZSu0Y6jJIB7UjAFe+0Hk+v8AnkUkA5gFQfw9z79KaBhMcFs5OOM8f5/Sgtjd9Off/P8AnrQVIbj5fU7f8/5FACEbkHpnIxn608bQw/i7A9v84/z0prnKYyRu46UZLhfu5U+mf8/4UAEAxt2nC4/w/wA/THegDcvPXHbpjj/6/wD9amu27nLfMuOnJ5/+vQsm7dnGMHJI4HbP86LdQHfxfd4bsOvt/T/OabJ/CevI9Oelcve/F3STO1rpgvfEV1H8rQ6TD9pCnpteXIhQ5OMO4x3wKrtL4y8UL8v9meE7dlwdyf2lfN16YZIImHykf68HJHHBIB1lzPDZ2hlkkjjhj5aV22qo9ST0/H+Vck3xgtdftt3hvT7/AMVM7YSSxVYrMnuftMpSJlyOsbOfY9KfZfCPS1nhm1RrrxJeQFWS51iQXBDBmZXWIKsKMCeGSNTgLzhRXUMN7Kzd+OfT09qYHGNofjDxQd15rNj4ctHxuttIh+0XK8nj7VOAvp923Hc5yQat6B8L9F8Oap9tjs2uNSUBft15NJd3Xf7sshZlGSThSByOOBXSKgPt8vGR0z/+vPNRs6713Nt3EAfU/wCODTAsw222MySNlh79QcD+vT6VLIPLDZ4Hp2qRiu3hgVK8cfnUMy55Py9e2OOv+H5VIAMM/P3eh9fy/GmliqBWHzH1P3f/ANXpRnJP8O7nGPz+n/1qaTuC5/Ids4/+t+VUA4jErfL7cfl/h+dcb8LJo5PE/j2ZCu7/AISHYceqWNmMHgdtp+hFde5Dx/NnaeSf8/5/mOM+GE3keJvHNmG3La6+ZgQpyPOs7WQj3wzNj8BQB3SHBK91OB/n8DTmGenPTHqf8n8qhTbGV7DkY68n/P61IznHONxOP8//AF6QEjx7M9PlPJ+tSFFB+XjPHPbP+f59KjjbEn3uO3t/n+ZHryKdrbu2cjA6YqQHK2Rj5cjge3+RTmAcDI7+v3QajAITc2c5OMD8f6/5zTs+Ux7dQM9+tICMsTuOfu8dOAO/+P5U1uNo6HI2kfwnv/X86kYKh2/3R0A6dD/n3xTX2iX/AHTwR/n/AB7VQA2BIWbbtXjP+fyph4KswG319AB/n8KR8rNuJHTBJ9uB/PpRnaG56HI9B/nrTAdnMLcqF5yfQ96GGyLB4ZQc8+lJtCL6d9uOh/z/ACp0SlQF3Yb1x/nqR+HFIB0nygdyOSfX0H8qJB+8xtHPAH+fekRdp2/wfeGBwT2/rQOF4x8vI4zj2/n9KAGS/ImWz+8YKSOf89f1pynaCC3OfwPrSMys7HnP6/5600DMZY/ewB0pgCHMjD2Gcd6ARszu+6egHTvx+n5UR/KF+bnrkHAyev6/54qMLtRewxjHoRTAmZ/LUsfQkn0A/wA5/wD109o9h77WJHXr/k8VEj7vlbHzZABHU8c/hn8akbhj7g/h1/8Ar/54EgNYblI/h9R2pxGE/U+v4f59etAKrluhPJ47f5zRs2qM7s89v8/5FMBrR5GPf9en+f8A9dM2gs33uCeg69P65p8wZWUfd6DP+HrTQdw2j5W5OOmMYPP+e9ADdnG0naSSCBzzzTh8o+9tX1x1NAGBx97gDP4/n26/40fMQT94qfzxTAcr5XCvjAOD/n04oX5Nv8RwRn2FNUdfr1x1NOyzj5Sd3I4H8v8APpSAHj3ELuY55HqTSOu7/gPI/GlmIP556dvWowy8AMOOoB5UHp/X8j6UwPCvjR+0dY/s3/FzXNQ1PQ/EWsaXdaXpEVxPpNv9oGnfv78KZAzD75k+XHJ8sjGdoatZ/wDBST4ULcrb6rq2r+G2ZA7DV9HuLdYgSR8xCsB909Tj5TzwcelaQ2742+KrWRWmjvdH059jkMhQPdoybfQ55z1/PHmvxB/4J9+C9X15dZ8L+d4R1RXDvHar5tjOQc58lj+6YdmiKhSASjYwZ5Wth6Hqfw4+OPg/4uQrJ4a8UaF4gWSJp1NhfxzF4wVDOADnaN6AnHBYA9RnrIGyn3sE8e/H+GMV85fAP9j3xZ8FbnVvEi+LND1Pxrrkim6W60uSfT4okG1LeGQyC5UAbizk/O7f6tQoWvTE+L2ueE2aPxZ4M1ezg+bOpaGf7Z08KuTuZUVbqPgA4NuQM43t1ov3F6HoYfcO7LwG/lSklnK9cisfwP8AEDQ/iLpTXmgatYaxbxMBK1pMsvkvtBCyAfNG2MfKwB56CthcSMdo3Z9D1H/6jj8BVAO3bh975W//AF0KflXcfwxzn/P+eaYrllO488HnnOKc6sob5vm75/z/AJ/WkA9TgYzjjj6etFwu63PLBlYHP4/0B/Q0xjsjb/a9P89sUkjGJ8HJ9x/n6f5zS1AcEUuq5/dkhT788/4VBEDg7mYYC7gAevX/ADj/AOvUrNllVR7Z/wA/5/OkVuGYdxg8Zzn9f89hQBlav4J0vxBdtd3FsPt2wRi7gZre5VePl81CH29PlJxkDI4FQiz1zReIb6HWIVypS9X7Pcev+tjXYeoGDGPdupraG3aF5+9kDng+/wCX+c0K37rd/DwPfpTAx18dWdqVj1JbjRWZggGoKI4ySTgLKpMTMewDls9q2gc/ePUA4wef88dKZcxLcK0cirJGww6MM5H/AOusRfANvpxX+xri40PaDtgttrWeMY2mBgUVckE+WEY8fNjimBv53v8Ae+9nt/n/AA/kGr8zK3PfnPNc+uva9oUjf2ppaalDvAF3pJy2MgZe3kO5evSN5eASccCrvhfxhpvi2Fjp9z5zQgNLbsDHc25xwskTAPG3B4YDofSpA1Fj+VvmP5fX+VOIDDrxjjHT0/pio9275fvcEE47YpxfM2Oev6/5/rTAd2POD1H+f8/yoJ2KxPQY7U2N9xXG4989xx/n6UifIFyOh59v/wBdMBdxUZ79D/n/AD0oK5AH+PrQXOehHP4UO+1Mbsf7R70AD4G0k8ZH5cZ/pz9OabFEHkWP72cA5zzng/5/yBflYkhunfjtz/n1pYCBcx4+Ybh2+lIDiP2fZZLj4D+DFkbEqaNawSj/AG0iVG+vzK3/ANamaI+349+K+Ru/sHRXxjpm41Yf5+hpfgHdyS/CPQ3l/wBYElViB/Es8i9AB3GOn59THp8Ri/aI8RFuRceGdIBOOfku9V79Okn60dPuDqanjqH59Bm+YC21iA5AGcOssXH/AH87c+neuhXlSSewGD+PH+eprA+IbtF4etWXIP8Aa2mr68HULdD+QOc9uvFdAq70AYcNj8DyMf57GmA/Iz64Ix2J7/yxT87B97uAfUfT8P8AIpozIx9M4Of0z/n+dLG7Lzz8pJwO/wDnn86AJWO7dz8ynIweB9KRwFTA6Z7f5+lIrqxLZIxgcduv/wBajduBVvm3Z3Y989/89elIBxIwDntjp0oZQwz93k/hgDP8v0prZ+6O59KcThvTaMntg5/z+dIA5O3+8e3WlRcHrnnoOP8AP/6qYFPJC/d6ZGMfX8qkz78sSOnpR0AbtyV6/Nnr2NDRqp3bj8vOSeCMdxnn8fWs3xN400rwbbJJqt9a2IncJEsjYedsniNOWc9RhQT7Vi3njbWtcO3QPD82zj/Tdac2Fvg45WLa1wx56GNAcfe6GgDqy2wbu+Rgdz2/rWF4h+Jug6Dqn9n3F/HPqMhAFjaxvdXTHqP3UYZwBg8kADGSQBms2X4bXniJ2/4SLxBfalC2AbCyj/s6zHOeQjGZvo0xU8Db1zveG/C+m+DtOW10nT7PTLU/MYbWFYUZs9SFHJOfvHnPNAHPza14w8WKv9m6bY+Grdj/AMfOtH7Tc4J+8ttA4QZHI3zA/wB5AQVpF+D9jqUyz+ILu+8UXEY4S/k/0NTgcrapiHPoWRmGfvV2OPnVf4VPPvxTlG4+x6HHT/P9aYFe0tYba3ihhCQwW4CxxooVEAPygAcDGOg4wacBj+LaT029B/nrTtnPHHH5dj/k+1G7ONv8Oc/nTAbjD8fT2H1/Wh492Fz14wT/AJ7f5NErh23csucg/UDB/wA//rHOE7t/nt/ntQA3bllYhi3Y46j/AD/Km7FLc7c8Efy/oKcX8tT9T+J6nn/PU9Kag3N8zFuOccY9qALKt5iL69CT2/yeaRhj+LqRnk88imxOWO0KWY/Lz16/z/8A1VzHiT4zeH/DmrPp51Aajq0bFRpunQtfXqkAHDQxBmTqOX2qCRzyKkDqUUFtp9QNvTBHH9K8k+MH7Z/w5+BPim60XxR4gn03VLG0jvJIf7Oupl8qTcUfzEjKDdscfMwGUI7HHRjxF408TFfsOhaf4XsWztuNauPtd4fTFrbt5fPJy1yCMgFOePlHxl/wTH1j9oH4963q3j3xR4kutDtZIra21C5uraW+1mHylaYQxRoY7OHzWmVOdypuBjORIByfQD0t/wDgqd8MdQ1210jQ7Xxt4o1i+ObWw0vRHkubobSw2KzKWBVd2AN2BnHDY7X9m74j6p8RfGXj241LwnrnhVft9rJGmpy2/nc2UICtHHIzxsVVHwwGA4HUNXRfBP8AZw8E/s7aF/Z3gvwzpOgwyIElktod1zdDOf3s7Zkk56B2O3oMYxU/w5VT8WfiJHuUn7ZYZK84zYQ8H8Bn33elGvUeh26fd4b736+n+e9TMpdF+YHvjpn/AA47VGowu5sdOc84/wAe/wCVSAYUN+hHTt/h/wDXFUIf/HuJ6nOPxzn/AD+lLjbj8z74H60knEmNxXryB3x/n/I4XovdVbIOf8/5/nIDlXLbd27n5Tnuefx7/jQw3u3zdDzx1/z+v40K+xD1PHYfgf60vlkAZ6rzkf55qQIpXCRr7EZ/z+NRj/WH5uOv1/z/AIUTH5Qp/h46fXmmgmQ/7SjoPy/z/WrAcdzSfL1Ynj+6P84/X2p0f3dv5Y5z/nFCDduI+gGOv+cH/PFKgGP4uM9uT7f56frQAixYTbu5Xgf5/wA/lzTio2tngd/8/pQp2leuWBPTP5//AK/zpy8fLyR14H+fSkAm1j1bdnjpxQqqsh/2vm91/D8vyo27t3XjngfeGccUqyKRgY4JXHTHP/1v89aAIEbDfzz3/wA/zoB529WJJx3P+FLhkXKn3AzwB/nNN+9hecA4z6k8VQDY22j733QM8dPT/wDV9PWhHD7fyHtz/wDq59qceVz6nJPvxyP88frTT++2n7u7sP8AP+f0oAfnJX0YkAY9hz/n1pW3Pxxz19v/ANVEinAz97B6evI69h0//XR5mEP8O3t6f5/rQAudqbiGVVGcH1H+f1px+8w9Pm4Hbt/n6UmMH+Ijuo6jkUKuwfd5z70gFcbx838XHHQCkMR3fdPp059v1/rTsgSE7dwJ59v8/wCelG3efm53Dntk4/8ArD8qYDdoP93Gcg44P+eKap3xZPCkdxzUgTKd2bB56Z7CjKuhB6N6f5/zx7UgE8zMZI655FIX+XPzH1p0Q2v6jGT+v/1qawG3vxgZ98f/AFqAEf5iF46hRzj3pgCh5Nqhd+Oi4Jxjnp2/pUjBsg9+g9/pTV6Y3bu4Pb/PT8B3pgcKIJLP48yS7n8u98PcrgBR5VwMHPXnzj9MH1JrtIU2n+LnjGOv+en9elUH8J2r+KIdYxN9uhtG08EyNtMTSLIQVzjduVfmxnA61p7MnngEen60PV3AIRtVcqRtAP1/yM/lTguWP/jv6f5/GnbMNubn+9xQOuMZbqR2Of8AJoA5fxl8G/DPjy+TUNQ0qFdWUALqtqz2eoxYzjFzCUlCjcfl3beeQaxv+EH8c+Dni/sPxVba7YqG3WHiW23T4IGAt7BtcYIIzLDKxDckkCvQx8g9cA84/wA/59KGBwVP8J2+p/zxUgedz/HlvCFs0ni/w3r3hmJBue+ijOqaagGSCZrcM0YwM5ljjAyATmuy8MeKdL8Z6JBqGi6hp+sabMPkurG4S4gfvw6EjPNaCptcsM/Kc9cfke3rXF+I/wBnjwl4o1eTVF0v+xtbck/2rossmmagcnq00BVnzzkPuB7g0ah6nZAYmKj+EYH4Y6fpQGEsef4sY+UdiOfz/wA9K87uPDnxI8H3Ekmk61ovjSxyzLY6/B/Z96owcIl5bIYz2A8y2J5OX7Ur/tFad4alkh8Y6TrvgiRQM3Go23naWSc9L6HfAucZxK0bkYOwdAAeh4ztQjceB0zkf/X/AM81y+s/ETfqEmn6HZ/29qEP7ufZOsVtZtjI86XnHYlVDPj+E8Ax+O9Gk+MHw3mh8O+JV0yPUVHlanYlbqKVM/ModGHysOMo4Yc89QfLfEl58WPB2nWHgvRNM+HVjeawk1vYXuli6jTSolA8y7kt3jKYTcnG87nZF6uBR5oLXPcNFW8i0mFdSmtZrwKBPLbRNHC79yiszMB6ZJJH6XfM/wAceg/ycVyfj/4z+FfhNtTxJrtnpe+3NxvuH2tIqsFOFGSWJJOFBOFY4wtdDDqdveXbW8VzBJMoEhjWQF1U9CV6gH6d6oC0uR97J45IH4f0p2f3R5UbuQfX3ppBcq3tgZ9/8/z9aegV17jvgH8x+n6YoAXO3a3PzN+IA7/nWfr3hTTvEsqrfWcV00PMMvKzQH1SRSHQ9eVIPX1xWgrMso/iwc9Pz/nQ33fTjJz1xj/P5VIHPnQdZ0RGbTtUXUIu1vqoLEHPRZ0G8DGB+8WQnrnrmNfiEunzGHWdPvtIcNgTyJ59mw4/5bx5VQeceYEOR93kZ6Qgr8xyu0jPv/n/AApsbEDI3KenB9hx/wDqpgRwXMdxaRyQyRzQ3CBo5VIaOUccqe456j1qVcH5scgED36/pWA3w20y1vXutOWfRbq4bfJJpzCFZW55ePBjcnOcspJI64oe68RaB801rb65arn57PFtdJ16xSP5bfUSIfRD0oA3x8rMp/h4ximiXZzjkc/pWZpPjLTdXv1sVl+z6ht3iwuVMFyQOCRG2CwHTcuV961D8zfN/ewT7+lMAVNox2Hf0poHK/j19hn/AOvUhTnbgtkfN7/X/P59Kjfc0rdd2eR2HU/57+mKAON+C8LW/gj7KyLDJbatqaMg7Y1G55+pDKfxpCq23x7ebcrLfeHBuQZyBDdnafcf6Q2AORz1yML8G4WstJ16Hay+X4k1d0BPOHvZZB/6GSM9jxxim6tEE+POh7fM/eeG9TyQeMJdadjj1y56+/tQtV/XdB1/rsaXxFiL+HrdSu7GsaW5HpjUbU5/ADP1HHat5PmiJKlm284Pp/8AqP8Ak1zvxTJj8D3EjNtW3ntp2IPJCXUTnn32kdz/ACrpF/dybu4PHt/n8+lLqA4/K/TcMn5hx/nk0eUyA5HyjknFCjjhenAA9akI+Xr8y85Pb0pgNLZ+oOMfp/X/ADzSofMj75x1x1/D/PWkdv3MjP8AKq5Zy3RRjkk9ABjH865tvinY6qso0K3vPEkiHG7TlDWxOQMfaHKwkjOSA5YbTx2KA6QbnXnjJ7c46Hr/APr6VDqusWvh6xkvL+4trK1jOWmuJBHGmBnlmwO2efSuf/sjxRroH2nULPQbfkmPT4RdXDZyBiaYbF4xkCFuc4bpVzTfhzpOm3q3v2VrzUIzlby9drq4U8fdaQkx5IzhNq57DswKbfEhtbiI8P6NqWsLj5bll+xWWe372XDOvP3okkHH0oPhfX/EMitq2uHT4sYay0ZfLHDE/NcSAyN2HyCPvxzgdQMNhydzHp15P+fWmhy278mPt3GKAMfwx4F0fwfM0lhYxx3Uy/vrp90tzNnk7pXJkYcDgnAxgADitdpOdyn5m5PH+f8AJp5+WVV5J/l/n/PeuZ+KfjKfwT4bWbT4EutXvriKw063cHy5biVwq78EYQZLMwPCqT2oA6LHllV42gfNn+f506MjzA2eDgmms2M7VO0Nhcnkgf1607dv/wB7qBn3/wDr/wD66AHAF0/A7vYU4DB4A+YZyP8AP1P400jY+4dP/QTzRu+Qcfu+5JPFIAB4UE+/1x3/AFqFRtHX5R7/AOf/AK9SN869MZxkevH+fyrI8aeOdE8BWsU2t6pY6Wlw2yAXEoSS5bOAsS/ekbkAKgLHIxzgUwNLazx7vyB7j/P4Uo5Rurbfm+vp/P8ASuLPxE1/xRD/AMUx4TuWjlG5b7xDI+kW7KTjiIxvdE7ckK0MY5A3gk4c/wAN9Y8QSs3iPxRqE0LkEWWih9Jt0x/00R2uWz3zMFPZR3QGt4z+J+gfDy4jh1bUre1vJxm3sow095cc/wDLK2jDTSdCfkQ4AJ4Gaxrjxl4s8RxxrofhuDTbeQKft/iGYwkKRnKWsW6Rj1BWV4CDk8gDO34M+HGg/Dq3mh0HRdM0lbj552tbdY3uT13SMPmkPu5JPrW0yFR3yOuev+ee/FMDiY/hPca8PM8UeI9Y1wFhJ9kt2Ol6epB3AeVAQ7qPSaWTJ6+ldJ4T8J6X4G0SPTdH02x0exj4S1s7dYYlx1+VQB9T1P550tuT79M4ySfp+vFOCZx0zjH48cfypANPDnLY7CoxHvPPDen6D8R6VOEPl/UcZ5J/zx/9alKfxfzpgRRxbAx68ZPHP4fpWPoHg7+wvGOvan9o8z+3Psx8ry8eQYovL67ju3AA9B6c8VvsnybeoQE9eSfT+tEaMwjyA24ZwBSARSerfQkj0/z/AJ5p/QD/AGsHjv8AX86YG3Drywwf0/z9Kftwy/pkf574pgAPyqwOFzg8UO+zdwdu0fh/nn8qDyCeMY5OO1H3QduV4xipAkjO4lefvd+1OQ5UH73GRz+tR/Mv17e3/wCrFPGNik/Nxnpn9KkCpdp5V00n8LYx6jjH1oQ7F46/z6/5/Gp5B8zfX8/85/8A1VE1t02g+mM9v8/zqgFflO21mwMHjrn/AA/+vSpyq54AHbqcen5f56ULHldvVGPBHOM/5/rTizeWPvbiBnn7tADgxAAH3v5H/P8AKjKxjdjnHy/XnA+vFNC/Keyjtg8Dt+lKE3Mvy7T3yOf8/wD1qAFyVPHTt6Dt/n/JpqDcMD8KEOU+g/KgDK9h7Z6/5/nQBC2F+bHygg9expnzI+3AHPHseOv+fT3pVk5X8fwH/wCugDcG27lPGW+p/TvVAAIlXJHynjHPJ/zj/wCtRMPkx6nGMZx/kf59VRNir167fujoOPpTPLBZV+9jpx9f8KAH42Oe7Dr7kDB/n/KnqVEjBflzkHvkHmo85fcG9+B1xx9O/wDkU5k2tt9wv0ye3+c8UAKoyjLjHAx/n8uvanHn73zMuduMjqeM/TH0OAcCmF90Q7g5I9OuR/kfWlOOMH35HQdv60gHAAtjH3vQ9OD/AIn86RXAfdkf7P8AXHt9fT8acBlto+bOcgj2/wAf8igDd/Fxu649f/1UANByGHXqBxjI6/4/56vbbtzj9McZ/wA+1I7bFB+U9xkcZ/z/ACpsfAX5m+bGNwxk/wCf60gJHJzxzz1B7/5zQeW6btxx9O+P8/rTdwVf7ze4wD/n+lOxuGV+Zgf16/0oAaTxu3fNwM/lTW+VS2O2CPX6DFPdfn+9yvHT/PfFMKMMEcMBwMf55HP5UwI96j5WVdzE/KT8xxjJ/lz649cAWJT/AHj9M9v8/hSsF8n5T24/XH6fz7d1ZMP/ALXBA6/Q/QZ/SmAqjB4VR2Pt/nj/AOtSkb3A6YXBz29Kcg2yfxc8+/8An/CkC8/e3bBjPtwP8/8A6qAFVhIzHueme/Hp/nPP4PG4Y2qo56fp/n8fWmZw6r0xzkjPuf8APsPWnN0/4FjHft+vX86kAZVZV/u9SD2x1/LI/wDr9KYpIfavRhk9eKd5nK/N8vU9PzpdwLY+6T+nH/6/89GA1tuC23rk/X/OKawOxuPvcZHfPb/PrTt2QGzjjPHpnH9AKasXmbh7cfTrTA881T9mXwnJqkmqaLaXPg3WpuX1HwzMdMlmbs0saDyZ+3+vjkHHSo4bH4meCdzR33h7x9Y7zuS6hOi6kqAnb+8j320rD/rlADzyM8ejnDFf4wwwcDr/AJ5pmAPlYnqAe3yj/J/WgDxXxfrngfxNf6g3iWy1j4c+J9esRo51HWbZYZI4CSDDb3u6WxDSDcCsUpdvlLK21K3fAH7NXh/4b/E6HxBoek6LpVrFpMtkjWsRa91HznjdpJ7lvmkUCNQqsX6AhkC7D6XeWsd9C8U8cc0MylJI5EDJIvcMp4IOM8+n0rgrf9nfT/DE7N4P1rxB4FRi2bPRnhbTnJz8wtLiKWGM55JhSMt3JBqbdQO+C5dmxnb8o4Pfk/y+tKRtXpubbg+3+cdvavPbm7+JngYFms/Dvj7TQBgWbnQ9VQDqAkrSW07k+stso3dBjNWdE/aL8L3eqw6bqs174R1i6by4tO8RWjabNO/zYWF5P3NwcKT+4kk4/GncDuizQzYx97leTyfT9acg+bhefXrn/PFJNCy7ywbzFG75h/n8/wBKUOoPykna2fqT0x/L/PIA0RlsBfmBx/8AX/xpysJGxhX25OB05J//AFZ/Gmqu9yv/AAInHXjimx7gPm+Zh2x+f+fWmBIr/KOcqOPr2/z35p0h3s3G5ueP7xxmo4ZV3HJYsvIP97HH6Z/nT2T95/ebkkY/T/PX9KAKut6LZ69p32XULW3v7dju8u4jEiBh0OGBAb0I5FY3/CGXmhjdo+s3kKfMfsmoE31sOvALnzlGcHCyYAGAoGMdEDuPzMS3fjP/AOs0iLuOfM+bHP68/wCfagDmpvHF5oUbNrmj3dtBHy17YFr+1AwDkhFEyj1LRbRjO48mtXQ/EGn+KbL7Vpt5a31s3HmW8yyrnOMEr3z265q+smwq/wAxYDOBwfX/AD+FYut+ANJ1rUftjwNDqLf8v9nI1rctjGAZEIZgOu1iy8YxgmgDD+Gt7suPGLXEkara+IJ90hb5UVooZAT2HyyAf5NYdp8TNL8Y/tH6Da6VeC+js/DutCeSJWMPmfatH2qr42uwAbJUnGRnk1jah+z7rFx4i1S81BrXxVpaaibu1sbq5NlNdBrW2jZpJIlEbNuicBGRRhclyGwuF8XPFOqWvxY+Gp0TQfEGif2JdXUep2kemsiyWjiKR0iMIeKVWNtkrGSwwvyjK0pB0sdh4v8AjboPjH4Z+LbKGa40/UrfR7ueO11GE20k6CF9k0ROVljbGQ0bNjo2CCK9WkYrcSLt+ZWI47c5/LpXDeLLK8+I/h/7DJ4YtZNPumMbNqrr5kKv8rypFG24fIWJxLHIM8DPFalp8OftbrJrWq6lrkikOEmk8i1VgDyIY8KevSQuc45Jp6gT3/xQ0m2uJLaxNxrV5F832bTI/tDg88M/+rjztPMjqOPXiopbjxVrqDZBpfh6Nj9+djf3A6jHlrsjXPH8b4GeM81v6bplvpFitraww29vEAEhijEccffAUcD8KsNGPL2/NtPUkds0AcvF8LbPUJVk1y6vvE7ryE1HY1qGzncLdFWLcMDBKkgLwckk9QqbYlUfwrsT2Hp+n6Ubf3at6nIP1pQvOd33hnn/AD6d/WkAjjKsv8WPXt/n/PFDjKfMvy49Ox9qVyDu5K98jnA9f5e/FOVMA88N6YGPx/Afn+NMBgG8/dGD/wDr/wA5/wDr09GLEfLtyefb/PtTIwcbslVzkEDHXPP8qd0GeVPdf8f0/wA80gGk+YQF3dwAD9415fcfEbRZ/E83jDXNSt9P0PSzLpegrI4MmpOXRLi5ijXLuWdVhjCDJAkOCJFNeoMgKFdzKehIODz7j8P8iuH8C/BTwt8H4f7StYna4sogn9p6ndNcz2sQXCqJpT+6QLxhdoIPOaQHP/Cr4p+IvHHwK8Q+I7yOOzvI5tVk0lpLXYoto2kNtuXI3bQFViQpJVh1G4+M6L8b/ix4u8G6baw6lbPqMPhmL4iz6lbaciy3VjNEZbfSkhUMrN5pMRYYaSOLqGBZ/bfB/jzQfD/hxdE8E6br3jS0824cPYxA2CebNJK4+2zGO2ZFd2XbG8jqMDYxGa1LDw9428TRIl1qGj+C9PjRI1ttBQX12qDon2m4iWJF6rtS2JAJw460Mfmdb4h8Wab4O0OTVdYv7HRdNhBMl1fXKwQxcEgM7kKMdOTk+lcqfjPceIYNnhHwvrfiTdjZe3Cf2VpY6fMZ51Ejp6NBFNntkdL3h34M+HfDmpQ6kLJtU1iEB11XVJ31C+X3WaYsyf7sexfQAHFdYzbyd3LH7x9e/wDLH50aiOLPgzxX4rmVte8TLpdoxBNh4et/s5cA52yXcu6Vuw3QrAeDzzWl4K+FXh34fXctxo+j21vfXAAuNQkZrm/uf+utzKWmk6n77k8n1NdCRtUbvmDcc/xE9vX3p+NzDOWDHOfbsf6//rpgR7chVHUHIz39P/1//qpD/DhcfN+dPZdo5bcwXIOPT/8AX/KnIvlkdeDjgfXj+VMCPncu3B3YOCPwpu4DDYYY6eo4/wA/5BqQKVVVXj/JpsY/1h+bHbnoP880AJ5e5uNvfBx1z0/DP8qXcGJxzwMAe2TTgGEnB5znp+BoKb1+VvvdeP8APPFACfeA+X5cYwBjOP8AOKe5YL6nBP0/zmhRhPlwc8/5+gx0pAjYXOep68/5/wDr/hQAucDdt+g/z/nimttKsvTPtnHbP/16cT/td+h/l+lJEMAZyNv+P9aAFXCsvHzNnH8v8/SjOTlfm3YI756mkjhZD1JJ9uPelWPcf4vmPReCe36ZpAAfDf7y5xnr/nFOUHKj+6cZ9h/9emxAnqRwcYHSlKhiO+Accevb/PpQApOxWbbkLg4z1/zxTm+QY67SMe3BppOwNyQSOOOlDjjG7hhz7UgBiM9CwHU/rzQDwT/EqnjGcGnMm9ju/jODx0701Wwdp+pOOmKAGFNkhyPTgdvenYDYwv3jtHbGcClHzBdvL9QP89s/ypo+VVDN369jQA1htAZfur/X/PNH3wq7emec8Dsf8/4U5sY3bvmx+f8An16USIGmPO78Pyz+H8z16FgKzYVj12g8/wCfxpTwD1yW3den+eKM4OWzx0yBkChhlW3dcZ6dPb/P/wCtAUhMIgw2/MF3ZznA9vy5p+0TpxnnoR3H+f8APSo5WMsbFWxztPy9xxz9entUkMsix42rhT8uO/f885H+NUBJHCHSNc7vU/59M0gUKuRz146f5/Wn4J2/L8vYEZ/z1/n604x85J+UryPw/wA9aAIXXcxPzNzn6/5/n+VG5mJ5/izjruqRYvLZifug8HH0HH+f06NAIHA27SAeOvOKAAtkccFs5P8An8fzofDq2N23kDHoT/8Aqo3ZA/ukcHb2zgf5/wD1U4f6zH944P8As/5NAAqFDux8y8kf3jTkOQP4ueCR0/z/AJ9mv8yyH64+v8qkclS23a3PQnrx/ge305pAMK+ZCpXO7ngfX+tLtYN7q2PalBI24Jc5wSR1/wA80EZl447DBH1/pQAjoBL/AHe45/z6frinfelOdvB5568ZxTVTHU4bPA/z9aCuH6/Nzn9f8+n4UgGu5I7846+tAPzc/eGByOf89OvejOA27rjnJzz/AJ7f5DfLzHlWLDOTnv6H/P8AOqAcn3k6fL/Pk/404NjkZ6j29P8ADn0zRt3svXPPfoef/r/l+TgF3fL8vQnPfn/9VADA+AvUcg4z0Gen+eaVn2s3589O/b8aEwDnB6ZJ74//AFUKuF2gH5uOTzQA2N9qj721R2P+ff8A+tThtDf73Q49CajI/d9+gzjueP6/z9qkAZgpPynj9P8A64H5Hr0pAIDvk3Ak7ffqP84H0x+KrwxY9ff/AA/Cmom5v7owAT+PX9KdHuLF8dcDH93n+lABy24845I5/wA//X/ClBbYMj5uhHv3/kaTO2Hp68+n+T6UNwmecjnoB3//AF/54oANi4G07QBjpQTubHdeE/Mf4foaHIVvn7Lgj/P+etBBjVSc9cD1z2H+B+lAEZOVU/whfu+v/wBfP86ckfm9hjr+vH1oZfk6ZGOo9Af8P0/CiNyvUZ9KYDgigsOOOgP4/wCFVtY0Oy8QaTcWOpWlrqGn3abLi1u4lmhmXnKsjZDDpwQashuy/dBJz69h/SiH5lUncvbjt/kZpAeet+znpPh35vCGra94FkRT5VvpN5u0yPrgDT5/MtFAzn93FGxwPmHGIZ9a+Jfghn+2aDofjzTw2RNos/8AZOpBdwGDa3LtBIwUn5hdR5xxGudo9I8vJb5RgkEZ9P8A63+eKVk9A3zH16emfypeYHn3h79pTwfrOuQ6PeahJ4Z1+bldJ1+BtLu5SOqx+cAk+P70DyKRggkYJ7xkKIwbcOmRjB/L1qr4g8Naf4u0WXTdX0+x1bT5xtltb22S4glGD1RwVPBOc8cn1rgx+zTaeE5d/gnxF4k8DbQNtlYzreaRwMBRY3KyRQoeQRbeST/ezijUD0gDBLKuH9MZokbEeCW5GR7YrzmHxN8RvA0BbXPDuj+MrGEH/TfDMxsr4gLk5sLpyhGR/BeOxz8qHHOp4T+P/hTxRrdvpH9qNpevXH+p0fWraXStSlwWzst7hUklXIPzRhlIGQWFFwO0U7W2r6kYHb/P8qjjGfugKDjHtn/DH+eae0bL8rKQV69upOPz5/zmmqBI2SfQDjr7f5/+tVAIWJ+bBO3p9Pb600jd/vEZPHbpx+GaceXP+zn/APX79f8APNN+7jPcY/pn9D+FAARgn+83UdecZ/p+OKaU3Kx7dMfU4Gf89fenkblb+I4wRnkcf/q/KuG+PMe7SvCkhkkjaPxbpDAL73SqQT6EMR6ZpdAO4AB+bA3duf6/nToxhGYDbtGcD0P+f89o4Tnn/npyB/n2/nU6fKxLZ9ORTATao+6pz2/z/Wnom0Y29Bnr3z0/z/WlIyPm+p+n+f8APajy8N8w789vX/69IBPmQL8vf1/T86XZhcdumMdf89KVzjgdsEHHTp/jmlKM5+VSzc4H6UgG7mkk+bOV5+tH/LMbe35f5/8Ar1x+t/HXwzo2tzaXb302u6ratsn0/RbWTU7m2bjiZYQwhznrKUHfIqgfEXjzxw3k6boMHgm1bh7/AF+WG/ux6eXaWszR89d0lwNueYm+6C4Hfuvyt0woJJ7KB3PsK4WT4/eH9Ukkh8NteeNrqGTymj8OxLeQo/QrJclltoyMciSVSPypv/DP2i6+yzeKJ9T8bzb9yrr04ntEOcgrZoqWgI7N5Jcd2J5rt4oVt7VY1VY44VCoijCxgdAAOgGOlGoHDLB8QPGT7pJNE8D2LHlIP+Jvqjrg9WcJbQOD2C3K9eehqxp/wQ0GK4S41SO88VXkbiUXOv3Lajsk4+eOJ/3FuflH+ojjHHTvXYJHhivPI5Gep/zj/wDXRt3Lncc4OT64qgDPmtuG48YGew9qI8Bfl4xgZHft+nXFOWPDt6jkAn/A/wCcUFDIqr/Fz+fQUAAbzY1+UnnBOc468/pSptdtw4zy36f5zTXKk5x6ZPpn/Ip4Ta/8TDpgf5/zwKQADtZvl4A656f5NAPy4yfckcgf5/WgDb6EKcjH+f8AOadzuHy45z/n/JoAYwZxt4HXnr2/kP60oj453fvDyDj0HNOVMbj6AAf1+vpTVPz/ADN/nr+NMBSuJ8f3QP8AgWaRR5shXr754H+cf55peSPukHgHIz9c+/8AhSqvmHlcqADj8P8AP4VIEan5VbAJx06Z6g0OvybcN97jFOiTEW1f1569M/pn+lKTkEj1yM/56dPz98UwEcEj5m7d/wAv8Kc3L57c5B9TQVyVbHY855H4/pSuNp9AOvsfT+VACOSGK5HzZxnt9f8ACmBQJN3zdOcj/P8Anvxmpc5P3WGeh9PYf5/wDVXB3eoByBj3pIAz1+8oHI+vT9On+eWuu7b8rdeffPb34704jtyrdDjqP88f56NjGzao+YdiP6dvT/IpgAUqf9rqCO9KrKjdW/Lt/wDW/pSMuThfvHuehI4/lmlIzFwPlyQAfof8P0pgLg5xg59B2/z+HajoFA9f++u9AfZlu+B+A5xj9aa3MhXOCoKkA9T1x9cGpAkX7ox97tz1HU/zzTVXDsfvdwf7wxx/T2/mULZKliN2M/X/AD/Pt2pcbEC5284BI7d/5H86ABX2I3sCc+vr/n/IQDah6t3570Bcx4Yc42ke/wDk0uWPfOMn/wDX/j9aYDEIXb355OOn+fypxbco9Rjt0P8An+VCco21SOg9Mev6/wCe9LEuR0bao+u4f5H6Z+jAU/KV9MZbH+f/AK1IfmYZ/wB3A5Ht/n+dLGzOpY/e9ailbcSOykDn1/zxUgQ9EC/dOBgc9Pr9M/kfSnHY8qjuv8HPP+cUgAByvsenX/Pb/wDVl8agSL6cZ9c+vX6+561QEn325zhgDj/P8+9CFWkO7+I9Qevf/H8j702N2Z/u4DDpnp0/xPNOhblv8Oo4NIBJcspLbdxJP4dv50ky/L06gZHp/n+tKx2RfN8xzj6f5FJKD5YXspySOh4//X+VIBpDKYy3XHPGef8A9ef196AF+X+I45/x/wA+lSP8+3puGDj/AD9RTSAH+mQSD/IflVAAb95htzKMZA9/8/UZpNm5QG27SMnAOD/nrSscEccscHsTg/5NLn90Mfdz0AxgdP8AD/OKQC5xuUDPTknoeOKHUhlP6+v4/wCelAB5+9kDPT8Tj/PahDtl6YJHJz0HT9f89aYDsc5HIIxzxjHH9abEd8Z/iwT9T7f59qF44x82AeB/n3pyDAZlXtg/Tp/n60gI/KbaV3bhimmPJGOw59WOf8P51Jhgm7uv+fWnMMEE/kP8/WgBNgTBDL16f59fX6Uq/vF5PysTSMWBxt78d/SlA/eD9eev+c/nmkA3Hy7sZY9fY/5zSFfMj2+4bnv/AJ/z3p29fIGfujv+PNI7YX5jjccnj60wGk/KvTdwFOeo/wA4p0aZ2HLfu16/1/8A10FSsm7G1jgEdM9P8/h+aoNu7ng8A+vfP+ff0pgNK4PJ7BTx0Hb8c5pQMJt6DvgdB1FKp8tPu9Ovpz7/AOevajdvTJwGAJGR/T/PQenEgJuCwjdz/n/P5U7AB+XG4ds9eaRRtA+UkD1H3cnn/PtSBtg5/iBOM/5/yfxpgK5Df8B6n69D+nHvSEkj+HpyOT24/wD1Uu7dJyPm6Z9f8/0puSG/HBGPTn/PfigBSMREL0U9euRyf6U0JkKBux/Fk9D/AJ9KRJB5Y3Hp3x0/zz+tP4Iz/Dg49uwoAYx2oP7q9MZ+bI4/z7/k9wAPXdnOOBnt/L9KApchieG4PH179u9KuFB9cjkjp9KAFLfPz0wDzxnBz+tG1RtPVc5we5/zxikV9w/u9AMmlyXX5R7Akde1IBu3lixOeu4de/8An/OaDECf0xnGOv8AjTpWU7j/AA5x+v8An9fems25mXG4/X9ev+c0ANjHyqzN9775H8v5/rVHxT4T0nx9ok2l67pun65pNxzJZahapdW8mP70bgqfxHGKuRkAf7THj0//AFf5+qpwAc9PXqQBn39D/wDrNMDzuL9ntfCKq3gnxR4k8HqCWGni4/tXSmIAwn2W78wxRj+5aSW/19QeL/iF4JkUa14T0/xdaDCte+FrkW9yowcu1heOAF6HbFdSueykgbvRVyuCew+bI/z/AJPrTm+Z16/KOh7/AP1/8+1KyA4/wl8b/C/jLXV0mHVBY63JlhpOqQS6bqL45JW3uFSV1BP30Vl56muqkPk/MzBFiXLFuNoHUnPp3HtVPxT4O0nxxoUmm65pWn6zp8jZa1v7dLmFj2OxwRx2PUH86+a/28vg74g8Ofs1a1pfw5i8aXkOsbLPUdIgu31KyW0eRVlBhlMl0iFGPyWRHCkbQDkmoH1AH3oCuBuOVX9cf0//AFVxPx7t2ufBOmMp4tfEOi3LNz8oTUrc5/MdPT64r4d8HftZ/FT9mTRrFta8VWfiCxOTHpWu6Zd26xx7PuNdXKRXNvtIbaWW5z8oIUZY+62H/BQb4cftKfBu+t9L1caH4oja1nbQdX2wXjMlzFKfJOdlwpCkhoixwOQGyoObQrlfQ+oY1EijB4XGB6VJH8zjtuJ4/wAK+Yf2qP8AgqV4F/Zz8S6h4d0mGTxh4t02V4Lu0hu47Cz0yQdrm6l+RD3wobO1h9/ap8j/AGfP2xfi7+0X+0R4bvLKSXUNAmkuUltdM0a7tfDmng2zhGuLho2uJ9sjIcSLAu/aVYJnA5JCSuffyDEX+0vAHr6n9a53xR8XfDvhDW20261JbjWlTzTpVhFJfaiUxw32aFXlCnj5ioHv6ZVl8LNR8RLu8VeKtU1cshRrHSg2i6cScgkJFI1w2RnKy3MidcKK6jwx4U0nwNoUem6Hpem6NpcZMq2thapbQgk5JCRgLk8knHOOaBHMS+JvG3iiUrpHh7T/AAza9ftniC4+0XA/2lsrVyrKePv3UTjunaiT4HW/iN/N8Xa1rHi7hs2V262+lAN1Q2cASOZfQXPnsAPvc89v0fv09+Mf5/znlekhAHyr82fSgCrpGi2fhvS4tO021tbDT7NQkFraxLDDCvYKqgKo+gAqwFypYHpyD/n/ADxTtrKW/PH49/5UKdwwBlSfy/z1/OgBP4ef4sg9vX/DFM278Kx3cYzg85zn/Pt2qQjI47gkHFOHzt+HX17/ANKoCMJmY8ruY4Bz9aahDRY24Vhn/D/P1pyZ9vl7dc0JyF5P4jOc/wD6v/1GgBFRnibvkc/j/nr/AJKnbtz0XJAP+fbFJ1i6ZbAAPuP8470spwF6Hofp/nFIACjcct3yRyfw/nSxpul7Lzk/Tp/T8v0VBy3X5uD+fTFCLt3blxklvqOKAGqqj7m35hwfTHP9cf5FCglemQf1pYwVDexweOp7f596Gfys5z2xn8P/AK3vQAqjDdfck57Y/wAf85ojVsds4+9+X6f59KcrbT3PP0xTQfnZTwAoJFIBGGxmYdehH+f88/Wli+V87vm5GQM9P8miNWd/u/fx0/z/AJz3pqsJTx8ynB/rz+dAAqiKJeMZ46HgD/OP0pWXKDP3umM9e/8An6UrDeuOc4H+f5fpQBlmPbjj2oAO5+bHPr1/z/hS5AP6deo7f5/nSAbj/dC9cDr/AJzTkJVyuBnsD7c0AMVcj5sdMNk9ee/6f5zSqfk25+n0HtQBs29fl9R3/wAilDbgVwCPr/h/SgBJCQvynheQT3Hb8P8APahl+UjPy44J79f6U05A6+3QH6596aPmdgu7pyM/5/yaYDwcdB8uf170LyOMYJzkjr/nmiMnBLc7hyf5n/P5UhO056EjoPX/AD/WkACPJVcfMRnr65GP8/rTiNxGW3bl75/z2/SkPzFcL93I9ABj/wDX/nmlXHXr9B0x/n9DTAap3MzZbao6jvx/+qjq21u3occjvj/HtjpQCQMfNu65wKD8iHA9c+1ADlIG5s/n29c/nR95l9/l+h/x5/l9aC20BfvdCM9D6/lx/k0knEYJ3N8pznqP/wBX9KQB/rD7N3x9P8/lSpyM577W9/8AP+cUbjGRnKt3IPf/AB/woUBozjoQccdBjn/PvTAklOLNmX7wGTg9P84qrFH8y9l9T2/z/hVonClccfTIzjFVwhzjpubpj8T/AEpRAcwyBkbuePb/AD/QdqB8j4X+Lp6en5/5+rmlMac9VHI/vYP9eKN212+XsMcdDxzigBi87m+bcTx9B/j/AF/JFXCYX5unWnfMC5+7z1Hpg/4/rTZF+ZR90lSDkdP8+3p+FMAMnB+XK459vQk/jz9KdjZNluo4P+f8/jmo5JN6/MPmYjIH1z/nHvSh859Tx+P+f89qYEiA5zknGDkH/P8A+qmKOGP3FxzjtThJmbHvjHvSZGwL+A/x/lQAhbg7R8vc9h/npT2O8qvK+vt/nmgNtVW9e/ue3+fQ0qvuI/h5ye4AH+f89KkAxlf7vIzjHJ9fw9qO+7tgk9PQGjJbaMMuG3Zz9f8AP4U0MCVb7obocflQAq4DsPmOCM+tKBiP0yc4/wAe3+cUFi8fopPAJ9x/9f8AT1o+868Enng/5/zigA4Yrtx9fU8c/X60hlVu3y4Oe2f/AK3BH/16SUlBuXLH+ft/n1oWXEq8HoDkdj3pgOPB6dSeT3poRcfKp2sP8/0/I/WgtznBXkAAfnj8f8+tBOSwHqeM4+n8qAF+8PmH3j0HpQEzuZfegrg7u4PcYyR/hz/nFIW3uv8AFtHTv9aAHF8Tbv4WwSvU/n+FJnaPwx9f89fwoH31X1PymlWTzN3uQMEfh/X9fzQAOASenGBjkfX/AD2pHGU5HDDJ56H3/E0A70YEfezj2pMl25yeuOOuKEAb8beMsuCSex//AFc//WoRf3vt057/AFP+e9OJwAfTnjpn+n+RTSfLl9jg/wCfpz+lUAMcIc85649P84/OkY/KccHn+n/6/Whjtj29G5OfT/P9KCQnmbdy5JP1P/68UgGEfvFA+Unk89O39f8A9WKbHdRxOo3dfQfdx/8AXI/SnMeT97rjHr6fl/Soottyhbbt5OMfU8+noaYEtrdR3J3K33sAZHTt3/z26jibJx059B/+v2qs0Sl2DfeUY5/z+H41ODuAXbg5Awe/+efwpAOUBScevzDP+eeaHZWf7o3DGPf/AD/nrSRybR3XjOevP+f5fmqt3B+6ew/L/PvSAGk+fb/CPu/l/wDrpM43E/MO49cUmdpYEnbg8+nWlH3OeS2fxFACKuU7ex4/z2H4/nRnA9h6Hvg4P65po+7j+92PQ/5/z7PYeZuVuuf++T/n/JpgIr5yoye47emPypSVMmRnafu59yP88/ypG4y27G3OWH0//VTim4qR1HGfr/k/hQA3BbkELkZx6/5/wqM7f4W+9xx3p+8DaRypGc9P89f1pifuiWGPl9scf5/pQA6OVwNiSSDdwpViM/r/AJH415Z+1P8ACLwv40+DviS41Dw3oOoXUFsbmKeewheZGUqSyyFdyvtBAYNu9xXqagDavPA6jP5fyrB+L0DX/wAKPFFvHuVpNIvFjKjJUmB8FfcEgjHei19AbtqcKv7FHwptvihqXi1vA+i6l4g1aX7RLe6iH1ANJ081UnZ41kPUyBd5yOcAAeqW0CIiQgFYo8KiL8qqOOAOwHGMetM0i6XUNJt5lbKzW6MGB+8GUEYP+fyqVE9u3HGB/n/PrSWw9tCbBMfPHGDwOvTj/P8A9YIO4/7K5+UfQjFBbYD/ALPQen+c/rRnLHK8jv6+n0o1EAGZPlHy9cH/AD/nn0oA2j2zj+Wc/wCe/wBaVUJKj7xzgf5/OlQr5bNuJGcH3x7/AOe1AArgH6HJz/n3pqnZEuW9/p/n/PSmx8Ln+8eW/wA/5/CnLtyf7vb60wDGCq7BluTg9Dxj/P5UAbjz/njj9KNzGUj+Lvx0zQNpbpu46H0Ix+NIAVQQynnrn2+vbsaGJJxgHcOQT3/w9/Sgtudsnv1x+H9f5UDhc46kgD16/wCFAAxHl/Mc7R1P16/nQ8YaT5uBz+B4pZGxGme/PPUnr/TNHBcD1PPue9ACNwm44+bp/P8Ax/KjdjczZOAOB/nr/n1ojbPA+XIxk9uP8mhW+8wBXnsPw/z9aABh8mMZ4IAz16cfl9TR91e57g/hS7/l3HBUcEe2P8/maZKjboyrY2Yz3z9f5/40ICQHcf4fmGcA/lTdpIbjb04zz/n9KM4X+LPfJ/D+n86UHB7fdBP6dKADrtI4DcKM+/8An86RjkZxngf4/wCH6UOwP55HHtj/ACKaj5j4XjhTz16DrQA5HGc/e2/qMdf8+lCKEIVefTPQ/wCeOaapUN6rkY4/L9MdfWlCbht5Xbz6kcev4/j1oAcq5ZuvsSe+T/n8fxpRhk+b5emMjGM+v8vyoVgWx90d8DpSEk5Xt79uT/k0AIy8fd+Vu2Op5/Xj/JoALn7oPpjnNHccH5sDvzk96azH5efvdsUWAcZA5zu65PPGOc/59MUwNlZIx8zZAYZ78df0P4inZ3tuOd3YY6f56UuDtA9s9OtABt3t+Pfv/nn8qTI8wdc8H6f5/wA+yKd8OeW4IpxYNITz8p5IH+f84pgBby23Z28nnpj/AD/WgkpJ/TPX2/pTYxuC/KNwx9D14/Q//X7KOYxjO7k+46UAKg2xKwH3RuHI5/zmjIxnjH06/T2/xoXay/Lnbjv29/0HNG0YbqdxGOM4oAQ9l6hue3Xr0/z+NKDngjB7e5/zj60FuSepYZFAOXbjjJHTrjt/T6UAD/KZPfOeenHNIx+9nByNze/p/n69eBSbi0WM/eHp2Gf8KA4B3ckH17nH9MUASJJkZ2/l3/z/AE9KAu8q3btz0pjgRsv95R6df8/59aUybmLfe4P8ulIBwKtFnl8Hj39qjxksWz8x5556f/WFMTaJ923nB7duAR+X5Y/ORJRK2CeoPXvnrQAuCAWxtJ6HPakkiw2P7uSQD/n/ADn0pQ27Hzfxdff/ADj6098AfeA3Y5PYf57/AEouBEUXKj+FcDHTHH9cD/JpqD9825slMA8cHt/9f8epqYnBx74+hH9elRhhnHZjwQfXn/P0HegBqtv/ANkE4Pf/ADj/AD0pcs7bm3bWycdSD/nt7fhTU5Qt/F1/z+FBkLocY5PIB659P/r0wHqdmewBJJ9PX/8AX6fhRGNg9Np7+v8AOk25PysDilbt13HI+n+f85oAcFJbbu5/hY+n+ScfSmquFbsMcY7fTFOWUb2VSC2eQO3+cGkj+7kY2N93tn/PH/1+tIBAcj7o+UcDNGdo+9u24P8An8v84pUfjPcEkj/H8s//AKqceT75wD3pgNDDadvqcnHX2x+VDjjkd+p7nNIgDjjGMZLY/wA/4UKcS7f+A+v+eooAc3znGVODjn8/8+tIqeUq7eGJGce2OP8APrQ2GVT03AgHPWlB+YAttH07dePwpAD7c7N3yk/Mcfdx0pjHI3Ebfm9e/b/P60uN23I7EHnkY/rmnbdz7ejdMe/+QaAGx8JtGVxjn/P0/SlY7F+nTHr/AJ/lTYpFkUyA/e5PXjv/AE/TFPVPlZv4l6/nx/KmAMNz+i4x7ZH+cU0cAN0UnnjpTm4b0x6dvSkZ9zdOMZHuO/8An+lIBQcpyPmOSc9v8j8s06Rcq3zfe4B+v/6qY5O3nv1yeeeD/P8AGnkMzjB+h9KAI5U8tFccc9z2/wA/59WP84b03ev5/wCf51YGEGc7cds+tRNGfMXvt7emM+3TFCAZt3Da2DjgDP1pIgqHCjbuGDnnrkk//q9fzbKGEZAYbscZHr1p1qGMRaQ/vFyOPXgf5/GqAcAHH3eXOT+Z4/z7fUu+Zl+Zu+Tx9OaUrhe3t6eo/wA+1MjOMNJtBJ+uev8AjSAUNtZjyduDk8Z/H/PSnouAMZPOfr/nH6U18A+px/PPf/P9aB06jnke5znP6ZoAcoZ41xx8o/D3/wA+tG8Mi4/hPp2Hr+P9aQKNpH3Sp+X8uP0p5OIwMd+5+n+f/wBWaQDViwNpzzyff/P9feleIH19M+5/T/8AXQBsO77vPQn/ADz+VPEa7z2HcY6e3+fWi4DACMnPzc9eM0PH8smfvKvGe4+v+NPDbe46E59P8/56cslk3Ljdt3EUagNY8dSvbB75H+enfmk8vn6c/XPI59eaVyPI9dvc9/anbtjbuOmfpk0AM3CTPGRgdRj/AD+P+NDn5xnO0cZ/X/H8vycT1HGM569PT+tNY7slei5J/LnNMAw2WyW+bGeecdvw/r9ac3+rz94njHQn/OP89KCAwK7l5wCD6/4U5WYpHjow4zSuA3Y27264/OgjcMkksvB/QUvl9fu7hwfYdKcpwSpPHTHr/n/GjoA0/fbdn2H+H/1/agD5G25+XofT1/L+lIMsD/n1waVR2U/e5b3/AMn+dACEZVT97HU9h/n/ABoDhW3c/MdxPoP8/wCRRu2Lj+Y9P8570Y2tj/gK+uf/ANYJoAAdg5PJHp+H6fpToz6H7wwcnpj/AD+lNY5BZemBtx+lOB2p6tgY9+cigBqNhP1xz6f/AK/8inbPkzwBz/n/AD6/WlDZX+E4znjp/wDr/wAfrTQuFX7vzcA59859/wD65oAUfO/8XzDse/8AkU0Btv3u2Afy/nx+tBbMnXcM8j1/z0pyvyVHysoJyB0/THf9fagBY8YAztbGOn+fb9aTgoF59Tj0+n+en5IxyFHp7/59qGbOcj1yfb/P8qAFbnG71/Pof6U3cUbgHcvcd+f/AK9Kz5wM45+XB6ev8qYcOOcFf5dP6mgBzcE85GQFx6f5/l+FHLDg5yRg9AT/AJIP+c0uf3ec87uOev8Annr6elJJGuBnndw2PXP+NADVGEVW7nHp9P6USBpI/vEbhjnsen9c8difwczMsSs33lOR+XT+f+erQNjqrN908n05/wDr/wA+9ADgctwPlXtn9P8AP+BoZmwSv3ugJ4z9P8f/AK9CjBw3y5x+H9c80mfMjYdNxwD6ZPP+PtzR6AKR0wG2qAB64xj/AD+f1Mso45b1Pb/Pv6U4FWbpjnBH9PzqM/LEN3O7IHv/AJx/+qgCRhjjsvXPekA78f4E9f6UhkUzld+0Fh1HTvQgyd2Nu0nP09v8/TNAAV8tf4vUZ9ff/PehkBY8bvT24/l/9b2pVbdHx+GD+H6/5zSOgVRuG3bjAJ9P/rUAClmj3Z/H9acygMGU/d7+n+cUKdjFuhUcDHTqP60A7SO3XI9On/6/w9KAGlWUbfXjI/L/AD+JoI8zd838R4B+vb6804knH8WDgn0prYWBdx+XB4+mKABV2+qq2RknOf8APp7ig4IXOfmHY+9KSFdm+U7ckd80obdJ8vzcjt157/TFADGPmSnJ9OvuPT6H/Ip5bjGMgnHH5frmkz5xYnnacZPPPP8AQD65/GlDH5TnBz6jHp+tADQPk+Yfd64P+fahVLMu77y88+vp9P8ADvQ7YgbB2tjgnjH+SM+2aGKo237vXH4f57+nvTAMHauT2C+vTH9eKbtJZfm6nrn9aPM3t83IGOAevp/n3+tOViDuXooDfUH2/wA9aQFdTnCr93PQ8Z7fywKdAnlvJ95u+Sfb/D8ASfwLiAo7EfdU8gH73+ev/wBbio0nGWA2++3nHvj/ACOD9KoC0vDMPvFjwAfTP+H8qeWVk7deR6f5/rUURxtXuTjrkc5/z+dDFZu5Crx9PT/P8qnqA5pMH3/h/wAM0AKHH3ecYPpj/wDX+v0ybsuqn2wB3/zz+dCfK7EewB7dOPyo6AM2YT6LwBxmkCb0xx9PTk05yqRlSDtAH+f1/XrTQmH2/wB0+vGDyP5/hQAhfKZHy5ODnuPT+v4/jSqSTyQDjtzxx/n8e2aE+X5uPlODg/09BTlO4Mo3fL0P6/4/rVAJgD5m2ruAyvX/APX1P4Gn/dT5h8zHgjn2/qf84oUADt83Q5465pDxtbDbsDv1/wA+tSAqPtJbFDDcMfe2jgjuM/p1HNRkqr8kYxyPQY/+sP8AOKdHLvKleuPUdeeP58UAAG0sM9sD6/5/yabGeN3uMZ7jr/n+lPAVRg9DznPQdf6/rUZUgN/Fnj07Z/rTAVV8v0bcOcdv8/0pzEqw6cZHA69On5/5601jlcZ9SD6f54pysoGcd/qR/nP60ALtxtA+XnIP5j/Gkb5ZDxnB9B8v+f8AH8URNp4/iHQnOKUOHUZxjufXuP6UAOSRgGbj5T2PXn/CjbtK8fKQSMdsf5//AFU0EqmOvZue2KPNX+L+Lpz1P/1utHmAIvcnOR/CPbuenXP+c047lY/mcnpx/n6Yoi+SZezZ9c4x/nj/ADhqOqydeWAxjjHrSAbtbY2MZXP4/wD6sVJH8v8As4z7475oJzzkqGY9P8fbn9KQDaBtVflHHt/nPagB7Dc+31Ofw4ppX5xk7tvTA/z/ADo+UyfNxkYGBnHT0+uP1oOO4PJwff8Azj9aADy8ovv2zxTYmyFbjHTIOfahhhTxwAP+BDvzTUXbGcr0wD83X/OKoBWG3C4yM59Mc/8A1qBGzKobDfN0PbNPEYU478g+/I/zx/8AXppVpsenoT16cfTr+VIBc/Mz8Y+nX/OB+lIHZzzg88nHX/J5FKsnzYHY5z7f5/l3pQdm4j8Gz37f/roAWNSo5A684Hc5pR8rcr97Jx057/5/nTdoK7ewxgevt/L8qkzyeCP8n+frUgMwxj3fePQ578/5/wA9ZFX5sAdOB/n8en8+7SwEm3nHAx6j1/nx/wDXp5k2SbsfMepz/n/P6AEQOS2R6tu/z+P50j8k9CR8v1PX/P8A9anKwC7l5HfP06/57Ux18kfgOT685/z7UwDG4Y2/L1HP9aU8n1C4IP4H8v8AP4NzsX/a459P8/8A16eqYyNxwvTjGP8APP8A+oUAIcqzYxuXn6/4UAYfp1xu9eo/x/z0oAXe3G3jHHUD/PFAcmMsF+bdwP8AP4frQAIjNGo9e5Gew/8ArU588duw9scf5/zhpG5Rub5ecHPTjB/kDn/Ghiwxu/iOfb/PWjqA4NmTGfcY78jP+f5U4/u2VuNvA6ZH+ev5+9NYjOQd24Ej+VOVsN2PfPrSAYg4OV7+vX/P9KOrBV74x6Dt/Lj8aM7F+8Pl+X0zn2/z19qazAIG5x0I/wA/lTAMc5X+ID/9X15/WlC4dl+82cce3T2/rQ2Ixt/u8k56f5/pSgbCq52nPI9PyoAQDewOd3PJz1H+T/nrTmJZePmK56DnP+f8+rHbaGHPy9BnrRJ8sfA3MPU8noR+X+fWgBS3HPY9fXgf4UDptLdAOf7vbNNcblwoHXBOcY56U7OxcbenBzxkjp+tADicHjAUD5SO1AyhHtx+R6f596bgqW7A4P1460B90jN8pzxx0X/P9aAAcgdMY/z/AF9P8XDg8Ybt0/z/AJ/Gmnn13Y79s/8A1v50Ngp7cYx74/r6dPwoAHy65+UtwwGOvv8ATpSOTs+nP69P8+tOU5ZQfvL156jPX6cA00IpVgT1wDzwMcdP1/GgBXBJb+9z+B9/r/n1oP3m7FskH09SPxx+tAzj5h83ft/n/wDV060FsKAOOg/pQAhBZxt27h056Hr/AEpFbfyMbVOR/wB85/n/AJ5pwHf7vH+T6fjQuDBxn5ec+vH/ANb+fTPAAfMoyo9Mc+5/z+BpxfaWxtyBx7fX19/6U3hmHVfmzz26dP8A6/p74pV3NwNw25x7f5/p3oARVO3/AHe3+fx6U2XhNv8AFj5snBx7/XpxSmQiPow3A4/Mf5/WnnH6cDutAEaZB5P3j2H+ffj/AOtTm+7uP8Ix9fTrQoJcj26ZppdfmJ/iIz7+n8/1oAkC4BH1/I/5H5U1izjt7c/l/WiR9qYGEbljz06dvy//AF01lZm6bfRfyzQgHJzjbx/SnMCHJPTPI9aQ/I6hfXP9abtwny9cYAPb/PP5UAPTP+e3qf0pCmUP8Puf64/L8KQ4DH06knsOn+fpSlf3J7FeB7n/AD/KgBCu9FOOFzjvgf40Fdp+X1wPXqKDxN/u8nn7vt+H58/SlJ2yfd249+n+f1oAMZA98kAfn/Uf/WpJFIiDfxZGP8/nSttC5K8KePfOcj9f89KTzhFGG9CD2570AOlXaV7Lnj8eP8+1NX5j+uexx/8Aro2/mOCT/k/X9fWlU5Pyn+HGe+Pb/P0oAQMVbd/Fx1zzx6fh9eDQoIUnb/CQRn/Oev8AnmhRkr2H04Azn+nT/wCvUcaZkZlz1yFz0Pr+gGf/AK+QB86qkW1VOF6DsBTLhfLjXjbkkHsc/T/Pf6VIZMqBj5sbh9f6f/Xo2fLtx8vTg9B2oArlNvyn659Ov8v6e9Pj/dSbfm7EcZxgn/P0pkg3E8bugPHUdqaB8/PVhznv2Hf0NUBY3bx8o2ttyOeM49e/Qfj9KAP7v3cgg+uf/wBf61Fu3DHoDnjqOtKJD827gLjB7+/1/rke1ICQL5m0YwOwA6YIpMsxBG5eMAn/AD9eaVTyox8zZVVz6daRjz1xjnryeKSAVWK4G35VUEn/AD+NOYeYjMPm4H0z/n/PFR7RjnndyQBnn3/X0604r5SlVOCzHB7e36/0oAcysBn5uFPA6N6f4daHzID8u32/D+X+NN3A9RhWJ4Hcdev+f60hkXG7rzn049utMBSu92H5ce2P8KgJ2/8AAm6f3eD/AIfjUu351GdueF7YP+TTZVExZf4VyrLjoMnr6/5/BAB7K2fxP3v84pVJLKrdTyOO/ekVXDMuM9eP7xxz/Q/hRGRz83uAB7/WmA45Y4565Oe3/wCrFJ5uzYrEbpBwvYnjj8qSP93tydq+w+h/yKAN02V6qO+ODTAevyE7fvYwOfu/5/z7IHLtn+6c8dabnavzfxD/AAyP8+tOAClQeGJwB3P4f56H3oAGOA2P4hj9OP8AH6Y/EIbKjp1IGf8AP+fWmJJtVdpyrHPHrnj/AD/9fErN83vGuOv+ev8ALntQAgUlsfMPXPHHb86TY27+8RnA9eD/AI9fehC7bgvQYA4xnn9KRZDu+X7vTPuf8/rQA/O1tq/wnbyf1o3NlSyYwcH9f/r/AORTTx8v+c8UL/q19uuMUgHEMFwflOMZHvTgWVd2Oh5z6dP8/lTcqzHOGDc49e/+fw/FsfyjP8JXGfTAI6fiTQBI4MkbLtbuePXj9R/nFNhh+zKsY3bUAwD1OMd/wpQdkOc4xw3P3R/9amRuZIQW28jOVOeD/TgUgJGZlLL1POeePb9c0MMnoMYx6Y9P8/8A6qCNzZ+nOewxSKMnaRg5yeOe1ACOo8tVX+LnGevr+X5dPxX5gufvHHH05OP6/h3pm35DxzjaBjO3nP48nH/66cxz7fN83fr/AJ/zjFADtvH+znrnk/406N8Hv1wTj3P/ANf/ADmoz/eb0GOe+f8A64NDSZ6/dXII9ef5dKAJEY5j454JPr/n/wCvTt2VbquBxj3/AP11GQSVbs3twP8APSlWTJbrwc5x19f5/rQAik4HXc/H/wCr/P8A9eTG9lyML1Jz1HP+cU1iyIeyjgDqfTj/AOtTVbHzbRgDnP4j/CgAiDKu7a3y+p9/8/jn3yE7eu7ap7fz/wA/pQ54HzYAPp69/wBP6c0ix7ucdD0H+f8AOaAFJK/RuefWgNsHH1Gfr/hikUYXduU84z6HHY/l3pWcr06tjI9CP89P5daYCgfd/h5yR0Lf5xSl+F7gc56ccfy/kaYyMm1cle5IH5//AKvelJLDt83APXt/n6/nlAOjLAMDywOQM9c8f5/yKMbnOOpyBzjJ+v65/wAluN/XcO5z/n2/yKFYhW3Llsc9+/IosAO2xVVTwfTjHPU/570khx8mO5bpjp/+v6cUFAEb+9jHTtzxSH7yrnvz/n/PWgBWyeP4sBeuT6/4UqSEfqDx78Z/SmJIzf7rYx7cUuF8psNtUjn/AGR0+n+fSmAK7bctwTwD6/560MmD90sewHUf1oI3bhtHzcDjqaIxtj5LEFe3+fxoAcg5C/3jj346f5FGOF4O7p6+/wDn6U3DInpnsB26f5/ClBzJ8zBRxxx68f4f4CkAAFArdCR8uO/+c/5NNDEL7E5x7n3/AM9aCNm5uOO5HHb/AD+NIsR2KMe+QOnbp/nrigBytnO5WU5wMds9f89eadu2sB+p9qjkDKjNuXoOPX/Jx7dac42D1C8jjn/OPx/WmA4HDL8p64x6HoKUO3ynH3hnr9Rn/PvTH4DZyW5xx1OfSjcULfxAEEAc+n8+lIBzbs7gPlbp/n/P68innO3oOufX+VNZ/LfcduB1Ud89O/0NCOWkXpjv0P50wHEA7ucH+H2PT+ef85oB/djn7o6E9B/kf5NDAMMdiOuc/X8ufzoV2A/iXIP1HelqA5flb/ZYY6dKRjhcYP0HscUgJz/CAx6HHHB/w/nTSWXHPAX+X+TQA5m/eleepyRxjp0/SkL/AC8fdPPrj/OMc+lI2Hjz95eo46cUAZIbP8XX165/SmA4tnszfp6D+tNJ2HP057n/APV7elNTJiHct69PxpXO5l5+VBjB78jr+v8AnqAK4MbfKPu56nsB/T/PpTj8w+b6YoUbZFP3sqM+/wDnmk3YCrz90/jgYH+e2c0tQFDFj+pz29P89P5UY42/xMcEk/p/n/61NU5kbrwM4xShCm3d94en50wAnCKp43Nn+97/ANaU8FgR93A/n2qMr+7VfcAHHvnOKfG7ZXHfJyccHn/63+eKQCmQlSPm6dD27/5+tLu28r/e+uOP/rf57RSPjKqNwxlaVUKs2c+m726f5/D6UwFk/wBXtHPI7/578UjzZG0q3QDGOvtTlG9PmP4Y680g5YfxY4/Hj/P4/hQAFyrL8u0NzjPT0qQrvQY+h/z/AJ6fSo24fHQ4yPy/rTo+dv8AD0HHY9aQAjFSWxwSMZOSVx/+qgAAN2wOATnvj8ep9/1pBwV/hGeR2A7ikIJUrz1wTjr6/wCH40AEbE4G37uM857mnIRnj+HggjjnP+IqGVm3fKeFOCP72eg/D/D8VB8w/e78EdKLAPkUbQemSCM9f84/lUKR7TtbdyQwyf4h/TpUxONrANxwCe/f/Hj2+lNIB3f3tvp9M+3SmgI9qjf+POOfr+tAcpbsMc4PBPX0z/8AW/XHD5Tgr97DZOeeRwf8/jTI9xHzNt2jBxzn1B/L+VMBsNwzxbmRlaRfuk9P8/T8jxVjJNwvXCjg/wCfw596hVinCluufx/z/nvS8KRtyVxj/P8An0oAldwrjt8+OO3QD+X+c01zsXd1GQR9P85/P3oeVtx+bjg7v1/z7VG8nHfnP4UrASl+Mclieg7ccfzpWYD5e3t6f1/+vTC3zAZ246ZHH+eRTvO2ZX1GMZ6dv8/WmA4rtPRuucD8c/1/KkDqw6N1OcdDz/n86QHy3XIx1B9v880h4bdkruYcHnHIz/n/ACJsAg+9ux+Hrkf/AKhj+uaWQYBbru4+Xn6fpn/INPV85+VvlXHXg/4f5602QeWG7t2Prj/OaAEK7i33vfPb/P8An1oKhmbOfUDP6f59KBkEDLd/w46/y5/lmhVydo3fQdzx+H+e2KYCk7Vx78nPX/OOtIPmlZSv+r6e/r/n/JSP5ZfLX/gJ3YPr/n6UIwdF6+gP9B+VAD3+dl9NpJP0/wA/oaRkUjnPcE/5/wA/Wl3bWj9MYz/n/PHvRGeOF3fxH6Z/njNADVTcxGeVHSnN8sm7n2yMc0gYPt+Y/L7Hn+vYf56uCqVxjhzkj/P+eKAEVAqZ+Y7Rk8YyOhoi+QKuWLYx/j/n0pu8spk/i6kf3ueO38vSjdjk5DY79D7/AM/yoAWSJd24feUN+Gf8/wD6qUSn7vt09P8APX8KRh02nJ9R2PXNIEw4X8uev+f89aQBK+1fmz6ZJ6H3/L/OaIlCW477QDgdPT/PsBTViwflGWQndn+Hsfy/T+UkW4BT8xzyO2Ppn6UAOEgdVb5sdz1OaVRuPf1Oe3f/AB9qYCBtz0z+X+c0hO0Ddnoe/wCP+fwoAXfub5txXPJHU8H/APX+X4A+RS3XaMqOn/1+xpm7+Hs3A54/L/P50qttHy/Pxzx1zkf5/wA5YEgUMnK/LjGB6Y9f89frQMsq9dx545/z/wDXppbduHU/w5HX/Oc0L8sm4fd2kkenP60gHZII7juB0P8An/PajaHix944wcjr/n9KApL/AMX1z+f4/p/QV/lK4+VjnHbg5oAczbnU/wAbdD/KgBWLd8jIJ/z/AJzTRwv8S4AJznP+f8/QA8zG7rnn9P8AP50APwGDejZx7/5/SkT5Tj72PmI9/wDP+fVoO4r/ALWTj+mfxpHkG7733mC4PfsB+dHQBQ+9S33uOuR065+nPWjG1fwxj0oeTO07jzzkfzoDYf0ZTxxzjn/6/FMAzkL97rx605YyxHddvBz1P+f8+rfM3Lj7oP5f5xTfNH3R16gd/wDP+PbugFJxL8vHfI79P/rfl3pw2qM7mz/Xv/k/pTA2RlfvYwO/b1/H9acDy2Oxzn8f8/nQAgONxOV3YP8Aun/P69KCvzbeeOpB69P/AK3+TRyyj5t3PXpx2Pv7/wBOlKh+baDwpzyOmf8AGgAJ/eN97k9uPU/1x+NLuyjdc4xkfr/X8qZGSSBtZeh6/T/J/wD1UrNjP0575oAXaq7vm9hk/X/OKEO4sDxuAOfQdv8AP/66HOC2fu46fzppf5mUjvzznOBkUAOzvI+9uXsBjccY/TmhNrP97cpA49abvzIY+evI/wA/Q/rRt+Zc8t19un+Qf50ADMApz831GPf8P/1ZpyDcOd2SSScdPb+dNQlvujrzjv0//V+VOcfJuU/MvOQOnTj8ev8ASmAFi3Xgqeue/p/n/CgH5m65zn69wPzFIWwPl6L8w/x/n+VJv2r8u7gZxnp/n+tIBWPmruGSfr/n/IP4rnKNuXgDp/n8KN2xmyzDbyfyx/j/AF9KCOOeMEjGef8APb8OtADQu7HB3EZ9ORTiQUPXaMdPX6e3H+RTXYfK3baTn0/zj/8AVxTvu/7zHPHemAMm/wCVtzccjjk8f5/yKAR83r7fh/n8aN247eRjj6dD/Ufl60gfcytj7o5/pSAcQMn7w3HJGenT8PSmKu4Llc8dc9/8/wA6ep2xtubG0EEj36n+f+eqZw2PoDz0yRn+ff1oQDX+bP3ty8k/j/8AW6+/0o+8c8jccEj/AD9aczfMGb3xx+f/AOum5+Yrt4wOc8D8P8KAFYgjOOmc8847k/lQCTuH3uhB/wA+/wDIfgP8/HzEdev1/wA/5FG7+H3/AA7n+ufzoAV2z8y9P5Dj+mfz+tIR8q7s44JB5x1/w/DFIp35POTnr/nPajdlNv3uex7c/wAueRQA5zuVevqSO/fGP896DjHAx3yfpnn/AD3poPmK271ySDxTs7j3+Xr157UADnaWyfl9v8/54xSFsJj+HOOO3b/Cm7vNfPPzcA564/zj8aUsUJ54Hp34zmmABsI2VbaCWH8/0oyFfd839OP/ANWaPNyg4GW6DGcDH+fz6U15wR+Ixn8cf15oAc2EG75uBzz1+tAOGXqDndjPAPf/ABxSh8q2Ox/T/PalDbd2M5yOPXpSADtdfT39OTx+H9aCzKuV+8wxg9vamxtgfL6HFDy7ZMfiQfT/APXQA6JudzblZeTg5/X/ADxQq4Q8lmBzwMZ9P6fjj60Fc+vp15PrRK5Z/wAOD/n/ADxQBXL/AN09sDnrznn9akjf6+v1qJn2YDbt2fyz/n8fbiljfAzj6fUVQE3LxHBB4yT+H+f84w2M7ivdmBOT2/z1/PpS4UScErjA6fr+FIW3Pt5zgZzx0/ljNIA2jc2O54A/z9P85pu7Ymd/bqO46d+n+fwCflI/hwMc8/r/AJ+nNOVAx2/N9TznHNADciKReTnqeM0ISy5bhvc9ePX8h0HfjigtuXk7Vz15GCf8KFbBVh8vJ4Hfp2z/APWoANuR+PHuO+PfnPH61DMGZGEeMsysc9/X8R6++KsEYQbmywGc+/I/QZqNR5i53bec/Tn179fxpgCt83VeOSvb/PAqTmVydpw3YdTULL5ZX+9njj+f/wBanlgp6kq2MnPb6/p+P4UAPd8lvu/Lnj2/w6ULhWOWyOpB9e3+FDRrtO3ge/Ht/kegppUyZ+Y4BLceuOn4UgHRnZGrLg4OCfU/55/Glzg+x5C+3P8AjTPMKDd97Lf/AF/546etOLbCp64PIz/n2/L8KYCffPYL6n2/z/OnoNoVvfP1H+f601EAZW+ZvbGe/wDn/OKDy3/18+vOf89aQDgflGCG6lTnpTGbJLbj1zkZ4H+f5Uobeu1f4m6Y6c9aakm5VZj8zHnnp6f0P5UwHYKhcfKRkA+3r6/5/MI/vHbwAO+P8+39aTbn5vu9Sx9DilH+uw35H/P1pAAZg5GWY47fj/j+QoU4boueS4z3zQBsGQDleMeuf89O9GfNUAds8DnPQ/rTAJG5A/hx6dOMf0prDEeN33uckZ/zyT+dOVPmwent29/856fWl8svHxnbjp6//qPFIAGXZv8AaIHTv2HuaR+VX7p5yo+n/wCv9aWMZI+bIYtjb3/yaVeqruPTIPqf8n/OaAI55AqbeeuScHnk9vWi3Km2X5l4HUHdj/Hryfeo762W7hZSW2yIUwP4QeP8/X6U61j+zQ+WNx2Dbg/7OP5D+dAEykJGP7v+P/66U/vG/vbie3+f/wBdNVQw2gfe6/zH+fenMNgKn5s5BK++P8/hSAYR83ygbWbp9Mf5/CmlBldxPzcNx/n2HtUp3Z647KP5/wCfxphgUthRtwegUY/z1/WmAAMZOOcHLDHfg+v8vb8SPlR04HUfT/PTpTd+RubcF6E9P845/Ojdhm3fxdfb/PP5UATK29edvynuOn+ev+eGFcH9c56UR7izY3H5uPfmhRnbtyQ6cn+v6/57ADt+P9nAweOmf8Mn8zTgWTjb8rH14/zzTPuIeeR1YDr+H+f6UFstgFsDOT6GkA1X2n72Tzz6/wCfz/OgbeV444Axjp2/T+tIy7SQudwHUHpSKucbjweANvrTAd52EZvlZmOcf3vT69vyoA/eLgdio479v89P0pFDIGzIx3nj2/H/AD/Klb96me/UD2/z/X0oAduDf7q9MduKUMYyzYKn0/pTI5BjP3t/J9/84/WjygJGb5sKc43HDZxnPOPzoAcw8gHb8yrwf8P509H2jcGB5/L/ADz+OPakB8sr8zYx6euP8/hTGXdH830znqBSAMFHUZ5xgd89qFbaWY/dIwcduD/n8qQlu38RHHr/AJz19qVRtIb5l44/z+XFMBygAFT83BOO9AbzF4I9OPf+h60xl279v8JxyaUFdnVuOnr0oAXZ8zY6npx2/r9P8k832HXjBycY/mOmO3FN3bFP06gevtTmPynk/h+v+f8A61AAxwWbjucZ/Q/lQXBOPvg8DjqPUfX/AD7pI2B3HTntUZDTHep27Tx049aAJTJv3ZYEDqR9O/0zn8KN+SqkDoRjPQdaYhUDcrZVsgd++Py/z24VjuVuemD+Hf8An+dADhwxbd/Fk8dcf5/l60HagUemCB7en9PzppOZPvFT24/PFBO47fmC4ween+eKAFZlCru+UYyR1PH/ANbvS72HVeQcn0//AFf568U1gYhl8r1Jx6f5z+VKikdflbAzz3zQApDHP0HJ7j1/l/nijfiLdkdznGP/ANf/ANftSKvloPUcf/r/AM96U8r8vfgYHJOe/wDnvTAH4JX+4MHv3BP170KA0jc4U4yff+g6fhTZOE6jcxHJ4B9h+dOLCKInr1yem73/AFJ/KpAczOV92wTz/n/JoKrjDcFR0HX/AD/L86YyLnn7vPB9v8P8+oXfsJwCeucjHsP8P8mgARgUXdzz1x1NIEZV69DgnPTH/wCqlO0j7x24BIz9aC2E+Xrx1HX1pgDLiTj+LJ47Hnj+dJGd3l5528nHYH/PahW3fxNhjx68/wD6utJubb7twQDjGOv+e2O3NAArZI+YcfhgEZ/D/AUAkordeMYJxx0/PgflSscOy9+56fj+n+elIzAu38S45Geox/n8O/SgBSu8ejYOB6c0qNwp2heenXPTj8KSJufqOvqaVWAO5vlYfpz/APWFIBudgG7+HPPril+4/HbHGOnr/L9aQKxXaOqrgfpj/PtSbGlA+Zto9OPT/P8AnhoBCS6dd3B78E9P8/5w4NuOf4VyfbP+ePzpxOS2eW4B45H+fSmqc7gu5ictjPsf5k/p+QAK7Z2jLEE8d88fh/n6UsRw6x53ZGAfXHB/Tv8AzppO6E/xDGcev+ePzp8iht3zf4n6flTAFYld2/kfMDjr7/p/nsLLub6HjnHfnv7H86SUbn53dfwpJGXB9F5PsP8AOf1oAdINqf3Vx+PrSkZmCgn5R+Z/ofb68UzkxfVRnHX1H9PegvuXlsZ+p7/560ANkjEkY3Kdyjb0/r9aFjBn2g7iOCfetJtBXO3zGxjAGPzpp0Ff+ejHb6j8Kz9oh8rKOFd9i/L/AAjPBB49qAylOMZAOOcd/wD6xq+NFVZS3mtjGOlIdAXkeY27BH3en+RxR7RByszQmZWYA55IA7Dr+HPb6fg7H7tSvUkZPouef0wfyrSOhoyjMjbhnkDFN/4R9XHMjNxxx36UvaIOVmccZ7huO/t/SnldzbWPydenb/Dirq+HsknzpCrdgABj+dOGhKvy7/v+3Jp+0QcrM/Zv2t93aM9eh/w/z6Uiw4OAvfP+9V5dCJiXdN+8OdxCYBOD05/r61INFUf8tG9uP8+1HtEHKzOYbF+Zhuzjpn/PcUksah1Zf4cZA9DV+XQ/MkXEgCLnPy+vp/jT/wCxFkf7/wBfl/8Ar/556Ue0QcrM9QuVycEHv+Xp9Py/MyBB6nJ+nOc/1rQ/sXAbMnXr8vT9aVNGx/y06Y6Lj+po9og5WZ0y73xjbu/n3/l/KmkCXb/C2M5XqM9Mf0rTbRFk3Ddjt93oKRtIVW4fH+zjil7RByszxhG/u8g8d/T60bdrBgVUDrxwOf61onRV3jDY5Jxj/wCvQNDUE/MeT2GOw9/r+dP2iDlZmYARRztxyW/w/D+f4iIoK/L2xjPTofwP5/l10n0MPkB2HTtTW0RW5DfXjr+tHtEHKyjjKf3eeB/n/PNOXMcv+6CB78/16c1fOjqDkNgZyeP/AK/r/Kj+xUA+8cA5HHA/Wj2kQsUNu51BzgYGD/F3/wAimqAw59evqK0Toy9d/OQc49OlDaKPlG7PXqPz/wA+5o9og5WZ2zf8zc7sgkjrjPP+f/1OY/wr/rG746enb8f88Xv7EXb8rfLjHTr+vvSNoas+RJ2x05/PNHtEHKyjuGG/udsDr/n9aRWKrjHzdOverw0MK/8ArMq3X5e/r/8AWpy6GvlbWkLdicdf8jil7SIcrMrzMpt/hYdfTj/69OL7wf7rA5A78A/1FX/7AUk/vs8f3e+c+tOGhjfuEuOOm3v69aftEFijE29exOOuO4AI/wA/WnZWNVP93HbrV4aLnpISOOMdB+dA0P73zn5hg4HUfn+GaXtEHKym5Uhv9k7T398fnj/PFBfIx/FnP58/j0x/k1afQ94Y+dj0+Tp1/wA/gKedGw/38egA7d6XOg5WUJBhVPXaO4/z/wDq4qCOXftU5IXqD2x/+rpWu2kq/wDy046fdqEeHlDcSHdztyvT9f8AOapVIhysojGR+TEjnPfH5/nTkGE3dvTGc88/z/mavJoKiLbvz77f/r05NFwvD8d8Dr+v1o9og5WZwVS+5un9085pIzlv1Of/ANX+fzrUGjK3O7cPpx/nj9KaNCCvy2d3Xjqfzo9pEOVmYxw3ct97OOh//V+tI4Ln8COnrwa0v7AV02mQnggYX/69C+H1G7azcnPTp+tHtIhyso7slWyV29j/AJ7+p9KaBsZs9FOemMdeP8+g6VpDQ1GRuPXjjp/nj8hQuhqp++ePQc5/Oj2iDlZnIMBlb6cfr+vr/Slkxu3bS3OfrwR/Wr39iL/FJnnI4xj9ac2iIyH5u2Cdv4dM/wCeaPaIOVlEnzB/e2jOew9eKCQ6Z6bv0/z/AJ9avDQ18xvmb6U6PRVwPmOP/wBXv7UvaRDlZnE7ZOn3QMAd8/05/wA8UjICzLuy3bjk8fr/AJ+taDaOrNu3449Ov+eacujLGoG47RnPHX0/pT9og5WZrHLZGCeuf73pQEXy/X0wMEA5H5VonRUORuO7tx0P+eaVtFR2OSzeoNHtEHKzMHEuONu3JwMe2KfGN42nbubPA6dq0F0hc/NIzdO3f1po0RQ4Kt93HUUe0QcrM4LvVsdyeSP8+3FJsyTnP3srntyMfru49/Trpx6MqLgMfbj8f8/5NC6Kqpt3exwOtL2iDlZmZATjnnKt/eB5oHB3Y6Zz27/5/StCTRo4gF3ONxwWH8JPT9f1IpzaGuF+Yrjr7+nen7RBYzl5j298gdP89QP505F/EtweOc/4/wA60ToyD/lowVvam/2Pgt8/ORjIJCjv37889s9+lHtEHKzPB/eMdvzKRnA6nt/L/PYHEY2+nOe/+elXxpEdtEP3m3kDcRye2OvfIp/9ir5eFb6ZHH86PaIOVmWkWw7lb/ZyP4APb86k3AfN94dTx0wM56dODV4aGpU5kZl3ZGR+ffr/APW/Ff7GQDhu2Bx0pe0QcrMyVM+X97dHnJ+v/wCv/GnCVVG4dAeu2rlzpKwRHHzbmC42/wB5sE/kc/hUp0SMj7xzjGcU/aRDlZQKhWT723geuev/AOv8vWmwLjGO3HH4f5/KtIaMm4EMR17U3+w0C8SMvTkUe0QcrKayc8H7oycDjGP8/pUcIyoHfaAeO5xV8aIm8N5jdc9Kf/Yy9NzdsjHWj2kQsZx2g4/EZ5/zjn8h+KF9rKDgeuDn36/5/CtBdFUr947upOOtL/YsZZmZtw7DFHtEHKzMDbFUD72MA/oPrzTlX5eOrHPH+P41onRUJ+Zm4II4/H1+n6+tKmjRxnIZuevvR7SIWZnjajK23cFOcD/P8qaRhvm4OB2644/z+FaK6MqNuVsEegofRI2x8zbRwOO3ej2iDlZQiPPTPrnjPFJImxVXHfI98VojR14wzH0yKaNGBUHzGDddwH9M0e0QcpQbaRgt/D8xI6HI6Z/H9KQYRFz95fb/AD/n8K0H0RWU7ZGXPXA6dP8AP40o0dF3AN945Bx0OT/9b8vwo9pEOVlAMBJu98Dn/Pt9aWM4OGPfnjoc4/8ArVf/ALHjV9wbHsabHoyoVO/7vt1HP/1qXtIhYoufmHy8t79Tx/j/AJ7ICrt2XjPHrxzV8aKp6sTnqfx44ofRxjhzn6U/aIOVlDGF5Dc8fhg+3+eaCq/LlccZwOw/z/P8KvJpMcuGSQFWUYwOCOMEc+n+fVf7Fjf+JscdsHj/ACfzo9ohF3H0/Kgc0uaZI+xGz/DWKiVdihufTHSnFqar7qdjFTZhcQHn6Ubfp+VIx20JyKrlYXFPFHT05/WmiTCigPgdKOULj6TFIrhtvH3qcVo5QuBHNNzTsZpCfmxQoiDO2jO3+ntS4xSM20UuVjuKAR+HSk/hpN27t0pVbcKfKHMITt989qUDI7UzzOenanb+OnSnyhzC4+n5UE4phYMQpX71ODbc+360uUVxaUcGm78dv1oD7j0o5dAuL/D+FLjP/wCqmodyUMSoocew7sCcnGacKjR923HSnFyHp8orju9IelMWQlRwDTt+O360co7it/SlIzTTJtj3YoVuV/2qXKIcCQevWm49P/102OTeBx96l38EkdO1HKx8w4nFB4H4Ujts7UKfmYelHKw5gd1jG5mCqO5pScNVUH7bKrEL5cTttHdiMqc+3Xjnt9Klt0MEW3O7HA+nb9OPwp8odCRFKoqltxUY3Ecn8uPypR1pu/2pd+R0o5QuLt+n5UdKQDd81CNu7UuVhcGVmXggHtxmmwSedArMu045Gc/ke496c/Ax602KRhGM9RweetHKHMSdP/1U0N8w9xxTRJuGdtO8z2/WnyiuKOtAPApu/P8ACPzpS2F3UuUB2KN3HXim7udv4U7mhxY+YOppOoppfb2zilDZY+1HKw5hQcmjHH/1qZ5mB07etKzbe3SjldxXH0m3nt+VIX+bp0oVsnpRyu1x3Y7GaM4P60wvsJ4pyLsUDr7nvRyhzCFcjHHr0p27PemtwQMdaUkijlYcwvejH+cUY4pivlunWjlDmH0Mc9eaahytHmfu91HKHML0peaRT8xHpSHhgPWjlDmFHJoHSkZtx2/rSE4yOtHKK44HNAORSB8leOuaEbf2o5WO47p/+qm7gV/+tRu/d7sU4jIo5QuGM/8A6qKM0VNmGoh9+9HU0ituXNKBtp8rC4ZzRuyKMYpc0WYXDk/14pvWlZtopFO4U+VhcM5NOx/nFIThvrTVX963XoBjt3/xo5QuKjbxu9aOAKU8UDrS5QQuDSA7hkUM20UxW2M33st2Pamo9xajwCB6+9LjFNMmO360F8bvaq5RH//Z[/img]
Dept : Oise
Env. 20 message Oise
[img]data:image/png;base64,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[/img]
Dept : Oise
Env. 20 message Oise
Bonjour, désolé je n'arrive pas à joindre mon dessin, avez-vous une adresse mail.
Dept : Oise
Env. 7000 message 06 (6)
Pour envoyer une image
se mettre en mode avancé
faire 'insérer une photo"
tout à fait en bas à droite "cliquez ici"
parcourir, pour chercher l'image sur votre machine
"envoyer l'image" - attendre
Deux liens apparaissent : cliquer sur celui du haut pour le copier, puis le coller dans le texte du post
Visualiser. C'est prêt
De : 06 (6)
Bonsoir, merci pour l'info et voici le plan.
En espérant que cette fois-ci ça marche.
Dept : Oise
Première impression
Tuiles plates 27 x 17 = 70 kg / m², et pente 33 °, soit 65 %
Neige région A1 : 45 kg / m²
Non compris l’accumulation de neige à déterminer, et pouvant être importante, selon configuration du mur et du toit éventuel en surplomb.
Vent Région  2  (qp = 50 kg / m²)
Une possibilité :
Lisse haute 7 x 15 chevillée dans le mur
Chevrons 5 x 15 entre lisse et sablière. Avec entailles de pas dans le chevron pour appuis.
Panne sablière 12 x 22 posée d’aplomb.
2 Poteaux 15 x 15
Traverse horizontale en pignon, en 7 x 15 (non chargée) ou 12 x 22 pour l’impression visuelle de solidité
Jambes de force entre poteaux et sablière en 5 x 15 (ou en 12 x 22 pour impression visuelle)
Facultatives entre poteau et traverse.
Assemblages poteaux, panne, bracons, par tenon et mortaises.
En résineux classe C 24
Vent provoquant un soulèvement, sans augmentation des contraintes en raison de la compensation partielle par le poids propre.
Autre solution avec  une panne intermédiaire, mais il faut alors créer deux demi-fermes en pignons. Aspect plus riche.
Merci de préciser les caractéristiques du bâtiment adossé : hauteur, toiture, photo éventuelle, pour apprécier l’accumulation de neige « règlementaire ». Cela peut changer la proposition.
De : 06 (6)
Bonjour llovir,
Merci pour toutes les informations de dimensions, par contre je n'ai pas de connaissance en termes de charpente. Pouvez-vous juste me dire où sont situées les différentes pièces de bois (lisses, pannes, etc...) ou me transmettre un croquis. Pour info, la pente est environ 50%.
Encore merci
Dept : Oise
Comment est la maison par rapport à l'appentis : hauteur et orientation du toit en surplomb ?
De : 06 (6)
Membre utile Env. 3000 message Pyrenees Orientales
Bonsoir a toutes et a tous
a titre indicatif Wink (aprés,suivez les conseils ici Smile )
http://www.anco.pro/blog/construire-en-bois-lexique
Cdrt JMarc
Dept : Pyrenees Orientales
Voici une photo de l'endroit où je souhaiterais construire l'appenti, au dessus de la porte d'entrée et posé sur le mur d'un côté et un poteau de l'autre. La hauteur en bord de toiture est de 3,6m.
Espérant que ces infos seront utiles.
Bonne soirée
Dept : Oise
Je vois qu'il y a une décharge de neige du toit.
Vu le cachet de l'architecture, il faut essayer de faire quelque chose de joli (là, je ne suis pas très fort).
Pour ces deux raisons, il faudra plutôt une ferme en pignon, avec panne intermédiaire, et des sections de bois un peu plus fortes donnant une impression de "qualité perçue".
Mais si on part de 3.60 m sous la gouttière, en laissant quand-même 20 cm pour travailler, puis qu'on descend de 50 % sur 4 m, soit 2 m, et qu'on enlève encore 20 à 30 cm d'épaisseur de charpente et toit, il ne restera que 1.10 m à 1.20 m de haut entre le bas du toit de l'appentis, et le sol terrasse.
Est-ce bien comme-ça que vous l'aviez vu ?
De : 06 (6)
si le toit descends aussi bas,et si il y a une cheminée bois buche,on peut garder cet espace comme bucher ?Mais au détriment de la surface utile de l'appenti
Cdt JMarc
Je pensais faire une continuité de la toiture de la maison en raccordant avec celle de l'appenti en réduisant au maximum la pente (30% ou moins si possible) de l'appenti pour obtenir une hauteur de 2m sous charpente tout en gardant une longueur de 4m.
Est-ce que c'est possible ou sinon réduire la longueur.
Pour mon info, qu'est-ce qu'une décharge de neige du toit. Dans l'oise il n'y a pas beaucoup de neige.
Dept : Oise
Dans l'Oise, comme pour la moitié du pays, c'est zone A1 pour la neige, soit 45 kg / m².
On doit tenir compte, sur le toit du dessous, de la neige qui glisse de celui du dessus, et il y en a d'autant plus que celui-ci est pentu. Cf dessin de l'EC1. Il faut donc connaître l'angle de la toiture du haut (j'ai dessiné 45°), et la largeur de la maison elle-même ( 8m ?)
Merci de préciser, au moins approximativement.
Ca fait quand-même un peu de charge sur l'appentis, à prendre en compte pour dimensionner la charpente.
Par ailleurs, les cotes permettraient, semble-t'il, de faire un toit de 25 %. Mais ça ne peut pas se faire avec des tuiles plates ; il faut des tuiles spéciales faible pente, avec écran sous-toiture. Ou un autre matériau, tôle, etc ...
Les pannes, portant les chevrons, seraient entre les arba de demi-fermes (avec des sabots), pour le moins de hauteur possible de l'ensemble.
De : 06 (6)
Ma maison fait 6m de large et la pente du toit est bien 45°.
Votre plan est parfait, il est possible de faire coïncider la fin de la toiture de la maison avec le début de celle de l'appenti ce qui permettrai d'augmenter la pente à 32%.
Pourriez-vous m'indiquer les dimensions des éléments de charpente pour faire mon budget dépense.
Merci encore.
Dept : Oise
Il faudra à mon avis laisser un espace entre le haut du toit de l'appentis, et le bas du toit existant, pour pouvoir réaliser correctement, et pour faire l'entretien. De plus, mettre les deux en continuité rendrait difficile l'étanchéité à la jonction.
J'ai pensé à un autre dessin, donnant un toit plus mince, et un passage plus dégagé, en plaçant pannes et chevrons dans la hauteur des éléments de ferme, et en supprimant l'entrait. C'est un peu plus technique à réaliser.
Pour la neige, je trouve 75 kg / m² moyen sur la partie haute de l'appentis, et 51 kg sur la partie basse, soit plus que les 0.8 x 45 = 36 kg d'un toit seul sans accumulation.
Je dirais des chevrons 8 x 8 tous les 40 cm, continus d'un seul morceau sur la longueur de 4 m du versant, et une panne milieu de 20 x 20  pour la hauteur.
Autres pannes : 8 x 20, l'une étant chevillée au mur.
Les éléments de ferme seront dimensionnés à l'aspect : 8 x 20 par exemple.
La suite est du domaine d'un charpentier de métier, ou d'un auto constructeur ayant des compétences vraiment équivalentes.
Il lui faudra d'abord valider ma suggestion qui n'a pas valeur de projet, et compléter ce que je n'ai pas indiqué.
Ensuite l'adaptation à l'existant amène toujours des surprises auxquelles le pro aguerri a toujours les solutions.
Une difficulté surtout sera de bien maitriser les systèmes d'assemblage et de fixations.
De : 06 (6)
Bonsoir llovir,
Je vais essayé de trouver quelqu'un pour faire l'assemblage suivant votre projet et vos conseils.
Je vous tiendrais informé de la suite et encore un grand MERCI.
Dept : Oise
En cache depuis le vendredi 04 avril 2025 à 11h19
Devis charpenteArtisan
Devis charpente
Photos charpentes
Photos charpentes
Photos couverture
Photos couverture
Photos toits terrasses
