Veranda en limite de propriété et plantation
Ce sujet comporte 3 messages et a été affiché 3.134 fois
Env. 10 message Châlons En Champagne (51)
<!--[if !mso]><style>v\:* {behavior:url(#default#VML);}o\:* {behavior:url(#default#VML);}w\:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);}</style><![endif]--><o:smarttagtype namespaceuri="urn:schemas-microsoft-com:office:smarttags" name="metricconverter"></o:smarttagtype><!--[if gte mso 9]> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:HyphenationZone>21</w:HyphenationZone> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument><![endif]--><!--[if gte mso 9]> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles><![endif]--><!--[if !mso]><style>st1\:*{behavior:url(#ieooui) }</style><![endif]--><style><!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";}@page Section1 {size:595.3pt 841.9pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;}div.Section1 {page:Section1;}--></style><!--[if gte mso 10]><style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}</style><![endif]--><!--[if gte mso 9]> <o:shapedefaults v:ext="edit" spidmax="1026"/><![endif]--><!--[if gte mso 9]> <o:shapelayout v:ext="edit"> <o:idmap v:ext="edit" data="1"/> </o:shapelayout><![endif]-->
Je cherche des avis et conseils concernant mon problème.
Voilà maintenant 12 ans que mon voisin a construit unemaison avec une véranda en hauteur et en limite de propriété (verres opaquescertes).
A l’époque, j’avais planté un bouleau afin de préserver notreintimité.
Seulement, voilà. L’arbre a bien grandi et je le regrettefinalement au regard des salissures qu’il provoque.
Que me conseillez vous ? Abbattage de l’arbre ?Plantation à la place de bambous ?
A noter que la véranda est à plus de <st1:metricconverter productid="4 m│tres" w:st="on">4 mètres</st1:metricconverter> de hauteur.
Merci de vos conseils.
<o:p> Je peux envoyer des photos.
</o:p>
<!--[if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600" o:spt="75" o:preferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"> <v:stroke joinstyle="miter"/> <v:formulas> <v:f eqn="if lineDrawn pixelLineWidth 0"/> <v:f eqn="sum @0 1 0"/> <v:f eqn="sum 0 0 @1"/> <v:f eqn="prod @2 1 2"/> <v:f eqn="prod @3 21600 pixelWidth"/> <v:f eqn="prod @3 21600 pixelHeight"/> <v:f eqn="sum @0 0 1"/> <v:f eqn="prod @6 1 2"/> <v:f eqn="prod @7 21600 pixelWidth"/> <v:f eqn="sum @8 21600 0"/> <v:f eqn="prod @7 21600 pixelHeight"/> <v:f eqn="sum @10 21600 0"/> </v:formulas> <v:path o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/> <o:lock v:ext="edit" aspectratio="t"/></v:shapetype><v:shape id="_x0000_i1025" type="#_x0000_t75" style='width:161.25pt; height:215.25pt'> <v:imagedata src="file:///C:\DOCUME~1\MAMAN(~1\LOCALS~1\Temp\msohtml1\01\clip_image001.jpg" o:title="DSC08422"/></v:shape><![endif]--><!--[if !vml]-->
<!--[endif]-->
De : Châlons En Champagne (51)
Ne vous prenez pas la tête pour la création d'une véranda...
Allez dans la section devis véranda du site, remplissez le formulaire et vous recevrez jusqu'à 3 devis comparatifs de professionnels de votre région. Comme ça vous ne courrez plus après les professionnels, c'est eux qui viennent à vous
C'est ici : https://www.forumconstruire.com/construire/devis-0-45-devis_veranda.php
mimibou a écrit:<!--[if !mso]><style>v\:* {behavior:url(#default#VML);}o\:* {behavior:url(#default#VML);}w\:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);}</style><![endif]--><o:smarttagtype namespaceuri="urn:schemas-microsoft-com:office:smarttags" name="metricconverter"></o:smarttagtype><!--[if gte mso 9]> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:HyphenationZone>21</w:HyphenationZone> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument><![endif]--><!--[if gte mso 9]> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles><![endif]--><!--[if !mso]><style>st1\:*{behavior:url(#ieooui) }</style><![endif]--><style><!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";}@page Section1 {size:595.3pt 841.9pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;}div.Section1 {page:Section1;}--></style><!--[if gte mso 10]><style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}</style><![endif]--><!--[if gte mso 9]> <o:shapedefaults v:ext="edit" spidmax="1026"/><![endif]--><!--[if gte mso 9]> <o:shapelayout v:ext="edit"> <o:idmap v:ext="edit" data="1"/> </o:shapelayout><![endif]-->
</o:p>
<!--[endif]-->
j'ai eu beau chercher dans ce bazar mais j'ai pas trouvé "bonjour" ; décidemment tout se perd
De : Sur Le Forum (77)
Photographe Env. 3000 message Orléat (63)
bonjour
il est vrai qu'une partie est illisibleSadW00tWub
début des travaux le 3 septembre 2007
livrée le 9 juillet 2008
soit 5 mois avant la date prévue
florélie37
De : Orléat (63)
En cache depuis le vendredi 04 avril 2025 à 00h35
Devis vérandaArtisan
Devis véranda
Les bonnes idées
Les bonnes idées "fenêtre"
