Eclairage connecté sans interrupteur
Ce sujet comporte 4 messages et a été affiché 144 fois
Env. 10 message Calvados
je souhaite mettre tout mon éclairage en lampe connecté, Philips hue par exemple. Je voudrais donc savoir si il est autorisé de les câbler sans passer par des interrupteur étant donnée qu'elle seront commandé informatiquement?
[url=https://www.forumconstruire.com/construire/javascript:Microsoft.Translator.FloaterShowSharePanel()][/url]
[ltr] TRANSLATE with x
English
[/ltr]Arabic
Hebrew
Polish
Bulgarian
Hindi
Portuguese
Catalan
Hmong Daw
Romanian
Chinese Simplified
Hungarian
Russian
Chinese Traditional
Indonesian
Slovak
Czech
Italian
Slovenian
Danish
Japanese
Spanish
Dutch
Klingon
Swedish
English
Korean
Thai
Estonian
Latvian
Turkish
Finnish
Lithuanian
Ukrainian
French
Malay
Urdu
German
Maltese
Vietnamese
Greek
Norwegian
Welsh
Haitian Creole
Persian
[ltr]
var LanguageMenu; var LanguageMenu_keys=["ar","bg","ca","zh-CHS","zh-CHT","cs","da","nl","en","et","fi","fr","de","el","ht","he","hi","mww","hu","id","it","ja","tlh","ko","lv","lt","ms","mt","no","fa","pl","pt","ro","ru","sk","sl","es","sv","th","tr","uk","ur","vi","cy"]; var LanguageMenu_values=["Arabic","Bulgarian","Catalan","Chinese Simplified","Chinese Traditional","Czech","Danish","Dutch","English","Estonian","Finnish","French","German","Greek","Haitian Creole","Hebrew","Hindi","Hmong Daw","Hungarian","Indonesian","Italian","Japanese","Klingon","Korean","Latvian","Lithuanian","Malay","Maltese","Norwegian","Persian","Polish","Portuguese","Romanian","Russian","Slovak","Slovenian","Spanish","Swedish","Thai","Turkish","Ukrainian","Urdu","Vietnamese","Welsh"]; var LanguageMenu_callback=function(){ }; var LanguageMenu_popupid='__LanguageMenu_popup';
[/url] [url=javascript:Microsoft.Translator.FloaterShowSharePanel()]
TRANSLATE with
COPY THE URL BELOW
Back
EMBED THE SNIPPET BELOW IN YOUR SITE
Enable collaborative features and customize widget: Bing Webmaster Portal
Back
var intervalId = setInterval(function () { if (MtPopUpList) { LanguageMenu = new MtPopUpList(); var langMenu = document.getElementById(LanguageMenu_popupid); var origLangDiv = document.createElement("div"); origLangDiv.id = "OriginalLanguageDiv"; origLangDiv.innerHTML = "<span id='OriginalTextSpan'>ORIGINAL: </span><span id='OriginalLanguageSpan'></span>"; langMenu.appendChild(origLangDiv); LanguageMenu.Init('LanguageMenu', LanguageMenu_keys, LanguageMenu_values, LanguageMenu_callback, LanguageMenu_popupid); window["LanguageMenu"] = LanguageMenu; clearInterval(intervalId); } }, 1);[/ltr]
Dept : Calvados
Membre utile Env. 200 message Haute Savoie
Philips vient de sortir un micro module à installer au niveau de l'interrupteur, qui permet de conserver l'interrupteur et d'avoir égalemetn le controle via la domotique Hue. Ca peut etre interessant si vous etes en recherche de solution sur une installation electrique existante.
Sinon, pour la question de base, il est possible d'avoir des lumières sans interrupteur, vu que ca sera géré par les ampoules Hue ( mais celle-ci font un léger bruit quand meme au bout d'un moment).
A dispo si vous avez des questions,
Dept : Haute Savoie
Env. 50 message Vendee
il y a plein de solution sur l'existant installation d'un module commandé via un réseau sans fil
quel domotique tu utilise?
Dept : Vendee
beaucoup de solutions existe.
Si aujourd'hui votre demande concerne les lampe demain ce sera peut être le chauffage, les volets roulants, le son , la commande vocale........
pour tout faire soit même il faut:
du temps
de très bonnes connaissances en info ,en programmation et en électricité
de prendre du recul et de voir votre projet dans la globalités au final je veux en arrivé la
le prix est un critère mais la garantie de l’interopérabilité dans la durée aussi exemple : les fabricants qui ne supportent plus un protocole ou qui en crée un sans préavis sans parler de ceux qui arrêtent la commercialisation car pas assez de clients.
dans tout les cas on est la pour un coup de main
la domotique c'est passionnant
seul on va plus vite à plusieurs on va plus loin
Dept : Vendee
En cache depuis le jeudi 11 décembre 2025 à 15h14
